yammdb - just another .mmdb
2
    edited June 2023
    @Neoon said:
    @Neoon said:
    It seems that a recent masscan is mandatory, I still used a 2 months old one.
    The build just finished 3 hours earlier and with +7% higher hitrate, so 80% without mtr.
    Lesson learned, masscan will be updated at least once per week, gg.
    As soon I get the mtr integration working It should easily get a 90%+ hitrate.
    I thought port scanning was frowned upon by most data-centers/hosts?
    I never said I was port scanning.
    90% hit rate as in for IPs or returning correct geo-loc/country?
    hit rate means, you get a result.
    Accuracy depends on the amount of locations.
    Isn't masscan used for port scanning?
    You should read up what masscan can do.
    Are you using it to scan for something else?
    Yes, as I said a few times.
  • Hello Sir, can you explain to me how to use that mmdb?
    i never using mmdb before. thanks
  • Any database guru please help with an indexing and sql statement for best performance on searching the dataset given an IP address.
    Thanks in advance :3
    edited June 2023
    Probably if you store it in binary, the .mmdb uses a binary search tree and does lookups in a fraction of a second, also just 15MB in size compared to the csv.
    You provide a IP address, it gives you the approximate location.
    Python example is on github.
    Thanked by (1)tuc
  • edited June 2023
    sorry, i mean step by step running/read file .mmdb , like as apt install blabla , and than next step.
    on linux , or android , or windows
  • somiksomik OG
    edited June 2023
    Convert the IP/subnet (CIDR) to a IP range containing the starting and ending IP.
    Convert the starting and ending IP to a "long" number.
    For PHP, you can use:
    function ipRange($cidr) {
        $range = array();
        $cidr = explode('/', $cidr);
        $range[0] = long2ip((ip2long($cidr[0])) & ((-1 << (32 - (int)$cidr[1]))));
        $range[1] = long2ip((ip2long($range[0])) + pow(2, (32 - (int)$cidr[1])) - 1);
        return $range;
    Save it in the DB like: index, startingIPLong, endingIPLong, Location
    When you want to check a IP, convert it to "long" number, and find the row WHERE startingIPLong>= searchIP AND endingIPLong<= searchIP
    I think you'll be able to figure it out from there?
    For PHP to convert the IP to long, use function: https://www.php.net/manual/en/function.ip2long.php
    Thanked by (2)tuc FrankZ
  • Thanks @somik for the function. That's really help.
    Btw, i did it other way around. Guess should not be browsing LES first thing after waking up:
    WHERE startingIPLong <= searchIP AND endingIPLong >= searchIP
    Just a small typo mistake :)
  • tuctuc
    edited June 2023
    I just made a tiny shell script to add two columns: ipfrom and ipto to the datasets made available by @Neoon. Not sure if my style of making data ready before importing into databases will help :)
    #!/bin/bash
    if [ -z "$1" ]; then exit; fi
    while IFS=',' read -r ipr cont cnt lat lng rad; do
      if [ -z "$ipr" ]; then break; fi
      IFS='/' read -r IP CIDR <<<"$ipr"
      MASK=$((-1 << (32 - ${CIDR})))
      IFS='.' read a b c d <<<${IP}
      base_ip=$((($b << 16) + ($c << 8) + $d))
      ipfrom=$((${base_ip} & ${MASK}))
      ipto=$((($a << 24) + ((${ipfrom} | ~${MASK}) & 0x7FFFFFFF)))
      ipfrom=$((($a << 24) + $ipfrom))
      echo "$ipr,$ipfrom,$ipto,$cont,$cnt,$lat,$lng,$rad"
    done <$1
    To use the script:
    script-name data-file | cat > new-data-file
    output sample
    1.0.0.0/24,16777216,16777471,EU,CZ,50.08,14.41,0
    1.1.1.0/24,16843008,16843263,EU,CZ,50.08,14.41,0
    2.16.2.0/24,34603520,34603775,EU,CZ,50.08,14.41,0
    2.56.253.0/24,37289216,37289471,EU,CZ,50.08,14.41,0
    3.33.144.0/20,52531200,52535295,EU,CZ,50.08,14.41,0
    5.23.39.0/24,85403392,85403647,EU,CZ,50.08,14.41,0
    5.39.200.0/22,86493184,86494207,EU,CZ,50.08,14.41,0
    5.59.34.0/24,87761408,87761663,EU,CZ,50.08,14.41,0
    5.145.104.0/22,93415424,93416447,EU,CZ,50.08,14.41,0
    #!/bin/bash
    done <$1
    To use the script:
    output sample
    That's what I did as well, just with PHP. Process the data before importing it into DB to make subsequent queries faster.
