I tried again and on another 2 machines. (Scaleway and Limitlesshost)
From the looks of it, its random if I get the script as response or an empty response.
Something is definitely broken.
Ah, I think I found the issue.
I can see requests from AS12876 Online SAS (looks like Scaleway) being rate-limited by Cloudflare.
I did add rate limiting last month or so, because someone had a misconfigured cron which was running every second for the first 2 minutes, every hour (60req/min) and all these tests used to be completed.
I think eventually Oookla noticed it, because now you can do only 30-32 tests in an hour.
Or did you have any instances were it did not run at all on the first try?
I did play around with my serverfactory SE and F4 Networks US v6 only VPS, but was not able to find this problem. I'll keep looking.
Thanks for letting me know!
So, the thing is, it does not always tell me I am getting rate limited.
Its just an empty response.
Sometimes Cloudflare does return a 1015 Error, only sometimes.
So I assume, that if I get an empty response, I am not getting rate limited, thus there is a issue.
Pretty sure it didn't run at first try on my Limitlesshost, hence I posted.
Version : v2023.09.04
Global Speedtest : wget -qO- network-speed.xyz | bash
Region Speedtest : wget -qO- network-speed.xyz | bash -s -- -r
Basic System Info
CPU Model : AMD EPYC 7713 64-Core Processor
CPU Cores : 4 @ 1999.998 MHz
CPU Cache : 512 KB
AES-NI : ✔ Enabled
Total Disk : 38.3 GB (4.9 GB Used)
Total RAM : 7.8 GB (191.8 MB Used)
Total Swap : 1022.0 MB (0 Used)
System uptime : 0 days, 1 hour 37 min
Load average : 0.03, 0.15, 0.71
OS : Ubuntu 22.04.3 LTS
Arch : x86_64 (64 Bit)
Kernel : 5.15.0-83-generic
Virtualization : KVM
Basic Network Info
Primary Network : IPv4
ISP : DataWagon LLC
ASN : AS27176 DataWagon LLC
Host : DataWagon LLC
Speedtest.net (Region: NORTH AMERICA)
Location Latency Loss DL Speed UP Speed Server
ISP: DataWagon LLC
Nearest 11.09 ms 0.0% 941.73 Mbps 941.62 Mbps Spectrum - New York, NY
Vancouver, BC 131.18 ms N/A 943.35 Mbps 600.54 Mbps TELUS - Vancouver, BC
Calgary, AB 65.30 ms N/A 958.41 Mbps 745.08 Mbps Shaw Communications - Calgary, AB
Winnipeg, MB 30.96 ms 0.0% 956.48 Mbps 913.72 Mbps Voyageur Internet - Winnipeg, MB
Toronto, ON 88.12 ms 0.0% 946.07 Mbps 821.32 Mbps Bell Canada - Toronto, ON
Montreal, QC 83.62 ms 0.0% 941.03 Mbps 809.48 Mbps Rogers Wireless - Montréal, QC
New York, NY 13.79 ms 0.0% 955.82 Mbps 941.44 Mbps Surfshark Ltd - New York, NY
Ashburn, VA 17.57 ms 0.0% 941.77 Mbps 941.51 Mbps Rackdog - Ashburn, VA
Charlotte, NC 31.13 ms 0.0% 957.09 Mbps 937.72 Mbps Windstream - Charlotte, NC
Atlanta, GA FAILED
