Comprehensive Speedtest Script | nws.sh | Share your bench
1356713
  • IPv6 only VPS
    ---------------------------- network-speed.xyz ----------------------------
          A simple script to test network performance using speedtest-cli
     Version            : v2023.05.01
     Global Speedtest   : wget -qO- network-speed.xyz | bash
     Region Speedtest   : wget -qO- network-speed.xyz | bash -s -- -r <region>
     Basic System Info
     CPU Model          : Common KVM processor
     CPU Cores          : 2 @ 3593.246 MHz
     CPU Cache          : 512 KB
     AES-NI             : ❌ Disabled
     VM-x/AMD-V         : ❌ Disabled
     Total Disk         : 4.9 GB (2.4 GB Used)
     Total RAM          : 475.8 MB (51.3 MB Used)
     Total Swap         : 1.0 GB (0 Used)
     System uptime      : 1 days, 21 hour 59 min
     Load average       : 0.05, 0.07, 0.06
     OS                 : Debian GNU/Linux 11
     Arch               : x86_64 (64 Bit)
     Kernel             : 5.10.0-22-cloud-amd64
     Virtualization     : KVM
     Basic Network Info
     Primary Network    : IPv6
     ISP                : Hop One Networks LLC
     ASN                : AS397391 Hop One Networks LLC
     Host               : Hop One Networks LLC
     Location (IPv4)    : Haarlem, North Holland, NL
     Location         Latency     Loss    DL Speed       UP Speed       Server
     ISP: Hop One Networks
     Nearest          46.78 ms    0.0%    249.16 Mbps    923.06 Mbps    Kansas Research and Education Network - Wichita, KS
     Kochi, IN        FAILED
     Bangalore, IN    244.77 ms   0.0%    12.37 Mbps     303.85 Mbps    Bharti Airtel Ltd - Bangalore
     Chennai, IN      226.66 ms   N/A     148.57 Mbps    122.96 Mbps    Jio - Chennai
     Mumbai, IN       246.65 ms   0.0%    88.97 Mbps     310.33 Mbps    i3D.net - Mumbai
     Delhi, IN        235.78 ms   0.0%    149.07 Mbps    95.59 Mbps     Tata Play Fiber - New Delhi
     Los Angeles, US  65.33 ms    0.0%    279.67 Mbps    912.60 Mbps    ReliableSite Hosting - Los Angeles, CA
     Dallas, US       36.50 ms    0.0%    733.72 Mbps    927.45 Mbps    Hivelocity - Dallas, TX
     New York, US     6.07 ms     0.0%    543.82 Mbps    926.80 Mbps    Clouvider Ltd - New York, NY
     Seattle, US      67.74 ms    N/A     139.24 Mbps    904.47 Mbps    Comcast - Seattle, WA
     Miami, US        FAILED
     Toronto, CA      27.09 ms    0.0%    421.64 Mbps    928.29 Mbps    Rogers - Toronto, ON
     Paris, FR        84.68 ms    0.0%    107.59 Mbps    870.32 Mbps    ORANGE FRANCE - Paris
     Amsterdam, NL    78.28 ms    0.0%    9.98 Mbps      880.85 Mbps    Clouvider Ltd - Amsterdam
     Warsaw, PL       112.23 ms   0.0%    330.43 Mbps    677.69 Mbps    UPC Polska - Warszawa
     London, UK       74.09 ms    0.0%    839.67 Mbps    887.28 Mbps    VeloxServ Communications - London
     Frankfurt, DE    86.11 ms    0.0%    531.89 Mbps    59.89 Mbps     23M GmbH - Frankfurt Am Main
     Dubai, AE        FAILED
     Fujairah, AE     FAILED
     Jeddah, KSA      152.60 ms   0.0%    390.02 Mbps    518.50 Mbps    Saudi Telecom Company
     Shanghai, CU-CN  246.13 ms   0.0%    347.37 Mbps    305.88 Mbps    China Unicom 5G - ShangHai
     Nanjing, CT-CN   FAILED
     Hong Kong, HKG   259.96 ms   N/A     151.91 Mbps    113.11 Mbps    STC - Hong Kong
     Singapore, SG    225.88 ms   0.0%    37.07 Mbps     351.91 Mbps    i3D.net - Singapore
     Jakarta, ID      254.58 ms   0.0%    224.11 Mbps    176.53 Mbps    PT Indosat Tbk - Jakarta
     Tokyo, JP        FAILED
     Avg DL Speed       : 286.81 Mbps
     Avg UL Speed       : 559.87 Mbps
     Total DL Data      : 8.23 GB
     Total UL Data      : 14.12 GB
     Total Data         : 22.35 GB
     Duration           : 10 min 6 sec
     System Time        : 10/05/2023 - 20:44:06 UTC
     Total Script Runs  : 2235
     Result             : https://cdn1.frocdn.ch/75AJEMfGT0WxHVx.txt
    Norway KVM Node
     Basic System Info
     CPU Model          : Intel(R) Xeon(R) CPU E5-2690 v4 @ 2.60GHz
     CPU Cores          : 56 @ 3500.000 MHz
     CPU Cache          : 35840 KB
     AES-NI             : ✔ Enabled
     VM-x/AMD-V         : ✔ Enabled
     Total Disk         : 3.5 TB (29.7 GB Used)
     Total RAM          : 251.2 GB (2.1 GB Used)
     Total Swap         : 4.0 GB (0 Used)
     System uptime      : 0 days, 0 hour 1 min
     Load average       : 0.45, 0.23, 0.09
     OS                 : AlmaLinux release 9.1 (Lime Lynx)
     Kernel             : 5.14.0-162.23.1.el9_1.x86_64
     Virtualization     : NONE
     Basic Network Info
     ISP                : WebHorizon IT Broadband Limited
     ASN                : AS149020 WebHorizon Internet Services
     Host               : WebHorizon IT Broadband Limited
     Location           : Washington, District of Columbia-DC, United States
     Location (IPv4)    : Sandefjord, Vestfold og Telemark, NO
     ISP: The PRIVACYFIRST Project
     Nearest          0.06 ms     0.0%    6369.09 Mbps   9383.90 Mbps   Speedtest.net - Oslo
     Kochi, IN        186.17 ms   0.0%    4095.79 Mbps   482.29 Mbps    Asianet Broadband - Cochin
     Bangalore, IN    207.20 ms   0.0%    4177.57 Mbps   481.99 Mbps    Bharti Airtel Ltd - Bangalore
     Chennai, IN      180.01 ms   N/A     4646.98 Mbps   588.33 Mbps    Jio - Chennai
     Mumbai, IN       139.02 ms   0.0%    5733.76 Mbps   500.00 Mbps    i3D.net - Mumbai
     Delhi, IN        173.25 ms   0.0%    4509.91 Mbps   313.67 Mbps    Tata Play Fiber - New Delhi
     Los Angeles, US  153.31 ms   0.0%    5054.14 Mbps   526.39 Mbps    ReliableSite Hosting - Los Angeles, CA
     Dallas, US       131.81 ms   0.0%    6034.92 Mbps   565.68 Mbps    Hivelocity - Dallas, TX
     New York, US     89.51 ms    0.0%    4380.00 Mbps   803.32 Mbps    Clouvider Ltd - New York, NY
     Seattle, US      161.50 ms   N/A     4892.62 Mbps   546.29 Mbps    Comcast - Seattle, WA
     Miami, US        130.00 ms   0.0%    5403.59 Mbps   846.39 Mbps    AT&T - Miami, FL
     Toronto, CA      105.86 ms   0.0%    7368.06 Mbps   836.17 Mbps    Rogers - Toronto, ON
     Paris, FR        30.50 ms    0.0%    8783.91 Mbps   3228.54 Mbps   ORANGE FRANCE - Paris
     Amsterdam, NL    21.04 ms    0.0%    7761.04 Mbps   2544.40 Mbps   Clouvider Ltd - Amsterdam
     Warsaw, PL       40.19 ms    0.0%    9177.10 Mbps   2303.54 Mbps   UPC Polska - Warszawa
     London, UK       33.28 ms    0.0%    8466.97 Mbps   2533.68 Mbps   VeloxServ Communications - London
     Frankfurt, DE    23.77 ms    2.8%    9234.57 Mbps   1005.41 Mbps   23M GmbH - Frankfurt Am Main
     Dubai, AE        145.85 ms   0.0%    4217.48 Mbps   666.35 Mbps    du - Dubai
     Fujairah, AE     142.08 ms   0.0%    5769.66 Mbps   804.89 Mbps    ETISALAT-UAE - Fujairah
     Jeddah, KSA      105.92 ms   0.0%    8106.89 Mbps   1167.43 Mbps   Saudi Telecom Company
     Shanghai, CU-CN  288.96 ms   0.0%    2922.58 Mbps   279.03 Mbps    China Unicom 5G - ShangHai
     Nanjing, CT-CN   281.14 ms   0.0%    2728.85 Mbps   338.95 Mbps    China Telecom JiangSu 5G - Nanjing
     Hong Kong, HKG   255.71 ms   N/A     2995.60 Mbps   335.68 Mbps    STC - Hong Kong
     Singapore, SG    190.38 ms   0.0%    2944.90 Mbps   461.35 Mbps    i3D.net - Singapore
     Jakarta, ID      188.18 ms   0.0%    3170.95 Mbps   249.23 Mbps    PT Indosat Tbk - Jakarta
     Tokyo, JP        275.20 ms   N/A     1620.45 Mbps   250.44 Mbps    fdcservers.net - Tokyo
     Avg DL Speed       : 5406.46 Mbps
     Avg UL Speed       : 1232.43 Mbps
     Total DL Data      : 200.10 GB
     Total UL Data      : 33.73 GB
     Total Data         : 233.83 GB
     Duration           : 13 min 29 sec
     System Time        : 11/05/2023 - 06:57:46 EDT
     Total Script Runs  : 2240
     Result             : https://cdn1.frocdn.ch/GPdexe8OaCBzsVQ.txt
    Thanked by (1)lapua
  • Netdynamics24 500GB Netherland FTP Backup to Asia,
    $0.00222/GB/m worth every single cent <3
     Basic System Info
     CPU Model          : Intel(R) Xeon(R) CPU E5-1650 v3 @ 3.50GHz
     CPU Cores          : 12 @ 3500.000 MHz
     CPU Cache          : 15360 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 58.0 TB (14.9 TB Used)
     Total RAM          : 31.2 GB (764.2 MB Used)
     Total Swap         : 4.0 GB (63.3 MB Used)
     System uptime      : 13 days, 14 hour 12 min
     Load average       : 0.02, 0.03, 0.00
     OS                 : Ubuntu 22.04.2 LTS
     Kernel             : 5.15.0-71-generic
     Basic Network Info
     ISP                : LeaseWeb Netherlands B.V.
     ASN                : AS60781 LeaseWeb Netherlands B.V.
     Host               : LeaseWeb Netherlands B.V
     Speedtest.net (Region: ASIA)
     ISP: LeaseWeb Netherlands B.V.
