Comprehensive Speedtest Script | network-speed.xyz | Share your bench
145791012
  • @sh97 said:
    @Neoon said:
    The Script doesn't work with IPv6, either I get a empty response or cloudflare gives me a error code 1015.
    Hmm, that is interesting. I will take a look at it.
    It has worked for me before on v6 only machines - https://lowendspirit.com/discussion/comment/146041/#Comment_146041
    Which host did you try this from?
    I tried again and on another 2 machines. (Scaleway and Limitlesshost)
    From the looks of it, its random if I get the script as response or an empty response.
    Something is definitely broken.
    Thanked by (1)sh97
    Ah, I think I found the issue.
    I can see requests from AS12876 Online SAS (looks like Scaleway) being rate-limited by Cloudflare.
    I did add rate limiting last month or so, because someone had a misconfigured cron which was running every second for the first 2 minutes, every hour (60req/min) and all these tests used to be completed.
    I think eventually Oookla noticed it, because now you can do only 30-32 tests in an hour.
    Or did you have any instances were it did not run at all on the first try?
    I did play around with my serverfactory SE and F4 Networks US v6 only VPS, but was not able to find this problem. I'll keep looking.
    Thanks for letting me know!
  • NeoonNeoon OG
    edited September 2023
    So, the thing is, it does not always tell me I am getting rate limited.
    Its just an empty response.
    Sometimes Cloudflare does return a 1015 Error, only sometimes.
    So I assume, that if I get an empty response, I am not getting rate limited, thus there is a issue.
    Pretty sure it didn't run at first try on my Limitlesshost, hence I posted.
    Thanked by (1)sh97
  • DataWagon LET Offer
     Version            : v2023.09.04
     Global Speedtest   : wget -qO- network-speed.xyz | bash
     Region Speedtest   : wget -qO- network-speed.xyz | bash -s -- -r
     Basic System Info
     CPU Model          : AMD EPYC 7713 64-Core Processor
     CPU Cores          : 4 @ 1999.998 MHz
     CPU Cache          : 512 KB
     AES-NI             : ✔ Enabled
     VM-x/AMD-V         : ✔ Enabled
     Total Disk         : 38.3 GB (4.9 GB Used)
     Total RAM          : 7.8 GB (191.8 MB Used)
     Total Swap         : 1022.0 MB (0 Used)
     System uptime      : 0 days, 1 hour 37 min
     Load average       : 0.03, 0.15, 0.71
     OS                 : Ubuntu 22.04.3 LTS
     Arch               : x86_64 (64 Bit)
     Kernel             : 5.15.0-83-generic
     Virtualization     : KVM
     Basic Network Info
     Primary Network    : IPv4
     ISP                : DataWagon LLC
     ASN                : AS27176 DataWagon LLC
     Host               : DataWagon LLC
     Speedtest.net (Region: NORTH AMERICA)
     Location         Latency     Loss    DL Speed       UP Speed       Server
     ISP: DataWagon LLC
     Nearest          11.09 ms    0.0%    941.73 Mbps    941.62 Mbps    Spectrum - New York, NY
     Vancouver, BC    131.18 ms   N/A     943.35 Mbps    600.54 Mbps    TELUS - Vancouver, BC
     Calgary, AB      65.30 ms    N/A     958.41 Mbps    745.08 Mbps    Shaw Communications - Calgary, AB
     Winnipeg, MB     30.96 ms    0.0%    956.48 Mbps    913.72 Mbps    Voyageur Internet - Winnipeg, MB
     Toronto, ON      88.12 ms    0.0%    946.07 Mbps    821.32 Mbps    Bell Canada - Toronto, ON
     Montreal, QC     83.62 ms    0.0%    941.03 Mbps    809.48 Mbps    Rogers Wireless - Montréal, QC
     New York, NY     13.79 ms    0.0%    955.82 Mbps    941.44 Mbps    Surfshark Ltd - New York, NY
     Ashburn, VA      17.57 ms    0.0%    941.77 Mbps    941.51 Mbps    Rackdog - Ashburn, VA
     Charlotte, NC    31.13 ms    0.0%    957.09 Mbps    937.72 Mbps    Windstream - Charlotte, NC
     Atlanta, GA      FAILED
     Miami, FL        46.12 ms    0.0%    956.78 Mbps    862.38 Mbps    AT&T - Miami, FL
     Dallas, TX       109.84 ms   0.0%    921.47 Mbps    701.16 Mbps    Hivelocity - Dallas, TX
     Houston, TX      48.40 ms    0.0%    956.50 Mbps    817.76 Mbps    Ezee Fiber - Houston, TX
     Kansas, MO       25.44 ms    0.0%    955.37 Mbps    911.40 Mbps    Xiber LLC - Kansas City, MO
     Minneapolis, MN  20.69 ms    0.0%    956.63 Mbps    941.75 Mbps    US Internet - Minneapolis, MN
     Chicago, IL      95.62 ms    0.0%    929.85 Mbps    813.57 Mbps    Enzu.com - Chicago, IL
     Cleveland, OH    25.44 ms    0.0%    955.59 Mbps    934.11 Mbps    Windstream - Cleveland, OH
     Albuquerque, NM  119.65 ms   N/A     937.55 Mbps    667.98 Mbps    Comcast - Albuquerque, NM
     Denver, CO       109.56 ms   0.0%    943.72 Mbps    705.62 Mbps    T-Mobile Fiber | Intrepid - Denver, CO
     Portland, OR     86.35 ms    N/A     981.92 Mbps    826.34 Mbps    CenturyLink - Portland, OR
     Las Vegas, NV    67.10 ms    N/A     963.21 Mbps    719.28 Mbps    Dish Wireless - Las Vegas, NV
     Salt Lake, UT    139.85 ms   N/A     829.85 Mbps    399.63 Mbps    Novva Data Centers - Salt Lake City, UT
     Phoenix, AZ      57.09 ms    0.0%    958.49 Mbps    771.00 Mbps    Xiber LLC - Phoenix, AZ
     Los Angeles, CA  133.63 ms   0.0%    929.22 Mbps    562.70 Mbps    ReliableSite Hosting - Los Angeles, CA
     Santa Clara, CA  60.25 ms    0.0%    954.31 Mbps    790.17 Mbps    AT&T - Santa Clara, CA
     San Jose, CA     138.49 ms   0.0%    790.05 Mbps    572.99 Mbps    Misaka Network, Inc. - San Jose, CA
     Seattle, WA      139.63 ms   0.0%    173.73 Mbps    539.98 Mbps    Misaka Network, Inc. - Seattle, WA
     Hermosillo, MX   158.53 ms   0.0%    645.92 Mbps    463.18 Mbps    Megacable - Hermosillo
     Guadalajara, MX  83.33 ms    0.0%    951.14 Mbps    801.89 Mbps    AT&T México - Guadalajara
     Mexico City, MX  FAILED
     Merida, MX       137.98 ms   0.0%    934.24 Mbps    578.19 Mbps    Totalplay - Mérida
     Avg DL Speed       : 902.31 Mbps
     Avg UL Speed       : 759.78 Mbps
     Total DL Data      : 36.14 GB
     Total UL Data      : 28.15 GB
     Total Data         : 64.29 GB
     Duration           : 13 min 52 sec