Miami, FL 46.12 ms 0.0% 956.78 Mbps 862.38 Mbps AT&T - Miami, FL
Dallas, TX 109.84 ms 0.0% 921.47 Mbps 701.16 Mbps Hivelocity - Dallas, TX
Houston, TX 48.40 ms 0.0% 956.50 Mbps 817.76 Mbps Ezee Fiber - Houston, TX
Kansas, MO 25.44 ms 0.0% 955.37 Mbps 911.40 Mbps Xiber LLC - Kansas City, MO
Minneapolis, MN 20.69 ms 0.0% 956.63 Mbps 941.75 Mbps US Internet - Minneapolis, MN
Chicago, IL 95.62 ms 0.0% 929.85 Mbps 813.57 Mbps Enzu.com - Chicago, IL
Cleveland, OH 25.44 ms 0.0% 955.59 Mbps 934.11 Mbps Windstream - Cleveland, OH
Albuquerque, NM 119.65 ms N/A 937.55 Mbps 667.98 Mbps Comcast - Albuquerque, NM
Denver, CO 109.56 ms 0.0% 943.72 Mbps 705.62 Mbps T-Mobile Fiber | Intrepid - Denver, CO
Portland, OR 86.35 ms N/A 981.92 Mbps 826.34 Mbps CenturyLink - Portland, OR
Las Vegas, NV 67.10 ms N/A 963.21 Mbps 719.28 Mbps Dish Wireless - Las Vegas, NV
Salt Lake, UT 139.85 ms N/A 829.85 Mbps 399.63 Mbps Novva Data Centers - Salt Lake City, UT
Phoenix, AZ 57.09 ms 0.0% 958.49 Mbps 771.00 Mbps Xiber LLC - Phoenix, AZ
Los Angeles, CA 133.63 ms 0.0% 929.22 Mbps 562.70 Mbps ReliableSite Hosting - Los Angeles, CA
Santa Clara, CA 60.25 ms 0.0% 954.31 Mbps 790.17 Mbps AT&T - Santa Clara, CA
San Jose, CA 138.49 ms 0.0% 790.05 Mbps 572.99 Mbps Misaka Network, Inc. - San Jose, CA
Seattle, WA 139.63 ms 0.0% 173.73 Mbps 539.98 Mbps Misaka Network, Inc. - Seattle, WA
Hermosillo, MX 158.53 ms 0.0% 645.92 Mbps 463.18 Mbps Megacable - Hermosillo
Guadalajara, MX 83.33 ms 0.0% 951.14 Mbps 801.89 Mbps AT&T México - Guadalajara
Mexico City, MX FAILED
Merida, MX 137.98 ms 0.0% 934.24 Mbps 578.19 Mbps Totalplay - Mérida
Avg DL Speed : 902.31 Mbps
Avg UL Speed : 759.78 Mbps
Total DL Data : 36.14 GB
Total UL Data : 28.15 GB
Total Data : 64.29 GB
Duration : 13 min 52 sec
System Time : 13/09/2023 - 05:08:31 UTC
Total Script Runs : 23087
Result : https://paste.kangserver.id/view/SShGaLo
---------------------------- network-speed.xyz ----------------------------
A simple script to test network performance using speedtest-cli
Region Speedtest : wget -qO- network-speed.xyz | bash -s -- -r <region>
Basic System Info
CPU Model : AMD Ryzen 5 3600 6-Core Processor
CPU Cores : 1 @ 3593.248 MHz
CPU Cache : 512 KB
AES-NI : ✔ Enabled
Total Disk : 9.8 GB (2.5 GB Used)
Total RAM : 3.8 GB (296.5 MB Used)
Total Swap : 1024.0 MB (0 Used)
System uptime : 0 days, 0 hour 24 min
Load average : 0.15, 0.53, 0.44
OS : Debian GNU/Linux 12
Kernel : 6.1.0-10-amd64
Basic Network Info
Primary Network : IPv6
ISP : AEZA GROUP Ltd
ASN : AS210644 AEZA GROUP Ltd
Host : Aeza Network Stockholm
Location (IPv4) : Herräng, Stockholm, SE
ISP: AEZA GROUP Ltd
