i buy indian vps some hour ago its active but no network reachable i create support ticket bt no response too much bad experience i need it urgent but its delay [Ticket ID: 792223]
A. Is LES official Helpdesk for Advin servers?
B. Do you typically start digging for a well after house is on fire?
C. Is this an offer thread for VPS?
D. What are your SLAs for responding to tickets! Do you respond in weekends?
E. Did you check with Advin servers on activation time before ordering ?
@woohostbd said:
yes i check activitation after order bt its show active bt network unreachable i ticketed bt no reply
Have you installed an operating system ?
yes i install almalinux 8
install an os you can handle.
i reinstall os 2 time do restart but when i connect via putty or terminal network unreachable show advin server i used few month they are good but just today this problem i face with new service
I would VNC into the VPS and check
1. That networking is up with a public IP. [ip addr show]
2. The default route is set correctly [ip route show]
3. Try to ping 1.1.1.1 and 8.8.8.8 to see if network is up, but maybe ssh is not.
i reinstalled an OS 2 times; done a restart but when i connected via putty or terminal, the network was unreachable. ( show advin server = incomprehensible mess ) i have used Advin for a few months; they are good but just today i face a problem with a new service.
Caveat: best of a bad lot.
Update: they give me single reply its need 48 hour dor setup but the service show active and also reserve dns work and give me ip also but network not reachable why they show its delivered i buy one provider contabo and many more when setup running they make service as pending after setup done service show active
@AlwaysSkint in plain speak, what is he trying to say pl?
(you don't really have to answer that)
i try to say this my service show active and ip also active with my reserve dns but vps offline
have you done the needful?
Some folks should stick to playing with their Switch. (Leave a VPS to the big boys & girls.)
Happy Saturday
blog | exploring visually |
@Advin
@AlwaysSkint for punctuation remediation
This is a total loss/lost cause.
Example:
I gave up trying to understand. The writing is not comprehensible.
Here was me, going to call on one of your nth language skills.
This reminds me of a certain cocui.
its not working yet
I think you meant this. But the needle is stuck on VPS.
free picture hosting website
