Needed a budget Dedi under 40USD/month (EU/APAC)
Needed a dedicated server baseline requirements are below, No Hetzner pls.
Processor Intel series (newer if possible) 4c/8t
Storage minimum 400Gb
Ram minimum 24GB
Bandwidth: >5Tb at least 1Gbps if possible
Dm or reply if available, Thanks!!
Hello @hostaspace it's possible give you
2x l5630 8c/16t
32 Gb ram
Location Europe/Romania
32 TB BW @ 1 Gbps port speed
1x dedicated IPv4
1x 960 GB SSD Enterprise
For 45 euros/month
Regards
If you can up your budget to within 50-60, you should be able to find alot of provider can provide you in Europe. As for APAC within this budget range, why not consider a VPS instead of DEDI. As APAC cost is really high, for such budget it will be really hard to find.
TemasekTech - AS139859 and AS209187
Building Cloud Technology with Global Network
Official Website - https://www.TemasekTech.com
EU (Italy)
i5 6500
SSD 480GB
RAM 32GB DDR4
10TB @ 1Gbps
€35 + 22% vat if private customer
C1V Hosting: Low cost Italian Cloud & Data Center Solutions 🚀 | Contact us for special offers. | Our deals on Telegram
The end is nigh.
Because of OP's username.
First thank you all for the response.
Do you provide Ipv6 ??
Yea, somewhat want to save some $$ just because i need for personal research work uses as already have colo and good dedi's. but yea if i cant find any go with AX-44 (EU) or OVH Advance-1 Gen 2 (APAC).
Can @OVHcloud_APAC confirm that the Intel Xeon-E 2386G iGpu working or not ?? as i find that its not even enabled in BIOS.
Thats to much
and no raid
Haha, you are very much on Δ-9-tetrahydrocannbinol... the end is nigh or high depending on CB(1) receptor. Better to have some bzd
anyway, the username is random not denote my work area.
Hello @hostaspace unfortunetly no , but it s possible make yourself tunnel
Regards,
Calin
DMed you with surprise offer!
https://www.kuroit.com - Managed cPanel Hosting & VPS Hosting in UK
Hi there, unfortunately we don't offer iGPU on the server. We have a bunch of offers currently ongoing : https://www.ovhcloud.com/en/lp/asia-pacific-hosting-deals/
@OVHcloud_APAC when I ordered .ovh domain on ovh website, I paid and the dns order fail ,OVH rejected to refund the money.
it was some months ago.
Get a £30 oneprovider with 2 x 1tb ssd and unlimited traffic on 1gbit. Works perfect for my iso hunting
Hi @nightcat , did you have a ticket # that you can share with us so we can have a look? Thanks!
@OV>; @OVHcloud_APAC said:
Thank you very much, it's not a lot of money. I have DM you .
