Are you still receiving invoices from SmallWeb or NexusBytes ?
SystemSystem Administrator
edited August 2023 in General
This discussion was created from comments split from: Psst...hey kid! You thought $13.69 was a good deal? Well....
As the title says. Are you still receiving invoices from SmallWeb or NexusBytes ?
Let us know below. Maybe post mail header info so we can see where they are coming from.
    @Nekki said:
    All this power used and heat generated, destroying our world. And for what? For nothing other than an endpoint for an uptime monitor.
    Wait, if no idlers, then what will the uptime monitors monitor?
    The uptime monitors will monitor NexusBytes.
    @yoursunny said: The uptime monitors will monitor NexusBytes.
    You seem a bit preoccupied with NexusBytes today. Having flashbacks ?
    Now that you mention it, SmallWeb keeps on sending me invoices. Got another one yesterday :#
    How? Is the billing panel still up?
    I would expect that means the billing panel is up somewhere, even if it is not accessible to public view. Not a good sign IMO, because that might mean that someone has the db. I'm going to split this off into a new thread in case others are seeing similar issues.
    Thanked by (1)bdl
  • bdlbdl OG
    edited August 2023
    Via email, billing panel down though. And agree with @FrankZ that it's not good the db is still somewhere.
  • TheDPTheDP OGSenpai
    IIRC, someone managed to get the domain when it expired earlier this year.
    @bdl said: Via email, billing panel down though.
    Want to post some email headers, redacting your info, so we can see where they are coming from ?
    The AI has taken over the companies.
    I just went to find them but had already nuked the email, will post them next month when the next invoice comes in (if someone doesn't post them beforehand).
    I mean, when you don't have idler, your uptime monitors can monitor ::1, which is what NexusBytes does.
    edited August 2023
    I recieved one earlier and saved it. They are coming from mailgun.
    Delivered-To: (redacted don't like it go blow)
    Received: by 2002:ab3:1981:0:b0:238:deca:891a with SMTP id 1csp2138315lti;
    Fri, 7 Jul 2023 16:00:21 -0700 (PDT)
    X-Google-Smtp-Source: APBJJlFJqPjLk/otVvKD2tgML0mmeVE8SJJjbTVLbi/TE58Ef09jUSG+2a/3NzVZfhyyddzXATR/
    X-Received: by 2002:a5b:250:0:b0:c70:d138:51b2 with SMTP id g16-20020a5b0250000000b00c70d13851b2mr1162645ybp.25.1688770820469;
    Fri, 07 Jul 2023 16:00:20 -0700 (PDT)
    ARC-Seal: i=1; a=rsa-sha256; t=1688770820; cv=none;
    d=google.com; s=arc-20160816;
    b=UOGsxE9qyqP2OVqU6dD2p3HtOEkw9DQGAl0I7NX1R32iTHZbzF3HXHlKfaE3fWYOps
    NrU6rSqfrI9RY4cyyRCe1PNbif6Lrl39xPssv0KNTyO4VjTjiRDyuGzLLWqe1pTq7Xvc
    +2CJxzMJ5xv/PWJopsz7+hCV2jhGJhw+hMU+tlAGb8Q4dXfn2VrNWOPjFPT1ua8ydPTZ
    a+hY9zVu0hHdI8a7x8V3T0oCF6w5nPdyz/ObTdA70BIdcgiUOt7RaBNubvCRTr0Q1ajc
    dnInhygOYyuPs0eN8NLGoz574SLNfG1gefsoYHc2Nk2dndiBvlhyNKuRIcLzXqjkJiGT
    izvQ==
    ARC-Message-Signature: i=1; a=rsa-sha256; c=relaxed/relaxed; d=google.com; s=arc-20160816;
