Looking for VPS Server in India for Wireguard
Virtualization: KVM
Storage:10GB will do
cpu: 1
ram: 1/0.5
Bandwidth: <500GB
ipv4 : 1
Billing: Annual
Virtualization: KVM
cpu: 1
ram: 1/0.5
Bandwidth: <500GB
ipv4 : 1
Billing: Annual
Budget?
Im not sure, Is $20 too low for mentioned specs ?
I suggest to go with Leaps switch.
Generally APAC (especially India) and cheap doesn't happen - good luck in your search.
If any provider can offer this, I'm also in. (Upto 25$ year)
@R4in Oracle Cloud Hyderabad/Mumbai is available for free, if that works for you.
Thanks for the tip , Def worth a try
Per month? No, that's too high for servers in India.
Per year? Yes, need to double it at the very least.
Vultr
yes I think vultr is my only option available
More suggestions are welcome.
Check ReadyDedis, two free months if you pay annually: https://readydedis.com/intel-cloud-servers