Nearest 6.83 ms N/A 97.00 Mbps 102.96 Mbps Netprotect - Stockholm
Kochi, IN 221.14 ms 1.7% 85.48 Mbps 105.60 Mbps Asianet Broadband - Cochin
Bangalore, IN 188.10 ms 2.0% 95.08 Mbps 105.34 Mbps Bharti Airtel Ltd - Bangalore
Chennai, IN 216.17 ms N/A 92.16 Mbps 93.81 Mbps Jio - Chennai
Mumbai, IN 158.00 ms 1.9% 96.23 Mbps 93.51 Mbps i3D.net - Mumbai
Delhi, IN 169.98 ms 2.1% 90.45 Mbps 101.05 Mbps Tata Teleservices Ltd - New Delhi
Seattle, US 153.62 ms 2.6% 90.31 Mbps 96.05 Mbps Ziply Fiber - Seattle, WA
Los Angeles, US 158.51 ms 1.5% 96.81 Mbps 107.13 Mbps ReliableSite Hosting - Los Angeles, CA
Dallas, US 127.21 ms 2.0% 33.51 Mbps 104.41 Mbps Hivelocity - Dallas, TX
Miami, US 196.68 ms 0.7% 102.90 Mbps 109.60 Mbps AT&T - Miami, FL
New York, US 176.65 ms 0.0% 106.26 Mbps 104.78 Mbps GSL Networks - New York, NY
Toronto, CA 190.75 ms 0.0% 101.07 Mbps 105.47 Mbps Rogers - Toronto, ON
London, UK 36.13 ms 1.6% 94.38 Mbps 101.29 Mbps VeloxServ Communications - London
Amsterdam, NL 27.16 ms 0.0% 97.75 Mbps 102.58 Mbps 31173 Services AB - Amsterdam
Paris, FR 38.52 ms N/A 99.06 Mbps 102.78 Mbps Axione - Paris
Frankfurt, DE 24.36 ms 1.8% 93.71 Mbps 103.53 Mbps 23M GmbH - Frankfurt am Main
Warsaw, PL 31.18 ms 1.7% 86.71 Mbps 100.50 Mbps UPC Polska - Warszawa
Bucharest, RO 57.04 ms 0.0% 98.01 Mbps 104.21 Mbps Vodafone Romania Fixed – Bucharest - Bucharest
Jeddah, SA 96.38 ms 0.0% 98.37 Mbps 103.13 Mbps Saudi Telecom Company
Dubai, AE 151.83 ms 0.0% 103.29 Mbps 108.35 Mbps du - Dubai
Fujairah, AE 140.22 ms 0.0% 108.70 Mbps 100.91 Mbps ETISALAT-UAE - Fujairah
Tokyo, JP 271.95 ms N/A 99.15 Mbps 110.98 Mbps fdcservers.net - Tokyo
Shanghai, CU-CN 275.11 ms 0.0% 97.97 Mbps 109.53 Mbps China Unicom 5G - Shanghai
Nanjing, CT-CN 245.37 ms 0.0% 98.03 Mbps 2.73 Mbps China Telecom JiangSu 5G - Nanjing
Hong Kong, CN 260.31 ms N/A 104.85 Mbps 93.58 Mbps STC - Hong Kong
Singapore, SG 294.47 ms 7.1% 102.65 Mbps 102.09 Mbps i3D.net - Singapore
Jakarta, ID 201.31 ms 1.4% 86.19 Mbps 98.96 Mbps PT. Telekomunikasi Indonesia - Jakarta
Avg DL Speed : 94.67 Mbps
Avg UL Speed : 99.07 Mbps
Total DL Data : 3.45 GB
Total UL Data : 3.76 GB
Total Data : 7.22 GB
Duration : 13 min 18 sec
System Time : 14/09/2023 - 19:02:44 CEST
Total Script Runs : 23172
Result : https://result.network-speed.xyz/r/1694710966_THYRYU_GLOBAL.txt
Basic System Info
CPU Cache : 512 KB
AES-NI : ✔ Enabled
Basic Network Info
ISP: AEZA GROUP Ltd
Basic System Info
CPU Model : AMD EPYC-Milan Processor
CPU Cores : 1 @ 1999.998 MHz
CPU Cache : 512 KB
AES-NI : ✔ Enabled
Total Disk : 9.8 GB (697.5 MB Used)
Total RAM : 878.0 MB (193.5 MB Used)
System uptime : 0 days, 0 hour 31 min
Load average : 0.05, 0.20, 0.10
