server-factory.com | Sweden | Help us test and win a VPS!
Hi!
We are expanding to Stockholm, Sweden!
First Server is ready and configuration is done! We only have to wait for the transfer of our new IPv4 Subnet to launch the new location.
Now we like to ask the community to help us test!
Limitations of the Test:
- 24 Hour Trial
- One Trial VPS per Client
- IPv6 Only, Mail Ports blocked
- noVNC Console is only usable via IPv6 connection to our proxy
Specs:
AMD EPYC™ XXS IPv6 ONLY VPS 24 HOUR TRIAL
TRIAL: 24 HOURS
IPv6 ONLY: NO IPv4
DATA CENTER: OBE.NET DATA CENTER, TORSHAMNSGATAN 48, 164 40 KISTA, SWEDEN
VIRTUALIZATION: KVM
NESTED VIRTUALIZATION: ENABLED
CPU: AMD EPYC™ 7452
BASE CLOCK: 2.35 GHZ
BOOST CLOCK: UP TO 3.35 GHZ
CORES: 1 (25 % LIMIT)
RAM: 2 GiB DDR4 3200 MHZ ECC
STORAGE: 25 GiB NVME PCIe 4.0 SSD (RAID 10)
UPLINK: 1 GBIT
TRAFFIC (INCOMING + OUTGOING): 100 GiB FOR 24 HOURS
IPV6 SUBNET: /64
FEATURE: 1 SNAPSHOT
FEATURE: CUSTOM ISO
FEATURE: RDNS MANAGEMENT
FEATURE: MAIL PORTS BLOCKED
Price
FREE!
Order Link: https://my.server-factory.com/?cmd=cart&action=add&id=3364
You want to win one of our AMD EPYC™ S VPS in Stockholm, Sweden for 12 months? Specs: 2 Cores, 8 GiB RAM, 100 GiB NVME SSD, 1 IPv4 Address, /64 IPv6 Subnet, 1 GBIT Uplink
Just order the Trial VPS and give us some feedback afterwards via comment here ![]()
Winner will be announced on 06.08.2023 15:00 CEST. VPS for winner will be deployed as soon as the IPv4 Subnet is transferred.
Kind regards,
mxmla
Congrats
Amadex • Hosting Forums • root.hr
I thought Singapore would be your next expansion location. Congratulations on Sweden launch.
Congratz bro.
Your Order Number is: 2076298645
https://microlxc.net/
good vps
I hesitate, this offer is intended for everyone.
Apart of this part of the specification (BASE CLOCK: 2.35 GHZ / CORES: 1 at 25 % LIMIT), which makes the VPS configuration closer to the "shared hosting" for the exclusevley "static content",
the user needs the own solution of
how to make the IP6 host visible for the users of IP4 networks.
There s no simple solution for OS debian, for instance.
To reach the configuration of such IP6 host will be impossible from the 95+% of modern phones.
We're in 2023. v6 is 25 years old.
I really appreciate every provider who's able to offer v4 as an additional add-on instead of a necessity.
That's a made-up number, right?
When there's 42% of users accessing Google via v6, I highly doubt the v6 adoption on phones is at 5% globally.
Locally speaking - all MNO's support v6 over here.
Read closer. It's a 24hour TRIAL. If you're going to try and run production on a 24 hour trial you're going to have a bad time.
EDIT: But if you, be sure to post here so I watch for the public freak out. I'll make some extra popcorn.
skorous : To add "update/upgrade" and to install additional 50 packages for PHP8*, Mariadb and the specific application takes 6-8 hours within your limit of 25% from 3.35Mhz of the single core.
The experinced user, if he finds your offer attractive with ~850Khz, is hardly become happy.
To configuree the whole construction of web server takes days, not 24 consequent hours.
So, expectations for the experienced user look as follows : either you add full core or you extend the trial till 72 hours in order the user can use his static web server practically.
Is this an experience you have with the trial VPS at the moment? Install via apt is lightning fast on my trial VPS.
server-factory.com
Static webserver? Why would you even need php and a database to serve static files?!
Troll somewhere else.
wow
Uptime : 0 days, 0 hours, 26 minutes
Processor : AMD EPYC 7452 32-Core Processor
CPU cores : 1 @ 2349.998 MHz
AES-NI : ✔ Enabled
RAM : 1.9 GiB
Swap : 0.0 KiB
Disk : 24.5 GiB
Kernel : 6.1.0-10-amd64
VM Type : KVM
IPv4/IPv6 : ❌ Offline / ✔ Online
Running fio random mixed R+W disk test wiRunning fio random mixed R+W disk test wiRunning fio random mixed R+W disk test wiRunning fio random mixed R+W disk test wifio Disk Speed Tests (Mixed R/W 50/50):
Block Size | 4k (IOPS) | 64k
(IOPS)
Read | 222.14 MB/s (55.5k) | 2.54
GB/s (39.7k)
Write | 222.73 MB/s (55.6k) | 2.55
GB/s (39.9k)
Total | 444.87 MB/s (111.2k) | 5.10
GB/s (79.7k)
Block Size | 512k (IOPS) | 1m
(IOPS)
Read | 8.47 GB/s (16.5k) | 9.94
GB/s (9.7k)
Write | 8.92 GB/s (17.4k) | 10.61 GB/s (10.3k)
Total | 17.40 GB/s (33.9k) | 20.56 GB/s (20.0k)
Running GB5 benchmark test... *cue elevatGeekbench releases can only be downloaded over IPv4. FTP the Geekbench files and run manually.
YABS completed in 16 sec
Congrats on the expansion!
Installation speeds seem very snappy, disks are screaming fast.
Docker stuff was also running fast.
Impressive stuff.
Real tests will start with IPv4
Congratulations on new location - rented, still own hardware? Did you visit it and install things manually or DC did things? Or this is via some 3rd-party proxy and you just have a place in theirs rack? :-)
Thank you! Owned Servers , we ship them, DC handles installation in the Rack
server-factory.com
Can someone check what location https://www.ripe.net show. (RIPE Database (Whois) search form on the upper right corner)
Its Sweden itself.
btw @mxmla any plans for BGP sessions in the future?
Deployed mine, took a snapshot, restored snapshot - seems like this is working! My tests concludes, anything else I can run is some little stress test, but I assume mxmla did it already before deploying it
Oh wait, this is the LeapSwitch review guy. Sorry everybody for engaging.
Took you long enough to notice.
Slow day, eh?
I'm on mobile and broke my glasses last night. :P
That's good!
All those little private dabatases like maxmind, iplocation ... means jack shit if location isn't properly listed in RIPE database.
Anyone use this DC before? Curious about network stability and DDOS protection.
Thank you for your order!
ORDER NUMBER: 1946007934
Dazn: No
HotStar: No
Disney+: Yes (Region: DE)
Netflix: Yes (Region: SE)
YouTube Premium: Yes (Region: DE)
Amazon Prime Video: Yes (Region: DE)
TVBAnywhere+: Yes
iQyi Oversea Region: GB
Viu.com: No
YouTube CDN: Amsterdam
Netflix Preferred CDN: Stockholm
Spotify Registration: Yes (Region: DE)
Steam Currency: EUR
ChatGPT: Yes
It's fast and loving it so far
Can't wait for this to be officially launched
I think everything has been said already... everything works and works well..
very stable network, no real ddos protection
Congrats on the new location! I think it should send an email with the IP and Password to the user otherwise some users may have a problem with the login.
What would be the pricing after the trial is over?
