I am actually deploying Pterodactyl on LXC and it works well. You just need to make sure nesting is enabled
@Voigon said: I am actually deploying Pterodactyl on LXC and it works well. You just need to make sure nesting is enabled
Yup In my case, ZAP Hosting also allows enabling Docker on LXC.
@Ympker said: show previous quotes @Voigon said: I am actually deploying Pterodactyl on LXC and it works well. You just need to make sure nesting is enabled Yup In my case, ZAP Hosting also allows enabling Docker on LXC.
@Ympker said:
Yep, docker works fine on zap hosting Lxc vps. Just tested today.
Yup