    Thanked by (2)Ganonk tuc
    Hi @Ganonk! Hi @Neoon!
    I never tried something like this before. Here is a transcript of the steps I tried. Maybe the transcript will be helpful to anybody who can show me my mistakes or who wants a beginner style recipe.
    • Step 1: Make an yammdb neighborhood
    notoles@fsn:~$ mkdir neoon
    notoles@fsn:~$ cd neoon/
    notoles@fsn:~/neoon$
    • Step 2: Grab the data
    notoles@fsn:~/neoon$ time wget https://yammdb.serv.app/geo.mmdb
    --2023-06-04 05:17:49--  https://yammdb.serv.app/geo.mmdb
    Resolving yammdb.serv.app (yammdb.serv.app)... 45.130.21.225
    Connecting to yammdb.serv.app (yammdb.serv.app)|45.130.21.225|:443... connected.
    HTTP request sent, awaiting response... 200 OK
    Length: 16172538 (15M) [application/octet-stream]
    Saving to: ‘geo.mmdb’
    geo.mmdb                100%[==============================>]  15.42M  71.8MB/s    in 0.2s
    2023-06-04 05:17:49 (71.8 MB/s) - ‘geo.mmdb’ saved [16172538/16172538]
    real    0m0.382s
    user    0m0.013s
    sys     0m0.017s
    notoles@fsn:~/neoon$ ls
    geo.mmdb
    notoles@fsn:~/neoon$ ls -al
    total 15804
    drwxr-xr-x 2 notoles notoles     4096 Jun  4 05:17 .
    drwx--x--x 9 notoles notoles     4096 Jun  4 05:17 ..
    -rw-r--r-- 1 notoles notoles 16172538 Jun  2 17:03 geo.mmdb
    • Step 3: Grab the program with which to read the data.
    I cut and pasted the program from https://github.com/Ne00n/yammdb
    notoles@fsn:~/neoon$ ed read.py
    read.py: No such file or directory
    a
    import geoip2.database
    reader = geoip2.database.Reader("geo.mmdb")
    response = reader.city("1.1.1.1")
    print("Continent",response.continent.code)
    print("Country",response.country.iso_code)
    print("Latitude",response.location.latitude,"Longitude",response.location.longitude)
    print(f"Latency {response.location.accuracy_radius}ms")
    w
    329
    q
    notoles@fsn:~/neoon$ sudo apt-get install python3-geoip2
    [sudo] password for notoles:
    Reading package lists... Done
    Building dependency tree... Done
    Reading state information... Done
    The following additional packages will be installed:
      python3-maxminddb
    Suggested packages:
      python-maxmindb-doc
    The following NEW packages will be installed:
      python3-geoip2 python3-maxminddb
    0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
    Need to get 50.4 kB of archives.
    After this operation, 203 kB of additional disk space will be used.
    Do you want to continue? [Y/n]
    Get:1 http://deb.debian.org/debian unstable/main amd64 python3-maxminddb amd64 2.2.0-1+b1 [27.6 kB]
    Get:2 http://deb.debian.org/debian unstable/main amd64 python3-geoip2 all 2.9.0+dfsg1-5 [22.8 kB]
    Fetched 50.4 kB in 0s (1,435 kB/s)
    Selecting previously unselected package python3-maxminddb.
