server-factory.com | Sweden | Help us test and win a VPS!
edited July 2023 in Offers
Hi!
We are expanding to Stockholm, Sweden!
First Server is ready and configuration is done! We only have to wait for the transfer of our new IPv4 Subnet to launch the new location.
Now we like to ask the community to help us test!
Limitations of the Test:
  • 24 Hour Trial
  • One Trial VPS per Client
  • IPv6 Only, Mail Ports blocked
  • noVNC Console is only usable via IPv6 connection to our proxy
Specs:
AMD EPYC™ XXS IPv6 ONLY VPS 24 HOUR TRIAL
TRIAL: 24 HOURS
IPv6 ONLY: NO IPv4
DATA CENTER: OBE.NET DATA CENTER, TORSHAMNSGATAN 48, 164 40 KISTA, SWEDEN
VIRTUALIZATION: KVM
NESTED VIRTUALIZATION: ENABLED
CPU: AMD EPYC™ 7452
BASE CLOCK: 2.35 GHZ
BOOST CLOCK: UP TO 3.35 GHZ
CORES: 1 (25 % LIMIT)
RAM: 2 GiB DDR4 3200 MHZ ECC
STORAGE: 25 GiB NVME PCIe 4.0 SSD (RAID 10)
UPLINK: 1 GBIT
TRAFFIC (INCOMING + OUTGOING): 100 GiB FOR 24 HOURS
IPV6 SUBNET: /64
FEATURE: 1 SNAPSHOT
FEATURE: CUSTOM ISO
FEATURE: RDNS MANAGEMENT
FEATURE: MAIL PORTS BLOCKED
Price
FREE!
Order Link: https://my.server-factory.com/?cmd=cart&action=add&id=3364
You want to win one of our AMD EPYC™ S VPS in Stockholm, Sweden for 12 months? Specs: 2 Cores, 8 GiB RAM, 100 GiB NVME SSD, 1 IPv4 Address, /64 IPv6 Subnet, 1 GBIT Uplink
Just order the Trial VPS and give us some feedback afterwards via comment here :)
Winner will be announced on 06.08.2023 15:00 CEST. VPS for winner will be deployed as soon as the IPv4 Subnet is transferred.
Kind regards,
mxmla
Thanked by (2)sh97 Brueggus
    Congrats
    Thanked by (1)mxmla
    AmadexHosting ForumsWie ist meine IP-Adresse?AS215325
  • I thought Singapore would be your next expansion location. Congratulations on Sweden launch.
  • edited July 2023
    Congratz bro.
    Your Order Number is: 2076298645
    Thanked by (1)mxmla
  • root@sweden:~# curl -sL yabs.sh | bash
    #                     v2023-04-23                    #
    Sun Jul 23 02:44:03 PM CEST 2023
    Uptime     : 0 days, 0 hours, 7 minutes
    Processor  : AMD EPYC 7452 32-Core Processor
    CPU cores  : 1 @ 2349.998 MHz
    RAM        : 1.9 GiB
    Swap       : 0.0 KiB
    Disk       : 24.5 GiB
    Kernel     : 6.1.0-10-amd64
    IPv4/IPv6  : ❌  Offline / ✔ Online
    Read       | 240.54 MB/s  (60.1k) | 2.50 GB/s    (39.1k)
    Write      | 241.17 MB/s  (60.2k) | 2.51 GB/s    (39.3k)
    Total      | 481.71 MB/s (120.4k) | 5.02 GB/s    (78.4k)
    Read       | 8.44 GB/s    (16.4k) | 8.15 GB/s     (7.9k)
    Write      | 8.89 GB/s    (17.3k) | 8.69 GB/s     (8.4k)
    Total      | 17.33 GB/s   (33.8k) | 16.84 GB/s   (16.4k)
    | Ping
    Clouvider       | London, UK (10G)          | busy            | busy
    Scaleway        | Paris, FR (10G)           | 662 Mbits/sec   | 978 Mbits/sec
    | 32.7 ms
    NovoServe       | North Holland, NL (40G)   | 699 Mbits/sec   | busy
    | 24.2 ms
    Uztelecom       | Tashkent, UZ (10G)        | busy            | busy
    Clouvider       | NYC, NY, US (10G)         | busy            | busy
    Clouvider       | Dallas, TX, US (10G)      | busy            | busy
    Clouvider       | Los Angeles, CA, US (10G) | busy            | busy
    Geekbench releases can only be downloaded over IPv4. FTP the Geekbench files and run manually.