     System Time        : 13/09/2023 - 05:08:31 UTC
     Total Script Runs  : 23087
     Result             : https://paste.kangserver.id/view/SShGaLo
    Thanked by (1)sh97
    📱: Samsung Galaxy | 💻: Windows 11
  • ---------------------------- network-speed.xyz ----------------------------
          A simple script to test network performance using speedtest-cli
     Region Speedtest   : wget -qO- network-speed.xyz | bash -s -- -r <region>
     Basic System Info
     CPU Model          : AMD Ryzen 5 3600 6-Core Processor
     CPU Cores          : 1 @ 3593.248 MHz
     CPU Cache          : 512 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 9.8 GB (2.5 GB Used)
     Total RAM          : 3.8 GB (296.5 MB Used)
     Total Swap         : 1024.0 MB (0 Used)
     System uptime      : 0 days, 0 hour 24 min
     Load average       : 0.15, 0.53, 0.44
     OS                 : Debian GNU/Linux 12
     Kernel             : 6.1.0-10-amd64
     Basic Network Info
     Primary Network    : IPv6
     ISP                : AEZA GROUP Ltd
     ASN                : AS210644 AEZA GROUP Ltd
     Host               : Aeza Network Stockholm
     Location (IPv4)    : Herräng, Stockholm, SE
     ISP: AEZA GROUP Ltd
     Nearest          6.83 ms     N/A     97.00 Mbps     102.96 Mbps    Netprotect - Stockholm
     Kochi, IN        221.14 ms   1.7%    85.48 Mbps     105.60 Mbps    Asianet Broadband - Cochin
     Bangalore, IN    188.10 ms   2.0%    95.08 Mbps     105.34 Mbps    Bharti Airtel Ltd - Bangalore
     Chennai, IN      216.17 ms   N/A     92.16 Mbps     93.81 Mbps     Jio - Chennai
     Mumbai, IN       158.00 ms   1.9%    96.23 Mbps     93.51 Mbps     i3D.net - Mumbai
     Delhi, IN        169.98 ms   2.1%    90.45 Mbps     101.05 Mbps    Tata Teleservices Ltd - New Delhi
     Seattle, US      153.62 ms   2.6%    90.31 Mbps     96.05 Mbps     Ziply Fiber - Seattle, WA
     Los Angeles, US  158.51 ms   1.5%    96.81 Mbps     107.13 Mbps    ReliableSite Hosting - Los Angeles, CA
     Dallas, US       127.21 ms   2.0%    33.51 Mbps     104.41 Mbps    Hivelocity - Dallas, TX
     Miami, US        196.68 ms   0.7%    102.90 Mbps    109.60 Mbps    AT&T - Miami, FL
     New York, US     176.65 ms   0.0%    106.26 Mbps    104.78 Mbps    GSL Networks - New York, NY
     Toronto, CA      190.75 ms   0.0%    101.07 Mbps    105.47 Mbps    Rogers - Toronto, ON
     London, UK       36.13 ms    1.6%    94.38 Mbps     101.29 Mbps    VeloxServ Communications - London
     Amsterdam, NL    27.16 ms    0.0%    97.75 Mbps     102.58 Mbps    31173 Services AB - Amsterdam
     Paris, FR        38.52 ms    N/A     99.06 Mbps     102.78 Mbps    Axione - Paris
     Frankfurt, DE    24.36 ms    1.8%    93.71 Mbps     103.53 Mbps    23M GmbH - Frankfurt am Main
     Warsaw, PL       31.18 ms    1.7%    86.71 Mbps     100.50 Mbps    UPC Polska - Warszawa
     Bucharest, RO    57.04 ms    0.0%    98.01 Mbps     104.21 Mbps    Vodafone Romania Fixed – Bucharest - Bucharest
     Jeddah, SA       96.38 ms    0.0%    98.37 Mbps     103.13 Mbps    Saudi Telecom Company
     Dubai, AE        151.83 ms   0.0%    103.29 Mbps    108.35 Mbps    du - Dubai
     Fujairah, AE     140.22 ms   0.0%    108.70 Mbps    100.91 Mbps    ETISALAT-UAE - Fujairah
     Tokyo, JP        271.95 ms   N/A     99.15 Mbps     110.98 Mbps    fdcservers.net - Tokyo
     Shanghai, CU-CN  275.11 ms   0.0%    97.97 Mbps     109.53 Mbps    China Unicom 5G - Shanghai
     Nanjing, CT-CN   245.37 ms   0.0%    98.03 Mbps     2.73 Mbps      China Telecom JiangSu 5G - Nanjing
     Hong Kong, CN    260.31 ms   N/A     104.85 Mbps    93.58 Mbps     STC - Hong Kong
     Singapore, SG    294.47 ms   7.1%    102.65 Mbps    102.09 Mbps    i3D.net - Singapore
     Jakarta, ID      201.31 ms   1.4%    86.19 Mbps     98.96 Mbps     PT. Telekomunikasi Indonesia - Jakarta
     Avg DL Speed       : 94.67 Mbps
     Avg UL Speed       : 99.07 Mbps
     Total DL Data      : 3.45 GB
     Total UL Data      : 3.76 GB
     Total Data         : 7.22 GB
     Duration           : 13 min 18 sec
     System Time        : 14/09/2023 - 19:02:44 CEST
     Total Script Runs  : 23172
     Result             : https://result.network-speed.xyz/r/1694710966_THYRYU_GLOBAL.txt
    Thanked by (1)Ganonk
    Basic System Info
    CPU Cache : 512 KB
    AES-NI : ✔ Enabled
    Basic Network Info
    ISP: AEZA GROUP Ltd
  • 1€ IONOS Frankfurt Equinix
     Basic System Info
     CPU Model          : AMD EPYC-Milan Processor
     CPU Cores          : 1 @ 1999.998 MHz
     CPU Cache          : 512 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 9.8 GB (697.5 MB Used)
     Total RAM          : 878.0 MB (193.5 MB Used)
     System uptime      : 0 days, 0 hour 31 min
     Load average       : 0.05, 0.20, 0.10
     Kernel             : 6.1.0-9-cloud-amd64
     Virtualization     : MICROSOFT
     Basic Network Info
     ISP                : Strato AG
     ASN                : AS6724 Strato AG
     Host               : Strato AG
     ISP: Strato AG
     Nearest          9.30 ms     0.0%    1921.91 Mbps   1901.28 Mbps   LWLcom GmbH - Berlin
     Kochi, IN        161.03 ms   0.0%    3672.67 Mbps   564.77 Mbps    Asianet Broadband - Cochin
     Bangalore, IN    127.40 ms   0.0%    4203.86 Mbps   677.07 Mbps    Bharti Airtel Ltd - Bangalore
     Chennai, IN      157.14 ms   N/A     3753.24 Mbps   405.54 Mbps    Jio - Chennai
     Mumbai, IN       134.59 ms   0.0%    3493.10 Mbps   679.81 Mbps    i3D.net - Mumbai
     Delhi, IN        142.88 ms   0.0%    2888.92 Mbps   600.43 Mbps    Tata Teleservices Ltd - New Delhi
     Seattle, US      162.12 ms   0.0%    1220.11 Mbps   495.35 Mbps    Ziply Fiber - Seattle, WA
     Los Angeles, US  160.87 ms   0.0%    4141.51 Mbps   480.15 Mbps    ReliableSite Hosting - Los Angeles, CA
     Dallas, US       116.04 ms   0.4%    1364.34 Mbps   157.61 Mbps    Hivelocity - Dallas, TX
     Miami, US        133.60 ms   0.0%    1063.92 Mbps   646.43 Mbps    AT&T - Miami, FL
     New York, US     78.68 ms    0.0%    1595.46 Mbps   1118.37 Mbps   GSL Networks - New York, NY
