NetBSD Not Quite Installed On Hetzner EX101
NetBSD has a serial, non-video installer which seems to work with qemu inside tmux inside Hetzner's rescue system:
root@rescue ~ # cat start-install
qemu-system-x86_64 \
    -enable-kvm \
    -nographic \
    -cpu host \
    -boot once=d \
    -cdrom ./boot-com.iso \
    -m 4096 \
    -drive file=/dev/nvme0n1,format=raw,media=disk,if=virtio \
    -drive file=/dev/nvme1n1,format=raw,media=disk,if=virtio
root@rescue ~ #
One downloads from the above linked page the SHA512 file and the boot-com.iso file, checks the SHA512, and runs something like the above qemu-command. A prerequisite might be having used Hetzner installimage to put a non-RAID install on the server so that the rescue system's qemu will see /dev/nvme* devices instead of /dev/md*.
After running through the install sequence and rebooting inside qemu inside tmux, the system seemed to come up from the NVMe drive.
After shutdown -h now inside NetBSD and then Ctrl-b, x, y to get out of tmux and then rebooting to get out of the Hetzner Rescue System, the server seemed to come up! It responded to IPv4 ping, but ssh [email protected] gave me ssh: connect to host fsn.metalvps.com port 22: Network is unreachable.
Re-enabling the Hetzner rescue system and restarting qemu, NetBSD booted again from the NVMe disk (same qemu command as above, but with the following two lines removed).
     -boot once=d \
Eventually I may figure out why the live, booted-from-metal server could respond to ping but ssh wouldn't work. It's been more than 20 years since I last used NetBSD, so I've forgotten everything.
Why didn't I use Hetzner's free KVM console option? Well, if qemu works, I don't have to bother Hetzner's support guys to have them attach and then remove the KVM.
Thanks to the depenguin.me guys for helpful hints.
Here's ps aux output from the rebooted server running inside qemu. Notice that there are fewer processes than contemporary Linux.
fsn# date -u; ps aux
Tue May 16 23:57:19 UTC 2023
USER     PID %CPU %MEM   VSZ   RSS TTY   STAT STARTED    TIME COMMAND
root       0  0.0  0.8     0 33688 ?     DKl  11:30PM 0:00.32 [system]
root       1  0.0  0.0 11944  1660 ?     Is   11:30PM 0:00.00 init
postfix  328  0.0  0.1 21456  4900 ?     I    11:30PM 0:00.01 pickup -l -t unix
postfix  329  0.0  0.1 21504  4968 ?     I    11:30PM 0:00.00 qmgr -l -t unix -
root     331  0.0  0.0 13360  1488 ?     Is   11:30PM 0:00.00 /usr/sbin/inetd -
root     339  0.0  0.0 12212  1740 ?     Is   11:30PM 0:00.00 /usr/sbin/cron
root     351  0.0  0.1 18408  2676 ?     S    11:30PM 0:00.03 ntpd: asynchronou
root     829  0.0  0.1 18036  2476 ?     Ss   11:30PM 0:00.03 /usr/sbin/syslogd
root    1313  0.0  0.0 11768  1416 ?     Is   11:30PM 0:00.00 /usr/sbin/powerd
root    1442  0.0  0.4 18272 17824 ?     Ss   11:30PM 0:00.14 /usr/sbin/ntpd -p
root    1532  0.0  0.1 23044  3200 ?     Is   11:30PM 0:00.00 sshd: /usr/sbin/s
root    1821  0.0  0.1 21528  2876 ?     Is   11:30PM 0:00.01 /usr/libexec/post
root     306  0.0  0.0 12076  1720 tty00 O+   11:57PM 0:00.00 ps -aux
root     335  0.0  0.1 12584  2228 tty00 S    11:31PM 0:00.07 -sh
root     347  0.0  0.3 24872 10492 tty00 Is   11:30PM 0:00.09 login
root     348  0.0  0.0 11860  1684 ttyE1 Is+  11:30PM 0:00.00 /usr/libexec/gett
root    2013  0.0  0.0 11856  1684 ttyE2 Is+  11:30PM 0:00.00 /usr/libexec/gett
root    1118  0.0  0.0 11856  1680 ttyE3 Is+  11:30PM 0:00.00 /usr/libexec/gett
fsn#
Here's dmesg output from the rebooted server running inside qemu.