    h=mime-version:to:from:subject:date:message-id:sender:dkim-signature
    :dkim-signature;
    bh=jlZGImtr0I86mOQ+fjvGfQCrPAtJjbqv07adjk2Ao34=;
    fh=Ad7GqAMf6cEkguDZ2235pfjzdaJVeTE+p56HMbd2IeE=;
    b=YAc4LgdQQ895v0LvIczjKCY873lh2eaFJJXyi7vS+Dbj/hsZTjt9vc+cxWlM9IjXC7
    sqWbbeKXzXJaqyfQ78yINDuvRuq//YRUN28mjd3iZ/3mZNsFMABLAWIhxN27NH9i3ZpG
    R8Z1OMA3sJaSpkB4OXYNmHpzQ92QIAADPfrzKkM9iEHgu6HKQdnrovPuscwjYpj/uQCk
    jL6L3TfnNrGaqoQZ4DhZ+eVnZ7XXt1GeL6t002ln8kq/xEUcvPVbALX4sAeJURnF++7l
    8SPZg/3WozeZc8AQL5qAN52zjFhPh5byriFn70Bi+NUUJIWZXd9E/aiMX/PKa02MxyQX
    BaIg==
    ARC-Authentication-Results: i=1; mx.google.com;
    dkim=temperror (dns failure for signature) header.i=@email.smallweb.net header.s=krs header.b=iOkXzFpu;
    dkim=pass header.i=@mailgun.org header.s=mg header.b=ZoHQzUxF;
    spf=temperror (google.com: error in processing during lookup of [email protected]: DNS error) smtp.mailfrom="[email protected]"
    Return-Path: bounce+44a491.a0b8e7f-nope@email.smallweb.net
    Received: from m43-7.mailgun.net (m43-7.mailgun.net. [69.72.43.7])
    by mx.google.com with UTF8SMTPS id ck5-20020a05690218c500b00c31dd3c6f0fsi1943914ybb.546.2023.07.07.16.00.19
    for
    (version=TLS1_3 cipher=TLS_AES_128_GCM_SHA256 bits=128/128);
    Received-SPF: temperror (google.com: error in processing during lookup of [email protected]: DNS error) client-ip=69.72.43.7;
    Authentication-Results: mx.google.com;
    DKIM-Signature: a=rsa-sha256; v=1; c=relaxed/relaxed; d=email.smallweb.net; q=dns/txt; s=krs; t=1688770819; x=1688778019; h=Content-Type: MIME-Version: To: To: From: From: Subject: Subject: Date: Message-ID: Sender: Sender: X-Feedback-Id; bh=jlZGImtr0I86mOQ+fjvGfQCrPAtJjbqv07adjk2Ao34=; b=iOkXzFpuCSq4GTKr+WihVGPydEkK8a58TVVBrMQ3gX9OWtsH6a9+0C/51dAQLSJmP/MLzH3/vuzKD5ksXcJCiX00ylIBc/tta1hP/wsHyajUcDOt8duokFt0CIzjz8fzl37BoqzuFsiR7KWOGy4qm4aZYp8c/v7rpddlZ7ZEOoeJ5r1kvXXjf7hOAkiKsB1jWhu/ThU8xGDlwWI0Aejx3xFDtKYtCD1dJoXNv2L1gTqbV/D10Ct0W3aix1WDCX4KxAkKl/kYdJ/Ne/7eJVBD9FFbiX1rYpVfrUrXuJm7vbR+LV7NAhQUwkvSi5M3s/rF/3oFSMM3/PMV0HeSK/VdLw==
    DKIM-Signature: a=rsa-sha256; v=1; c=relaxed/relaxed; d=mailgun.org; q=dns/txt; s=mg; t=1688770819; x=1688778019; h=Content-Type: MIME-Version: To: To: From: From: Subject: Subject: Date: Message-ID: Sender: Sender: X-Feedback-Id; bh=jlZGImtr0I86mOQ+fjvGfQCrPAtJjbqv07adjk2Ao34=; b=ZoHQzUxFMbRvycA2uHnQAu9TZCYHGTv0R7wQDcH4TPNWJR5K3nvt2bRgETPuMhxG+WsMM23+2mzGj44HnMfmZRjGxC+8+72M2KmPr6IXISL3/A/GTmnszFg9wr7vb/iz2QB6KtlSfsntXdi4tvA57dpWsbNGQ7hqgoVxn8zCcxc=
    X-Feedback-Id: [email protected]::610721afd5f705cf39212ec3:mailgun
    X-Mailgun-Sending-Ip: 69.72.43.7
    X-Mailgun-Sid: WyJmMGU2NCIsInNsYWNrZXJzdUBnbWFpbC5jb20iLCJhMGI4ZTdmIl0=
    Received: from [127.0.0.1] (kilner.baseserv.com [193.164.206.16]) by 4f4fe08642ab with SMTP id 64a898feb5e7f8e2c0a3adef (version=TLS1.2, cipher=TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256); Fri, 07 Jul 2023 23:00:14 GMT
    Sender: [email protected]