     Nearest          0.42 ms     1.4%    940.54 Mbps    940.75 Mbps    PhoenixNAP Global IT Services - Amsterdam
     Mumbai, IN       118.43 ms   0.0%    753.89 Mbps    727.85 Mbps    i3D.net - Mumbai
     Chennai, IN      144.97 ms   N/A     469.15 Mbps    620.95 Mbps    Jio - Chennai
     Bangalore, IN    179.57 ms   0.0%    642.16 Mbps    497.00 Mbps    Bharti Airtel Ltd - Bangalore
     Singapore, SG    175.68 ms   0.0%    454.30 Mbps    324.25 Mbps    i3D.net - Singapore
     Tokyo, JP        FAILED
     China Unicom     166.96 ms   0.0%    532.71 Mbps    594.25 Mbps    China Unicom 5G - ShangHai
     China Telecom    226.41 ms   N/A     401.28 Mbps    3.37 Mbps      China Telecom - Shanghai
     China Mobile     257.26 ms   0.0%    528.93 Mbps    355.04 Mbps    China Mobile Henan 5G - Zhengzhou
     Hong Kong, CN    248.30 ms   4.7%    559.12 Mbps    159.83 Mbps    i3D.net - Hong Kong
     Karachi, PK      FAILED
     Islamabad, PK    FAILED
     Kathmandu, NP    209.57 ms   0.0%    933.09 Mbps    375.97 Mbps    Nepal Telecom - Hetauda
     Colombo, SL      166.18 ms   N/A     479.30 Mbps    550.33 Mbps    Airtel Lanka - Colombo
     Dhaka, BD        288.85 ms   N/A     446.40 Mbps    329.71 Mbps    Grameenphone Ltd - Dhaka
     Bangkok, TH      177.79 ms   0.0%    447.32 Mbps    549.16 Mbps    3BB - Bangkok
     Ho Chi Minh, VN  190.88 ms   0.0%    489.03 Mbps    305.59 Mbps    Viettel Network - Ho Chi Minh
     Hanoi, VN        213.71 ms   0.3%    626.77 Mbps    9.33 Mbps      Vietnamobile - Hanoi
     Tapei, TW        200.66 ms   N/A     918.52 Mbps    442.15 Mbps    Chunghwa Mobile - Taipei
     Jakarta, ID      176.38 ms   0.0%    476.45 Mbps    273.76 Mbps    PT Indosat Tbk - Jakarta
     Bandah Aceh, ID  205.46 ms   0.0%    856.57 Mbps    366.51 Mbps    PT Acehlink Media - Banda Aceh
     Kuala Lum, MY    194.47 ms   0.0%    443.78 Mbps    487.58 Mbps    Telekom Malaysia Berhad - Kuala Lumpur
     Novosibirsk, RU  83.54 ms    0.0%    916.85 Mbps    525.37 Mbps    Megafon - Novosibirsk
     Istanbul, TR     52.37 ms    0.0%    930.48 Mbps    933.49 Mbps    Turkcell - Istanbul
     Avg DL Speed       : 630.80 Mbps
     Avg UL Speed       : 446.30 Mbps
     Total DL Data      : 18.67 GB
     Total UL Data      : 12.65 GB
     Total Data         : 31.31 GB
     Duration           : 11 min 5 sec
     System Time        : 11/05/2023 - 06:04:07 UTC
     Total Script Runs  : 2239
    Thanked by (1)sh97
  • natvpsuk, limburg-germany
     Basic System Info
     CPU Model          : Intel(R) Xeon(R) CPU D-1541 @ 2.10GHz
     CPU Cores          : 1 @ 1397.351 MHz
     CPU Cache          : 12288 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 1.9 GB (617.1 MB Used)
     Total RAM          : 64.0 MB (19.9 MB Used)
     Total Swap         : 256.0 MB (10.7 MB Used)
     System uptime      : 90 days, 13 hour 28 min
     Load average       : 0.08, 0.03, 0.05
     OS                 : Ubuntu 20.04.5 LTS
     Kernel             : 5.4.0
     Virtualization     : OPENVZ
     Basic Network Info
     ISP                : OVH SAS
     ASN                : AS16276 OVH SAS
     Host               : OVH GmbH
     Location           : Wentorf bei Hamburg, Schleswig-Holstein-SH, Germany
     Location (IPv4)    : Frankfurt am Main, Hesse, DE
     Speedtest.net (Region: EUROPE)
     ISP: OVH SAS
     Nearest          10.26 ms    12.3%   1513.52 Mbps   234.18 Mbps    Nextmap - LeKloud - Paris
     London, UK       12.70 ms    0.0%    2276.52 Mbps   237.65 Mbps    VeloxServ Communications - London
     Edinburgh, UK    23.73 ms    N/A     2547.22 Mbps   240.11 Mbps    Vodafone UK - Edinburgh
     Dublin, IE       23.01 ms    0.0%    7092.21 Mbps   242.21 Mbps    Three Ireland - Dublin
     Amsterdam, NL    8.30 ms     0.0%    2265.66 Mbps   235.80 Mbps    GSL Networks - Amsterdam
     Paris, FR        10.52 ms    0.0%    2554.57 Mbps   235.39 Mbps    ORANGE FRANCE - Paris
     Marseille, FR    16.62 ms    0.0%    2880.84 Mbps   239.22 Mbps    GSL Networks - Marseille
     Madrid, ES       25.23 ms    0.0%    1835.65 Mbps   231.26 Mbps    Orange - Jazztel - Madrid
     Barcelona, ES    33.33 ms    0.0%    2077.05 Mbps   236.18 Mbps    Adamo - Barcelona
     Lisbon, PT       40.12 ms    N/A     2827.66 Mbps   235.05 Mbps    fdcservers.net - Lisbon
     Rome, IT         18.60 ms    0.0%    3161.75 Mbps   237.32 Mbps    TIM SpA - Rome
     Zurich, CH       6.51 ms     0.0%    5411.71 Mbps   237.86 Mbps    Sunrise Communication AG - Zurich
     Frankfurt, DE    1.57 ms     2.5%    2219.76 Mbps   232.54 Mbps    23M GmbH - Frankfurt Am Main
     Berlin, DE       16.11 ms    0.5%    1692.21 Mbps   231.84 Mbps    Misaka Network, Inc. - Berlin
     Vienna, AT       13.19 ms    0.0%    8251.99 Mbps   248.67 Mbps    A1 Telekom Austria AG - Vienna
     Budapest, HU     19.19 ms    0.0%    2171.41 Mbps   237.79 Mbps    Yettel Hungary - Budapest
     Gdansk, PL       26.90 ms    0.0%    1917.70 Mbps   240.53 Mbps    Orange Polska S.A. - Gdansk
     Warsaw, PL       19.20 ms    0.0%    1865.60 Mbps   235.85 Mbps    UPC Polska - Warszawa
     Lviv, UA         37.71 ms    0.0%    4329.42 Mbps   243.70 Mbps    Kyivstar - Lviv
     Kyiv, UA         33.86 ms    0.0%    2932.84 Mbps   236.89 Mbps    o3 - Kyiv
     Minsk, BY        53.10 ms    0.0%    1574.25 Mbps   238.14 Mbps    A1 - Minsk
     Bucharest, RO    43.70 ms    0.0%    2705.17 Mbps   235.24 Mbps    Orange Romania Communications - Bucharest
     Helsinki, FI     30.32 ms    0.0%    1722.52 Mbps   235.88 Mbps    Elisa Oyj - Helsinki
     Stockholm, SE    30.35 ms    0.0%    1876.30 Mbps   232.67 Mbps    i3D.net - Stockholm
     Oslo, NO         28.25 ms    0.0%    3284.36 Mbps   232.42 Mbps    Speedtest.net - Oslo
     Moscow, RU       39.65 ms    0.0%    1503.18 Mbps   230.64 Mbps    MTS - Moscow
     Moscow, RU       40.57 ms    0.0%    1473.74 Mbps   228.18 Mbps    Rostelecom - Moscow
     Istanbul, TR     43.31 ms    0.0%    1897.75 Mbps   232.05 Mbps    Turkcell - Istanbul
     Istanbul, TR     44.47 ms    0.0%    3677.24 Mbps   233.01 Mbps    Vodafone TR - Istanbul
     Avg DL Speed       : 2811.72 Mbps
     Avg UL Speed       : 236.15 Mbps
     Total DL Data      : 107.90 GB
     Total UL Data      : 6.16 GB
     Total Data         : 114.06 GB
     Duration           : 10 min 46 sec
     System Time        : 11/05/2023 - 19:16:40 UTC
     Total Script Runs  : 2252
     curl is not installed, Unable to share result online
     Result stored locally in /root/network-speed.txt
    root@ger2-natvps-limburg:~#
  • natvpsuk canada
     Basic System Info
     CPU Model          : Intel(R) Xeon(R) CPU D-1521 @ 2.40GHz
     CPU Cores          : 1 @ 1758.691 MHz
     CPU Cache          : 6144 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 2.9 GB (1.9 GB Used)
     Total RAM          : 64.0 MB (45.5 MB Used)
     Total Swap         : 256.0 MB (111.7 MB Used)
     System uptime      : 163 days, 4 hour 1 min
     Load average       : 0.24, 0.17, 0.15
     Kernel             : 5.4.0
     Basic Network Info
     ISP                : OVH SAS
     Host               : OVH Hosting, Inc
     Location (IPv4)    : Montréal, Quebec, CA
     Speedtest.net (Region: NORTH AMERICA)
     ISP: OVH Hosting
     Nearest          7.29 ms     0.0%    926.39 Mbps    251.47 Mbps    Teksavvy Solutions Inc - Toronto, ON
     Vancouver, BC    70.59 ms    N/A     917.17 Mbps    248.78 Mbps    TELUS - Vancouver, BC
     Toronto, ON      8.20 ms     0.0%    918.14 Mbps    250.81 Mbps    TELUS - Toronto, ON
     Toronto, ON      8.15 ms     0.0%    894.11 Mbps    257.87 Mbps    Bell Canada - Toronto, ON
     Montreal, QC     18.24 ms    0.0%    913.92 Mbps    246.75 Mbps    Rogers Wireless - Montréal, QC
     New York, NY     8.89 ms     0.0%    926.49 Mbps    253.71 Mbps    Clouvider Ltd - New York, NY
     Ashburn, VA      12.93 ms    0.0%    937.33 Mbps    255.55 Mbps    Rackdog - Ashburn, VA
     Charlotte, NC    26.36 ms    0.0%    936.13 Mbps    256.91 Mbps    Windstream - Charlotte, NC
     Atlanta, GA      FAILED
     Miami, FL        43.01 ms    0.0%    935.93 Mbps    260.06 Mbps    AT&T - Miami, FL
     Dallas, TX       61.61 ms    0.0%    872.89 Mbps    257.68 Mbps    Hivelocity - Dallas, TX
     Kansas, MO       69.21 ms    0.0%    875.76 Mbps    228.99 Mbps    August Internet - Kansas City, MO
     Minneapolis, MN  25.41 ms    0.0%    939.40 Mbps    261.59 Mbps    US Internet - Minneapolis, MN
     Chicago, IL      20.86 ms    0.0%    945.25 Mbps    263.92 Mbps    GSL Networks - Chicago, IL
     Cleveland, OH    22.70 ms    0.0%    940.58 Mbps    261.13 Mbps    Windstream - Cleveland, OH
     Albuquerque, NM  57.58 ms    N/A     929.17 Mbps    236.39 Mbps    Comcast - Albuquerque, NM
     Denver, CO       50.30 ms    N/A     931.09 Mbps    250.88 Mbps    Comcast - Denver, CO
     Portland, OR     72.72 ms    N/A     963.91 Mbps    251.72 Mbps    CenturyLink - Portland, OR
     Las Vegas, NV    77.30 ms    N/A     926.14 Mbps    175.36 Mbps    Dish Wireless - Las Vegas, NV
     Phoenix, AZ      85.95 ms    0.0%    958.49 Mbps    255.05 Mbps    GSL Networks - Phoenix, AZ
     Los Angeles, CA  69.36 ms    0.0%    922.78 Mbps    232.63 Mbps    ReliableSite Hosting - Los Angeles, CA
     San Jose, CA     64.44 ms    0.0%    827.89 Mbps    256.52 Mbps    Misaka Network, Inc. - San Jose, CA
     Seattle, WA      68.30 ms    0.0%    940.74 Mbps    249.73 Mbps    GSL Networks - Seattle, WA
     Mexico City, MX  64.58 ms    0.0%    882.28 Mbps    238.30 Mbps    AT&T México - Mexico City
     Guadalajara, MX  92.43 ms    N/A     834.54 Mbps    247.42 Mbps    INFINITUM - Guadalajara
     Hermosillo, MX   80.68 ms    0.0%    937.20 Mbps    234.93 Mbps    Totalplay - Hermosillo
     Avg DL Speed       : 917.35 Mbps
     Avg UL Speed       : 247.37 Mbps
     Total DL Data      : 30.10 GB
     Total UL Data      : 7.62 GB
     Total Data         : 37.72 GB
     Duration           : 10 min 38 sec
     System Time        : 11/05/2023 - 19:27:40 UTC
