LevelOneHosting 512GB storage $17.76/year in Dallas.
sunny@vps5:~$ curl -sL yabs.sh | bash -s -- -s "https://yabsdb.com/add"
# Yet-Another-Bench-Script #
# v2023-04-23 #
Fri 23 Jun 2023 12:00:54 AM EDT
Uptime : 24 days, 13 hours, 39 minutes
Processor : Intel(R) Xeon(R) CPU E5-2690 v3 @ 2.60GHz
CPU cores : 1 @ 2593.992 MHz
AES-NI : ✔ Enabled
RAM : 961.3 MiB
Swap : 992.6 MiB
Disk : 512.0 GiB
Distro : Debian GNU/Linux 11 (bullseye)
Kernel : 6.1.0-0.deb11.7-amd64
VM Type : KVM
ISP : Dot-Tech LLC
ASN : AS398395 Dot-Tech LLC
Host : Dot-Tech LLC
Country : United States
Read | 12.48 MB/s (3.1k) | 46.58 MB/s (727)
Write | 12.48 MB/s (3.1k) | 46.87 MB/s (732)
Total | 24.97 MB/s (6.2k) | 93.46 MB/s (1.4k)
Read | 25.55 MB/s (49) | 23.62 MB/s (23)
Write | 27.20 MB/s (53) | 26.44 MB/s (25)
Total | 52.75 MB/s (102) | 50.06 MB/s (48)
Clouvider | London, UK (10G) | 680 Mbits/sec | 205 Mbits/sec | 104 ms
Scaleway | Paris, FR (10G) | busy | busy | 113 ms
NovoServe | North Holland, NL (40G) | busy | 698 Mbits/sec | 123 ms
Uztelecom | Tashkent, UZ (10G) | busy | 258 Mbits/sec | 208 ms
Clouvider | NYC, NY, US (10G) | 903 Mbits/sec | 842 Mbits/sec | 41.2 ms
Clouvider | Dallas, TX, US (10G) | 931 Mbits/sec | 925 Mbits/sec | 0.723 ms
Clouvider | Los Angeles, CA, US (10G) | 903 Mbits/sec | 807 Mbits/sec | 26.9 ms
Clouvider | London, UK (10G) | busy | busy | 103 ms
Scaleway | Paris, FR (10G) | 762 Mbits/sec | busy | 103 ms
NovoServe | North Holland, NL (40G) | 669 Mbits/sec | 623 Mbits/sec | 119 ms
Uztelecom | Tashkent, UZ (10G) | 659 Mbits/sec | 241 Mbits/sec | 208 ms
Clouvider | NYC, NY, US (10G) | 893 Mbits/sec | 873 Mbits/sec | 37.8 ms
Clouvider | Dallas, TX, US (10G) | 917 Mbits/sec | 916 Mbits/sec | 0.576 ms
Clouvider | Los Angeles, CA, US (10G) | 895 Mbits/sec | busy | 26.8 ms
Geekbench test failed and low memory was detected. Add at least 1GB of SWAP or use GB4 instead (higher compatibility with low memory systems).
YABS completed in 20 min 22 sec
View your YABS here https://yabsdb.com/yabs/VaeWgEGe
iHostART 50GB LowEndSeedbox €5.50/year in Orastie.
This has been migrated to SSD storage.
Link to previous benchmark on HDD storage.
IPv6 is via WireGuard tunnel to iHostART KVM 1GB; native IPv6 does not work.
root@box7:~# curl -sL yabs.sh | bash -s -- -s "https://yabsdb.com/add"
# v2023-04-23 #
Fri Jun 23 04:12:34 UTC 2023
Uptime : 3 days, 15 hours, 5 minutes
Processor : Intel(R) Xeon(R) CPU X5650 @ 2.67GHz
CPU cores : 1 @ 2659.998 MHz
AES-NI : ✔ Enabled
VM-x/AMD-V : ❌ Disabled
RAM : 512.0 MiB
Swap : 0.0 KiB
Disk : 49.1 GiB
Distro : Ubuntu 22.04.2 LTS
Kernel : 5.2.0
VM Type : OPENVZ
ISP : Orange Romania S.A.