     Toronto, CA      88.02 ms    0.0%    3980.96 Mbps   1000.52 Mbps   Rogers - Toronto, ON
     London, UK       13.46 ms    0.0%    1226.48 Mbps   1895.75 Mbps   VeloxServ Communications - London
     Amsterdam, NL    13.22 ms    0.0%    1293.45 Mbps   1896.66 Mbps   31173 Services AB - Amsterdam
     Paris, FR        10.64 ms    N/A     1970.36 Mbps   1747.52 Mbps   Axione - Paris
     Frankfurt, DE    0.89 ms     0.0%    4525.49 Mbps   1864.91 Mbps   23M GmbH - Frankfurt am Main
     Warsaw, PL       24.36 ms    0.0%    2428.51 Mbps   1827.77 Mbps   UPC Polska - Warszawa
     Bucharest, RO    42.57 ms    0.0%    3090.16 Mbps   1784.04 Mbps   Vodafone Romania Fixed – Bucharest - Bucharest
     Jeddah, SA       67.22 ms    0.0%    2923.08 Mbps   1300.46 Mbps   Saudi Telecom Company
     Dubai, AE        139.91 ms   0.0%    3859.20 Mbps   661.00 Mbps    du - Dubai
     Fujairah, AE     116.83 ms   0.0%    1576.83 Mbps   798.09 Mbps    ETISALAT-UAE - Fujairah
     Tokyo, JP        280.34 ms   N/A     994.67 Mbps    352.80 Mbps    fdcservers.net - Tokyo
     Shanghai, CU-CN  356.73 ms   0.0%    1378.38 Mbps   296.15 Mbps    China Unicom 5G - Shanghai
     Nanjing, CT-CN   172.73 ms   0.0%    990.86 Mbps    59.65 Mbps     China Telecom JiangSu 5G - Nanjing
     Hong Kong, CN    239.20 ms   N/A     3152.48 Mbps   371.11 Mbps    STC - Hong Kong
     Singapore, SG    159.26 ms   0.0%    4297.84 Mbps   589.66 Mbps    i3D.net - Singapore
     Jakarta, ID      200.98 ms   0.0%    2234.30 Mbps   223.17 Mbps    PT. Telekomunikasi Indonesia - Jakarta
     Avg DL Speed       : 2564.53 Mbps
     Avg UL Speed       : 903.56 Mbps
     Total DL Data      : 96.20 GB
     Total UL Data      : 30.58 GB
     Total Data         : 126.78 GB
     Duration           : 13 min 7 sec
     System Time        : 17/09/2023 - 01:41:54 UTC
     Total Script Runs  : 23296
     Result             : https://result.network-speed.xyz/r/1694914915_LTRKVE_GLOBAL.txt
     Basic System Info
     CPU Model          : AMD EPYC-Rome Processor
     CPU Cores          : 1 @ 2349.998 MHz
     CPU Cache          : 512 KB
     AES-NI             : ✔ Enabled
     VM-x/AMD-V         : ❌ Disabled
     Total Disk         : 39.3 GB (2.0 GB Used)
     Total RAM          : 1.9 GB (120.7 MB Used)
     System uptime      : 0 days, 0 hour 44 min
     Load average       : 0.00, 0.00, 0.05
     OS                 : Debian GNU/Linux 11
     Kernel             : 5.10.0-21-amd64
     Basic Network Info
     ISP                : Host Europe GmbH
     ASN                : AS21499 Host Europe GmbH
     Host               : Host Europe GmbH
     Speedtest.net (Region: EUROPE)
     ISP: Host Europe GmbH
     Nearest          5.14 ms     0.0%    9371.56 Mbps   5057.19 Mbps   TelemaxX Telekommunikation GmbH - Karlsruhe
     London, UK       13.67 ms    0.0%    9270.36 Mbps   3548.33 Mbps   M247 Ltd - London
     Edinburgh, UK    30.98 ms    N/A     9152.59 Mbps   2806.41 Mbps   Vodafone UK - Edinburgh
     Dublin, IE       28.72 ms    0.0%    8943.50 Mbps   3070.16 Mbps   Three Ireland - Dublin
     Amsterdam, NL    9.57 ms     0.0%    9976.09 Mbps   8018.28 Mbps   GSL Networks - Amsterdam
     Dronten, NL      15.32 ms    0.0%    8930.08 Mbps   5590.06 Mbps   Serverius Connectivity - Amsterdam
     Paris, FR        7.87 ms     0.0%    1866.62 Mbps   2050.83 Mbps   ORANGE FRANCE - Paris
     Marseille, FR    18.92 ms    0.0%    10088.15 Mbps  4762.15 Mbps   GSL Networks - Marseille
     Madrid, ES       30.03 ms    0.0%    9091.68 Mbps   3480.73 Mbps   Orange - Jazztel - Madrid
     Barcelona, ES    30.68 ms    0.0%    9248.10 Mbps   960.61 Mbps    Adamo - Barcelona
     Lisbon, PT       40.64 ms    0.0%    2227.93 Mbps   2133.50 Mbps   Edgoo Networks - Lisbon
     Rome, IT         33.72 ms    0.0%    6630.36 Mbps   2778.72 Mbps   TIM SpA - Rome
     Milan, IT        17.55 ms    0.0%    6313.50 Mbps   6078.85 Mbps   Vodafone IT - Milan
     Zurich, CH       15.96 ms    0.0%    10854.59 Mbps  5176.43 Mbps   Sunrise Communication AG - Zurich
     Frankfurt, DE    3.53 ms     0.0%    8619.99 Mbps   8035.63 Mbps   23M GmbH - Frankfurt am Main
     Berlin, DE       10.91 ms    0.0%    6571.14 Mbps   5224.58 Mbps   Misaka Network, Inc. - Berlin
     Vienna, AT       14.72 ms    0.0%    8911.08 Mbps   5902.27 Mbps   A1 Telekom Austria AG - Vienna
     Budapest, HU     18.36 ms    0.0%    11127.97 Mbps  4876.60 Mbps   ATW Internet Kft. - Budapest
     Gdansk, PL       28.81 ms    0.0%    3543.75 Mbps   3322.91 Mbps   T-Mobile Polska S.A. - Gdańsk
     Warsaw, PL       21.59 ms    0.0%    9081.29 Mbps   4013.30 Mbps   Orange Polska S.A. - Warsaw
     Lviv, UA         29.63 ms    0.0%    9061.39 Mbps   2071.92 Mbps   Kyivstar - Lviv
     Kyiv, UA         30.72 ms    0.0%    9143.25 Mbps   919.86 Mbps    o3 - Kyiv
     Minsk, BY        34.97 ms    0.0%    7714.35 Mbps   2968.01 Mbps   A1 - Minsk
     Bucharest, RO    32.49 ms    0.0%    8761.90 Mbps   1273.72 Mbps   Orange Romania Communications - Bucharest
     Iasi, RO         36.70 ms    0.0%    9451.88 Mbps   2812.49 Mbps   Digi
     Helsinki, FI     24.32 ms    0.0%    10253.06 Mbps  3611.78 Mbps   Elisa Oyj - Helsinki
     Stockholm, SE    30.78 ms    0.0%    9679.07 Mbps   2128.35 Mbps   i3D.net - Stockholm
     Oslo, NO         31.67 ms    0.0%    7782.14 Mbps   1661.83 Mbps   Speedtest.net - Oslo
     Moscow, RU       36.61 ms    0.0%    9301.63 Mbps   2614.28 Mbps   Rostelecom - Moscow
     Petersburg, RU   33.83 ms    0.0%    4679.03 Mbps   2422.49 Mbps   MTS OJSC - Saint Petersburg
     Istanbul, TR     45.27 ms    0.0%    8783.45 Mbps   2027.10 Mbps   Turkcell - Istanbul
     Tbilisi, GE      61.65 ms    N/A     8474.85 Mbps   908.65 Mbps    Silknet JSC - Tbilisi
     Avg DL Speed       : 8215.78 Mbps
     Avg UL Speed       : 3509.59 Mbps
     Total DL Data      : 338.60 GB
     Total UL Data      : 124.20 GB
     Total Data         : 462.80 GB
     Duration           : 13 min 34 sec
     System Time        : 18/09/2023 - 09:40:54 UTC
    ^C
     Basic System Info