fsn# dmesg | cat -n
     1  [     1.000000] Copyright (c) 1996, 1997, 1998, 1999, 2000, 2001, 2002, 2003,
     2  [     1.000000]     2004, 2005, 2006, 2007, 2008, 2009, 2010, 2011, 2012, 2013,
     3  [     1.000000]     2014, 2015, 2016, 2017, 2018, 2019, 2020, 2021, 2022, 2023
     4  [     1.000000]     The NetBSD Foundation, Inc.  All rights reserved.
     5  [     1.000000] Copyright (c) 1982, 1986, 1989, 1991, 1993
     6  [     1.000000]     The Regents of the University of California.  All rights reserved.
     7
     8  [     1.000000] NetBSD 10.99.4 (GENERIC) #0: Sat May 13 11:19:19 UTC 2023
     9  [     1.000000]         [email protected]:/usr/src/sys/arch/amd64/compile/GENERIC
    10  [     1.000000] total memory = 4095 MB
    11  [     1.000000] avail memory = 3935 MB
    12  [     1.000000] timecounter: Timecounters tick every 10.000 msec
    13  [     1.000000] Kernelized RAIDframe activated
    14  [     1.000000] timecounter: Timecounter "i8254" frequency 1193182 Hz quality 100
    15  [     1.000004] mainbus0 (root)
    16  [     1.000004] ACPI: RSDP 0x00000000000F5AF0 000014 (v00 BOCHS )
    17  [     1.000004] ACPI: RSDT 0x00000000BFFE1550 000034 (v01 BOCHS  BXPCRSDT 00000001 BXPC 00000001)
    18  [     1.000004] ACPI: FACP 0x00000000BFFE1404 000074 (v01 BOCHS  BXPCFACP 00000001 BXPC 00000001)
    19  [     1.000004] ACPI: DSDT 0x00000000BFFE0040 0013C4 (v01 BOCHS  BXPCDSDT 00000001 BXPC 00000001)
    20  [     1.000004] ACPI: FACS 0x00000000BFFE0000 000040
    21  [     1.000004] ACPI: APIC 0x00000000BFFE1478 000078 (v01 BOCHS  BXPCAPIC 00000001 BXPC 00000001)
    22  [     1.000004] ACPI: HPET 0x00000000BFFE14F0 000038 (v01 BOCHS  BXPCHPET 00000001 BXPC 00000001)
    23  [     1.000004] ACPI: WAET 0x00000000BFFE1528 000028 (v01 BOCHS  BXPCWAET 00000001 BXPC 00000001)
    24  [     1.000004] ACPI: 1 ACPI AML tables successfully acquired and loaded
    25  [     1.000004] ioapic0 at mainbus0 apid 0: pa 0xfec00000, version 0x11, 24 pins
    26  [     1.000004] cpu0 at mainbus0 apid 0
    27  [     1.000004] cpu0: Use lfence to serialize rdtsc
    28  [     1.000004] cpu0: 13th Gen Intel(R) Core(TM) i9-13900, id 0xb0671
    29  [     1.000004] cpu0: node 0, package 0, core 0, smt 0
    30  [     1.000004] acpi0 at mainbus0: Intel ACPICA 20221020
    31  [     1.000004] acpi0: X/RSDT: OemId <BOCHS ,BXPCRSDT,00000001>, AslId <BXPC,00000001>
    31  [     1.000004] acpi0: X/RSDT: OemId <BOCHS ,BXPCRSDT,00000001>, AslId <BXPC,00000001>                                                     [76/526]
    32  [     1.000004] LNKS: ACPI: Found matching pin for 0.1.INTA at func 3: 9
    33  [     1.000004] LNKC: ACPI: Found matching pin for 0.3.INTA at func 0: 11
    34  [     1.000004] LNKD: ACPI: Found matching pin for 0.4.INTA at func 0: 11
    35  [     1.000004] LNKA: ACPI: Found matching pin for 0.5.INTA at func 0: 10
    36  [     1.000004] acpi0: SCI interrupting at int 9
    37  [     1.000004] acpi0: fixed power button present
    38  [     1.000004] timecounter: Timecounter "ACPI-Fast" frequency 3579545 Hz quality 1000
    39  [     1.046041] hpet0 at acpi0: high precision event timer (mem 0xfed00000-0xfed00400)
    40  [     1.046041] timecounter: Timecounter "hpet0" frequency 100000000 Hz quality 2000
