I have now also tested it with a Hetzner Cloud CAX41 instance. Just to have a comparison. The result of the Geekbench 6 test behaves strangely here as well.
Hetzner Cloud CAX41 - 16 ARM64 vCPU, 32 GB RAM
# Yet-Another-Bench-Script #
# v2023-03-24 #
Fri Apr 14 10:22:24 PM UTC 2023
Uptime : 0 days, 0 hours, 2 minutes
Processor : Neoverse-N1
CPU cores : 16 @ ??? MHz
AES-NI : ✔ Enabled
VM-x/AMD-V : ❌ Disabled
RAM : 30.5 GiB
Swap : 0.0 KiB
Disk : 300.4 GiB
Distro : Ubuntu 22.04.2 LTS
Kernel : 5.15.0-69-generic
VM Type : NONE
Net Online : IPv4 & IPv6
ISP : Hetzner Online GmbH
ASN : AS24940 Hetzner Online GmbH
Host : Hetzner
Country : Germany
Read | 151.97 MB/s (37.9k) | 1.32 GB/s (20.7k)
Write | 151.87 MB/s (37.9k) | 1.36 GB/s (21.3k)
Total | 303.84 MB/s (75.9k) | 2.69 GB/s (42.1k)
Read | 2.67 GB/s (5.2k) | 2.72 GB/s (2.6k)
Write | 2.90 GB/s (5.6k) | 3.03 GB/s (2.9k)
Total | 5.57 GB/s (10.8k) | 5.76 GB/s (5.6k)
Clouvider | London, UK (10G) | 6.19 Gbits/sec | 8.09 Gbits/sec | 20.3 ms
Scaleway | Paris, FR (10G) | 8.21 Gbits/sec | 8.58 Gbits/sec | 21.2 ms
NovoServe | North Holland, NL (40G) | 12.9 Gbits/sec | busy | 12.1 ms
Uztelecom | Tashkent, UZ (10G) | 2.50 Gbits/sec | 2.08 Gbits/sec | 89.0 ms
Clouvider | NYC, NY, US (10G) | 787 Mbits/sec | busy | 84.8 ms
Clouvider | Dallas, TX, US (10G) | 1.41 Gbits/sec | 1.48 Gbits/sec | 124 ms
Clouvider | Los Angeles, CA, US (10G) | 718 Mbits/sec | 441 Mbits/sec | 148 ms
Clouvider | London, UK (10G) | 6.64 Gbits/sec | 276 Mbits/sec | 20.2 ms
Scaleway | Paris, FR (10G) | 7.06 Gbits/sec | 6.52 Gbits/sec | 21.9 ms
NovoServe | North Holland, NL (40G) | busy | busy | 12.0 ms
Uztelecom | Tashkent, UZ (10G) | 1.87 Gbits/sec | 2.09 Gbits/sec | 88.7 ms
Clouvider | NYC, NY, US (10G) | 1.79 Gbits/sec | 2.17 Gbits/sec | 84.8 ms
Clouvider | Dallas, TX, US (10G) | 1.06 Gbits/sec | 1.48 Gbits/sec | 124 ms
Clouvider | Los Angeles, CA, US (10G) | 1.06 Gbits/sec | 286 Mbits/sec | 148 ms
ARM architecture not supported by Geekbench 4, use Geekbench 5 or 6.
Geekbench 5 Benchmark Test:
Test | Value
Single Core | 867
Multi Core | 11876
Full Test | https://browser.geekbench.com/v5/cpu/21059290
Test | Value
Single Core | 1109
Multi Core | 8883
Full Test | https://browser.geekbench.com/v6/cpu/919027
YABS completed in 13 min 41 sec
Obviously it won't have either of these CPUID bits as they're Intel/AMD specific, but it'd be interesting to know if you can run KVM on these... Originally I didn't think it was possible, but I guess the CAX range shows that it must be somehow...
I have already tried it, KVM works on the RX220.
At least directly via qemu-system-aarch64 -enable-kvm. I have not yet got a VM running via libvirt. (and so far not yet a Windows VM).
Someone mentioned PiMox or something, Proxmox fork for arm64.
Maybe worth trying.
