https://buyvm.net offers unmetered transfer and they are very good. Stock is hard to find, but they normally have some around the 7th of the month after they release the cancellations. Although I would suggest you double check their AUP about torrenting.
@FrankZ said: https://buyvm.net offers unmetered transfer and they are very good. Stock is hard to find, but they normally have some around the 7th of the month after they release the cancellations. Although I would suggest you double check their AUP about torrenting.
Yes, 4GB and under have 1 Ryzen core, 8GB has 2 Ryzen cores. It should be noted that the cores are dedicated so you can use them at 100% all the time. Since you're new, please consider cores offered by LES providers to be fair share, unless stated as dedicated in their offer threads.
Another one with unmetered transfer and dedicated cores is Wishosting. Latest offer here once again it has only two cores i7-8700 CPU @ 3.20GHz, but you can use them at 100% all the time.
Also going to tag @Calin who is in Romania and might have a small dedicated server at a reasonable price. IIRC he was offering 56TB upload and 56TB download with that dedi.
Yes, there are.
I've put the same effort into my post that you put in yours, don't be mad.
I am new bro what more do you expect from me? there was no template for me to write or something
Sadly all have only 1 core
rdp.sh has 5gbit unmetered for $10. I've actually used that 5gbit to it's fullest for a few months and can confirm it's unmetered.
Okay thanks man I will look into it
Ok Bro I will check it
Thanks
https://www.serverhunter.com/
Since you'll be distributing copyright content, your options will be limited.
ExtraVM - High RAM Specials
Yours truly.
Thanks for mention @FrankZ , check https://panel.ihostart.com/index.php?rp=/store/storage it's dedicated port speed
200 mbit 24/7 it's approx 60 TB Bw/month and we have ignore DMCA
Regards
i see so its better to get a seedbox then?
wish 9$ had 4gig of ram
also all are out of stock
yeah real help