    41  [     1.046619] pckbc1 at acpi0 (KBD, PNP0303) (kbd port): io 0x60,0x64 irq 1
    42  [     1.046619] pckbc2 at acpi0 (MOU, PNP0F13) (aux port): irq 12
    43  [     1.046619] fdc0 at acpi0 (FDC0, PNP0700): io 0x3f2-0x3f5,0x3f7 irq 6 drq 2
    44  [     1.046619] lpt0 at acpi0 (LPT1, PNP0400-1): io 0x378-0x37f irq 7
    45  [     1.046619] com0 at acpi0 (COM1, PNP0501-1): io 0x3f8-0x3ff irq 4
    46  [     1.046619] com0: ns16550a, 16-byte FIFO
    47  [     1.046619] com0: console
    48  [     1.046619] qemufwcfg0 at acpi0 (FWCF, QEMU0002): io 0x510-0x51b
    49  [     1.046619] qemufwcfg0: <QEMU>
    50  [     1.046619] ACPI: Enabled 2 GPEs in block 00 to 0F
    51  [     1.046619] pckbd0 at pckbc1 (kbd slot)
    52  [     1.046619] pckbc1: using irq 1 for kbd slot
    53  [     1.046619] wskbd0 at pckbd0 mux 1
    54  [     1.046619] pms0 at pckbc1 (aux slot)
    55  [     1.046619] pckbc1: using irq 12 for aux slot
    56  [     1.046619] wsmouse0 at pms0 mux 0
    57  [     1.046619] pci0 at mainbus0 bus 0: configuration mode 1
    58  [     1.046619] pci0: i/o space, memory space enabled, rd/line, rd/mult, wr/inv ok
    59  [     1.046619] pchb0 at pci0 dev 0 function 0: Intel 82441FX (PMC) PCI and Memory Controller (rev. 0x02)
    60  [     1.046619] pcib0 at pci0 dev 1 function 0: Intel 82371SB (PIIX3) PCI-ISA Bridge (rev. 0x00)
    61  [     1.046619] piixide0 at pci0 dev 1 function 1: Intel 82371SB IDE Interface (PIIX3) (rev. 0x00)
    62  [     1.046619] piixide0: bus-master DMA support present
    63  [     1.046619] piixide0: primary channel wired to compatibility mode
    64  [     1.046619] piixide0: primary channel interrupting at ioapic0 pin 14
    65  [     1.046619] atabus0 at piixide0 channel 0
    66  [     1.046619] piixide0: secondary channel wired to compatibility mode
    67  [     1.046619] piixide0: secondary channel interrupting at ioapic0 pin 15
    68  [     1.046619] atabus1 at piixide0 channel 1
    69  [     1.046619] piixpm0 at pci0 dev 1 function 3: Intel 82371AB (PIIX4) Power Management Controller (rev. 0x03)                            [38/526]
    70  [     1.046619] timecounter: Timecounter "piixpm0" frequency 3579545 Hz quality 1000
    71  [     1.046619] piixpm0: 24-bit timer
    72  [     1.046619] piixpm0: interrupting at ioapic0 pin 9
    73  [     1.046619] iic0 at piixpm0 port 0: I2C bus
    74  [     1.046619] vga0 at pci0 dev 2 function 0: vendor 1234 product 1111 (rev. 0x02)
    75  [     1.046619] wsdisplay0 at vga0 kbdmux 1
    76  [     1.046619] wsmux1: connecting to wsdisplay0
    77  [     1.046619] wskbd0: connecting to wsdisplay0
    78  [     1.046619] drm at vga0 not configured
    79  [     1.046619] wm0 at pci0 dev 3 function 0, 64-bit DMA: Intel i82540EM 1000BASE-T Ethernet (rev. 0x03)
    80  [     1.046619] wm0: interrupting at ioapic0 pin 11
    81  [     1.046619] wm0: 32-bit 33MHz PCI bus
    82  [     1.046619] wm0: 64 words (6 address bits) MicroWire EEPROM
    83  [     1.046619] wm0: Ethernet address 52:54:00:12:34:56
    84  [     1.046619] wm0: 0x200002<LOCK_EECD,WOL>
    85  [     1.046619] makphy0 at wm0 phy 1: Marvell 88E1011 Gigabit PHY, rev. 0
    86  [     1.046619] makphy0: Failed to access EADR. Are you an emulator?