Maybe worth trying.
I have now set up a VM (via QEMU with KVM enabled) with almost the same specifications as the Hetzner Cloud CAX11 ARM64 server (I made a mistake with the hard disk size) on my RX220.
For comparison I also ran YABS on a regular Hetzner Cloud CAX11 server.
One thing that seems interesting is that the VM type is not recognized on the Hetzner Cloud Server.
ARM64 VM (on Hetzner RX220) - 2 vCPUs - 4GB RAM
# v2023-03-24 #
Sun Apr 16 13:08:49 UTC 2023
CPU cores : 2 @ ??? MHz
AES-NI : ✔ Enabled
RAM : 3.8 GiB
Swap : 0.0 KiB
Disk : 29.4 GiB
VM Type : KVM
Net Online : IPv4
Host : Hetzner Online GmbH
Country : Germany
Read | 308.50 MB/s (77.1k) | 1.99 GB/s (31.1k)
Write | 308.30 MB/s (77.0k) | 2.05 GB/s (32.0k)
Total | 616.80 MB/s (154.2k) | 4.04 GB/s (63.2k)
Read | 2.29 GB/s (4.4k) | 2.32 GB/s (2.2k)
Write | 2.49 GB/s (4.8k) | 2.59 GB/s (2.5k)
Total | 4.78 GB/s (9.3k) | 4.92 GB/s (4.8k)
Clouvider | London, UK (10G) | 930 Mbits/sec | 924 Mbits/sec | 22.4 ms
Scaleway | Paris, FR (10G) | 931 Mbits/sec | busy | 25.0 ms
NovoServe | North Holland, NL (40G) | 938 Mbits/sec | 936 Mbits/sec | 10.5 ms
Uztelecom | Tashkent, UZ (10G) | 685 Mbits/sec | 493 Mbits/sec | 90.8 ms
Clouvider | NYC, NY, US (10G) | 758 Mbits/sec | 234 Mbits/sec | 162 ms
Clouvider | Dallas, TX, US (10G) | 809 Mbits/sec | 414 Mbits/sec | 123 ms
Clouvider | Los Angeles, CA, US (10G) | 784 Mbits/sec | 189 Mbits/sec | 168 ms
Test | Value
Single Core | 876
Multi Core | 1695
Full Test | https://browser.geekbench.com/v5/cpu/21067378
Test | Value
Single Core | 1123
Multi Core | 2044
Full Test | https://browser.geekbench.com/v6/cpu/937906
YABS completed in 12 min 11 sec
Hetzner Cloud CAX11 - 2 vCPUs - 4GB RAM
# v2023-03-24 #
Sun Apr 16 01:14:59 PM UTC 2023
Uptime : 0 days, 0 hours, 0 minutes
AES-NI : ✔ Enabled
RAM : 3.7 GiB
Swap : 0.0 KiB
Disk : 37.5 GiB
VM Type : NONE
Host : Hetzner
Country : Germany
Read | 147.61 MB/s (36.9k) | 1.22 GB/s (19.1k)
Write | 147.51 MB/s (36.8k) | 1.26 GB/s (19.7k)
Total | 295.12 MB/s (73.7k) | 2.49 GB/s (38.9k)
Read | 2.82 GB/s (5.5k) | 2.58 GB/s (2.5k)
Write | 3.06 GB/s (5.9k) | 2.88 GB/s (2.8k)
Total | 5.89 GB/s (11.5k) | 5.46 GB/s (5.3k)
Clouvider | London, UK (10G) | 2.91 Gbits/sec | 7.87 Gbits/sec | 20.8 ms
Scaleway | Paris, FR (10G) | 6.07 Gbits/sec | 8.55 Gbits/sec | 21.2 ms
NovoServe | North Holland, NL (40G) | busy | 15.3 Gbits/sec | 12.3 ms
Uztelecom | Tashkent, UZ (10G) | 1.27 Gbits/sec | 1.99 Gbits/sec | 94.0 ms
Clouvider | NYC, NY, US (10G) | 886 Mbits/sec | 1.07 Gbits/sec | 85.4 ms
Clouvider | Dallas, TX, US (10G) | 1.28 Gbits/sec | 1.47 Gbits/sec | 124 ms
Clouvider | Los Angeles, CA, US (10G) | 834 Mbits/sec | 1.04 Gbits/sec | 155 ms
Clouvider | London, UK (10G) | 7.04 Gbits/sec | 687 Mbits/sec | 20.5 ms
Scaleway | Paris, FR (10G) | 4.26 Gbits/sec | 8.15 Gbits/sec | 21.7 ms
NovoServe | North Holland, NL (40G) | 6.97 Gbits/sec | 12.1 Gbits/sec | 12.6 ms