     Total Script Runs  : 2254
     Result             : https://cdn1.frocdn.ch/2chMWWlA34vPbOP.txt
    root@ca1-natvps-beau:~#
    stromonic/leapswitch Mumbai
     Basic System Info
     CPU Model          : AMD EPYC-Milan Processor
     CPU Cores          : 1 @ 2794.750 MHz
     CPU Cache          : 512 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 24.5 GB (9.1 GB Used)
     Total RAM          : 969.4 MB (314.6 MB Used)
     System uptime      : 16 days, 23 hour 57 min
     Load average       : 0.44, 0.22, 0.12
     Kernel             : 5.15.0-69-generic
     Basic Network Info
     ISP                : Hostgoi Technologies Private Limited
     ASN                : AS146930 HOSTGOI TECHNOLOGIES PRIVATE LIMITED
     Host               : NIXI
     Speedtest.net (Region: INDIA भारत)
     ISP: Hostgoi Technologies Private Limited
     Nearest          13.24 ms    0.0%    883.79 Mbps    306.71 Mbps    D Nex Technology Pvt ltd - Nagpur
     Mumbai, MH       3.05 ms     0.0%    621.22 Mbps    103.01 Mbps    Tata Teleservices Ltd - Mumbai
     Mumbai, MH       3.31 ms     N/A     852.02 Mbps    939.24 Mbps    Jio - Mumbai
     Pune, MH         4.80 ms     0.0%    584.35 Mbps    939.10 Mbps    Tata Play Fiber - Pune
     Hyderabad, AP-TL 24.67 ms    N/A     191.20 Mbps    63.81 Mbps     Airtel Broadband - Hyderabad
     Bangalore, KA    20.20 ms    0.3%    277.04 Mbps    69.63 Mbps     Bharti Airtel Ltd - Bangalore
     Bangalore, KA    22.31 ms    0.3%    335.62 Mbps    65.77 Mbps     ACT FIBERNET - Bangalore
     Mangalore, KA    28.04 ms    0.0%    280.74 Mbps    53.96 Mbps     BBNL - Mangalore
     Chennai, TN      22.49 ms    N/A     375.99 Mbps    922.64 Mbps    Jio - Chennai
     Chennai, TN      23.14 ms    0.0%    96.09 Mbps     97.32 Mbps     Extreme IX - Chennai
     Coimbatore, TN   30.41 ms    0.5%    149.61 Mbps    59.04 Mbps     Airtel Broadband - Coimbatore
     Madurai, TN      168.30 ms   1.3%    248.30 Mbps    2.23 Mbps      Vi India - Madurai
     Kochi, KL        28.00 ms    N/A     269.24 Mbps    920.79 Mbps    Jio - Kochi
     Kochi, KL        35.34 ms    0.0%    246.99 Mbps    911.66 Mbps    Asianet Broadband - Cochin
     Trivandrum, KL   30.52 ms    3.3%    177.48 Mbps    72.06 Mbps     Keralavision Broadband - Trivandrum
     Kolkata, WB      35.63 ms    0.0%    159.78 Mbps    67.57 Mbps     Alliance Broadband Services Pvt. Ltd. - Kolkata
     Delhi, DL        21.09 ms    0.0%    125.99 Mbps    928.71 Mbps    Extreme IX - New Delhi
     Gurgaon, HR      22.11 ms    0.0%    414.94 Mbps    923.58 Mbps    Powernet - Gurgaon
     Patna, BH        71.07 ms    N/A     297.74 Mbps    867.06 Mbps    Vi India - Patna
     Avg DL Speed       : 346.74 Mbps
     Avg UL Speed       : 437.57 Mbps
     Total DL Data      : 8.17 GB
     Total UL Data      : 8.33 GB
     Total Data         : 16.51 GB
     Duration           : 8 min 23 sec
     System Time        : 11/05/2023 - 19:32:58 UTC
     Total Script Runs  : 2255
     Result             : https://cdn1.frocdn.ch/GpN9lAk85SopXrz.txt
    root@ind1-stromonic-mumbai:~#
  • VPS CrownCloud 2 Cores AMD 2GB RAM - 15 USD
     Basic System Info
     CPU Model          : AMD Ryzen 9 5950X 16-Core Processor
     CPU Cores          : 2 @ 3393.624 MHz
     CPU Cache          : 512 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 58.5 GB (2.8 GB Used)
     Total RAM          : 1.9 GB (153.1 MB Used)
     Total Swap         : 512.0 MB (524.0 KB Used)
     System uptime      : 0 days, 2 hour 23 min
     Load average       : 0.27, 0.47, 0.40
     OS                 : Ubuntu 20.04.6 LTS
     Kernel             : 5.4.0-135-generic
     Basic Network Info
     ISP                : QuadraNet Enterprises LLC
     ASN                : AS8100 QuadraNet Enterprises LLC
     Host               : Crowncloud US LLC
     ISP: QuadraNet
     Nearest          39.43 ms    0.0%    3593.05 Mbps   1965.75 Mbps   Cox - Wichita - Wichita, KS
     Vancouver, BC    41.26 ms    N/A     5290.86 Mbps   1906.56 Mbps   TELUS - Vancouver, BC
     Toronto, ON      60.42 ms    0.0%    4459.98 Mbps   1188.05 Mbps   TELUS - Toronto, ON
     Toronto, ON      66.32 ms    0.0%    3698.13 Mbps   1198.84 Mbps   Bell Canada - Toronto, ON
     Montreal, QC     63.77 ms    0.0%    3586.88 Mbps   1252.24 Mbps   Rogers Wireless - Montréal, QC
     New York, NY     56.67 ms    0.0%    543.55 Mbps    1368.84 Mbps   Clouvider Ltd - New York, NY
     Ashburn, VA      63.53 ms    0.3%    2000.47 Mbps   1231.33 Mbps   Rackdog - Ashburn, VA
     Charlotte, NC    51.51 ms    0.0%    2708.96 Mbps   1583.12 Mbps   Windstream - Charlotte, NC
     Atlanta, GA      FAILED
     Miami, FL        64.32 ms    0.0%    3191.77 Mbps   1258.98 Mbps   AT&T - Miami, FL
     Dallas, TX       34.66 ms    0.0%    4333.19 Mbps   2364.03 Mbps   Hivelocity - Dallas, TX
     Kansas, MO       36.41 ms    0.0%    5603.68 Mbps   1504.44 Mbps   August Internet - Kansas City, MO
     Minneapolis, MN  59.03 ms    0.0%    2113.01 Mbps   1429.48 Mbps   US Internet - Minneapolis, MN
     Chicago, IL      43.70 ms    0.0%    4956.65 Mbps   1900.93 Mbps   GSL Networks - Chicago, IL
     Cleveland, OH    61.40 ms    0.0%    2311.96 Mbps   1309.84 Mbps   Windstream - Cleveland, OH
     Albuquerque, NM  31.72 ms    N/A     3164.83 Mbps   1938.05 Mbps   Comcast - Albuquerque, NM
     Denver, CO       33.81 ms    N/A     4109.33 Mbps   1980.83 Mbps   Comcast - Denver, CO
     Portland, OR     28.68 ms    N/A     4728.66 Mbps   2156.34 Mbps   CenturyLink - Portland, OR
     Las Vegas, NV    6.12 ms     N/A     5947.63 Mbps   3583.01 Mbps   Dish Wireless - Las Vegas, NV
     Phoenix, AZ      7.73 ms     0.0%    4604.02 Mbps   2442.27 Mbps   GSL Networks - Phoenix, AZ
     Los Angeles, CA  0.44 ms     0.0%    6951.30 Mbps   2282.37 Mbps   ReliableSite Hosting - Los Angeles, CA
     San Jose, CA     10.98 ms    0.0%    5004.79 Mbps   1961.23 Mbps   Misaka Network, Inc. - San Jose, CA
     Seattle, WA      29.53 ms    0.0%    4959.74 Mbps   1968.02 Mbps   GSL Networks - Seattle, WA
     Mexico City, MX  64.78 ms    0.0%    915.84 Mbps    650.68 Mbps    AT&T México - Mexico City
     Guadalajara, MX  31.92 ms    N/A     4172.04 Mbps   2066.01 Mbps   INFINITUM - Guadalajara
     Hermosillo, MX   61.00 ms    0.0%    3028.64 Mbps   1223.95 Mbps   Totalplay - Hermosillo
     Avg DL Speed       : 3839.16 Mbps
     Avg UL Speed       : 1748.60 Mbps
     Total DL Data      : 123.45 GB
     Total UL Data      : 51.17 GB
     Total Data         : 174.61 GB
     Duration           : 11 min 14 sec
     System Time        : 11/05/2023 - 11:39:51 UTC
     Total Script Runs  : 2246
     Result             : https://cdn1.frocdn.ch/VA0FSwS0XoidYQj.txt
    Global Speedtest
     Basic System Info
     CPU Cache          : 512 KB
     AES-NI             : ✔ Enabled
     Total RAM          : 1.9 GB (152.8 MB Used)
     System uptime      : 0 days, 2 hour 9 min
     Load average       : 0.71, 0.39, 0.22
     Basic Network Info
     ISP: QuadraNet
     Nearest          39.45 ms    0.0%    4407.61 Mbps   2061.17 Mbps   Cox - Wichita - Wichita, KS
     Kochi, IN        250.41 ms   0.7%    1798.12 Mbps   351.02 Mbps    Asianet Broadband - Cochin
     Bangalore, IN    235.58 ms   0.0%    1491.65 Mbps   309.61 Mbps    Bharti Airtel Ltd - Bangalore
     Chennai, IN      202.30 ms   N/A     2043.96 Mbps   343.58 Mbps    Jio - Chennai
     Mumbai, IN       241.28 ms   0.0%    2088.95 Mbps   311.67 Mbps    i3D.net - Mumbai
     Delhi, IN        265.79 ms   0.0%    2222.27 Mbps   283.99 Mbps    Tata Play Fiber - New Delhi
     Los Angeles, US  0.36 ms     0.0%    5882.56 Mbps   2257.96 Mbps   ReliableSite Hosting - Los Angeles, CA
     Dallas, US       34.72 ms    0.0%    3018.84 Mbps   1920.87 Mbps   Hivelocity - Dallas, TX
     New York, US     56.61 ms    0.0%    641.63 Mbps    1323.04 Mbps   Clouvider Ltd - New York, NY
     Seattle, US      25.45 ms    N/A     4871.67 Mbps   2022.26 Mbps   Comcast - Seattle, WA
     Miami, US        65.82 ms    0.0%    3802.72 Mbps   1251.96 Mbps   AT&T - Miami, FL
     Toronto, CA      54.84 ms    0.0%    1888.03 Mbps   1413.25 Mbps   Rogers - Toronto, ON
     Paris, FR        144.23 ms   0.0%    1826.62 Mbps   567.44 Mbps    ORANGE FRANCE - Paris
     Amsterdam, NL    128.96 ms   0.3%    2063.52 Mbps   615.60 Mbps    Clouvider Ltd - Amsterdam
     Warsaw, PL       157.50 ms   0.0%    2700.30 Mbps   460.61 Mbps    UPC Polska - Warszawa
     London, UK       127.84 ms   0.3%    5509.71 Mbps   632.49 Mbps    VeloxServ Communications - London
     Frankfurt, DE    151.97 ms   0.0%    2664.14 Mbps   552.00 Mbps    23M GmbH - Frankfurt Am Main
     Dubai, AE        251.41 ms   0.0%    1389.87 Mbps   323.91 Mbps    du - Dubai
     Fujairah, AE     247.33 ms   0.0%    3195.01 Mbps   329.39 Mbps    ETISALAT-UAE - Fujairah
     Jeddah, KSA      198.67 ms   0.0%    2022.77 Mbps   399.01 Mbps    Saudi Telecom Company
     Shanghai, CU-CN  279.38 ms   0.0%    2314.54 Mbps   293.14 Mbps    China Unicom 5G - ShangHai
     Nanjing, CT-CN   134.17 ms   0.0%    2537.85 Mbps   489.83 Mbps    China Telecom JiangSu 5G - Nanjing
     Hong Kong, HKG   149.08 ms   N/A     1606.95 Mbps   533.42 Mbps    STC - Hong Kong
     Singapore, SG    185.87 ms   0.0%    2087.84 Mbps   402.72 Mbps    i3D.net - Singapore
     Jakarta, ID      179.09 ms   0.0%    1859.49 Mbps   250.40 Mbps    PT Indosat Tbk - Jakarta
     Tokyo, JP        98.69 ms    N/A     1936.83 Mbps   790.20 Mbps    fdcservers.net - Tokyo
     Avg DL Speed       : 2610.51 Mbps
     Avg UL Speed       : 788.10 Mbps
     Total DL Data      : 97.27 GB
     Total UL Data      : 27.57 GB
     Total Data         : 124.84 GB
     Duration           : 14 min 10 sec
     System Time        : 11/05/2023 - 11:28:35 UTC
     Total Script Runs  : 2245
     Result             : https://cdn1.frocdn.ch/9tsVCoogQYxTeI9.txt
    📱: Samsung Galaxy | 💻: Windows 11
  • @Abdullah said:
    Norway KVM Node
    any norway deal availble?