     CPU Cache          : 512 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 39.3 GB (1.9 GB Used)
     Total RAM          : 1.9 GB (121.8 MB Used)
     System uptime      : 0 days, 0 hour 35 min
     Load average       : 0.00, 0.02, 0.10
     Basic Network Info
     ISP                : GoDaddy.com, LLC
     ASN                : AS26496 GoDaddy.com, LLC
     Host               : Godaddy.com
     ISP: GoDaddy.com, LLC
     Nearest          0.85 ms     0.0%    8250.24 Mbps   9256.92 Mbps   PhoenixNAP Global IT Services - Singapore
     Kochi, IN        46.38 ms    0.0%    8395.78 Mbps   1571.89 Mbps   Asianet Broadband - Cochin
     Bangalore, IN    38.04 ms    0.0%    8231.80 Mbps   2135.66 Mbps   Bharti Airtel Ltd - Bangalore
     Chennai, IN      68.26 ms    N/A     8296.34 Mbps   762.53 Mbps    Jio - Chennai
     Mumbai, IN       68.31 ms    0.0%    3587.42 Mbps   996.71 Mbps    i3D.net - Mumbai
     Delhi, IN        FAILED
     Seattle, US      181.68 ms   0.0%    2800.43 Mbps   555.46 Mbps    Ziply Fiber - Seattle, WA
     Los Angeles, US  FAILED
     Dallas, US       FAILED
     Miami, US        236.77 ms   0.0%    3311.37 Mbps   439.60 Mbps    AT&T - Miami, FL
     New York, US     224.05 ms   0.0%    2955.42 Mbps   433.64 Mbps    GSL Networks - New York, NY
     Toronto, CA      FAILED
     London, UK       FAILED
     Amsterdam, NL    242.30 ms   0.0%    3269.28 Mbps   377.65 Mbps    31173 Services AB - Amsterdam
     Paris, FR        257.31 ms   N/A     1892.32 Mbps   0.31 Mbps      Axione - Paris
     Frankfurt, DE    FAILED
     Warsaw, PL       183.69 ms   0.0%    2705.26 Mbps   485.15 Mbps    UPC Polska - Warszawa
     Bucharest, RO    252.88 ms   1.0%    2939.72 Mbps   351.54 Mbps    Vodafone Romania Fixed – Bucharest - Bucharest
     Jeddah, SA       FAILED
     Dubai, AE        25.10 ms    0.0%    8696.71 Mbps   994.96 Mbps    du - Dubai
     Fujairah, AE     78.06 ms    0.0%    8177.19 Mbps   1105.35 Mbps   ETISALAT-UAE - Fujairah
     Tokyo, JP        276.30 ms   N/A     2814.44 Mbps   337.77 Mbps    fdcservers.net - Tokyo
     Shanghai, CU-CN  241.28 ms   5.3%    2678.64 Mbps   5.59 Mbps      China Unicom 5G - Shanghai
     Nanjing, CT-CN   FAILED
     Hong Kong, CN    33.72 ms    N/A     9266.67 Mbps   2322.40 Mbps   STC - Hong Kong
     Singapore, SG    FAILED
     Jakarta, ID      FAILED
     Avg DL Speed       : 5192.29 Mbps
     Avg UL Speed       : 1301.95 Mbps
     Total DL Data      : 116.50 GB
     Total UL Data      : 24.16 GB
     Total Data         : 140.66 GB
     Duration           : 9 min 33 sec
     System Time        : 18/09/2023 - 09:55:00 UTC
     Total Script Runs  : 23395
     Result             : https://result.network-speed.xyz/r/1695030902_H1XIE7_GLOBAL.txt
     Basic System Info
     CPU Cache          : 512 KB
     AES-NI             : ✔ Enabled
     Total RAM          : 1.9 GB (122.2 MB Used)
     Load average       : 0.10, 0.44, 0.32
     Basic Network Info
     ASN (IPv4)         : AS398791 GoDaddy.com, LLC
     Host               : Godaddy.com
     Location (IPv4)    : Mumbai, Maharashtra, IN
     Nearest          1.84 ms     0.0%    967.29 Mbps    8564.48 Mbps   Tata Play Fiber - Mumbai
     Kochi, IN        38.42 ms    0.0%    1013.45 Mbps   2292.81 Mbps   Asianet Broadband - Cochin
     Bangalore, IN    18.72 ms    0.0%    981.29 Mbps    1126.21 Mbps   Bharti Airtel Ltd - Bangalore
     Chennai, IN      21.38 ms    N/A     8832.30 Mbps   2717.33 Mbps   Jio - Chennai
     Mumbai, IN       2.02 ms     0.0%    9283.47 Mbps   7988.22 Mbps   i3D.net - Mumbai
     Delhi, IN        21.12 ms    0.0%    2905.99 Mbps   511.58 Mbps    Tata Teleservices Ltd - New Delhi
     Seattle, US      248.21 ms   0.0%    908.30 Mbps    403.24 Mbps    Ziply Fiber - Seattle, WA
     Los Angeles, US  224.01 ms   0.0%    999.20 Mbps    115.08 Mbps    ReliableSite Hosting - Los Angeles, CA
     Dallas, US       271.39 ms   0.0%    982.94 Mbps    181.86 Mbps    Hivelocity - Dallas, TX
     Miami, US        251.10 ms   0.0%    206.09 Mbps    398.79 Mbps    AT&T - Miami, FL
     New York, US     188.40 ms   0.0%    494.98 Mbps    293.27 Mbps    GSL Networks - New York, NY
     Toronto, CA      253.20 ms   0.0%    943.26 Mbps    349.79 Mbps    Rogers - Toronto, ON
     London, UK       139.30 ms   0.0%    1013.81 Mbps   756.71 Mbps    VeloxServ Communications - London
     Amsterdam, NL    122.44 ms   0.0%    480.94 Mbps    435.68 Mbps    31173 Services AB - Amsterdam
     Paris, FR        161.57 ms   N/A     392.14 Mbps    248.02 Mbps    Axione - Paris
     Frankfurt, DE    128.42 ms   0.0%    956.10 Mbps    368.01 Mbps    23M GmbH - Frankfurt am Main
     Warsaw, PL       142.33 ms   0.0%    168.56 Mbps    573.86 Mbps    UPC Polska - Warszawa
     Bucharest, RO    153.49 ms   0.0%    201.56 Mbps    629.07 Mbps    Vodafone Romania Fixed – Bucharest - Bucharest
     Jeddah, SA       207.61 ms   0.0%    999.13 Mbps    115.47 Mbps    Saudi Telecom Company
     Dubai, AE        117.65 ms   0.0%    238.86 Mbps    146.47 Mbps    du - Dubai
     Fujairah, AE     84.37 ms    0.0%    461.68 Mbps    1221.83 Mbps   ETISALAT-UAE - Fujairah
     Tokyo, JP        352.00 ms   N/A     205.62 Mbps    232.37 Mbps    fdcservers.net - Tokyo
     Shanghai, CU-CN  124.04 ms   0.0%    160.69 Mbps    577.96 Mbps    China Unicom 5G - Shanghai
     Hong Kong, CN    90.03 ms    N/A     4923.88 Mbps   521.21 Mbps    STC - Hong Kong
     Singapore, SG    64.25 ms    0.0%    1006.32 Mbps   1161.80 Mbps   i3D.net - Singapore
     Jakarta, ID      172.17 ms   0.0%    816.49 Mbps    223.16 Mbps    PT. Telekomunikasi Indonesia - Jakarta
     Avg DL Speed       : 1559.40 Mbps
     Avg UL Speed       : 1236.71 Mbps
     Total DL Data      : 51.68 GB
     Total UL Data      : 41.84 GB
     Total Data         : 93.52 GB
     Duration           : 13 min 16 sec
     System Time        : 18/09/2023 - 10:01:54 UTC
     Total Script Runs  : 23401
     Result             : https://result.network-speed.xyz/r/1695031578_8B1RYR_GLOBAL.txt
  • @Neoon wow, how much is that godaddy india VPS?