Uztelecom | Tashkent, UZ (10G) | 2.08 Gbits/sec | 2.05 Gbits/sec | 93.9 ms
Clouvider | NYC, NY, US (10G) | 1.83 Gbits/sec | 2.17 Gbits/sec | 85.3 ms
Clouvider | Dallas, TX, US (10G) | 1.18 Gbits/sec | 1.47 Gbits/sec | 124 ms
Clouvider | Los Angeles, CA, US (10G) | 983 Mbits/sec | 1.22 Gbits/sec | 154 ms
Test | Value
Single Core | 828
Multi Core | 1622
Full Test | https://browser.geekbench.com/v5/cpu/21067419
Test | Value
Single Core | 1082
Multi Core | 1945
Full Test | https://browser.geekbench.com/v6/cpu/937999
YABS completed in 15 min 41 sec
YABS (Geekbench 6 aborted,Geekbench 5 worked).
Disk speed is kind of meh (it's no ssd though), and IP Location shows Pakistan (not correct) but still I'll be able to make use of this machine.
Hetzner RX220
This doesn't look right to me... Previous GB5 scores have been significantly higher (for the one with less memory).
https://lowendtalk.com/discussion/comment/3562506#Comment_3562506
GB5 score was 40k
Actually this also was the RX220 with the full memory
I have now ran YABS again, this time also with Geekbench 5 result. The result for Geekbench 6 is still strange, just like the last attempt.
Interesting, it's hard to tell from the results, but I guess GB6 puts more emphasis on floating point tests than GB5.
first, this one: https://alphavps.com/ryzen-vps.html
qemu-system-aarch64 -enable-kvm. I have not yet got a VM running via libvirt. (and so far not yet a Windows VM).Someone mentioned PiMox or something, Proxmox fork for arm64.
Maybe worth trying.
edit: https://github.com/pimox/pimox7
I also found another ARM64 proxmox fork, which was even tested with Ampere processors.
https://github.com/jiangcuo/Proxmox-Arm64
Maybe I'll have a look at it in the next days.
Netcup RS 1000 G9.5
v2023-03-24
Mon 17 Apr 2023 10:43:38 AM UTC
ARM compatibility is considered experimental
Uptime : 0 days, 0 hours, 4 minutes
AES-NI : ✔ Enabled
RAM : 3.7 GiB
Swap : 0.0 KiB
Disk : 37.5 GiB
Distro : Debian GNU/Linux 11 (bullseye)
Kernel : 5.10.0-21-arm64
VM Type : NONE
Host : Hetzner
Country : Germany
Test | Value
Single Core | 1045
Multi Core | 1902
Full Test | https://browser.geekbench.com/v6/cpu/947885
YABS completed in 13 min 42 sec
Hetzner CAX11 ARM Server
Another day, another YABS benchmark.
Hetzner Server Auction Server (seems like some kind of variant of the EX51-SSD-GPU) - Intel i7-7700 (4 Cores, 8 Threads) - 64GB RAM
ZAP Hosting Lifetime VPS LXC Finland, 2vCores, 8GB RAM, 25GB Disk Space, 500 Mbit/s
HostHatch 2023 Anniversary AMD Compute 4 GB PROMO in Sydney, double RAM double bandwidth double storage.
AdvinServers chess special in Mumbai, migrated to OVH network.
link to previous benchmark
No hostname available. affbrr
PQ.hosting Aluminium Ireland (10G unlimited) - 4.77€/month
Hetzner EX44
AdvinServers - KVM Standard L - Eygelshoven (NL) Location
Hetzner AX41