  • Updated to v2023.05.12
    * Optimize awk usage to handle overflow
    * No more link generation on failed script execution (if no wget is found)
    * Update broken servers in a few locations
    @carlin0 check if the overflow issue is happening now. I tried on Debian 11 Vultr and it worked fine for me!
    WebHorizon JP NAT -> Asia (USD 4.20/year)
     Version            : v2023.05.12
     Basic System Info
     CPU Model          : Intel(R) Xeon(R) CPU E3-1270 v3 @ 3.50GHz
     CPU Cores          : 1 @ 3365.830 MHz
     CPU Cache          : 8192 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 3.9 GB (2.0 GB Used)
     Total RAM          : 256.0 MB (126.9 MB Used)
     Total Swap         : 128.0 MB (44.1 MB Used)
     System uptime      : 137 days, 22 hour 31 min
     Load average       : 0.38, 0.44, 0.22
     OS                 : Ubuntu 18.04.6 LTS
     Kernel             : 4.15.0
     Basic Network Info
     Primary Network    : IPv4
     ISP                : Shock Hosting LLC
     ASN                : AS395092 Shock Hosting LLC
     Host               : Shock
     ISP: Shock Hosting LLC
     Nearest          0.26 ms     N/A     872.10 Mbps    928.37 Mbps    fdcservers.net - Tokyo
     Mumbai, IN       127.09 ms   0.0%    598.52 Mbps    603.04 Mbps    i3D.net - Mumbai
     Chennai, IN      119.05 ms   N/A     574.91 Mbps    732.14 Mbps    Jio - Chennai
     Bangalore, IN    124.04 ms   0.0%    463.56 Mbps    677.21 Mbps    Bharti Airtel Ltd - Bangalore
     Singapore, SG    65.85 ms    0.0%    566.42 Mbps    894.04 Mbps    i3D.net - Singapore
     Tokyo, JP        1.13 ms     0.0%    933.91 Mbps    936.76 Mbps    IPA CyberLab 400G - Tokyo
     China Unicom     FAILED
     China Telecom    FAILED
     China Mobile     FAILED
     Hong Kong, CN    41.55 ms    0.0%    722.15 Mbps    929.68 Mbps    i3D.net - Hong Kong
     Karachi, PK      326.48 ms   0.0%    3.34 Mbps      139.53 Mbps    JAZZ - Karachi
     Islamabad, PK    192.65 ms   N/A     887.07 Mbps    436.25 Mbps    Telenor Pakistan - Islamabad
     Kathmandu, NP    140.51 ms   N/A     760.98 Mbps    623.28 Mbps    Nepal Telecom - Hetauda
     Colombo, SL      110.25 ms   N/A     564.42 Mbps    407.94 Mbps    Airtel Lanka - Colombo
     Dhaka, BD        180.17 ms   N/A     481.27 Mbps    0.78 Mbps      Grameenphone Ltd - Dhaka
     Bangkok, TH      109.67 ms   0.0%    529.09 Mbps    741.06 Mbps    3BB - Bangkok
     Ho Chi Minh, VN  85.10 ms    0.0%    511.08 Mbps    855.67 Mbps    Viettel Network - Ho Chi Minh
     Hanoi, VN        105.65 ms   1.7%    642.24 Mbps    346.24 Mbps    Vietnamobile - Hanoi
     Tapei, TW        33.26 ms    N/A     945.05 Mbps    601.47 Mbps    Chunghwa Mobile - Taipei
     Jakarta, ID      112.86 ms   0.7%    430.35 Mbps    21.06 Mbps     PT Indosat Tbk - Jakarta
     Bandah Aceh, ID  130.28 ms   0.0%    838.18 Mbps    14.01 Mbps     PT Acehlink Media - Banda Aceh
     Kuala Lum, MY    78.33 ms    0.0%    693.36 Mbps    875.29 Mbps    Telekom Malaysia Berhad - Kuala Lumpur
     Novosibirsk, RU  315.60 ms   0.0%    7.65 Mbps      193.47 Mbps    Megafon - Novosibirsk
     Istanbul, TR     274.78 ms   0.0%    587.84 Mbps    22.67 Mbps     Turkcell - Istanbul
     Avg DL Speed       : 600.65 Mbps
     Avg UL Speed       : 522.86 Mbps
     Total DL Data      : 16.05 GB
     Total UL Data      : 14.47 GB
     Total Data         : 30.52 GB
     Duration           : 10 min 29 sec
     System Time        : 12/05/2023 - 20:37:12 IST
     Total Script Runs  : 2282
     Result             : https://cdn1.frocdn.ch/3k8oyGYNvlGbbJq.txt
    root@jp1-webhorizon-tokyo:~#
    Thanked by (1)carlin0
  • @sh97 the problem persists
     Basic System Info
     CPU Model          : Intel(R) Xeon(R) CPU E5-2690 0 @ 2.90GHz
     CPU Cores          : 1 @ 2899.996 MHz
     CPU Cache          : 16384 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 18,2 GB (2,1 GB Used)
     Total RAM          : 1,4 GB (145,5 MB Used)
     Total Swap         : 1,5 GB (0 Used)
     System uptime      : 13 days, 6 hour 22 min
     Load average       : 0.00, 0.00, 0.00
     Kernel             : 5.10.0-22-amd64
     Basic Network Info
     ISP                : Multacom Corporation
     ASN                : AS35916 MULTACOM CORPORATION
     Host               : Multacom Corporation
     ISP: Multacom Corporation
     Nearest          0.39 ms     0.0%    846.64 Mbps    836.45 Mbps    Race Communications - Los Angeles, CA
     Vancouver, BC    31.40 ms    N/A     614.21 Mbps    832.84 Mbps    TELUS - Vancouver, BC
     Toronto, ON      66.90 ms    0.0%    557.65 Mbps    846.35 Mbps    TELUS - Toronto, ON
     Toronto, ON      76.06 ms    0.0%    567.25 Mbps    862.61 Mbps    Bell Canada - Toronto, ON
     Montreal, QC     79.14 ms    0.0%    256.27 Mbps    856.36 Mbps    Rogers Wireless - Montréal, QC
     New York, NY     60.38 ms    0.0%    48.62 Mbps     785.06 Mbps    Clouvider Ltd - New York, NY
     Ashburn, VA      67.82 ms    0.0%    121.16 Mbps    676.82 Mbps    Rackdog - Ashburn, VA
    awk: line 1: 46679e+11281 : decimal overflow
    awk: line 1: 36878e+11917 : decimal overflow
    ^C
    The script has been terminated.
    Have you tried IPV4 or IPV6 ?
    "He sounds like hearing him say to the liquor merchant: you who sell it what buys you better ?"