    YABS completed in 2 min 31 sec
    Thanked by (1)mxmla
  • good vps
    Thanked by (1)mxmla
  • edited July 2023
    I hesitate, this offer is intended for everyone.
    1. Advanatage: speed of IP6 hosting is higher than IP4.
    2. Disadvantage:
      Apart of this part of the specification (BASE CLOCK: 2.35 GHZ / CORES: 1 at 25 % LIMIT), which makes the VPS configuration closer to the "shared hosting" for the exclusevley "static content",
      the user needs the own solution of
      how to make the IP6 host visible for the users of IP4 networks.
      There s no simple solution for OS debian, for instance.
    To reach the configuration of such IP6 host will be impossible from the 95+% of modern phones.
  • edited July 2023
    @abcnew said: the user needs the own solution of
    We're in 2023. v6 is 25 years old.
    I really appreciate every provider who's able to offer v4 as an additional add-on instead of a necessity.
  • edited July 2023
    @abcnew said: To reach the configuration of such IP6 host from the 95+% of modern phones will be impossible.
    That's a made-up number, right?
    When there's 42% of users accessing Google via v6, I highly doubt the v6 adoption on phones is at 5% globally.
    Locally speaking - all MNO's support v6 over here.
    Thanked by (3)mxmla fluttershy yoursunny
  • skorousskorous OGSenpai
    edited July 2023
    2. Disadvantage:
    Read closer. It's a 24hour TRIAL. If you're going to try and run production on a 24 hour trial you're going to have a bad time.
    EDIT: But if you, be sure to post here so I watch for the public freak out. I'll make some extra popcorn.
    Thanked by (1)mxmla
  • edited July 2023
    skorous : To add "update/upgrade" and to install additional 50 packages for PHP8*, Mariadb and the specific application takes 6-8 hours within your limit of 25% from 3.35Mhz of the single core.
    The experinced user, if he finds your offer attractive with ~850Khz, is hardly become happy.
    To configuree the whole construction of web server takes days, not 24 consequent hours.
    So, expectations for the experienced user look as follows : either you add full core or you extend the trial till 72 hours in order the user can use his static web server practically.
  • @abcnew said:
    skorous : To add "update/upgrade" and to install additional 50 packages for PHP8*, Mariadb and the specific application takes 4-6 hours. To configuree the whole construction of web server takes days, not 24 hours.
    Is this an experience you have with the trial VPS at the moment? Install via apt is lightning fast on my trial VPS.
    Thanked by (2)yoursunny Asim
  • edited July 2023
    @abcnew said: his static web server practically.
    Static webserver? Why would you even need php and a database to serve static files?!
    Troll somewhere else.
    @abcnew said: PHP8*, Mariadb
    Thanked by (1)mxmla
  • wow
    Uptime : 0 days, 0 hours, 26 minutes
    AES-NI : ✔ Enabled
    RAM : 1.9 GiB
    Swap : 0.0 KiB
    Disk : 24.5 GiB
    VM Type : KVM
    Running fio random mixed R+W disk test wiRunning fio random mixed R+W disk test wiRunning fio random mixed R+W disk test wiRunning fio random mixed R+W disk test wifio Disk Speed Tests (Mixed R/W 50/50):
    Block Size | 4k (IOPS) | 64k
    (IOPS)
    Read | 222.14 MB/s (55.5k) | 2.54
    GB/s (39.7k)
    Write | 222.73 MB/s (55.6k) | 2.55
    GB/s (39.9k)
    Total | 444.87 MB/s (111.2k) | 5.10
    GB/s (79.7k)
    Block Size | 512k (IOPS) | 1m
    (IOPS)
    Read | 8.47 GB/s (16.5k) | 9.94
    GB/s (9.7k)
    Write | 8.92 GB/s (17.4k) | 10.61 GB/s (10.3k)
    Total | 17.40 GB/s (33.9k) | 20.56 GB/s (20.0k)
    Running GB5 benchmark test... *cue elevatGeekbench releases can only be downloaded over IPv4. FTP the Geekbench files and run manually.
    YABS completed in 16 sec
  • Congrats on the expansion!
    Installation speeds seem very snappy, disks are screaming fast.
    Docker stuff was also running fast.
    Impressive stuff.
