Imgur will be without pr0n.
2»
  • Hopefully this doesn't extend to K-Pop gifs or what's the point.
    Huh? Why would banning adult content extend to K-Pop? What kind of K-Pop gifs are you looking at!!!
  • skorupionskorupion Hosting Provider
    @somik said: What kind of K-Pop gifs are you looking at!!!
    Srsly have to ask that question? It's Nekki afterall
    Contact me at: +1 (509) 606-3569 or [email protected]
    You don't want to know that.
    Right....
    Good point....
    Thanked by (1)root
  • edited April 2023
    @MallocVoidstar said:
    More than just porn: https://help.imgur.com/hc/en-us/articles/14415587638029/
    We will be focused on removing old, unused, and inactive content that is not tied to a user account from our platform as well as nudity, pornography, & sexually explicit content.
    Seems like anyone who uploaded stuff without registering/logging-in is getting their stuff removed.
    This part is a much bigger deal and is going to cause a lot of problems.
    Anyone with lists of Imgur URL's (which you can even export from your browser history, if you keep it) should submit them here and anyone who wants to lend their idlers to help with the archiving can try using docker.
    Indeed. Just imagine all that "love stuff" being removed. So sad! :cry:
    There is a lot more than porn on Imgur. Everyone will find out in a few weeks how much more.
    This is correct. Hopefully they won't spam low-end communities with complaints.
    Why, will it turn up in the results of the term ‘sweater boobs’ and ‘sadface minge’?
    Thanked by (1)hornet
  • edited April 2023
    Is this where we answer cat pictures and smirk because it's a trick answer?
    EDIT: Fortunately this doesn't use imgur: https://animalsbeingdicks.tumblr.com/
    Bahaha! I sort of want to websearch that to see what it is, but I also do not!
    edited June 2023
    They start banning images of unclothed Yeti amd I shall have to organize a burning and looting of a city.
    That is a perfectly acceptable response right guys?
  • Literally proned!
    'Sweater boobs' is pretty safe, do not try the other one, you won't be able to un-see the results.