    F. De André --- Free NAT KVM
  • Well somehow I found a free alibaba cloud thingie and here is the specs on it
    https://cdn1.frocdn.ch/Uy9GpE3ilwJL1cZ.txt
  • edited May 2023
    @schism said: Well somehow I found a free alibaba cloud thingie and here is the specs on it
    1 Mbps? =)
  • VPS Hypere 2 Cores AMD 2GB RAM - 8 GBP
     Basic System Info
     CPU Cache          : 512 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 67.8 GB (2.8 GB Used)
     Total RAM          : 1.9 GB (223.3 MB Used)
     System uptime      : 0 days, 1 hour 15 min
     Load average       : 0.27, 0.09, 0.19
     Kernel             : 5.4.0-148-generic
     Basic Network Info
     ISP                : August Internet
     ASN                : AS200636 Paravirt LTD
     Host               : hkgo LLC
     Location (IPv4)    : London, England, GB
     ISP: August-internet
     Nearest          79.97 ms    0.0%    942.77 Mbps    835.62 Mbps    Nitel - New York, NY
     London, UK       0.66 ms     0.0%    912.81 Mbps    924.59 Mbps    VeloxServ Communications - London
     Edinburgh, UK    11.59 ms    N/A     935.84 Mbps    939.11 Mbps    Vodafone UK - Edinburgh
     Dublin, IE       12.88 ms    0.0%    938.96 Mbps    939.01 Mbps    Three Ireland - Dublin
     Amsterdam, NL    5.83 ms     0.0%    938.67 Mbps    938.55 Mbps    GSL Networks - Amsterdam
     Paris, FR        7.97 ms     0.0%    938.66 Mbps    932.04 Mbps    ORANGE FRANCE - Paris
     Marseille, FR    25.53 ms    0.0%    939.92 Mbps    929.16 Mbps    GSL Networks - Marseille
     Madrid, ES       28.28 ms    0.0%    938.47 Mbps    932.10 Mbps    Orange - Jazztel - Madrid
     Barcelona, ES    23.93 ms    0.5%    936.88 Mbps    935.32 Mbps    Adamo - Barcelona
     Lisbon, PT       46.78 ms    N/A     944.07 Mbps    921.66 Mbps    fdcservers.net - Lisbon
     Rome, IT         27.97 ms    0.0%    947.53 Mbps    943.69 Mbps    TIM SpA - Rome
     Zurich, CH       21.87 ms    0.0%    940.84 Mbps    933.43 Mbps    Sunrise Communication AG - Zurich
     Frankfurt, DE    13.47 ms    0.0%    946.27 Mbps    936.28 Mbps    23M GmbH - Frankfurt Am Main
     Berlin, DE       FAILED
     Vienna, AT       26.42 ms    0.0%    963.23 Mbps    935.46 Mbps    A1 Telekom Austria AG - Vienna
     Budapest, HU     32.78 ms    N/A     939.29 Mbps    938.57 Mbps    Yettel Hungary - Budapest
     Gdansk, PL       32.30 ms    0.0%    943.82 Mbps    938.24 Mbps    Orange Polska S.A. - Gdansk
     Warsaw, PL       33.42 ms    0.0%    940.40 Mbps    937.80 Mbps    UPC Polska - Warszawa
     Lviv, UA         34.07 ms    0.0%    951.21 Mbps    933.50 Mbps    Kyivstar - Lviv
     Kyiv, UA         39.21 ms    0.0%    938.60 Mbps    919.42 Mbps    o3 - Kyiv
     Minsk, BY        33.91 ms    0.0%    939.00 Mbps    934.44 Mbps    A1 - Minsk
     Bucharest, RO    41.70 ms    1.0%    941.86 Mbps    936.47 Mbps    Orange Romania Communications - Bucharest
     Helsinki, FI     38.67 ms    0.0%    943.36 Mbps    938.83 Mbps    Elisa Oyj - Helsinki
     Stockholm, SE    30.80 ms    0.0%    939.77 Mbps    939.00 Mbps    i3D.net - Stockholm
     Oslo, NO         32.31 ms    0.0%    939.78 Mbps    934.47 Mbps    Speedtest.net - Oslo
     Moscow, RU       55.70 ms    0.0%    939.44 Mbps    920.67 Mbps    MTS - Moscow
     Moscow, RU       47.40 ms    0.0%    944.83 Mbps    928.98 Mbps    Rostelecom - Moscow
     Istanbul, TR     51.18 ms    0.3%    980.20 Mbps    928.06 Mbps    Turkcell - Istanbul
     Istanbul, TR     50.85 ms    0.0%    966.57 Mbps    928.47 Mbps    Vodafone TR - Istanbul
     Avg DL Speed       : 943.32 Mbps
     Avg UL Speed       : 929.75 Mbps
     Total DL Data      : 32.97 GB
     Total UL Data      : 29.88 GB
     Total Data         : 62.85 GB
     Duration           : 11 min 13 sec
     System Time        : 13/05/2023 - 09:57:47 WIB
     Total Script Runs  : 2302
     Result             : https://cdn1.frocdn.ch/mhzIU1kXA3Dqx0y.txt
    Global Speedtest
     Basic System Info
     CPU Cache          : 512 KB
     AES-NI             : ✔ Enabled
     Total RAM          : 1.9 GB (222.1 MB Used)
     System uptime      : 0 days, 1 hour 3 min
     Load average       : 0.00, 0.08, 0.41
     Basic Network Info
     Host               : hkgo LLC
     Nearest          82.81 ms    0.0%    942.98 Mbps    882.39 Mbps    Windstream - New York, NY
     Kochi, IN        259.36 ms   0.0%    942.24 Mbps    296.68 Mbps    Asianet Broadband - Cochin
     Bangalore, IN    169.14 ms   0.0%    942.73 Mbps    466.88 Mbps    Bharti Airtel Ltd - Bangalore
     Chennai, IN      251.53 ms   N/A     948.40 Mbps    335.10 Mbps    Jio - Chennai
     Mumbai, IN       239.11 ms   0.0%    942.07 Mbps    343.48 Mbps    i3D.net - Mumbai
     Delhi, IN        196.69 ms   0.0%    942.89 Mbps    408.15 Mbps    Tata Play Fiber - New Delhi
     Los Angeles, US  131.53 ms   0.0%    947.17 Mbps    581.05 Mbps    ReliableSite Hosting - Los Angeles, CA
     Dallas, US       102.96 ms   0.0%    935.42 Mbps    779.58 Mbps    Hivelocity - Dallas, TX
     New York, US     75.54 ms    0.0%    940.23 Mbps    904.44 Mbps    Clouvider Ltd - New York, NY
     Seattle, US      147.54 ms   N/A     948.28 Mbps    525.40 Mbps    Comcast - Seattle, WA
     Miami, US        145.70 ms   0.0%    943.11 Mbps    753.65 Mbps    AT&T - Miami, FL
     Toronto, CA      96.36 ms    0.0%    938.76 Mbps    766.09 Mbps    Rogers - Toronto, ON
     Paris, FR        12.27 ms    0.0%    940.58 Mbps    938.73 Mbps    ORANGE FRANCE - Paris
     Amsterdam, NL    5.15 ms     0.0%    939.77 Mbps    937.66 Mbps    Clouvider Ltd - Amsterdam
     Warsaw, PL       32.08 ms    0.0%    941.68 Mbps    938.10 Mbps    UPC Polska - Warszawa
     London, UK       0.70 ms     0.0%    937.09 Mbps    934.99 Mbps    VeloxServ Communications - London
     Frankfurt, DE    14.33 ms    0.0%    948.57 Mbps    927.48 Mbps    23M GmbH - Frankfurt Am Main
     Dubai, AE        313.55 ms   0.0%    967.49 Mbps    254.85 Mbps    du - Dubai
     Fujairah, AE     309.76 ms   0.0%    805.52 Mbps    247.19 Mbps    ETISALAT-UAE - Fujairah
     Jeddah, KSA      80.35 ms    0.0%    985.55 Mbps    902.97 Mbps    Saudi Telecom Company
     Shanghai, CU-CN  FAILED
     Hong Kong, HKG   238.88 ms   N/A     945.41 Mbps    345.20 Mbps    STC - Hong Kong
     Singapore, SG    158.04 ms   0.3%    944.53 Mbps    493.40 Mbps    i3D.net - Singapore
     Jakarta, ID      269.98 ms   0.0%    951.91 Mbps    180.76 Mbps    PT Indosat Tbk - Jakarta
     Tokyo, JP        244.97 ms   N/A     946.94 Mbps    321.93 Mbps    fdcservers.net - Tokyo
     Avg DL Speed       : 940.39 Mbps
     Avg UL Speed       : 602.76 Mbps
     Total DL Data      : 31.08 GB
     Total UL Data      : 17.60 GB
     Total Data         : 48.68 GB
     Duration           : 11 min 49 sec
     System Time        : 13/05/2023 - 09:46:32 WIB
     Total Script Runs  : 2301
     Result             : https://cdn1.frocdn.ch/V0Sl7T0itsoerKc.txt
    I will check again. I have never been able to get this issue so it's hard.
    Yes, tried IPv6 only. (Debian 11/Vultr Germany)
    1 Mbps? =)
    Yeah the vps itself sucks lol. Not even sure how I found it. I had heard that alibaba is supposed tobe a really awesome vps host however if the freebie is any indication.......
  • 10 Gbps? Also why Asia speedtests failed?
    No idea. I was surprised at that. As far as the speed I have no idea except I was beating the snot out of running a bunch of compile stuff.
    Thanked by (1)somik
  • Hostslick - BRUTAL 2023 10Gbit VPS Killer Deal I (€48.00/y recurring)
     Basic System Info
     CPU Model          : Intel(R) Xeon(R) CPU E5-2690 v2 @ 3.00GHz
     CPU Cores          : 4 @ 2992.792 MHz
     CPU Cache          : 25600 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 98.3 GB (1.5 GB Used)
     Total RAM          : 3.8 GB (66.6 MB Used)
     System uptime      : 0 days, 0 hour 3 min
     Load average       : 0.08, 0.05, 0.01
     Kernel             : 5.10.0-23-amd64
     Basic Network Info
     ISP                : ColocationX Ltd.
     ASN                : AS208046 ColocationX Ltd.
     Host               : ColocationXV6
     Location (IPv4)    : Berngau, Bavaria, DE
     ISP: ColocationX Ltd.
     Nearest          125.12 ms   0.0%    3552.81 Mbps   640.14 Mbps    Metronet - Fayetteville, NC
     Kochi, IN        234.23 ms   0.0%    4064.67 Mbps   416.47 Mbps    Asianet Broadband - Cochin
     Bangalore, IN    155.59 ms   0.0%    4664.83 Mbps   610.42 Mbps    Bharti Airtel Ltd - Bangalore
     Chennai, IN      162.04 ms   N/A     4325.06 Mbps   632.02 Mbps    Jio - Chennai
     Mumbai, IN       120.52 ms   0.0%    4338.30 Mbps   654.11 Mbps    i3D.net - Mumbai
     Delhi, IN        151.06 ms   0.0%    4348.50 Mbps   434.29 Mbps    Tata Play Fiber - New Delhi
     Los Angeles, US  139.54 ms   0.0%    2701.32 Mbps   496.95 Mbps    ReliableSite Hosting - Los Angeles, CA
     Dallas, US       118.34 ms   0.0%    1716.30 Mbps   663.92 Mbps    Hivelocity - Dallas, TX
     New York, US     87.21 ms    0.0%    3411.34 Mbps   927.74 Mbps    Clouvider Ltd - New York, NY
     Seattle, US      166.56 ms   N/A     4531.61 Mbps   505.57 Mbps    Comcast - Seattle, WA
     Miami, US        114.74 ms   0.0%    2134.01 Mbps   443.96 Mbps    AT&T - Miami, FL
     Toronto, CA      93.94 ms    0.0%    4913.53 Mbps   926.89 Mbps    Rogers - Toronto, ON
     Paris, FR        17.64 ms    0.0%    3298.25 Mbps   1610.35 Mbps   ORANGE FRANCE - Paris
     Amsterdam, NL    8.65 ms     0.0%    2751.50 Mbps   2113.52 Mbps   Clouvider Ltd - Amsterdam
     Warsaw, PL       26.37 ms    0.0%    2633.01 Mbps   1538.47 Mbps   UPC Polska - Warszawa
     London, UK       12.63 ms    0.0%    5225.60 Mbps   1387.36 Mbps   VeloxServ Communications - London
     Frankfurt, DE    12.29 ms    0.0%    3861.23 Mbps   1064.66 Mbps   23M GmbH - Frankfurt Am Main
     Dubai, AE        130.82 ms   0.0%    4092.51 Mbps   717.68 Mbps    du - Dubai
     Fujairah, AE     121.79 ms   0.0%    3550.33 Mbps   731.18 Mbps    ETISALAT-UAE - Fujairah
     Jeddah, KSA      78.29 ms    0.0%    3734.30 Mbps   847.61 Mbps    Saudi Telecom Company
     Shanghai, CU-CN  168.59 ms   0.0%    1518.08 Mbps   466.67 Mbps    China Unicom 5G - ShangHai
     Nanjing, CT-CN   253.15 ms   0.0%    2355.20 Mbps   170.85 Mbps    China Telecom JiangSu 5G - Nanjing
     Hong Kong, HKG   182.58 ms   N/A     4105.46 Mbps   471.63 Mbps    STC - Hong Kong
     Singapore, SG    160.96 ms   0.0%    3825.57 Mbps   565.64 Mbps    i3D.net - Singapore
     Jakarta, ID      171.51 ms   0.0%    3365.01 Mbps   282.14 Mbps    PT Indosat Tbk - Jakarta
     Tokyo, JP        280.84 ms   N/A     1907.95 Mbps   349.57 Mbps    fdcservers.net - Tokyo
     Avg DL Speed       : 3497.16 Mbps
     Avg UL Speed       : 756.53 Mbps
     Total DL Data      : 132.20 GB
     Total UL Data      : 27.92 GB
     Total Data         : 160.12 GB
     Duration           : 13 min 46 sec
     System Time        : 17/05/2023 - 19:48:20 EDT
     Total Script Runs  : 2466
     Result             : https://cdn1.frocdn.ch/YoD7GlAI5IiBgsc.txt
    All are 4Gbps or lower for down, while 2Gbps or lower for up. For servers, up is more important then down, and as most of the speeds are bellow 1Gbps, I wont really call it a "10Gbit killer deal"...