    (Reading database ... 56808 files and directories currently installed.)
    Preparing to unpack .../python3-maxminddb_2.2.0-1+b1_amd64.deb ...
    Unpacking python3-maxminddb (2.2.0-1+b1) ...
    Selecting previously unselected package python3-geoip2.
    Preparing to unpack .../python3-geoip2_2.9.0+dfsg1-5_all.deb ...
    Unpacking python3-geoip2 (2.9.0+dfsg1-5) ...
    Setting up python3-maxminddb (2.2.0-1+b1) ...
    Setting up python3-geoip2 (2.9.0+dfsg1-5) ...
    geo.mmdb  read.py
    • Step 5: Get an IP address to check
    notoles@fsn:~/neoon$ w
     20:22:21 up 3 days, 21:00,  1 user,  load average: 0.00, 0.00, 0.00
    USER     TTY      FROM             LOGIN@   IDLE   JCPU   PCPU WHAT
    notoles  pts/0    187.189.238.1    20:17    0.00s  0.03s   ?    w
    • Step 6: Read the data for the IP address
    notoles@fsn:~/neoon$ time python3 ./read.py 187.189.238.1
    Continent EU
    Country CZ
    Latitude 50.08 Longitude 14.41
    Latency 0.0ms
    real    0m0.026s
    user    0m0.022s
    sys     0m0.004s
    • Step 7: Ponder
    The IP address that I am using seems to be shown as located in CZ. However, the address best might be located here where I am using it, visiting, in Sonora, Mexico. :) Probably I made some mistakes! Is everything reported as EU/CZ because I need to add additional, basic steps? Can someone please help me understand why my geolocation result seems possibly incorrect?
    Thanked by (1)Ganonk
    edited June 2023
    real    0m0.382s
    user    0m0.013s
    sys     0m0.017s
    geo.mmdb
    total 15804
    a
    w
    329
    q
      python3-maxminddb
    Suggested packages:
      python-maxmindb-doc
    geo.mmdb  read.py
    Continent EU
    Country CZ
    Latency 0.0ms
    real    0m0.026s
    user    0m0.022s
    sys     0m0.004s
    • Step 7: Ponder
    Because you didn't changed the IP in the script.
    You probably want to replace the line 1.1.1.1 with
    response = reader.city(sys.argv[1])
    which takes your argument.
    Need to import sys though.
    edited June 2023
    @Neoon said: Because you didn't changed the IP in the script.
    Thanks so much! I will make that change and post the result.
    If you wish, here is another question:
    notoles@fsn:~/neoon$ wget https://yammdb.serv.app/geo.mmdb
    --2023-06-04 21:56:05--  https://yammdb.serv.app/geo.mmdb
    Saving to: ‘geo.mmdb.1’
    geo.mmdb.1              100%[==============================>]  15.42M  73.2MB/s    in 0.2s
    2023-06-04 21:56:05 (73.2 MB/s) - ‘geo.mmdb.1’ saved [16172538/16172538]
    notoles@fsn:~/neoon$ # Cut and paste checksum from https://github.com/Ne00n/yammdb/blob/master/sha256sum + add filename
    notoles@fsn:~/neoon$ ed SHA256SUM
    SHA256SUM: No such file or directory
    a
    e5ba4b5e3fd4fd19fb3e056adbb956ad3640c14e72eb86d73aafdd39b2cf39b8 geo.mmdb
    w
    74
    q
    notoles@fsn:~/neoon$ sha256sum -c SHA256SUM
    geo.mmdb: FAILED
    sha256sum: WARNING: 1 computed checksum did NOT match
    notoles@fsn:~/neoon$ sha256sum geo.mmdb
    daac3daeca83835400584b5ab81b2ec84657428bcd6290b7b392a6ad7e4e9922  geo.mmdb
    What mistake am I making here? Have I wrongly identified the file whose checksum should match? Thanks!
    a
    w
    74
    q
    geo.mmdb: FAILED
    The checksum wasn't updated since the last build, probably a issue in my build script.
