Cloudflare Access wildcard logic change
 bikegremlin
                ModeratorOGContent Writer
bikegremlin
            In case you are using Cloudflare Zero Trust with wildcards, and have missed this note from the company:
You are receiving this email because your account has an Access Application with a wildcard definition that will begin to cover more URL combinations. We are updating our wildcard behavior in Cloudflare Access for wildcards at the end of a path not following a slash character (e.g. example.com/text*). If no action is taken before April 20th, 2023, an Access login screen will be presented for additional path combinations.
Current Access Application behavior
example.com/alpha*will coverexample.com/alphaandexample.com/alpha/onebut notexample.com/alphabet.Change impact
After April 20th, 2023 at 20:00 UTC, all three path combinations will be covered by Access. If you would like to exempt specific paths from Access, a Bypass policy can be configured.How to identify impacted Access Applications
To identify which Access Applications will be impacted by this change, please open the Zero Trust Dashboard, navigate to Access→Applications and search for the * character. This will highlight any applications that may require modification.
I consider this to be the logical way the wildcard should work - as it should have been from the start.
I've updated my Cloudflare Zero Trust article - as this wildcard function was one of my complaints.
Relevant blog entry for further reference: https://blog.cloudflare.com/access-wildcard-and-multi-hostname/
May I know why you choose to use ZeroTrust instead of masking your login page with Wordpress security plugin?
Like site.tld/mysecretaccess for backend.
Deny access to wp-login and wp-admin with htaccess,
Or even whitelist access to WP backend only to your own IP.
https://microlxc.net/
That's a good and reasonable question. The short answer is: layers.
This protection acts before the visitor even reaches the hosting server (so it wont even "bother" it if it's a bot).
For more details on my security approach & philosophy, I wrote several articles:
How to secure a WordPress website
Domain and website security