ASN : AS8953 Orange Romania S.A.
Country : Romania
Read | 9.72 MB/s (2.4k) | 50.94 MB/s (796)
Write | 9.74 MB/s (2.4k) | 51.27 MB/s (801)
Total | 19.46 MB/s (4.8k) | 102.21 MB/s (1.5k)
Read | 66.47 MB/s (129) | 106.24 MB/s (103)
Write | 69.85 MB/s (136) | 113.31 MB/s (110)
Total | 136.32 MB/s (265) | 219.56 MB/s (213)
Clouvider | London, UK (10G) | 110 Mbits/sec | 647 Mbits/sec | 113 ms
Scaleway | Paris, FR (10G) | 134 Mbits/sec | busy | 58.6 ms
NovoServe | North Holland, NL (40G) | 213 Mbits/sec | busy | 115 ms
Uztelecom | Tashkent, UZ (10G) | 184 Mbits/sec | busy | 179 ms
Clouvider | NYC, NY, US (10G) | 133 Mbits/sec | 402 Mbits/sec | 202 ms
Clouvider | Dallas, TX, US (10G) | 8.35 Mbits/sec | 384 Mbits/sec | 228 ms
Clouvider | Los Angeles, CA, US (10G) | 9.59 Mbits/sec | 159 Mbits/sec | 278 ms
Clouvider | London, UK (10G) | 33.8 Mbits/sec | 42.4 Mbits/sec | 123 ms
Scaleway | Paris, FR (10G) | busy | 89.0 Mbits/sec | 125 ms
NovoServe | North Holland, NL (40G) | 47.3 Mbits/sec | 58.1 Mbits/sec | 114 ms
Uztelecom | Tashkent, UZ (10G) | 56.1 Mbits/sec | 59.7 Mbits/sec | 242 ms
Clouvider | NYC, NY, US (10G) | 51.2 Mbits/sec | 56.2 Mbits/sec | 181 ms
Clouvider | Dallas, TX, US (10G) | 50.1 Mbits/sec | busy | 231 ms
Clouvider | Los Angeles, CA, US (10G) | busy | 39.5 Mbits/sec | 270 ms
YABS completed in 9 min 9 sec
View your YABS here https://yabsdb.com/yabs/wql9XQyv
NatVPS UK Raspberry Pi demo unit in Newcastle Upon Tyne.
debian@ixp0:~ $ curl -sL yabs.sh | bash -s -- -s "https://yabsdb.com/add"
# v2023-04-23 #
Fri 23 Jun 04:01:29 UTC 2023
Uptime : 3 days, 3 hours, 55 minutes
Processor : Cortex-A72
CPU cores : 4 @ 1800.0000 MHz
AES-NI : ❌ Disabled
RAM : 1.8 GiB
Swap : 100.0 MiB
Disk : 57.3 GiB
Kernel : 6.1.21-v8+
VM Type : NONE
ISP : Natvps UK LTD
ASN : AS199044 Natvps UK LTD
Host : Natvps UK LTD
Read | 1.27 MB/s (318) | 9.76 MB/s (152)
Write | 1.30 MB/s (326) | 10.24 MB/s (160)
Total | 2.57 MB/s (644) | 20.00 MB/s (312)
Read | 11.78 MB/s (23) | 11.92 MB/s (11)
Write | 13.19 MB/s (25) | 13.34 MB/s (13)
Total | 24.98 MB/s (48) | 25.27 MB/s (24)
Clouvider | London, UK (10G) | 102 Mbits/sec | 191 Mbits/sec | 19.5 ms
Scaleway | Paris, FR (10G) | 103 Mbits/sec | 162 Mbits/sec | 27.9 ms
NovoServe | North Holland, NL (40G) | 105 Mbits/sec | busy | 25.7 ms
Uztelecom | Tashkent, UZ (10G) | 100 Mbits/sec | 112 Mbits/sec | 208 ms
Clouvider | NYC, NY, US (10G) | 97.0 Mbits/sec | 111 Mbits/sec | 87.8 ms
Clouvider | Dallas, TX, US (10G) | 91.9 Mbits/sec | 99.2 Mbits/sec | 121 ms
Clouvider | Los Angeles, CA, US (10G) | 93.0 Mbits/sec | 95.9 Mbits/sec | 144 ms