Kernel : 6.1.0-9-cloud-amd64
Virtualization : MICROSOFT
Basic Network Info
ISP : Strato AG
ASN : AS6724 Strato AG
Host : Strato AG
ISP: Strato AG
Nearest 9.30 ms 0.0% 1921.91 Mbps 1901.28 Mbps LWLcom GmbH - Berlin
Kochi, IN 161.03 ms 0.0% 3672.67 Mbps 564.77 Mbps Asianet Broadband - Cochin
Bangalore, IN 127.40 ms 0.0% 4203.86 Mbps 677.07 Mbps Bharti Airtel Ltd - Bangalore
Chennai, IN 157.14 ms N/A 3753.24 Mbps 405.54 Mbps Jio - Chennai
Mumbai, IN 134.59 ms 0.0% 3493.10 Mbps 679.81 Mbps i3D.net - Mumbai
Delhi, IN 142.88 ms 0.0% 2888.92 Mbps 600.43 Mbps Tata Teleservices Ltd - New Delhi
Seattle, US 162.12 ms 0.0% 1220.11 Mbps 495.35 Mbps Ziply Fiber - Seattle, WA
Los Angeles, US 160.87 ms 0.0% 4141.51 Mbps 480.15 Mbps ReliableSite Hosting - Los Angeles, CA
Dallas, US 116.04 ms 0.4% 1364.34 Mbps 157.61 Mbps Hivelocity - Dallas, TX
Miami, US 133.60 ms 0.0% 1063.92 Mbps 646.43 Mbps AT&T - Miami, FL
New York, US 78.68 ms 0.0% 1595.46 Mbps 1118.37 Mbps GSL Networks - New York, NY
Toronto, CA 88.02 ms 0.0% 3980.96 Mbps 1000.52 Mbps Rogers - Toronto, ON
London, UK 13.46 ms 0.0% 1226.48 Mbps 1895.75 Mbps VeloxServ Communications - London
Amsterdam, NL 13.22 ms 0.0% 1293.45 Mbps 1896.66 Mbps 31173 Services AB - Amsterdam
Paris, FR 10.64 ms N/A 1970.36 Mbps 1747.52 Mbps Axione - Paris
Frankfurt, DE 0.89 ms 0.0% 4525.49 Mbps 1864.91 Mbps 23M GmbH - Frankfurt am Main
Warsaw, PL 24.36 ms 0.0% 2428.51 Mbps 1827.77 Mbps UPC Polska - Warszawa
Bucharest, RO 42.57 ms 0.0% 3090.16 Mbps 1784.04 Mbps Vodafone Romania Fixed – Bucharest - Bucharest
Jeddah, SA 67.22 ms 0.0% 2923.08 Mbps 1300.46 Mbps Saudi Telecom Company
Dubai, AE 139.91 ms 0.0% 3859.20 Mbps 661.00 Mbps du - Dubai
Fujairah, AE 116.83 ms 0.0% 1576.83 Mbps 798.09 Mbps ETISALAT-UAE - Fujairah
Tokyo, JP 280.34 ms N/A 994.67 Mbps 352.80 Mbps fdcservers.net - Tokyo
Shanghai, CU-CN 356.73 ms 0.0% 1378.38 Mbps 296.15 Mbps China Unicom 5G - Shanghai
Nanjing, CT-CN 172.73 ms 0.0% 990.86 Mbps 59.65 Mbps China Telecom JiangSu 5G - Nanjing
Hong Kong, CN 239.20 ms N/A 3152.48 Mbps 371.11 Mbps STC - Hong Kong
Singapore, SG 159.26 ms 0.0% 4297.84 Mbps 589.66 Mbps i3D.net - Singapore
Jakarta, ID 200.98 ms 0.0% 2234.30 Mbps 223.17 Mbps PT. Telekomunikasi Indonesia - Jakarta
Avg DL Speed : 2564.53 Mbps
Avg UL Speed : 903.56 Mbps
Total DL Data : 96.20 GB
Total UL Data : 30.58 GB
Total Data : 126.78 GB
Duration : 13 min 7 sec
System Time : 17/09/2023 - 01:41:54 UTC
Total Script Runs : 23296
Result : https://result.network-speed.xyz/r/1694914915_LTRKVE_GLOBAL.txt
Basic System Info
CPU Model : AMD EPYC-Rome Processor
CPU Cores : 1 @ 2349.998 MHz
CPU Cache : 512 KB
AES-NI : ✔ Enabled
VM-x/AMD-V : ❌ Disabled