    87  [     1.046619] makphy0: Failed to read EXTSR. Are you an emulator?. Regard as 1000BASE-T.
    88  [     1.046619] makphy0: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, 1000baseT, 1000baseT-FDX, auto
    89  [     1.046619] virtio0 at pci0 dev 4 function 0
    90  [     1.046619] virtio0: block device (id 2, rev. 0x00)
    91  [     1.046619] ld0 at virtio0: features: 0x10000a54<INDIRECT_DESC,CONFIG_WCE,FLUSH,BLK_SIZE,GEOMETRY,SEG_MAX>
    92  [     1.046619] virtio0: allocated 1060864 byte for virtqueue 0 for I/O request, size 256
    93  [     1.046619] virtio0: using 1048576 byte (65536 entries) indirect descriptors
    94  [     1.046619] virtio0: config interrupting at msix0 vec 0
    95  [     1.046619] virtio0: queues interrupting at msix0 vec 1
    96  [     1.046619] ld0: 1788 GB, 16383 cyl, 16 head, 63 sec, 512 bytes/sect x 3750748848 sectors
    97  [     1.046619] virtio1 at pci0 dev 5 function 0
    98  [     1.046619] virtio1: block device (id 2, rev. 0x00)
    99  [     1.046619] ld1 at virtio1: features: 0x10000a54<INDIRECT_DESC,CONFIG_WCE,FLUSH,BLK_SIZE,GEOMETRY,SEG_MAX>
   100  [     1.046619] virtio1: allocated 1060864 byte for virtqueue 0 for I/O request, size 256
   101  [     1.046619] virtio1: using 1048576 byte (65536 entries) indirect descriptors
   102  [     1.046619] virtio1: config interrupting at msix1 vec 0
   103  [     1.046619] virtio1: queues interrupting at msix1 vec 1
   104  [     1.046619] ld1: 1788 GB, 16383 cyl, 16 head, 63 sec, 512 bytes/sect x 3750748848 sectors
   105  [     1.046619] isa0 at pcib0
   106  [     1.046619] attimer0 at isa0 port 0x40-0x43
   107  [     1.046619] pcppi0 at isa0 port 0x61
   108  [     1.046619] spkr0 at pcppi0: PC Speaker
   109  [     1.046619] wsbell at spkr0 not configured
   110  [     1.046619] midi0 at pcppi0: PC speaker
   111  [     1.046619] sysbeep0 at pcppi0
   112  [     1.046619] attimer0: attached to pcppi0
   113  [     1.046619] acpicpu0 at cpu0: ACPI CPU
   114  [     1.046619] acpicpu0: C1: HLT, lat   0 us, pow     0 mW
   115  [     1.046619] vmt0 at cpu0
   116  [     1.046619] vmt0: UUID: 00000000-0000-0000-0000-000000000000
   117  [     1.046619] vmware: open failed, eax=0xffffffff, ecx=0x1e, edx=0x5658
   118  [     1.046619] vmt0: autoconfiguration error: failed to open backdoor RPC channel (TCLO protocol)
   119  [     1.046619] timecounter: Timecounter "clockinterrupt" frequency 100 Hz quality 0
   120  [     1.046619] fd0 at fdc0 drive 0: 1.44MB, 80 cyl, 2 head, 18 sec
   121  [     1.046619] ld1: GPT GUID: 7ac59b06-d775-499c-b672-f71133e62986
   122  [     1.046619] ld0: GPT GUID: 868d363e-b930-4142-944f-e70905997bdb
   123  [     1.046619] IPsec: Initialized Security Association Processing.