Clouvider | London, UK (10G) | busy | 152 Mbits/sec | 19.6 ms
Scaleway | Paris, FR (10G) | busy | 143 Mbits/sec | 30.2 ms
NovoServe | North Holland, NL (40G) | busy | busy | 25.8 ms
Uztelecom | Tashkent, UZ (10G) | busy | 78.3 Mbits/sec | 207 ms
Clouvider | NYC, NY, US (10G) | busy | 47.6 Mbits/sec | 87.4 ms
Clouvider | Dallas, TX, US (10G) | busy | 31.8 Mbits/sec | 121 ms
Clouvider | Los Angeles, CA, US (10G) | busy | 25.3 Mbits/sec | 144 ms
Geekbench 6 test failed. Run manually to determine cause.
YABS completed in 42 min 39 sec
F4 Networks IPv6-only BGP-enabled VM in Kansas City.
This is using native IPv6, as BGP is not yet configured.
NVME-KVM-4GB (Singapore) - $9.9 / mo
https://webhorizon.net
31$ per month dedicated server uk
RackNode.net - High-Performance VDS & Dedicated Servers
|Paypal, Card and Crypto Payments Accepted|
Wow... from where? Link pls
VPSag 3 €/m Too old CPU and slow for GB6, so anyone interested in their plans better chek before buy.
ServerStatus , slackvpn , linux mirrors
Recommended Providers: Servarica(aff) | HostBRR(aff) | SolidVPS(aff) | RackNerd(aff) | KuroIT(aff) | AlphaVPS(aff) | HostDare(aff)
ExtraVM-16G-Dallas
HostHatch E5 NVMe Promo 8 Legacy $60/year
Linode Dedicated CPU VPS
Hetzner CAX21 ARM 6.49 Euro /Mo
Node 32GB G2 - 23,99€ /mon
still luv it
spaceberg
Racknerd LEB Special 1.5GB - $16.5/year
ExtraVM 2G 2C 30G (Piscataway, NJ)
Free Online DevTools
Kuroit NL Custom Plan
Sign up at Dynadot [aff], spend $9.99 within 48 hours, and get $5.00 DynaDollars for domain registrations!
ExtraVM 5G 4C 75G (Dallas, TX)
ADTAQ 2TB free 1-month trial in Coeur d'Alene.
HostBrr 1TB storage $24/year in Falkenstein.
Disk test is on 8GB NVMe boot drive.
HostBrr 1TB storage, with disk test is on 1TB storage drive, with Geekbench 5.
F4 Networks Free IPv6 only VPS (Launch promo)
SSDNodes Coupon 30% - SSDNodes
pebblehost
https://lowendtalk.com/discussion/185440/pebblehost-i7-4790k-flash-sale-40-off-instant-setup-free-bgp-4-8-trustpilot-3-000-reviews#latest
https://www.ovhcloud.com/en-ie/vps/limited-edition/
If someone have yabs for the 16 vcore package I would REALLY appreciate it...
IncogNET great service with System Uptime: 234d 8hr 36min, Hetrixtools uptime monitors since 253d 18hr ago.
FirstByte 0.80$/m .
Madcityservers.com
HostBrr IPv6 Only 7950X3D
Kimsufi with free upgrades for 14€.
2x 800GB Intel SSD instead of 2 x 240GB and 32gigs of memram
ServerHost LEB Special
This is the lowest score I have ever gotten in a VPS
Another KS-LE with free upgrades for 14.24€ / 15.99$
KuroIT L.A. Location 5£/y. It was a crazy hidden deal. Yabs before retiring.