     Basic Network Info
     Primary Network    : IPv6
     ISP                : DE-MAXIMILIAN-JACOBSEN
     ASN                : Unknown
     ASN (IPv4)         : AS44684 Mythic Beasts Ltd
     Location (IPv4)    : Amsterdam, North Holland, NL
     Location         Latency     Loss    DL Speed       UP Speed       Server
     ISP:
     Nearest          24.01 ms    0.0%    989.18 Mbps    583.22 Mbps    Schlueter Onlinedienste - Ruethen
     Kochi, IN        184.03 ms   0.0%    989.37 Mbps    106.26 Mbps    Asianet Broadband - Cochin
     Bangalore, IN    166.00 ms   0.0%    958.41 Mbps    168.34 Mbps    Bharti Airtel Ltd - Bangalore
     Chennai, IN      173.65 ms   0.0%    936.16 Mbps    59.43 Mbps     Tata Play Fiber - Chennai
     Mumbai, IN       148.30 ms   0.0%    987.21 Mbps    158.01 Mbps    i3D.net - Mumbai
     Delhi, IN        201.81 ms   0.0%    968.92 Mbps    205.37 Mbps    Tata Teleservices Ltd - New Delhi
     Seattle, US      177.41 ms   0.0%    988.29 Mbps    139.35 Mbps    DediPath - Seattle, WA
     Los Angeles, US  152.73 ms   0.0%    986.92 Mbps    171.07 Mbps    ReliableSite Hosting - Los Angeles, CA
     Dallas, US       129.05 ms   0.0%    777.03 Mbps    161.27 Mbps    Hivelocity - Dallas, TX
     Miami, US        145.54 ms   0.7%    76.74 Mbps     33.96 Mbps     AT&T - Miami, FL
     New York, US     100.64 ms   0.0%    991.31 Mbps    204.44 Mbps    Clouvider Ltd - New York, NY
     Toronto, CA      101.74 ms   0.0%    958.02 Mbps    242.04 Mbps    Rogers - Toronto, ON
     London, UK       30.47 ms    0.0%    1004.84 Mbps   552.76 Mbps    VeloxServ Communications - London
     Amsterdam, NL    25.22 ms    0.0%    996.56 Mbps    468.16 Mbps    Clouvider Ltd - Amsterdam
     Paris, FR        FAILED
     Frankfurt, DE    32.24 ms    0.0%    1003.62 Mbps   370.34 Mbps    23M GmbH - Frankfurt Am Main
     Warsaw, PL       37.46 ms    0.0%    992.85 Mbps    350.34 Mbps    UPC Polska - Warszawa
     Bucharest, RO    63.37 ms    1.0%    48.81 Mbps     38.22 Mbps     Vodafone Romania Fixed – Bucharest - Bucharest
     Jeddah, KSA      95.58 ms    0.0%    1001.90 Mbps   261.99 Mbps    Saudi Telecom Company
     Dubai, AE        FAILED
     Fujairah, AE     171.16 ms   5.0%    44.76 Mbps     22.40 Mbps     ETISALAT-UAE - Fujairah
     Tokyo, JP        284.67 ms   N/A     47.26 Mbps     31.53 Mbps     fdcservers.net - Tokyo
     Shanghai, CU-CN  243.97 ms   0.0%    914.16 Mbps    141.50 Mbps    China Unicom 5G - ShangHai
     Nanjing, CT-CN   FAILED
     Hong Kong, HKG   217.06 ms   N/A     44.47 Mbps     33.77 Mbps     STC - Hong Kong
     Singapore, SG    188.45 ms   0.0%    986.67 Mbps    156.36 Mbps    i3D.net - Singapore
     Jakarta, ID      237.38 ms   0.0%    988.15 Mbps    147.06 Mbps    PT. Telekomunikasi Indonesia - Jakarta
     Avg DL Speed       : 778.41 Mbps
     Avg UL Speed       : 200.30 Mbps
     Total DL Data      : 27.01 GB
     Total UL Data      : 6.59 GB
     Total Data         : 33.60 GB
    Uptime     : 0 days, 0 hours, 50 minutes
    RAM        : 1.9 GiB
    Swap       : 0.0 KiB
    Disk       : 24.5 GiB
    Country    : Sweden
    Read       | 235.61 MB/s  (58.9k) | 2.42 GB/s    (37.8k)
    Write      | 236.23 MB/s  (59.0k) | 2.43 GB/s    (38.0k)
    Total      | 471.85 MB/s (117.9k) | 4.85 GB/s    (75.8k)
    Read       | 9.03 GB/s    (17.6k) | 10.68 GB/s   (10.4k)
    Write      | 9.51 GB/s    (18.5k) | 11.39 GB/s   (11.1k)
    Total      | 18.55 GB/s   (36.2k) | 22.07 GB/s   (21.5k)
    Geekbench 5 Benchmark Test:
    Single Core     | 1058
    Multi Core      | 1014
    Full Test       | https://browser.geekbench.com/v5/cpu/21488692
    YABS completed in 2 min 46 sec
    Thanked by (1)mxmla
  • JabJab Senpai
    Real tests will start with IPv4 :D
    Congratulations on new location - rented, still own hardware? Did you visit it and install things manually or DC did things? Or this is via some 3rd-party proxy and you just have a place in theirs rack? :-)
    Thanked by (1)mxmla
    Thank you! Owned Servers , we ship them, DC handles installation in the Rack ;)
    Thanked by (1)Jab
  • Can someone check what location https://www.ripe.net show. (RIPE Database (Whois) search form on the upper right corner)
    Thanked by (1)mxmla
  • edited July 2023
    Its Sweden itself.