    All of them 1.20€/m for the first 12 months.
    Thanked by (1)sh97
    How? Shows 849 for me?
    849€ what?
  • @Neoon said:
    849€ what?
    ₹849
  • NeoonNeoon OG
    @dosai said:
    @Neoon said:
    849€ what?
    ₹849
    Its available for Europe at least for this price.
    No one else commented that it wasn't available in other countries.
    So no idea.
  • @Neoon said:
    @dosai said:
    @Neoon said:
    849€ what?
    ₹849
    So no idea.
    Same for me too, shows 849 INR/month yearly pay, no discounts.
    https://www.godaddy.com/en-in/hosting/vps-hosting
  • @sh97 said:
    @Neoon said:
    @dosai said:
    @Neoon said:
    849€ what?
    ₹849
    So no idea.
    Nah you need to use the other Brand.
    https://www.hosteurope.de/en/Server/Virtual-Server/
    Thanked by (1)sh97
  • Crunchbits Yearly KVM SSD VPS - 4.5GB
     Basic System Info
     CPU Model          : Intel Core Processor (Broadwell)
     CPU Cores          : 3 @ 2095.322 MHz
     CPU Cache          : 16384 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 125.0 GB (8.6 GB Used)
     Total RAM          : 4.3 GB (1.1 GB Used)
     Total Swap         : 2.0 GB (55.7 MB Used)
     System uptime      : 1 days, 22 hour 46 min
     Load average       : 0.16, 0.06, 0.01
     Kernel             : 5.10.0-20-amd64
     Basic Network Info
     ISP                : Redoubt Networks
     ASN                : AS400304 REDOUBT NETWORKS
     Host               : Redoubt Networks
     ISP: Crunchbits, LLC
     Nearest          10.54 ms    0.0%    952.08 Mbps    1007.93 Mbps   Intechtel - Managed IT Services - Coeur d'Alene, ID
     Kochi, IN        220.53 ms   0.0%    569.88 Mbps    381.11 Mbps    Asianet Broadband - Cochin
     Bangalore, IN    235.23 ms   0.0%    786.05 Mbps    383.52 Mbps    Bharti Airtel Ltd - Bangalore
     Chennai, IN      265.67 ms   N/A     858.41 Mbps    419.05 Mbps    Jio - Chennai
     Mumbai, IN       252.60 ms   0.0%    895.17 Mbps    329.91 Mbps    i3D.net - Mumbai
     Delhi, IN        284.58 ms   0.0%    604.27 Mbps    320.39 Mbps    Tata Teleservices Ltd - New Delhi
     Seattle, US      10.43 ms    0.0%    933.20 Mbps    1006.15 Mbps   Ziply Fiber - Seattle, WA
     Los Angeles, US  35.99 ms    0.0%    924.93 Mbps    1004.67 Mbps   ReliableSite Hosting - Los Angeles, CA
     Dallas, US       68.62 ms    0.0%    921.11 Mbps    1076.63 Mbps   Hivelocity - Dallas, TX
     Miami, US        91.49 ms    0.0%    890.76 Mbps    1102.61 Mbps   AT&T - Miami, FL
     New York, US     82.38 ms    0.0%    920.75 Mbps    1007.38 Mbps   GSL Networks - New York, NY
     Toronto, CA      77.72 ms    0.0%    930.89 Mbps    1020.01 Mbps   Rogers - Toronto, ON
     London, UK       134.74 ms   0.0%    947.63 Mbps    828.63 Mbps    VeloxServ Communications - London
     Amsterdam, NL    138.98 ms   0.0%    989.63 Mbps    704.61 Mbps    31173 Services AB - Amsterdam
     Paris, FR        140.73 ms   N/A     979.15 Mbps    728.57 Mbps    Axione - Paris
     Frankfurt, DE    146.77 ms   0.0%    930.31 Mbps    558.13 Mbps    23M GmbH - Frankfurt am Main
     Warsaw, PL       191.45 ms   0.0%    816.79 Mbps    481.45 Mbps    UPC Polska - Warszawa
     Bucharest, RO    176.74 ms   0.0%    938.44 Mbps    281.38 Mbps    Vodafone Romania Fixed – Bucharest - Bucharest
     Jeddah, SA       208.59 ms   0.0%    923.50 Mbps    551.61 Mbps    Saudi Telecom Company
     Dubai, AE        247.34 ms   0.0%    875.58 Mbps    471.15 Mbps    du - Dubai
     Fujairah, AE     247.92 ms   0.0%    927.08 Mbps    434.87 Mbps    ETISALAT-UAE - Fujairah
     Tokyo, JP        114.99 ms   N/A     928.74 Mbps    702.23 Mbps    fdcservers.net - Tokyo
     Shanghai, CU-CN  189.86 ms   0.0%    575.92 Mbps    573.75 Mbps    China Unicom 5G - Shanghai
     Nanjing, CT-CN   177.71 ms   0.0%    855.74 Mbps    3.38 Mbps      China Telecom JiangSu 5G - Nanjing
     Hong Kong, CN    156.75 ms   N/A     928.06 Mbps    588.87 Mbps    STC - Hong Kong
     Singapore, SG    168.79 ms   0.0%    935.54 Mbps    549.73 Mbps    i3D.net - Singapore
     Jakarta, ID      201.46 ms   0.0%    616.75 Mbps    216.35 Mbps    PT. Telekomunikasi Indonesia - Jakarta
     Avg DL Speed       : 865.04 Mbps
     Avg UL Speed       : 619.78 Mbps
     Total DL Data      : 34.17 GB
     Total UL Data      : 23.66 GB
     Total Data         : 57.83 GB
     Duration           : 14 min 2 sec
     System Time        : 19/09/2023 - 13:40:35 WIB
     Total Script Runs  : 23566
     Result             : https://result.network-speed.xyz/r/1695105636_FCDSD4_GLOBAL.txt
    >  Basic System Info
    >  AES-NI             : ✔ Enabled
    >  Basic Network Info
    >  Location           : Spokane, Washington-WA, United States
    Thanked by (1)nyamenk
    > >  Basic System Info
