I need a non-shared rdp encoding.
I am currently on oneprovider on a dedicated AMD Ryzen 7 1700X (41 dollar) but the support is too slow.
+budget 30 to 50 dollars.
+ storage 100 GB minimum
+ good processor with high frequencies for encoding.
+ windows or ipmi or kvm to be able to install it.
I need it as soon as possible.
  • Consider hostbrr vps, install windows yourself. Those 7950x are rippin fast, and i bet he could do something custom for you if you need more than the stock packages.
    Thanked by (1)emanuelErazo
  • Speaking of high performance VPS, you could go with @SpeedyPage . They specialized in Ryzen VPS. The support is really good.
    Otherwise, you could choose HostBrr @Labze . It's relatively new host, but looks promising.
  • ReliableSite_RadicReliableSite_Radic Hosting Provider
    I think the issue with a VPS is that he plans to rape the CPU. So he wants something that isn't shared.
    Thanked by (2)emanuelErazo skorous
  • I don't use vps because they don't normally allow encoding video.
  • havochavoc OGContent Writer
    Wouldn't something with x264 encode be better suited?
    It's that there's a big problem. I don't make the videos, they're made by 2 workers and they don't know how to use computers much. I bought movavi some time ago.
  • Hello @emanuelErazo it s possible give you
    ryzen 3 2200g
    16 GB DDr4
    1x 240 GB SSD
    Windows
    1x GTX 1050 TI 4 GB
    For 40$ / month
    Regards
  • @emanuelErazo said: the support is too slow
    How much support do you need?
    Personally, I prefer the tech support to fix issues before I notice :lol:
    practically the basic one was only asking to install ipmi and the first response took almost 24 hours, I can't afford to wait 18 to 20 hours for a response and more when you pay for ipmi.