  • @treesmokah said: Hostslick - BRUTAL 2023 10Gbit VPS Killer Deal I (€48.00/y recurring)
    Try Region (EUROPE) speedtest.
  • edited May 2023
    VPS ExtraVM 2 Cores AMD 2GB RAM - 10 USD | USA (Piscataway, New Jersey)
     Basic System Info
     CPU Model          : AMD Ryzen 9 7900 12-Core Processor
     CPU Cores          : 2 @ 3693.062 MHz
     CPU Cache          : 1024 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 29.0 GB (2.5 GB Used)
     Total RAM          : 1.9 GB (221.4 MB Used)
     System uptime      : 0 days, 1 hour 17 min
     Load average       : 0.11, 0.12, 0.13
     Basic Network Info
     ISP                : IPvX.Solutions LLC
     ASN                : AS23470 ReliableSite.Net LLC
     Host               : EXTRAVM, LLC
     ISP: ReliableSite.Net LLC
     Nearest          0.16 ms     0.0%    8069.98 Mbps   931.68 Mbps    ReliableSite Hosting - Piscataway, NJ
     Vancouver, BC    58.81 ms    N/A     6612.78 Mbps   935.35 Mbps    TELUS - Vancouver, BC
     Toronto, ON      11.68 ms    0.0%    7154.35 Mbps   928.81 Mbps    TELUS - Toronto, ON
     Toronto, ON      51.65 ms    0.0%    6103.12 Mbps   924.15 Mbps    Bell Canada - Toronto, ON
     Montreal, QC     10.08 ms    0.0%    7397.74 Mbps   925.20 Mbps    Rogers Wireless - Montréal, QC
     New York, NY     3.16 ms     0.0%    5525.93 Mbps   924.62 Mbps    Clouvider Ltd - New York, NY
     Ashburn, VA      6.77 ms     0.0%    7515.13 Mbps   935.81 Mbps    Rackdog - Ashburn, VA
     Charlotte, NC    24.10 ms    0.0%    7764.84 Mbps   944.94 Mbps    Windstream - Charlotte, NC
     Atlanta, GA      44.69 ms    0.0%    6594.01 Mbps   929.28 Mbps    DediPath - Atlanta, GA
     Miami, FL        34.85 ms    0.0%    5280.79 Mbps   944.17 Mbps    AT&T - Miami, FL
     Dallas, TX       73.98 ms    0.0%    4411.91 Mbps   957.57 Mbps    Hivelocity - Dallas, TX
     Kansas, MO       27.87 ms    0.0%    7071.87 Mbps   931.27 Mbps    August Internet - Kansas City, MO
     Minneapolis, MN  26.76 ms    0.0%    7441.44 Mbps   939.36 Mbps    US Internet - Minneapolis, MN
     Chicago, IL      17.45 ms    0.0%    5524.46 Mbps   938.95 Mbps    GSL Networks - Chicago, IL
     Cleveland, OH    17.71 ms    0.0%    7648.67 Mbps   933.48 Mbps    Windstream - Cleveland, OH
     Albuquerque, NM  49.03 ms    N/A     6144.62 Mbps   921.74 Mbps    Comcast - Albuquerque, NM
     Denver, CO       41.72 ms    N/A     6439.63 Mbps   930.31 Mbps    Comcast - Denver, CO
     Portland, OR     70.34 ms    N/A     5744.49 Mbps   948.19 Mbps    CenturyLink - Portland, OR
     Las Vegas, NV    75.47 ms    N/A     4361.69 Mbps   975.72 Mbps    Dish Wireless - Las Vegas, NV
     Phoenix, AZ      98.35 ms    0.0%    3974.65 Mbps   829.78 Mbps    GSL Networks - Phoenix, AZ
     Los Angeles, CA  61.88 ms    0.0%    6244.13 Mbps   930.17 Mbps    ReliableSite Hosting - Los Angeles, CA
     San Jose, CA     64.27 ms    0.0%    5581.45 Mbps   936.92 Mbps    Misaka Network, Inc. - San Jose, CA
     Seattle, WA      59.79 ms    0.0%    4664.68 Mbps   921.37 Mbps    GSL Networks - Seattle, WA
     Mexico City, MX  60.44 ms    N/A     901.96 Mbps    517.23 Mbps    AT&T México - Mexico City
     Guadalajara, MX  91.06 ms    N/A     4310.81 Mbps   895.36 Mbps    INFINITUM - Guadalajara
     Hermosillo, MX   88.61 ms    0.0%    2857.11 Mbps   919.72 Mbps    Totalplay - Hermosillo
     Avg DL Speed       : 5820.88 Mbps
     Avg UL Speed       : 913.51 Mbps
     Total DL Data      : 198.30 GB
     Total UL Data      : 28.02 GB
     Total Data         : 226.32 GB
     Duration           : 10 min 37 sec
     System Time        : 18/05/2023 - 12:39:24 WIB
     Total Script Runs  : 2470
     Result             : https://cdn1.frocdn.ch/Rtco0kouTxLGHMv.txt
    Global Speedtest
     Basic System Info
     CPU Cache          : 1024 KB
     AES-NI             : ✔ Enabled
     Total RAM          : 1.9 GB (221.8 MB Used)
     System uptime      : 0 days, 1 hour 5 min
     Load average       : 0.09, 0.10, 0.20
     Basic Network Info
     Host               : EXTRAVM, LLC
     Nearest          0.17 ms     0.0%    8031.86 Mbps   928.34 Mbps    ReliableSite Hosting - Piscataway, NJ
     Kochi, IN        214.47 ms   0.0%    3204.41 Mbps   375.57 Mbps    Asianet Broadband - Cochin
     Bangalore, IN    216.49 ms   0.0%    3259.36 Mbps   382.98 Mbps    Bharti Airtel Ltd - Bangalore
     Chennai, IN      217.33 ms   N/A     3552.46 Mbps   381.62 Mbps    Jio - Chennai
     Mumbai, IN       233.87 ms   0.0%    3290.12 Mbps   326.34 Mbps    i3D.net - Mumbai
     Delhi, IN        205.97 ms   0.0%    3042.28 Mbps   349.52 Mbps    Tata Play Fiber - New Delhi
     Los Angeles, US  82.08 ms    0.0%    3845.16 Mbps   927.38 Mbps    ReliableSite Hosting - Los Angeles, CA
     Dallas, US       71.22 ms    0.0%    3302.04 Mbps   851.32 Mbps    Hivelocity - Dallas, TX
     New York, US     3.15 ms     0.0%    7637.30 Mbps   926.70 Mbps    Clouvider Ltd - New York, NY
     Seattle, US      66.71 ms    N/A     7389.43 Mbps   942.07 Mbps    Comcast - Seattle, WA
     Miami, US        FAILED
     Toronto, CA      14.07 ms    0.0%    6837.06 Mbps   927.44 Mbps    Rogers - Toronto, ON
     Paris, FR        78.54 ms    0.0%    3677.96 Mbps   962.18 Mbps    ORANGE FRANCE - Paris
     Amsterdam, NL    74.33 ms    0.0%    4554.99 Mbps   954.67 Mbps    Clouvider Ltd - Amsterdam
     Warsaw, PL       98.54 ms    0.0%    2940.02 Mbps   827.32 Mbps    UPC Polska - Warszawa
     London, UK       69.74 ms    0.3%    5635.94 Mbps   947.76 Mbps    VeloxServ Communications - London
     Frankfurt, DE    78.75 ms    0.0%    5940.81 Mbps   307.74 Mbps    23M GmbH - Frankfurt Am Main
     Dubai, AE        195.92 ms   0.0%    3124.82 Mbps   410.84 Mbps    du - Dubai
     Fujairah, AE     196.18 ms   0.0%    4262.95 Mbps   440.35 Mbps    ETISALAT-UAE - Fujairah
     Jeddah, KSA      142.15 ms   0.0%    4116.28 Mbps   420.78 Mbps    Saudi Telecom Company
     Shanghai, CU-CN  236.06 ms   9.0%    1668.38 Mbps   288.54 Mbps    China Unicom 5G - ShangHai
     Nanjing, CT-CN   198.83 ms   0.3%    3095.90 Mbps   246.49 Mbps    China Telecom JiangSu 5G - Nanjing
     Hong Kong, HKG   218.82 ms   N/A     2977.13 Mbps   357.91 Mbps    STC - Hong Kong
     Singapore, SG    206.60 ms   0.0%    3230.45 Mbps   393.74 Mbps    i3D.net - Singapore
     Jakarta, ID      244.88 ms   0.0%    2047.96 Mbps   197.62 Mbps    PT Indosat Tbk - Jakarta
     Tokyo, JP        157.60 ms   N/A     1326.26 Mbps   521.90 Mbps    fdcservers.net - Tokyo
     Avg DL Speed       : 4079.64 Mbps
     Avg UL Speed       : 583.88 Mbps
     Total DL Data      : 130.50 GB
     Total UL Data      : 18.68 GB
     Total Data         : 149.18 GB
     Duration           : 12 min 9 sec
     System Time        : 18/05/2023 - 12:28:46 WIB
     Total Script Runs  : 2468
     Result             : https://cdn1.frocdn.ch/CWtB4PVgMgC20mN.txt
    Now that is a impressive peering and download speed, even for global!
  • Let me try our result ..thank you for sharing looks good.
  • @somik said: Now that is a impressive peering and download speed, even for global!
    Yes. Inbound 10Gbps, Outbound 1Gbps, as advertised.
    That's just almost perfectly as advertised! Nice!