   124  [     1.046619] dk0 at ld1: "be45d1a2-c15f-4fa9-a36b-db22ab2e15e0", 524288 blocks at 4096, type: msdos
   125  [     1.046619] dk1 at ld1: "c6fc5a64-7669-464c-8578-77c52a1ebe6c", 1048576 blocks at 528384, type: <unknown>
   126  [     1.046619] dk2 at ld1: "24fde94d-ca86-46bd-8358-93c1ac2f8b9e", 3749171855 blocks at 1576960, type: <unknown>
   127  [     1.046619] dk3 at ld0: "02a153e5-14e1-45f0-8e65-d55f5f7da62c", 3742359552 blocks at 2048, type: ffs
   128  [     1.046619] dk4 at ld0: "981d2b55-1018-4fc9-9f3c-5847d6751eb7", 8387215 blocks at 3742361600, type: swap
   129  [     5.005793] atapibus0 at atabus1: 2 targets
   130  [     5.015571] cd0 at atapibus0 drive 0: <QEMU DVD-ROM, QM00003, 2.5+> cdrom removable
   131  [     5.015571] cd0: 32-bit data port
   132  [     5.015571] cd0: drive supports PIO mode 4, DMA mode 2, Ultra-DMA mode 5 (Ultra/100)
   133  [     5.015571] cd0(piixide0:1:0): using PIO mode 4, DMA mode 2 (using DMA)
   134  [     5.015571] swwdog0: software watchdog initialized
   135  [     5.025557] WARNING: 1 error while detecting hardware; check system log.
   136  [     5.025557] boot device: ld0
   137  [     5.025557] root on dk3 dumps on dk4
   138  [     5.025557] root file system type: ffs
   139  [     5.025557] kern.module.path=/stand/amd64/10.99.4/modules
   140  [    10.485560] wsdisplay0: screen 1 added (80x25, vt100 emulation)
   141  [    10.485560] wsdisplay0: screen 2 added (80x25, vt100 emulation)
   142  [    10.485560] wsdisplay0: screen 3 added (80x25, vt100 emulation)
   143  [    10.485560] wsdisplay0: screen 4 added (80x25, vt100 emulation)
fsn#
Just curious, what is the use case for netbsd these days?
pfsense is based on NetBSD so a lot of people come across it through that.
zfs is probably the main reason I can think of to actively chose it over Linux.
I think nowadays NetBSD can also run Linux binaries, so it might work out pretty well. For me, the big turn off was not having good wireguard support - I know it's possible to run usermode, but for something like that I'd want it in the kernel.
NetBSD 10 has in-kernel wireguard support.
That sounds weird...
I wonder if the real hardware just uses a different device name for the network interface. How do the boot messages from the real hardware boot look like (hopefully those would show up in
/var/log/messages)?A bit of an update. . . . Been through the install a couple more times. The installer seems to work fine inside qemu. During the installation (and also by rebooting still inside qemu from the NVMe drive after the installation has finished), I have been trying to adjust the network configuration so that IPv4 and IPv6 work when the installed system is booted raw, "in real life."
I woke up this morning to find emails from Hetzner saying there was a router issue affecting the server.
I did look all through /var/log/messages. There were multiple boots recorded. Both the boots inside qemu and also the direct from hardware boots seemed included. I didn't notice anything special. It would have been easy for me to miss something.
