Crunchbits shiny new router switch
edited August 2023 in Help
Do anyone have luck switching to @crunchbits' new router, 2606:a8c0:3::1?
I tried switching but no luck. Can't ping the new gateway. My VPS is in the 2606:a8c0:3::/48 range so I tried tweaking the prefix length to no avail.
If you got it working can you post your ip -6 a and ip -6 r?
  • how are you configuring your network? ifupdown? or netplan?
    systemd-networkd.
    Regardless, the two commands above should show the configured state.
  • your have 2 different IPv6 ranges, first one is a /128 that is your default route, then you have a second one thatis a /64 routed via your /128
    so you need to have your /128 assigned for IPv6 to work
  • edited August 2023
    The /128 (2606:a8c0:3::xx) is on link.
    just to show the ip responses,
    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 state UNKNOWN qlen 1000
        inet6 ::1/128 scope host
    2: enp3s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 state UP qlen 1000
        inet6 2606:a8c0:3:29::xxxx/64 scope global
        inet6 2606:a8c0:xxxx:29::a/64 scope global
        inet6 2606:a8c0:3::xx/128 scope global
    ::1 dev lo proto kernel metric 256 pref medium
    2606:a8c0:3::xxxx dev enp3s0 proto kernel metric 256 pref medium
    2606:a8c0:3:xxxx::/64 dev enp3s0 proto kernel metric 256 pref medium
    default via 2606:a8c0:3::1 dev enp3s0 proto static metric 1024 onlink pref medium
    traceroute to google.com (2607:f8b0:400e:c03::64), 30 hops max, 80 byte packets
     1  * _gateway (2606:a8c0:3::1)  12.039 ms *
     2  ae0.edge1.lblkwa.crunchbits.net (2606:a8c0:0:2::10:18)  0.228 ms  0.262 ms  0.265 ms
    Interesting. You seem to have two /64s and one /128, none of which is in the same /64 as the router. Which is why your default route has a "onlink" notation so that your machine knows where to find the router.
    I tried the "onlink" trick and did a tcpdump and all I can see is that my machine is trying to find the router by sending neighbor solicitation messages but never received any responses.
    Would you mind PM me your actual IP addresses so I can traceroute to them?
    EDIT: he did and I can't ping him. Will try again in the morning.
    @terrorgen
    Get things working? I have a Debian and OpenBSD working, would be glad to help.
    Thanked by (2)FrankZ terrorgen
  • Actually, looks like I am situated in an older hypervisor that only has access to the old gateway. I was scheduled to get a ticket today asking for permission to move to the new hypervisor, but I caught them earlier.
    Migrated the VM and problem solved!
    Admin please close?
    /thread