  • edited May 2023
    Vultr Delhi-NCR
    1 Core 1GB RAM
    6 USD/Monthly
    `---------------------------- network-speed.xyz ----------------------------
     Basic System Info
     CPU Model          : AMD EPYC-Rome Processor
     CPU Cores          : 1 @ 1996.248 MHz
     CPU Cache          : 512 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 23.3 GB (6.9 GB Used)
     Total RAM          : 969.4 MB (83.0 MB Used)
     Total Swap         : 2.3 GB (48.7 MB Used)
     System uptime      : 0 days, 0 hour 15 min
     Load average       : 0.66, 0.60, 0.29
     Kernel             : 5.15.0-72-generic
     Virtualization     : MICROSOFT
     Basic Network Info
     ISP                : The Constant Company, LLC
     ASN                : AS20473 The Constant Company, LLC
     Host               : The Constant Company, LLC
     ISP: Choopa, LLC
     Nearest          1.17 ms     0.0%    2423.65 Mbps   3525.85 Mbps   Esto Internet - Noida
     Kochi, IN        71.90 ms    0.0%    1710.76 Mbps   1738.49 Mbps   Asianet Broadband - Cochin
     Bangalore, IN    39.50 ms    0.0%    2478.43 Mbps   2073.30 Mbps   Bharti Airtel Ltd - Bangalore
     Chennai, IN      43.10 ms    N/A     2539.43 Mbps   2654.78 Mbps   Jio - Chennai
     Mumbai, IN       19.83 ms    0.0%    2658.31 Mbps   2950.19 Mbps   i3D.net - Mumbai
     Delhi, IN        2.84 ms     0.9%    2680.14 Mbps   3625.03 Mbps   Tata Play Fiber - New Delhi
     Los Angeles, US  241.89 ms   0.0%    2549.90 Mbps   342.15 Mbps    ReliableSite Hosting - Los Angeles, CA
     Dallas, US       290.17 ms   0.0%    822.19 Mbps    710.23 Mbps    Hivelocity - Dallas, TX
     New York, US     275.61 ms   0.0%    533.97 Mbps    325.89 Mbps    Clouvider Ltd - New York, NY
     Seattle, US      258.98 ms   N/A     2999.59 Mbps   330.80 Mbps    Comcast - Seattle, WA
     Miami, US        278.04 ms   0.0%    759.65 Mbps    598.76 Mbps    AT&T - Miami, FL
     Toronto, CA      266.50 ms   0.0%    2733.83 Mbps   317.74 Mbps    Rogers - Toronto, ON
     Paris, FR        FAILED
     Amsterdam, NL    142.36 ms   0.0%    1163.03 Mbps   558.02 Mbps    Clouvider Ltd - Amsterdam
     Warsaw, PL       221.57 ms   0.0%    1160.31 Mbps   388.41 Mbps    UPC Polska - Warszawa
     London, UK       150.48 ms   0.0%    713.54 Mbps    1589.22 Mbps   VeloxServ Communications - London
     Frankfurt, DE    136.84 ms   0.0%    3613.94 Mbps   607.84 Mbps    23M GmbH - Frankfurt Am Main
     Dubai, AE        252.37 ms   0.0%    2287.20 Mbps   408.38 Mbps    du - Dubai
     Fujairah, AE     85.64 ms    0.0%    739.92 Mbps    2733.25 Mbps   ETISALAT-UAE - Fujairah
     Jeddah, KSA      217.12 ms   0.0%    1353.88 Mbps   1135.19 Mbps   Saudi Telecom Company
     Shanghai, CU-CN  187.78 ms   0.0%    548.02 Mbps    522.58 Mbps    China Unicom 5G - ShangHai
     Nanjing, CT-CN   288.49 ms   0.0%    1033.77 Mbps   261.62 Mbps    China Telecom JiangSu 5G - Nanjing
     Hong Kong, HKG   112.20 ms   N/A     3457.88 Mbps   775.23 Mbps    STC - Hong Kong
     Singapore, SG    257.21 ms   0.0%    3376.76 Mbps   338.08 Mbps    i3D.net - Singapore
     Jakarta, ID      97.14 ms    0.0%    3467.22 Mbps   290.66 Mbps    PT Indosat Tbk - Jakarta
     Tokyo, JP        259.31 ms   N/A     288.14 Mbps    915.94 Mbps    fdcservers.net - Tokyo
     Avg DL Speed       : 1923.74 Mbps
     Avg UL Speed       : 1188.70 Mbps
     Total DL Data      : 67.84 GB
     Total UL Data      : 37.95 GB
     Total Data         : 105.80 GB
     Duration           : 13 min 21 sec
     System Time        : 18/05/2023 - 08:44:38 UTC
     Total Script Runs  : 2472
     Result             : https://cdn1.frocdn.ch/xY7hvOSWsIWaiE5.txt
  • Hostcram Dallas Tx
     Basic System Info
     CPU Model          : 11th Gen Intel(R) Core(TM) i9-11900K @ 3.50GHz
     CPU Cores          : 2 @ 3504.000 MHz
     AES-NI             : ✔ Enabled
     Total Disk         : 22.7 GB (9.1 GB Used)
     Total RAM          : 1.9 GB (354.1 MB Used)
     Total Swap         : 1.9 GB (63.2 MB Used)
     System uptime      : 37 days, 22 hour 51 min
     Kernel             : 5.4.0-146-generic
     Basic Network Info
     ISP                : HostCram LLC
     ASN                : AS39618 HostCram LLC
     Host               : HostCram LLC
     ISP: HostCram LLC
     Nearest          0.77 ms     0.0%    940.68 Mbps    861.85 Mbps    Frontier - Dallas, TX
     Kochi, IN        256.45 ms   0.0%    383.47 Mbps    339.27 Mbps    Asianet Broadband - Cochin
     Bangalore, IN    251.00 ms   0.0%    462.93 Mbps    355.68 Mbps    Bharti Airtel Ltd - Bangalore
     Chennai, IN      247.61 ms   N/A     340.78 Mbps    349.76 Mbps    Jio - Chennai
     Mumbai, IN       237.44 ms   0.0%    388.33 Mbps    320.76 Mbps    i3D.net - Mumbai
     Delhi, IN        279.81 ms   0.0%    478.48 Mbps    302.31 Mbps    Tata Play Fiber - New Delhi
     Los Angeles, US  37.96 ms    0.0%    929.12 Mbps    879.24 Mbps    ReliableSite Hosting - Los Angeles, CA
     Dallas, US       0.86 ms     0.0%    940.21 Mbps    867.44 Mbps    Hivelocity - Dallas, TX
     New York, US     38.81 ms    0.0%    815.07 Mbps    876.79 Mbps    Clouvider Ltd - New York, NY
     Seattle, US      46.57 ms    N/A     931.22 Mbps    848.41 Mbps    Comcast - Seattle, WA
     Miami, US        31.76 ms    0.0%    889.00 Mbps    863.68 Mbps    AT&T - Miami, FL
     Toronto, CA      34.47 ms    0.0%    937.75 Mbps    850.63 Mbps    Rogers - Toronto, ON
     Paris, FR        112.67 ms   0.0%    644.37 Mbps    729.90 Mbps    ORANGE FRANCE - Paris
     Amsterdam, NL    112.42 ms   0.0%    668.23 Mbps    736.89 Mbps    Clouvider Ltd - Amsterdam
     Warsaw, PL       151.52 ms   0.0%    568.55 Mbps    567.85 Mbps    UPC Polska - Warszawa
     London, UK       104.56 ms   0.0%    945.56 Mbps    771.35 Mbps    VeloxServ Communications - London
     Frankfurt, DE    123.07 ms   0.0%    823.85 Mbps    706.62 Mbps    23M GmbH - Frankfurt Am Main
     Dubai, AE        238.15 ms   0.0%    482.56 Mbps    282.77 Mbps    du - Dubai
     Fujairah, AE     234.19 ms   0.0%    896.36 Mbps    378.66 Mbps    ETISALAT-UAE - Fujairah
     Jeddah, KSA      173.22 ms   0.0%    497.64 Mbps    510.97 Mbps    Saudi Telecom Company
     Shanghai, CU-CN  204.23 ms   0.0%    549.72 Mbps    378.26 Mbps    China Unicom 5G - ShangHai
     Nanjing, CT-CN   185.34 ms   0.8%    357.37 Mbps    28.79 Mbps     China Telecom JiangSu 5G - Nanjing
     Hong Kong, HKG   187.32 ms   N/A     451.14 Mbps    459.64 Mbps    STC - Hong Kong
     Singapore, SG    215.49 ms   0.0%    354.59 Mbps    208.64 Mbps    i3D.net - Singapore
     Jakarta, ID      270.27 ms   0.0%    376.05 Mbps    109.48 Mbps    PT Indosat Tbk - Jakarta
     Tokyo, JP        140.35 ms   N/A     688.23 Mbps    619.16 Mbps    fdcservers.net - Tokyo
     Avg DL Speed       : 643.89 Mbps
     Avg UL Speed       : 546.34 Mbps
     Total DL Data      : 22.75 GB
     Total UL Data      : 17.88 GB
     Total Data         : 40.63 GB
     Duration           : 12 min 51 sec
     System Time        : 16/05/2023 - 12:44:18 UTC
     Total Script Runs  : 2383
    https://cdn1.frocdn.ch/ER7aPTVGBYIvRVP.txt
    Thanked by (1)Shakib
  • VPS HostBrr 2 Cores AMD 4GB RAM - 9.99 USD
     Basic System Info
     CPU Model          : AMD Ryzen 9 7950X3D 16-Core Processor
     CPU Cores          : 2 @ 4192.120 MHz
     CPU Cache          : 1024 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 58.1 GB (4.0 GB Used)
     Total RAM          : 3.8 GB (314.2 MB Used)
     Total Swap         : 1024.0 MB (1.0 MB Used)
     System uptime      : 0 days, 12 hour 35 min
     Load average       : 0.10, 0.03, 0.09
     Basic Network Info
     ISP                : Hetzner Online GmbH
     ASN                : AS24940 Hetzner Online GmbH
     Location (IPv4)    : Ingolstadt, Bavaria, DE
     ISP: Hetzner Online
     Nearest          4.01 ms     0.0%    51.63 Mbps     89.39 Mbps     WebseitenDesigner.com - Hannover
     London, UK       21.90 ms    0.0%    928.36 Mbps    863.42 Mbps    VeloxServ Communications - London
     Edinburgh, UK    33.79 ms    N/A     932.20 Mbps    871.65 Mbps    Vodafone UK - Edinburgh
     Dublin, IE       26.16 ms    0.0%    942.46 Mbps    868.91 Mbps    Three Ireland - Dublin
     Amsterdam, NL    10.60 ms    0.0%    923.23 Mbps    874.32 Mbps    GSL Networks - Amsterdam
     Paris, FR        27.37 ms    0.0%    896.21 Mbps    873.04 Mbps    ORANGE FRANCE - Paris
     Marseille, FR    20.40 ms    0.0%    941.02 Mbps    883.34 Mbps    GSL Networks - Marseille
     Madrid, ES       31.52 ms    0.0%    919.42 Mbps    860.01 Mbps    Orange - Jazztel - Madrid
     Barcelona, ES    26.69 ms    0.0%    934.23 Mbps    881.62 Mbps    Adamo - Barcelona
     Lisbon, PT       49.20 ms    N/A     931.91 Mbps    807.04 Mbps    fdcservers.net - Lisbon
     Rome, IT         33.59 ms    0.0%    945.99 Mbps    889.44 Mbps    TIM SpA - Rome
     Zurich, CH       10.97 ms    0.0%    937.81 Mbps    893.73 Mbps    Sunrise Communication AG - Zurich
