hetzner-k3s v1.1.1 is out! πŸŽ‰
This is my tool to quicly create k3s clusters in Hetzner Cloud. The main change in this release allows creating node pools with any number of nodes - you are limited only by the caps on your Hetzner account.
This update makes it possible to create pretty large clusters for cheap 😎
https://github.com/vitobotta/hetzner-k3s
Thanked by (1)jureve
Lead Platform Architect at the day job, Ethical Hacker/Bug Bounty Hunter on the side
  • @vitobotta sorry , if it is a bit unrelated but since you seem to be very well versed with kubernetes can you recommend some resources for me to get started with k8s ? This summer I am going to do an internship as a devops engineer and the company I would work for heavily utilises k8s in their infrastructure so I would need to learn it,
    I am not up to date myself with courses these days (I have been working with k8s for 5 years) but I have heard good feedback from a few people about the courses at https://kodekloud.com/ - they say that these courses are straightforward and give a good foundation. They are quite inexpensive too, so you may want to give them a try :)