    > >  AES-NI             : ✔ Enabled
    > >  Basic Network Info
    You guys want Indonesia added as a region? 😄
    > > >  Basic System Info
    > > >  AES-NI             : ✔ Enabled
    > > >  Basic Network Info
    Hahaha... lets gooooooo ;)
    > > > >  Basic System Info
    > > > >  AES-NI             : ✔ Enabled
    > > > >  Basic Network Info
    Let me see if I can do it over the weekend :)
  • Hosthatch BF2021 Flash — Storage 2TB
     Basic System Info
     CPU Model          : AMD EPYC 7551P 32-Core Processor
     CPU Cores          : 2 @ 1999.999 MHz
     CPU Cache          : 512 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 1.8 TB (1.1 TB Used)
     Total RAM          : 1.9 GB (378.8 MB Used)
     Total Swap         : 2.0 GB (0 Used)
     System uptime      : 0 days, 3 hour 15 min
     Load average       : 0.00, 0.00, 0.00
     Kernel             : 5.10.0-25-amd64
     Basic Network Info
     ISP                : HostHatch
     ASN                : AS63473 HostHatch, LLC
     Host               : HostHatch LLC
     ISP: HostHatch
     Nearest          0.62 ms     0.0%    6240.98 Mbps   9258.80 Mbps   Tele2 Sweden - Kista
     Kochi, IN        163.51 ms   0.0%    3459.59 Mbps   505.60 Mbps    Asianet Broadband - Cochin
     Bangalore, IN    157.27 ms   0.0%    4269.84 Mbps   555.45 Mbps    Bharti Airtel Ltd - Bangalore
     Chennai, IN      149.76 ms   N/A     4525.62 Mbps   537.38 Mbps    Jio - Chennai
     Mumbai, IN       152.70 ms   0.0%    3183.11 Mbps   483.22 Mbps    i3D.net - Mumbai
     Delhi, IN        166.55 ms   0.0%    2386.76 Mbps   538.21 Mbps    Tata Teleservices Ltd - New Delhi
     Seattle, US      160.88 ms   0.0%    2114.56 Mbps   691.41 Mbps    Ziply Fiber - Seattle, WA
     Los Angeles, US  160.20 ms   0.0%    2516.21 Mbps   442.35 Mbps    ReliableSite Hosting - Los Angeles, CA
     Dallas, US       133.10 ms   0.0%    3780.79 Mbps   567.07 Mbps    Hivelocity - Dallas, TX
     Miami, US        128.19 ms   6.0%    2017.95 Mbps   3.27 Mbps      AT&T - Miami, FL
     New York, US     97.69 ms    0.0%    6205.68 Mbps   1135.34 Mbps   GSL Networks - New York, NY
     Toronto, CA      120.76 ms   0.0%    6601.93 Mbps   781.37 Mbps    Rogers - Toronto, ON
     London, UK       28.41 ms    0.0%    6524.53 Mbps   3579.08 Mbps   VeloxServ Communications - London
     Amsterdam, NL    25.97 ms    0.0%    5336.11 Mbps   2836.83 Mbps   31173 Services AB - Amsterdam
     Paris, FR        37.62 ms    N/A     3725.22 Mbps   849.03 Mbps    Axione - Paris
     Frankfurt, DE    18.46 ms    0.0%    4379.59 Mbps   3510.33 Mbps   23M GmbH - Frankfurt am Main
     Warsaw, PL       38.16 ms    1.1%    4081.53 Mbps   2325.22 Mbps   UPC Polska - Warszawa
     Bucharest, RO    53.56 ms    0.0%    4988.48 Mbps   1630.87 Mbps   Vodafone Romania Fixed – Bucharest - Bucharest
     Jeddah, SA       90.62 ms    0.0%    4786.41 Mbps   1178.51 Mbps   Saudi Telecom Company
     Dubai, AE        147.82 ms   0.0%    3991.91 Mbps   729.28 Mbps    du - Dubai
     Fujairah, AE     137.75 ms   0.0%    4130.51 Mbps   794.62 Mbps    ETISALAT-UAE - Fujairah
     Tokyo, JP        267.73 ms   N/A     1947.21 Mbps   90.19 Mbps     fdcservers.net - Tokyo
     Shanghai, CU-CN  256.83 ms   0.0%    2009.09 Mbps   398.73 Mbps    China Unicom 5G - Shanghai
     Nanjing, CT-CN   246.91 ms   0.0%    1459.67 Mbps   21.80 Mbps     China Telecom JiangSu 5G - Nanjing
     Hong Kong, CN    176.75 ms   N/A     2840.21 Mbps   525.57 Mbps    STC - Hong Kong
     Singapore, SG    223.52 ms   0.0%    3393.19 Mbps   428.32 Mbps    i3D.net - Singapore
     Jakarta, ID      212.10 ms   0.0%    3463.22 Mbps   76.31 Mbps     PT. Telekomunikasi Indonesia - Jakarta
     Avg DL Speed       : 3865.19 Mbps
     Avg UL Speed       : 1276.82 Mbps
     Total DL Data      : 146.80 GB
     Total UL Data      : 45.67 GB
     Total Data         : 192.47 GB
     Duration           : 14 min 41 sec
     System Time        : 20/09/2023 - 03:00:55 UTC
     Total Script Runs  : 23655
     Result             : https://result.network-speed.xyz/r/1695178862_INCAYH_GLOBAL.txt
  • Virmach
     Basic System Info
     CPU Cores          : 1 @ 3799.948 MHz
     CPU Cache          : 512 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 913.4 GB (769.8 GB Used)
     Total RAM          : 976.4 MB (398.4 MB Used)
     Total Swap         : 975.0 MB (709.2 MB Used)
     System uptime      : 9 days, 0 hour 41 min
     Load average       : 0.00, 0.05, 0.17
     Kernel             : 5.10.0-16-amd64
     Basic Network Info
     ISP                : WorldStream B.V.
     ASN                : AS212477 RoyaleHosting BV
     Host               : Sheimo Scorpion Data AB
     Location (IPv4)    : Los Angeles, California, US
     ISP: WorldStream B.V.