As of right now, I could retry NetBSD, reinstall Debian, or play with something else. It's been so, so much fun to play with NetBSD again! I've been skimming manpages, the NetBSD wiki, etc. I see that, with stuff like Wireguard in the kernel and fast + slow processor support, NetBSD still is as cool as ever!
I guess the thing to look out for is where it detects the network interface
If the direct hardware boot shows a different interface name, you'll likely have to create a corresponding
/etc/ifconfig.if0configuration file for that interface (changeif0to the interface name).Been down the fun rabbit hole a few more times, with Alpine and FreeBSD in addition to NetBSD. I've also enjoyed equally grand unsuccess with depenguin.me.
On the initial group of NetBSD installs I thought I did see previous boot messages from the direct hardware boots showing up in NetBSD's /var/log/messages when NetBSD subsequently was rebooted into qemu running inside the rescue system. Unfortunately, I didn't save these logs.
On the later group of NetBSD installs and on the Alpine installs, no direct from hardware boot messages seem to appear on subsequent reboots back into qemu.
Following the early group of qemu installs, I did believe that the server initially seemed to respond to ping when booted directly. Later, maybe checking more carefully, there seemed to be no response to ping and no ssh on either IPv4 or IPv6 after hardware boot.
I imagined that a problem could be that the installs done from qemu somehow were remembering the qemu MAC address. If so, I imagined that Hetzner's MAC address filtering might have blocked network connectivity? I tried a few installs with the MAC address manually configured to match the actual hardware address. I also tried manually configuring the IPv4 and IPv6 networking. Lots of joy, but still no workee.
Besides the possible change of ethernet interface name, and the somehow perhaps possible persistence of the qemu MAC or IP addresses into the hardware install, I have a new idea about what the problem might be. Looking at the qemu command shown in the OP, I'm wondering if there is a boot environment mismatch between my simple qemu command and the real boot firmware/hardware. Maybe I need to add something to the qemu command to make the qemu based install emulate the real hardware?
Of course I probably could get the installs to work by using Hetzner's free KVM Console instead of qemu.
Happily, the one thing that does seem to work is rebooting the installed NVMe disk back into qemu even after having tried a full hardware boot. It does seem like the installs indeed might be being written to the NVMe hard disks and that hand made changes persist.
I guess I'm gonna try looking at the early stage booting some more. Unless somebody has a better idea? As always, any hints would be much appreciated! Thanks so much!
Okay, so it looks like I have to install the Debian ovmf package along with inside the rescue system and boot the installer inside qemu with Tianocore. That might make the installers select and install for UEFI instead of BIOS? See https://github.com/tianocore/tianocore.github.io/wiki/OVMF-FAQ#what-is-open-virtual-machine-firmware-ovmf See also How To Boot UEFI On QEMU
Guessing that the nice, new hardware on the i9-13900 might not be happy with BIOS. Does that sound right? Maybe I will try the ovmf and see if the installs work better. . . . 🤔
From
dmidecodeoutput:I hope everyone gets the servers they want!
Honestly for the CPU it doesn't really matter if you install EFI or BIOS, as it is handled by motherboard, not CPU. If your CPU supports UEFI, it will support BIOS and will play nicely with BIOS as well.
Unless you need secure boot or other features supported by EFI boot, BIOS will work just fine, specially for a server, which does not reboot often, and thus mostly runs the OS. Once the OS takes over from the boot manager, UEFI or BIOS makes almost no differences.
For network boots, EFI is generally not supported and only BIOS works.
You can read this for more info on differences between UEFI and BIOS managers: https://www.freecodecamp.org/news/uefi-vs-bios/
Final note from intel website. Link: https://www.intel.com/content/www/us/en/products/docs/processors/embedded/13th-gen-core-product-brief.html
Text 1:
Text 2:
So your CPU clearly supports and plays nicely with legacy bios boot managers.
Hi @somik! Thanks for your helpful comments! Every morning brings an opportunity for me to learn a little more! Best wishes! Tom
