Germany / UK 2GB Ryzen 9 KVM - Unmetered Bandwidth - 1 vCore - IPv4 & IPv6 w/ BGP - £4/month
Hello,
We're offering the following spec VPS for only £4/month!
HS2:
- 2GB DDR4 RAM
- 1vCore on Ryzen 9 5950X
- 20GB NVMe SSD 40GB if you send your server ID
- Unmetered Bandwidth on a shared 1G port
- 1 IPv4 address & /64 IPv6 addresses
Locations Available:
- Frankfurt am Main, Germany
- Kettering, United Kingdom
Extra IPv4 addresses are £0.80/each/month
DE Looking glass: https://lg.de-1-fra.sys.hostaris.com
UK Looking glass: https://lg.uk-1-ke.sys.hostaris.com
ASN: AS199765 (https://bgp.tools/as/199765)
Status Page: https://status.hostaris.com
BGP is also available for £5/month + £5/setup on request.
Wut? Seriously?
Comment your VPS IP for free weasel attacks (150000 pps).
Yep. The Frankfurt server has about 7.5TB in NVMe and with full stock, we only have about 2TB allocated, so we have plenty to give.
Yeahhh, some people might not feel comfortable sharing that publicly, so you can share the VPS name instead.
Why not just order IDs/numbers?
They’re unique.
We don't display any order IDs yet on the dashboard.
Let's name all our VPS as "sisters".
reliable? @ehab @Mumbly
I don't have experience with this one... yet.
Hop on live chat and we can setup a short free trial if that interests you.
We've enabled the visibility of the server ID on the table. You can now send just the server id as there could be issues with IPs & names.
@lapua no services with them either ... i recall i used to love him but then he got upset and i was too.
he might give us a special 1 year discount for the 3 of us at 30€ and then we can love him again.
God, I don't know what's up with V6 there. Will look into it.
You can get 1 year for £32 with the 50% extra promotion on the home page. https://hostaris.com
dude!
"We're running a limited time launch offer. Deposit over £5 and we will add 50% extra free of charge to your Hostaris account balance! " - so its 32 pounds for one year
Thank you ,,,, i will wait some time.... need to love you again.
No worries.
This offer will end on 22nd March.
Done benchmarking one of your VPS. Thanks. Overall great VPS.
Benchmark VPS Hostaris 1 Core AMD 2GB RAM - 4 GBP/month
Bench.sh
YABS.sh
UnixBench
------------------------------------------------------------------------ Benchmark Run: Thu Mar 16 2023 23:38:40 - 00:23:20 1 CPU in system; running 1 parallel copy of tests Dhrystone 2 using register variables 59722072.5 lps (10.0 s, 10 samples) Double-Precision Whetstone 10435.7 MWIPS (9.9 s, 10 samples) Execl Throughput 7020.1 lps (29.9 s, 4 samples) File Copy 1024 bufsize 2000 maxblocks 1552499.3 KBps (30.0 s, 4 samples) File Copy 256 bufsize 500 maxblocks 411643.7 KBps (30.0 s, 4 samples) File Copy 4096 bufsize 8000 maxblocks 4279506.5 KBps (30.0 s, 4 samples) Pipe Throughput 2619839.3 lps (10.0 s, 10 samples) Pipe-based Context Switching 295839.4 lps (10.0 s, 10 samples) Process Creation 23498.9 lps (30.0 s, 4 samples) Shell Scripts (1 concurrent) 14849.7 lpm (60.0 s, 4 samples) Shell Scripts (8 concurrent) 1938.7 lpm (60.0 s, 4 samples) System Call Overhead 3146151.6 lps (10.0 s, 10 samples) System Benchmarks Index Values BASELINE RESULT INDEX Dhrystone 2 using register variables 116700.0 59722072.5 5117.6 Double-Precision Whetstone 55.0 10435.7 1897.4 Execl Throughput 43.0 7020.1 1632.6 File Copy 1024 bufsize 2000 maxblocks 3960.0 1552499.3 3920.5 File Copy 256 bufsize 500 maxblocks 1655.0 411643.7 2487.3 File Copy 4096 bufsize 8000 maxblocks 5800.0 4279506.5 7378.5 Pipe Throughput 12440.0 2619839.3 2106.0 Pipe-based Context Switching 4000.0 295839.4 739.6 Process Creation 126.0 23498.9 1865.0 Shell Scripts (1 concurrent) 42.4 14849.7 3502.3 Shell Scripts (8 concurrent) 6.0 1938.7 3231.1 System Call Overhead 15000.0 3146151.6 2097.4 ======== System Benchmarks Index Score 2558.4For more detailed benchmark, just hit my signature post, and searched for "Hostaris"
Thanks for running that for us, very useful for new clients
Sure.
@Hostaris are "422 Kbits/sec" useful? please check!
Yep, we are looking into this. In the meantime please use IPv4 for the majority of your bandwidth use.
is it possible to deactivate ip6?
https://techdocs.broadcom.com/us/en/ca-enterprise-software/it-operations-management/network-flow-analysis/21-2/installing/system-recommendations-and-requirements/linux-servers/disable-ipv6-networking-on-linux-servers.html
The IPv6 issue seems to be with our upstream, we've contacted them and it is being looked into.
@Hostaris could you please help check the ticket-0082 ? I can't contact you on Discord, thanks
Sorry about the wait, been unwell recently.
the DE IPv6 network seems still have issue, and the IPv4 also not so good as UK