Total Disk : 39.3 GB (1.9 GB Used)
Total RAM : 1.9 GB (121.8 MB Used)
System uptime : 0 days, 0 hour 35 min
Load average : 0.00, 0.02, 0.10
OS : Debian GNU/Linux 11
Kernel : 5.10.0-21-amd64
Basic Network Info
ISP : GoDaddy.com, LLC
ASN : AS26496 GoDaddy.com, LLC
Host : Godaddy.com
ISP: GoDaddy.com, LLC
Nearest 0.85 ms 0.0% 8250.24 Mbps 9256.92 Mbps PhoenixNAP Global IT Services - Singapore
Kochi, IN 46.38 ms 0.0% 8395.78 Mbps 1571.89 Mbps Asianet Broadband - Cochin
Bangalore, IN 38.04 ms 0.0% 8231.80 Mbps 2135.66 Mbps Bharti Airtel Ltd - Bangalore
Chennai, IN 68.26 ms N/A 8296.34 Mbps 762.53 Mbps Jio - Chennai
Mumbai, IN 68.31 ms 0.0% 3587.42 Mbps 996.71 Mbps i3D.net - Mumbai
Delhi, IN FAILED
Seattle, US 181.68 ms 0.0% 2800.43 Mbps 555.46 Mbps Ziply Fiber - Seattle, WA
Los Angeles, US FAILED
Dallas, US FAILED
Miami, US 236.77 ms 0.0% 3311.37 Mbps 439.60 Mbps AT&T - Miami, FL
New York, US 224.05 ms 0.0% 2955.42 Mbps 433.64 Mbps GSL Networks - New York, NY
Toronto, CA FAILED
London, UK FAILED
Amsterdam, NL 242.30 ms 0.0% 3269.28 Mbps 377.65 Mbps 31173 Services AB - Amsterdam
Paris, FR 257.31 ms N/A 1892.32 Mbps 0.31 Mbps Axione - Paris
Frankfurt, DE FAILED
Warsaw, PL 183.69 ms 0.0% 2705.26 Mbps 485.15 Mbps UPC Polska - Warszawa
Bucharest, RO 252.88 ms 1.0% 2939.72 Mbps 351.54 Mbps Vodafone Romania Fixed – Bucharest - Bucharest
Jeddah, SA FAILED
Dubai, AE 25.10 ms 0.0% 8696.71 Mbps 994.96 Mbps du - Dubai
Fujairah, AE 78.06 ms 0.0% 8177.19 Mbps 1105.35 Mbps ETISALAT-UAE - Fujairah
Tokyo, JP 276.30 ms N/A 2814.44 Mbps 337.77 Mbps fdcservers.net - Tokyo
Shanghai, CU-CN 241.28 ms 5.3% 2678.64 Mbps 5.59 Mbps China Unicom 5G - Shanghai
Nanjing, CT-CN FAILED
Hong Kong, CN 33.72 ms N/A 9266.67 Mbps 2322.40 Mbps STC - Hong Kong
Singapore, SG FAILED
Jakarta, ID FAILED
Avg DL Speed : 5192.29 Mbps
Avg UL Speed : 1301.95 Mbps
Total DL Data : 116.50 GB
Total UL Data : 24.16 GB
Total Data : 140.66 GB
Duration : 9 min 33 sec
System Time : 18/09/2023 - 09:55:00 UTC
Total Script Runs : 23395
Result : https://result.network-speed.xyz/r/1695030902_H1XIE7_GLOBAL.txt
Basic System Info
CPU Cache : 512 KB
AES-NI : ✔ Enabled
Total RAM : 1.9 GB (122.2 MB Used)
Load average : 0.10, 0.44, 0.32
Basic Network Info
ASN (IPv4) : AS398791 GoDaddy.com, LLC
Host : Godaddy.com
Location (IPv4) : Mumbai, Maharashtra, IN
Nearest 1.84 ms 0.0% 967.29 Mbps 8564.48 Mbps Tata Play Fiber - Mumbai
Kochi, IN 38.42 ms 0.0% 1013.45 Mbps 2292.81 Mbps Asianet Broadband - Cochin
Bangalore, IN 18.72 ms 0.0% 981.29 Mbps 1126.21 Mbps Bharti Airtel Ltd - Bangalore
Chennai, IN 21.38 ms N/A 8832.30 Mbps 2717.33 Mbps Jio - Chennai
Mumbai, IN 2.02 ms 0.0% 9283.47 Mbps 7988.22 Mbps i3D.net - Mumbai