     Nearest          88.44 ms    0.0%    2507.31 Mbps   887.96 Mbps    Telenor AB - Stockholm
     Kochi, IN        246.24 ms   0.0%    1166.30 Mbps   311.71 Mbps    Asianet Broadband - Cochin
     Bangalore, IN    210.86 ms   0.0%    1164.58 Mbps   402.63 Mbps    Bharti Airtel Ltd - Bangalore
     Chennai, IN      213.66 ms   N/A     1197.81 Mbps   391.89 Mbps    Jio - Chennai
     Mumbai, IN       216.77 ms   0.0%    1074.82 Mbps   291.60 Mbps    i3D.net - Mumbai
     Delhi, IN        241.15 ms   0.0%    1471.33 Mbps   360.86 Mbps    Tata Teleservices Ltd - New Delhi
     Seattle, US      71.13 ms    0.0%    3327.81 Mbps   852.83 Mbps    Ziply Fiber - Seattle, WA
     Los Angeles, US  54.37 ms    0.0%    2798.40 Mbps   882.73 Mbps    ReliableSite Hosting - Los Angeles, CA
     Dallas, US       34.38 ms    0.0%    3157.76 Mbps   918.12 Mbps    Hivelocity - Dallas, TX
     Miami, US        43.06 ms    0.0%    3092.45 Mbps   907.59 Mbps    AT&T - Miami, FL
     New York, US     0.20 ms     0.0%    1875.81 Mbps   939.60 Mbps    GSL Networks - New York, NY
     Toronto, CA      19.40 ms    0.0%    3555.93 Mbps   930.63 Mbps    Rogers - Toronto, ON
     London, UK       66.70 ms    0.0%    2522.52 Mbps   817.49 Mbps    VeloxServ Communications - London
     Amsterdam, NL    72.08 ms    0.0%    2538.48 Mbps   870.36 Mbps    31173 Services AB - Amsterdam
     Paris, FR        FAILED
     Frankfurt, DE    77.12 ms    0.0%    1758.21 Mbps   838.36 Mbps    23M GmbH - Frankfurt am Main
     Warsaw, PL       94.19 ms    0.0%    1981.14 Mbps   868.12 Mbps    UPC Polska - Warszawa
     Bucharest, RO    109.10 ms   0.0%    1680.96 Mbps   663.54 Mbps    Vodafone Romania Fixed – Bucharest - Bucharest
     Jeddah, SA       141.81 ms   0.0%    1936.94 Mbps   623.26 Mbps    Saudi Telecom Company
     Dubai, AE        188.35 ms   0.0%    1443.59 Mbps   472.73 Mbps    du - Dubai
     Fujairah, AE     246.59 ms   0.0%    2059.15 Mbps   402.63 Mbps    ETISALAT-UAE - Fujairah
     Tokyo, JP        156.86 ms   N/A     1161.31 Mbps   529.39 Mbps    fdcservers.net - Tokyo
     Shanghai, CU-CN  297.86 ms   0.0%    24.98 Mbps     245.40 Mbps    China Unicom 5G - Shanghai
     Nanjing, CT-CN   227.31 ms   41.7%   1557.99 Mbps   82.10 Mbps     China Telecom JiangSu 5G - Nanjing
     Hong Kong, CN    222.94 ms   N/A     667.18 Mbps    394.54 Mbps    STC - Hong Kong
     Singapore, SG    219.69 ms   0.0%    1177.89 Mbps   391.88 Mbps    i3D.net - Singapore
     Jakarta, ID      250.43 ms   0.0%    931.81 Mbps    122.48 Mbps    PT. Telekomunikasi Indonesia - Jakarta
     Avg DL Speed       : 1839.71 Mbps
     Avg UL Speed       : 592.32 Mbps
     Total DL Data      : 68.90 GB
     Total UL Data      : 20.67 GB
     Total Data         : 89.56 GB
     Duration           : 13 min 39 sec
     System Time        : 20/09/2023 - 12:06:24 WIB
     Total Script Runs  : 23659
     Result             : https://result.network-speed.xyz/r/1695186386_AH8MKH_GLOBAL.txt
  • @sh97 said:
    Selamat malam @nyamenk @Ganonk
    Coming in a few hours!
    Lololo ga bahaya ta ;)
    Selamat malam juga @sh97
    Thanked by (2)sh97 Ganonk
  • Updated to v2023.09.22
    * Update broken servers
    * Add new region: Indonesia
     Version            : v2023.09.22
     Basic System Info
     CPU Model          : Intel(R) Xeon(R) CPU E5-2698 v4 @ 2.20GHz
     CPU Cores          : 4 @ 2199.986 MHz
     AES-NI             : ✔ Enabled
     Total Disk         : 55.1 GB (33.2 GB Used)
     Total RAM          : 7.8 GB (498.8 MB Used)
     Total Swap         : 4.0 GB (0 Used)
     System uptime      : 22 days, 7 hour 19 min
     Load average       : 0.38, 0.29, 0.17
     Kernel             : 5.15.0-82-generic
     Basic Network Info
     ISP                : Leaseweb Singapore
     ASN                : AS59253 Leaseweb Asia Pacific pte. ltd.
     Host               : Leaseweb Asia Pacific pte. ltd
     Speedtest.net (Region: INDONESIA)
     ISP: Leaseweb Asia
     Nearest          0.84 ms     0.0%    5849.82 Mbps   8091.28 Mbps   MyRepublic Singapore - Singapore
     Jakarta          46.32 ms    0.0%    856.38 Mbps    301.16 Mbps    Hutchison 3 Indonesia  CGK-MM - Jakarta
     Jakarta          13.10 ms    0.0%    2331.45 Mbps   221.71 Mbps    DomaiNesia - Jakarta
     Jakarta          16.30 ms    0.0%    2591.35 Mbps   703.08 Mbps    PT. Telekomunikasi Indonesia - Jakarta
     Jakarta          12.30 ms    0.0%    3331.01 Mbps   4519.83 Mbps   PT Indosat Tbk - Jakarta
     Jakarta          17.60 ms    0.0%    1341.44 Mbps   3725.87 Mbps   MyRepublic Indonesia - South Jakarta
     Bandung          17.58 ms    N/A     270.68 Mbps    231.93 Mbps    HYPERNET - Bandung
     Bekasi           13.41 ms    0.0%    889.68 Mbps    537.63 Mbps    PT Lintas Jaringan Nusantara - Bekasi
     Bogor            14.42 ms    0.0%    930.01 Mbps    383.15 Mbps    PT. Java Digital Nusantara - Bogor
     Malang           25.44 ms    0.0%    1299.41 Mbps   813.30 Mbps    GlobalXtreme - Malang
     Semarang         21.36 ms    N/A     7616.98 Mbps   3287.08 Mbps   PT. Indonesia Comnets Plus - Semarang
     Surabaya         24.59 ms    N/A     3092.44 Mbps   2704.08 Mbps   PT. Indonesia Comnets Plus - Surabaya
     Yogyakarta       23.63 ms    0.6%    762.81 Mbps    149.85 Mbps    PT Union Routelink Communication - Yogyakarta
     Banda Aceh       18.43 ms    0.0%    2863.06 Mbps   726.63 Mbps    PT. Telekomunikasi Indonesia - Banda Aceh
     Medan            13.40 ms    3.2%    3871.59 Mbps   125.65 Mbps    Biznet Networks - Medan
     Palembang        11.51 ms    N/A     657.00 Mbps    601.05 Mbps    PT. Sakti Putra Mandiri - Palembang
     Pekanbaru        28.68 ms    0.0%    566.86 Mbps    95.70 Mbps     PT Hexa Media Sarana - Pekanbaru
     Bali             32.22 ms    0.0%    2930.45 Mbps   2605.09 Mbps   Biznet Networks - Bali
     Makassar         57.90 ms    25.4%   754.02 Mbps    0.72 Mbps      Biznet Networks - Makassar
     Depok            18.19 ms    19.1%   523.84 Mbps    4.51 Mbps      ADI - Depok
     Tangerang        12.88 ms    0.0%    891.87 Mbps    103.94 Mbps    PT. Java Medianet Tekhnologi - Tangerang