     Frankfurt, DE    5.53 ms     0.0%    924.17 Mbps    875.91 Mbps    23M GmbH - Frankfurt Am Main
     Berlin, DE       11.42 ms    0.0%    870.50 Mbps    876.57 Mbps    Misaka Network, Inc. - Berlin
     Vienna, AT       11.69 ms    0.0%    832.87 Mbps    882.21 Mbps    A1 Telekom Austria AG - Vienna
     Budapest, HU     23.39 ms    0.0%    924.97 Mbps    860.38 Mbps    Yettel Hungary - Budapest
     Gdansk, PL       29.73 ms    0.0%    925.50 Mbps    869.06 Mbps    Orange Polska S.A. - Gdansk
     Warsaw, PL       20.35 ms    0.0%    923.11 Mbps    867.60 Mbps    UPC Polska - Warszawa
     Lviv, UA         39.74 ms    0.0%    935.06 Mbps    887.67 Mbps    Kyivstar - Lviv
     Kyiv, UA         30.42 ms    0.0%    936.74 Mbps    873.54 Mbps    o3 - Kyiv
     Minsk, BY        28.90 ms    0.0%    933.10 Mbps    865.90 Mbps    A1 - Minsk
     Bucharest, RO    35.37 ms    0.0%    939.45 Mbps    908.50 Mbps    Orange Romania Communications - Bucharest
     Helsinki, FI     33.58 ms    0.0%    927.86 Mbps    869.43 Mbps    Elisa Oyj - Helsinki
     Stockholm, SE    55.11 ms    0.0%    924.81 Mbps    881.24 Mbps    i3D.net - Stockholm
     Oslo, NO         33.36 ms    0.0%    791.02 Mbps    860.95 Mbps    Speedtest.net - Oslo
     Moscow, RU       39.28 ms    0.0%    929.88 Mbps    864.50 Mbps    MTS - Moscow
     Moscow, RU       37.47 ms    0.0%    917.62 Mbps    859.92 Mbps    Rostelecom - Moscow
     Istanbul, TR     45.79 ms    0.0%    933.50 Mbps    839.96 Mbps    Turkcell - Istanbul
     Istanbul, TR     41.02 ms    0.0%    937.38 Mbps    833.03 Mbps    Vodafone TR - Istanbul
     Avg DL Speed       : 915.69 Mbps
     Avg UL Speed       : 859.04 Mbps
     Total DL Data      : 31.86 GB
     Total UL Data      : 27.52 GB
     Total Data         : 59.37 GB
     Duration           : 11 min 10 sec
     System Time        : 19/05/2023 - 07:19:25 BST
     Total Script Runs  : 2492
     Result             : https://cdn1.frocdn.ch/TDz8j0vQiFx1Wvb.txt
    Global Speedtest
     Basic System Info
     CPU Cache          : 1024 KB
     AES-NI             : ✔ Enabled
     Total RAM          : 3.8 GB (312.9 MB Used)
     System uptime      : 0 days, 12 hour 21 min
     Load average       : 0.00, 0.02, 0.24
     Basic Network Info
     ISP: Hetzner Online
     Nearest          3.27 ms     0.0%    43.70 Mbps     54.97 Mbps     WebseitenDesigner.com - Hannover
     Kochi, IN        167.11 ms   0.0%    478.80 Mbps    487.65 Mbps    Asianet Broadband - Cochin
     Bangalore, IN    148.78 ms   0.0%    192.59 Mbps    472.15 Mbps    Bharti Airtel Ltd - Bangalore
     Chennai, IN      141.04 ms   N/A     46.01 Mbps     561.14 Mbps    Jio - Chennai
     Mumbai, IN       115.04 ms   0.0%    63.55 Mbps     579.19 Mbps    i3D.net - Mumbai
     Delhi, IN        158.74 ms   0.0%    369.30 Mbps    522.20 Mbps    Tata Play Fiber - New Delhi
     Los Angeles, US  151.78 ms   0.0%    412.85 Mbps    534.88 Mbps    ReliableSite Hosting - Los Angeles, CA
     Dallas, US       126.27 ms   0.0%    366.56 Mbps    652.51 Mbps    Hivelocity - Dallas, TX
     New York, US     85.21 ms    0.0%    808.12 Mbps    622.43 Mbps    Clouvider Ltd - New York, NY
     Seattle, US      160.47 ms   N/A     87.11 Mbps     494.02 Mbps    Comcast - Seattle, WA
     Miami, US        131.71 ms   0.0%    851.95 Mbps    606.62 Mbps    AT&T - Miami, FL
     Toronto, CA      102.74 ms   0.0%    905.76 Mbps    743.60 Mbps    Rogers - Toronto, ON
     Paris, FR        18.23 ms    0.0%    400.31 Mbps    834.20 Mbps    ORANGE FRANCE - Paris
     Amsterdam, NL    10.52 ms    0.0%    907.95 Mbps    855.64 Mbps    Clouvider Ltd - Amsterdam
     Warsaw, PL       20.10 ms    0.0%    907.84 Mbps    853.08 Mbps    UPC Polska - Warszawa
     London, UK       22.70 ms    0.0%    909.97 Mbps    854.74 Mbps    VeloxServ Communications - London
     Frankfurt, DE    5.32 ms     0.0%    908.27 Mbps    863.70 Mbps    23M GmbH - Frankfurt Am Main
     Dubai, AE        151.20 ms   0.0%    910.38 Mbps    566.57 Mbps    du - Dubai
     Fujairah, AE     109.98 ms   0.0%    915.17 Mbps    680.14 Mbps    ETISALAT-UAE - Fujairah
     Jeddah, KSA      81.37 ms    0.0%    918.03 Mbps    717.30 Mbps    Saudi Telecom Company
     Shanghai, CU-CN  235.52 ms   0.0%    465.00 Mbps    372.52 Mbps    China Unicom 5G - ShangHai
     Nanjing, CT-CN   226.52 ms   0.0%    476.41 Mbps    313.01 Mbps    China Telecom JiangSu 5G - Nanjing
     Hong Kong, HKG   166.99 ms   N/A     545.65 Mbps    480.89 Mbps    STC - Hong Kong
     Singapore, SG    160.57 ms   0.0%    714.88 Mbps    506.84 Mbps    i3D.net - Singapore
     Jakarta, ID      174.92 ms   0.0%    368.25 Mbps    264.53 Mbps    PT Indosat Tbk - Jakarta
     Tokyo, JP        248.07 ms   N/A     707.18 Mbps    308.78 Mbps    fdcservers.net - Tokyo
     Avg DL Speed       : 564.68 Mbps
     Avg UL Speed       : 569.35 Mbps
     Total DL Data      : 19.39 GB
     Total UL Data      : 18.61 GB
     Total Data         : 38.00 GB
     Duration           : 12 min 33 sec
     System Time        : 19/05/2023 - 07:08:15 BST
     Total Script Runs  : 2491
     Result             : https://cdn1.frocdn.ch/kzXGEaPuEdVNy7L.txt
  • edited May 2023
    Kuroit Storage VPS London
     Basic System Info
     CPU Model          : Intel Core Processor (Skylake, IBRS)
     CPU Cores          : 1 @ 3407.998 MHz
     AES-NI             : ✔ Enabled
     Total Disk         : 726.8 GB (199.0 GB Used)
     Total RAM          : 1.9 GB (421.8 MB Used)
     System uptime      : 20 days, 22 hour 18 min
     Load average       : 0.54, 0.45, 0.45
     Basic Network Info
     ISP                : Kuroit Limited
     ASN                : AS203363 Kuroit Limited
     Host               : Kuroit Limited
     ISP: Kuroit Limited
     Nearest          23.13 ms    0.0%    814.32 Mbps    866.52 Mbps    TecnoADSL - Perugia
     London, UK       0.64 ms     0.0%    928.57 Mbps    883.86 Mbps    VeloxServ Communications - London
     Edinburgh, UK    11.54 ms    N/A     866.58 Mbps    886.67 Mbps    Vodafone UK - Edinburgh
     Dublin, IE       12.95 ms    0.0%    940.31 Mbps    872.37 Mbps    Three Ireland - Dublin
     Amsterdam, NL    6.10 ms     0.0%    926.50 Mbps    862.73 Mbps    GSL Networks - Amsterdam
     Paris, FR        7.96 ms     0.0%    852.56 Mbps    868.01 Mbps    ORANGE FRANCE - Paris
     Marseille, FR    24.78 ms    0.0%    937.49 Mbps    882.42 Mbps    GSL Networks - Marseille
     Madrid, ES       27.66 ms    0.0%    757.26 Mbps    872.64 Mbps    Orange - Jazztel - Madrid
     Barcelona, ES    24.99 ms    0.0%    833.82 Mbps    879.95 Mbps    Adamo - Barcelona
     Lisbon, PT       36.94 ms    N/A     639.69 Mbps    869.95 Mbps    fdcservers.net - Lisbon
     Rome, IT         31.29 ms    0.0%    863.19 Mbps    897.74 Mbps    TIM SpA - Rome
     Zurich, CH       20.64 ms    0.0%    844.96 Mbps    886.71 Mbps    Sunrise Communication AG - Zurich
     Frankfurt, DE    14.68 ms    0.0%    904.90 Mbps    438.12 Mbps    23M GmbH - Frankfurt Am Main
     Berlin, DE       16.18 ms    0.0%    606.53 Mbps    869.97 Mbps    Misaka Network, Inc. - Berlin
     Vienna, AT       27.08 ms    0.0%    902.13 Mbps    880.76 Mbps    A1 Telekom Austria AG - Vienna
     Budapest, HU     31.43 ms    0.0%    744.87 Mbps    873.90 Mbps    Yettel Hungary - Budapest
     Gdansk, PL       34.86 ms    0.0%    695.64 Mbps    872.96 Mbps    Orange Polska S.A. - Gdansk
     Warsaw, PL       32.28 ms    0.0%    757.74 Mbps    685.33 Mbps    UPC Polska - Warszawa
     Lviv, UA         32.64 ms    0.0%    906.87 Mbps    880.06 Mbps    Kyivstar - Lviv
     Kyiv, UA         37.61 ms    0.0%    888.79 Mbps    883.94 Mbps    o3 - Kyiv
     Minsk, BY        41.51 ms    0.0%    921.91 Mbps    713.39 Mbps    A1 - Minsk
     Bucharest, RO    51.76 ms    0.0%    555.57 Mbps    861.34 Mbps    Orange Romania Communications - Bucharest
     Helsinki, FI     37.33 ms    0.0%    733.37 Mbps    879.32 Mbps    Elisa Oyj - Helsinki
     Stockholm, SE    28.13 ms    0.0%    768.60 Mbps    882.30 Mbps    i3D.net - Stockholm
     Oslo, NO         31.07 ms    0.0%    860.14 Mbps    890.37 Mbps    Speedtest.net - Oslo
     Moscow, RU       49.08 ms    0.0%    930.62 Mbps    557.99 Mbps    MTS - Moscow
     Moscow, RU       49.40 ms    0.0%    715.59 Mbps    844.30 Mbps    Rostelecom - Moscow
     Istanbul, TR     59.41 ms    0.0%    906.13 Mbps    861.00 Mbps    Turkcell - Istanbul
     Istanbul, TR     48.55 ms    0.0%    922.36 Mbps    724.51 Mbps    Vodafone TR - Istanbul
     Avg DL Speed       : 825.07 Mbps
     Avg UL Speed       : 832.04 Mbps
     Total DL Data      : 31.01 GB
     Total UL Data      : 27.59 GB
     Total Data         : 58.60 GB
     Duration           : 11 min 37 sec
     System Time        : 20/05/2023 - 15:56:08 IST
     Total Script Runs  : 2551
     Result             : https://cdn1.frocdn.ch/Ncsz8mQPqMRK5a3.txt
    root@UK1-kuroit-ldn-storage:~#
    Request for worldwide speed test!