Delhi, IN 21.12 ms 0.0% 2905.99 Mbps 511.58 Mbps Tata Teleservices Ltd - New Delhi
Seattle, US 248.21 ms 0.0% 908.30 Mbps 403.24 Mbps Ziply Fiber - Seattle, WA
Los Angeles, US 224.01 ms 0.0% 999.20 Mbps 115.08 Mbps ReliableSite Hosting - Los Angeles, CA
Dallas, US 271.39 ms 0.0% 982.94 Mbps 181.86 Mbps Hivelocity - Dallas, TX
Miami, US 251.10 ms 0.0% 206.09 Mbps 398.79 Mbps AT&T - Miami, FL
New York, US 188.40 ms 0.0% 494.98 Mbps 293.27 Mbps GSL Networks - New York, NY
Toronto, CA 253.20 ms 0.0% 943.26 Mbps 349.79 Mbps Rogers - Toronto, ON
London, UK 139.30 ms 0.0% 1013.81 Mbps 756.71 Mbps VeloxServ Communications - London
Amsterdam, NL 122.44 ms 0.0% 480.94 Mbps 435.68 Mbps 31173 Services AB - Amsterdam
Paris, FR 161.57 ms N/A 392.14 Mbps 248.02 Mbps Axione - Paris
Frankfurt, DE 128.42 ms 0.0% 956.10 Mbps 368.01 Mbps 23M GmbH - Frankfurt am Main
Warsaw, PL 142.33 ms 0.0% 168.56 Mbps 573.86 Mbps UPC Polska - Warszawa
Bucharest, RO 153.49 ms 0.0% 201.56 Mbps 629.07 Mbps Vodafone Romania Fixed – Bucharest - Bucharest
Jeddah, SA 207.61 ms 0.0% 999.13 Mbps 115.47 Mbps Saudi Telecom Company
Dubai, AE 117.65 ms 0.0% 238.86 Mbps 146.47 Mbps du - Dubai
Fujairah, AE 84.37 ms 0.0% 461.68 Mbps 1221.83 Mbps ETISALAT-UAE - Fujairah
Tokyo, JP 352.00 ms N/A 205.62 Mbps 232.37 Mbps fdcservers.net - Tokyo
Shanghai, CU-CN 124.04 ms 0.0% 160.69 Mbps 577.96 Mbps China Unicom 5G - Shanghai
Hong Kong, CN 90.03 ms N/A 4923.88 Mbps 521.21 Mbps STC - Hong Kong
Singapore, SG 64.25 ms 0.0% 1006.32 Mbps 1161.80 Mbps i3D.net - Singapore
Jakarta, ID 172.17 ms 0.0% 816.49 Mbps 223.16 Mbps PT. Telekomunikasi Indonesia - Jakarta
Avg DL Speed : 1559.40 Mbps
Avg UL Speed : 1236.71 Mbps
Total DL Data : 51.68 GB
Total UL Data : 41.84 GB
Total Data : 93.52 GB
Duration : 13 min 16 sec
System Time : 18/09/2023 - 10:01:54 UTC
Total Script Runs : 23401
Result : https://result.network-speed.xyz/r/1695031578_8B1RYR_GLOBAL.txt
Basic System Info
CPU Model : Intel Core Processor (Broadwell)
CPU Cores : 3 @ 2095.322 MHz
CPU Cache : 16384 KB
AES-NI : ✔ Enabled
Total Disk : 125.0 GB (8.6 GB Used)
Total RAM : 4.3 GB (1.1 GB Used)
Total Swap : 2.0 GB (55.7 MB Used)
System uptime : 1 days, 22 hour 46 min
Load average : 0.16, 0.06, 0.01
Kernel : 5.10.0-20-amd64
Basic Network Info
ISP : Redoubt Networks
ASN : AS400304 REDOUBT NETWORKS
Host : Redoubt Networks
ISP: Crunchbits, LLC
Nearest 10.54 ms 0.0% 952.08 Mbps 1007.93 Mbps Intechtel - Managed IT Services - Coeur d'Alene, ID
Kochi, IN 220.53 ms 0.0% 569.88 Mbps 381.11 Mbps Asianet Broadband - Cochin
Bangalore, IN 235.23 ms 0.0% 786.05 Mbps 383.52 Mbps Bharti Airtel Ltd - Bangalore
