hosting in BC (Basement Center ) almost the same shit, just better !
Basement hosting is great, because the hosting owner is willing to put his own peace, quiet and property on the line, in case something goes bad.
The government shall come to his house and knock on his door and kick his kitty, so it would limp till the rest of it's life and lose quality.
@Janevski said:
The government shall . . . . kick his kitty, so it would limp till the rest of it's life and lose quality.
What do you people have against cats?!?
PS: Then they would proceed to use the kitty as a floor rag and basically, mop the floor with it.
Hello police? Yes, this post right here.
I can't connect to the hdd based nat server since last 24hrs. Uptime monitor on ihostart shows all the servers are up. Has ip address or anything else changed?
@xpeng said:
Invoice #1765
And I want to ask how long does it take for a new server to start.
Thank you !
Depends. Does the starter crank over? Does your battery have charge? Did you try using starter fluid? Does it produce fumes from the exhaust when you try to start it?
@xpeng said:
Invoice #1765
Thank you !
Don't forget to check the blinker fluid and the canuter valve that is hooked to the muffler bearing
@xpeng said:
Invoice #1765
Thank you !
And if it still doesn't crack over, may need to change your car's piston return spring. Here is a great video on how to do it:
@xpeng said:
Invoice #1765
Thank you !
Hello @Shakespeare i m talk with developers of panel and I m try add Centos 7 on panel , leave you replay if it's possible or no
Regards,
Calin
debian10,ubuntu20 and ubuntu22
delete the mini version and update the full version
i need cheap vps year payment .
my vps still pending
Invoice #1609
honey, it's your weekly downtime again
Hello, I added some Gbps to our network and unfortunately, our ISP has deleted all configuration of the main router, now everything is going well
Regards,
Calin
Hi Calin, dont forget our RAM
Hello @mee2 open please ticket on website for check , the deal with HDD coming soon change to SSD
Regards,
Calin
Files copied or deleted?
vps9hostname is available. affbrr>
we plan to deliver VPS with SSD to all those with HDD, and after that let's leave about 1-2 weeks to backup and move everything to the new VPS
Ticket opened, please have a look. Thanks.
Dont worry, got it going. Ticket closed. Thanks.
When i was young i wanted to become a farmer and produce the best quality dick cheese.
Please check my ticket #QBE-985890
Invoice #1765
Thank you !
just realized that I'm on the wrong post
Anyone having public page HetrixTools for theirs VPS?
What is the uptime this month?
Hello @Jab check https://uptime.ihostart.com
Any update when my VPS will be up or migrated
New all-time low.
Shure there is for dedicated Servers, but not for VPS like nat.
I have one for my nat VPS 🤔