    Message-ID: cd71bd7bb9c50349801ede98e44cfc1b@swift.generated
    Date: Fri, 07 Jul 2023 23:00:14 +0000
    Subject: Your unpaid SmallWeb invoice reminder
    To: (redacted again don't like it you can still blow)
    MIME-Version: 1.0
    Content-Type: multipart/mixed; boundary="=_swift_1688770814_a04f4ef76fb3226826ae47d5211e5d9d=_"
    --=_swift_1688770814_a04f4ef76fb3226826ae47d5211e5d9d=_
    Content-Type: text/plain; charset=UTF-8
    Content-Transfer-Encoding: quoted-printable
    Hey friend! =F0=9F=98=80
    You have an invoice due. Please log in to pay it.
    Please note: The email address this message was sent from is not monitored.=
    Please use our official support channels to contact us.
    [redacted]
    Content-Type: application/pdf; name=2618.pdf
    Content-Transfer-Encoding: base64
    Content-Disposition: attachment; filename=2618.pdf
    --=_swift_1688770814_a04f4ef76fb3226826ae47d5211e5d9d=_--
    have fun with it boys and gals.
    Thanked by (2)FrankZ bdl
    *grabs popcorn*
    Thanks, but not going to get much info from there.
  • bdlbdl OG
    edited August 2023
    I hadn't received any since SmallWeb went down, and have received two recently. Mine were for a domain renewal (I'd moved it to NameSilo January this year when NB/SmallWeb fell over) - which would have been due for renewal a month from now (Sept 20).
    Family never forget.
    Unless we storm mailgun we sure as hell wont be getting squat.
    Still has a Europe address for the business if that helps any, but doubtful.
  • I have not received anything from nexusbytes
    *knocksonwood
    Thanked by (2)AuroraZero FrankZ
    *knocksonwood
    hey staqy away from my P.E.N.I.S!!!!
    Thanked by (1)bdl
  • Is the Yeti wood 10ft long?
    From a sus email straight to viagra, lovely.
    *knocksonwood
    3 1/2 inches of the hardest thing known to man :p
    Thanked by (1)crunchbits
    @Neoon said: From a sus email straight to viagra, lovely.
    Had a feeling that it would that kind of thread when I split it, but I did it anyway.
    Thanked by (2)skorous Wonder_Woman
    Luckily I didn't knock on diamonds.
    Okay okay I shall stop geeezzz party poopers.
    I am sorry I would make a smart ass reply but I just said I would be a good Yeti and I shall not break my solemn vow. ;)
    Yeti dude, no objections to that kind of stuff in my threads. Knock your pants off.
    Well, it is the warm season. ;)
    Thanked by (1)AuroraZero
  • Thanked by (1)FrankZ
    @FrankZ Please can you redact the address mentioned in the email posted in this thread. That is my personal home address, that Jay had no right in continuing to use after I dissolved that company, even though I contacted him multiple times to remove it and any mentions of me, my home address and the since defunct company. Thank you.
    Thanked by (3)MannDude AuroraZero imok
    Absolutely, address redacted. I am sure all concerned in this thread were unaware of this issue. My apologies for any inconvenience this may have caused you.