    inet6num:        2a07:e041::/32
    netname:         DE-MAXIMILIAN-JACOBSEN-20230620
    country:         SE
    btw @mxmla any plans for BGP sessions in the future?
    Thanked by (2)Mumbly mxmla
  • JabJab Senpai
    edited July 2023
    @Mumbly said: Can someone check what location https://www.ripe.net show. (RIPE Database (Whois) search form on the upper right corner)
    country:         SE
    admin-c:         MJ84365-RIPE
    tech-c:          MJ84365-RIPE
    status:          ASSIGNED
    mnt-by:          maximilian-jacobsen
    created:         2023-06-20T07:35:00Z
    last-modified:   2023-07-23T13:08:35Z
    source:          RIPE
    geofeed:         https://server-factory.com/geofeed.csv
    geoloc:          59.40928708480201 17.949097615956706
    descr:           server-factory.com
    Deployed mine, took a snapshot, restored snapshot - seems like this is working! My tests concludes, anything else I can run is some little stress test, but I assume mxmla did it already before deploying it :)
    Oh wait, this is the LeapSwitch review guy. Sorry everybody for engaging.
    Thanked by (2)FrankZ mxmla
  • JabJab Senpai
    @skorous said: Oh wait, this is the LeapSwitch review guy. Sorry everybody for engaging.
    Took you long enough to notice.
    Slow day, eh?
    Thanked by (3)skorous fluttershy mxmla
    Slow day, eh?
    I'm on mobile and broke my glasses last night. :P
    Thanked by (2)Jab mxmla
  • edited July 2023
    @sh97 said: Its Sweden itself.
    country: SE
    @Jab said: country: SE
    That's good!
    All those little private dabatases like maxmind, iplocation ... means jack shit if location isn't properly listed in RIPE database.
    Thanked by (1)mxmla
  • Anyone use this DC before? Curious about network stability and DDOS protection.
    Thanked by (1)mxmla
  • Thank you for your order!
    ORDER NUMBER: 1946007934
    Dazn: No
    HotStar: No
    Disney+: Yes (Region: DE)
    Netflix: Yes (Region: SE)
    YouTube Premium: Yes (Region: DE)
    Amazon Prime Video: Yes (Region: DE)
    TVBAnywhere+: Yes
    iQyi Oversea Region: GB
    Viu.com: No
    YouTube CDN: Amsterdam
    Netflix Preferred CDN: Stockholm
    Spotify Registration: Yes (Region: DE)
    Steam Currency: EUR
    ChatGPT: Yes
    Thanked by (2)mxmla Asim
  • TheDPTheDP OGSenpai
    edited July 2023
    root@tartarus:~# time echo "Hello, World!"
    Hello, World!
    real    0m0.000s
    user    0m0.000s
    sys     0m0.000s
    It's fast and loving it so far <3
    Can't wait for this to be officially launched :smiley:
  • I think everything has been said already... everything works and works well..
    Thanked by (1)mxmla
    very stable network, no real ddos protection
    Thanked by (1)mxmla
  • Congrats on the new location! I think it should send an email with the IP and Password to the user otherwise some users may have a problem with the login.
    Thanked by (1)mxmla
  • What would be the pricing after the trial is over?
    Thanked by (2)mxmla rcy026