    @Neoon said: The checksum wasn't updated since the last build, probably a issue in my build script.
    Thanks!
    Making the change that @Neoon suggested:
    notoles@fsn:~/neoon$ cat read.py
    329
    /res
    d
    i
    w
    331
    q
    Traceback (most recent call last):
      File "/home/notoles/neoon/./read.py", line 4, in <module>
    NameError: name 'sys' is not defined
    real    0m0.026s
    user    0m0.019s
    sys     0m0.007s
    Looks like we need to import the sys module. :)
    331
    2
    i
    import sys
    w
    342
    q
    Continent NA
    Country US
    Latitude 32.77 Longitude -96.8
    Latency 43.0ms
    real    0m0.024s
    user    0m0.024s
    sys     0m0.000s
    According to findlatitudeandlongitude.com the reported latitude and longitude is in Dallas, TX USA.
    The ISP here, as of the last time I checked awhile ago, seemed to use multiple hops with private addresses between my location and 187.189.238.1. Based on ping times and other factors, I previously imagined that 187.189.238.1 might be located in Missouri. Maybe it was in Dallas, or it is in Dallas now.
    Vendors seem universally to identify 187.189.238.1 as a Mexican IP. I can pretty much count on being offered default pages in Spanish and default prices in pesos.
    Thanks @Neoon! :)
    Yes, seems like the DB i am using also identifies your IP as mexico: https://ip2c.ziox.us/?ip=187.189.238.1
    The source code is located here: https://github.com/somik123/IP-to-Country
    I am currently using the "lite" database from ip2location.com
    I don't have a probe in Mexico, the closest is Texas, so its as close as it can get.
    how do you calculate the positions? i assumed you are triangulating different "nearby" probes? eg in this case the results of Texas and Sao Paulo.
    If you mean by nearby, all, yes.
    If 20 of them say, Texas is the lowest, its the lowest.
    I am to lazy and I don't wanna risk in accuracy because I fucked on the mapping or their was a routing issue.
  • @Neoon said: I am to lazy and I don't wanna risk in accuracy because I fucked on the mapping or their was a routing issue.
    ah, i see. so no triangulation but rather finding the closest datacenter.
    i imagine using the latency of the ~three closest probes could be used to put the ip somewhere between them. but the calculation of course could be messed up by "non-straightforward" routing.
    Well, I find this to be the most reliable.
    I can define an area, in-between, these 3 probes, that's no issue.
    Lets say I traceroute them from the closest 3.
    It still doesn't tell me, where the location is.
    Its off limits, since I don't have a prob there.
    Yes I could ask a 3rd party, to tell me where it is and cross verify if the data given by them, is in this area.
    However, I don't want to use a 3rd party.
    I can try a build with that for sure, a company already reached out to me and told me I could use their data but I refused.
    Will see.
    if you know the locations of the closest 3 and take the latencies as an estimate for the distances you can calculate an educated guess...
    https://github.com/TBMSP/Trilateration
    Latency is unreliable as fuck, you can't tell, when its 10ms, where it is.
    Bad Routing? Still might be around the corner. Could also be not.
    I get latency that's fluctuating all the time. So best to avoid latency.
    edited June 2023
    Usually its stable but routes can change or links can become congested.
    Hence I do the measurements from all Locations in a very small time frame, usually seconds apart.
    Otherwise results may differ on each build, due to these fluctuations or they even drift away, sometimes hours from each apart which makes it even worse.
  • @Not_Oles many thanks for your awesam tutorial 🤝🏽 but very difficult for me try :#
    edited June 2023
    @Ganonk said: @Not_Oles many thanks for your awesam tutorial 🤝🏽 but very difficult for me try
    You are welcome!
    How can we make it easy for you to try?
    You are welcome!
    make a ready to deploy docker container with required configurations and web ui? :lol:
    Thanked by (2)Not_Oles Ganonk
