hetzner-k3s v1.1.1 is out! 🎉
This is my tool to quicly create k3s clusters in Hetzner Cloud. The main change in this release allows creating node pools with any number of nodes - you are limited only by the caps on your Hetzner account.
This update makes it possible to create pretty large clusters for cheap 😎
SprintPulse - Retrospectives for Teams That Ship
Thanked by (1)jureve
@vitobotta sorry , if it is a bit unrelated but since you seem to be very well versed with kubernetes can you recommend some resources for me to get started with k8s ? This summer I am going to do an internship as a devops engineer and the company I would work for heavily utilises k8s in their infrastructure so I would need to learn it,
I am not up to date myself with courses these days (I have been working with k8s for 5 years) but I have heard good feedback from a few people about the courses at https://kodekloud.com/ - they say that these courses are straightforward and give a good foundation. They are quite inexpensive too, so you may want to give them a try