     Avg DL Speed       : 2105.81 Mbps
     Avg UL Speed       : 1425.39 Mbps
     Total DL Data      : 56.82 GB
     Total UL Data      : 33.89 GB
     Total Data         : 90.70 GB
     System Time        : 22/09/2023 - 20:00:39 IST
     Total Script Runs  : 23823
     Result             : https://result.network-speed.xyz/r/1695393041_9GD26Z_INDONESIA.txt
    Thanked by (2)nyamenk Ganonk
     Basic System Info
     AES-NI             : ✔ Enabled
     Total Disk         : 125.0 GB (9.4 GB Used)
     Total RAM          : 4.3 GB (1.2 GB Used)
     Total Swap         : 2.0 GB (117.8 MB Used)
     System uptime      : 5 days, 7 hour 13 min
     Basic Network Info
     Nearest          10.39 ms    0.0%    949.60 Mbps    1008.43 Mbps   Intechtel - Managed IT Services - Coeur d'Alene, ID
     Jakarta          179.23 ms   0.0%    941.27 Mbps    217.74 Mbps    Hutchison 3 Indonesia  CGK-MM - Jakarta
     Jakarta          219.75 ms   0.0%    795.81 Mbps    71.23 Mbps     DomaiNesia - Jakarta
     Jakarta          200.84 ms   0.0%    519.11 Mbps    195.66 Mbps    PT. Telekomunikasi Indonesia - Jakarta
     Jakarta          187.93 ms   0.0%    614.11 Mbps    363.16 Mbps    PT Indosat Tbk - Jakarta
     Jakarta          218.57 ms   0.3%    640.73 Mbps    46.84 Mbps     MyRepublic Indonesia - South Jakarta
     Bandung          201.12 ms   N/A     256.47 Mbps    30.88 Mbps     HYPERNET - Bandung
     Bekasi           190.97 ms   0.0%    696.64 Mbps    201.47 Mbps    PT Lintas Jaringan Nusantara - Bekasi
     Bogor            197.41 ms   0.6%    21.30 Mbps     248.48 Mbps    PT. Java Digital Nusantara - Bogor
     Malang           209.90 ms   0.0%    834.74 Mbps    263.06 Mbps    GlobalXtreme - Malang
     Semarang         184.05 ms   N/A     796.34 Mbps    487.66 Mbps    PT. Indonesia Comnets Plus - Semarang
     Surabaya         211.94 ms   N/A     955.34 Mbps    460.17 Mbps    PT. Indonesia Comnets Plus - Surabaya
     Yogyakarta       262.05 ms   0.3%    684.40 Mbps    85.15 Mbps     PT Union Routelink Communication - Yogyakarta
     Banda Aceh       203.89 ms   0.0%    701.19 Mbps    440.94 Mbps    PT. Telekomunikasi Indonesia - Banda Aceh
     Medan            182.10 ms   1.3%    818.12 Mbps    26.03 Mbps     Biznet Networks - Medan
     Palembang        218.60 ms   N/A     338.26 Mbps    7.93 Mbps      PT. Sakti Putra Mandiri - Palembang
     Pekanbaru        189.28 ms   3.4%    451.81 Mbps    39.69 Mbps     PT Hexa Media Sarana - Pekanbaru
     Bali             207.62 ms   N/A     895.26 Mbps    0.53 Mbps      Biznet Networks - Bali
     Makassar         241.44 ms   N/A     27.76 Mbps     0.57 Mbps      Biznet Networks - Makassar
     Depok            197.05 ms   9.7%    483.11 Mbps    3.06 Mbps      ADI - Depok
     Tangerang        200.85 ms   0.0%    930.88 Mbps    72.51 Mbps     PT. Java Medianet Tekhnologi - Tangerang
     Avg DL Speed       : 635.83 Mbps
     Avg UL Speed       : 203.39 Mbps
     Total DL Data      : 19.25 GB
     Total UL Data      : 7.87 GB
     Total Data         : 27.12 GB
     Duration           : 11 min 22 sec
     System Time        : 22/09/2023 - 22:04:20 WIB
     Total Script Runs  : 23825
     Result             : https://result.network-speed.xyz/r/1695395060_N5BM87_INDONESIA.txt
  • Virmach Free
     Basic System Info
     CPU Cache          : 512 KB
     AES-NI             : ✔ Enabled
     Total RAM          : 976.4 MB (367.3 MB Used)
     Total Swap         : 975.0 MB (720.7 MB Used)
     System uptime      : 11 days, 10 hour 56 min
     Load average       : 0.13, 0.41, 0.33
     Basic Network Info
     Nearest          88.47 ms    0.0%    2391.63 Mbps   895.69 Mbps    Telenor AB - Stockholm
     Jakarta          231.49 ms   0.0%    905.87 Mbps    381.29 Mbps    Hutchison 3 Indonesia  CGK-MM - Jakarta
     Jakarta          237.54 ms   0.7%    451.80 Mbps    63.70 Mbps     DomaiNesia - Jakarta
     Jakarta          258.92 ms   0.0%    1182.44 Mbps   165.62 Mbps    PT. Telekomunikasi Indonesia - Jakarta
     Jakarta          249.54 ms   0.0%    1036.18 Mbps   107.35 Mbps    PT Indosat Tbk - Jakarta
     Jakarta          337.45 ms   0.0%    722.12 Mbps    335.17 Mbps    MyRepublic Indonesia - South Jakarta
     Bandung          239.16 ms   N/A     250.07 Mbps    32.19 Mbps     HYPERNET - Bandung
     Bekasi           239.30 ms   0.0%    570.55 Mbps    218.28 Mbps    PT Lintas Jaringan Nusantara - Bekasi
     Bogor            235.32 ms   0.3%    51.23 Mbps     246.86 Mbps    PT. Java Digital Nusantara - Bogor
     Malang           252.15 ms   0.0%    460.85 Mbps    336.76 Mbps    GlobalXtreme - Malang
     Semarang         256.61 ms   N/A     919.02 Mbps    340.09 Mbps    PT. Indonesia Comnets Plus - Semarang
     Surabaya         259.73 ms   N/A     981.12 Mbps    339.24 Mbps    PT. Indonesia Comnets Plus - Surabaya
     Yogyakarta       242.62 ms   0.0%    821.04 Mbps    71.73 Mbps     PT Union Routelink Communication - Yogyakarta
     Banda Aceh       254.41 ms   0.0%    1163.11 Mbps   320.41 Mbps    PT. Telekomunikasi Indonesia - Banda Aceh
     Medan            251.91 ms   6.7%    1011.20 Mbps   1.01 Mbps      Biznet Networks - Medan
     Palembang        237.88 ms   N/A     941.59 Mbps    358.09 Mbps    PT. Sakti Putra Mandiri - Palembang
     Pekanbaru        244.76 ms   0.0%    573.56 Mbps    86.92 Mbps     PT Hexa Media Sarana - Pekanbaru
     Bali             298.72 ms   0.7%    968.90 Mbps    129.00 Mbps    Biznet Networks - Bali
     Makassar         234.68 ms   0.0%    503.18 Mbps    172.80 Mbps    Biznet Networks - Makassar
     Depok            243.55 ms   0.0%    269.78 Mbps    22.21 Mbps     ADI - Depok
     Tangerang        231.83 ms   2.0%    725.60 Mbps    4.71 Mbps      PT. Java Medianet Tekhnologi - Tangerang
     Avg DL Speed       : 804.80 Mbps
     Avg UL Speed       : 220.43 Mbps
     Total DL Data      : 23.62 GB
     Total UL Data      : 6.24 GB
     Total Data         : 29.86 GB
     Duration           : 11 min 43 sec
     System Time        : 22/09/2023 - 22:19:02 WIB
     Total Script Runs  : 23826
     Result             : https://result.network-speed.xyz/r/1695395943_ZC1Z7E_INDONESIA.txt