Chennai, IN 265.67 ms N/A 858.41 Mbps 419.05 Mbps Jio - Chennai
Mumbai, IN 252.60 ms 0.0% 895.17 Mbps 329.91 Mbps i3D.net - Mumbai
Delhi, IN 284.58 ms 0.0% 604.27 Mbps 320.39 Mbps Tata Teleservices Ltd - New Delhi
Seattle, US 10.43 ms 0.0% 933.20 Mbps 1006.15 Mbps Ziply Fiber - Seattle, WA
Los Angeles, US 35.99 ms 0.0% 924.93 Mbps 1004.67 Mbps ReliableSite Hosting - Los Angeles, CA
Dallas, US 68.62 ms 0.0% 921.11 Mbps 1076.63 Mbps Hivelocity - Dallas, TX
Miami, US 91.49 ms 0.0% 890.76 Mbps 1102.61 Mbps AT&T - Miami, FL
New York, US 82.38 ms 0.0% 920.75 Mbps 1007.38 Mbps GSL Networks - New York, NY
Toronto, CA 77.72 ms 0.0% 930.89 Mbps 1020.01 Mbps Rogers - Toronto, ON
London, UK 134.74 ms 0.0% 947.63 Mbps 828.63 Mbps VeloxServ Communications - London
Amsterdam, NL 138.98 ms 0.0% 989.63 Mbps 704.61 Mbps 31173 Services AB - Amsterdam
Paris, FR 140.73 ms N/A 979.15 Mbps 728.57 Mbps Axione - Paris
Frankfurt, DE 146.77 ms 0.0% 930.31 Mbps 558.13 Mbps 23M GmbH - Frankfurt am Main
Warsaw, PL 191.45 ms 0.0% 816.79 Mbps 481.45 Mbps UPC Polska - Warszawa
Bucharest, RO 176.74 ms 0.0% 938.44 Mbps 281.38 Mbps Vodafone Romania Fixed – Bucharest - Bucharest
Jeddah, SA 208.59 ms 0.0% 923.50 Mbps 551.61 Mbps Saudi Telecom Company
Dubai, AE 247.34 ms 0.0% 875.58 Mbps 471.15 Mbps du - Dubai
Fujairah, AE 247.92 ms 0.0% 927.08 Mbps 434.87 Mbps ETISALAT-UAE - Fujairah
Tokyo, JP 114.99 ms N/A 928.74 Mbps 702.23 Mbps fdcservers.net - Tokyo
Shanghai, CU-CN 189.86 ms 0.0% 575.92 Mbps 573.75 Mbps China Unicom 5G - Shanghai
Nanjing, CT-CN 177.71 ms 0.0% 855.74 Mbps 3.38 Mbps China Telecom JiangSu 5G - Nanjing
Hong Kong, CN 156.75 ms N/A 928.06 Mbps 588.87 Mbps STC - Hong Kong
Singapore, SG 168.79 ms 0.0% 935.54 Mbps 549.73 Mbps i3D.net - Singapore
Jakarta, ID 201.46 ms 0.0% 616.75 Mbps 216.35 Mbps PT. Telekomunikasi Indonesia - Jakarta
Avg DL Speed : 865.04 Mbps
Avg UL Speed : 619.78 Mbps
Total DL Data : 34.17 GB
Total UL Data : 23.66 GB
Total Data : 57.83 GB
Duration : 14 min 2 sec
System Time : 19/09/2023 - 13:40:35 WIB
Total Script Runs : 23566
Result : https://result.network-speed.xyz/r/1695105636_FCDSD4_GLOBAL.txt
Basic System Info
CPU Model : AMD EPYC 7551P 32-Core Processor
CPU Cores : 2 @ 1999.999 MHz
CPU Cache : 512 KB
AES-NI : ✔ Enabled
Total Disk : 1.8 TB (1.1 TB Used)
Total RAM : 1.9 GB (378.8 MB Used)
Total Swap : 2.0 GB (0 Used)
System uptime : 0 days, 3 hour 15 min
Load average : 0.00, 0.00, 0.00
Kernel : 5.10.0-25-amd64
Basic Network Info
ISP : HostHatch
ASN : AS63473 HostHatch, LLC
Host : HostHatch LLC
ISP: HostHatch
Nearest 0.62 ms 0.0% 6240.98 Mbps 9258.80 Mbps Tele2 Sweden - Kista
Kochi, IN 163.51 ms 0.0% 3459.59 Mbps 505.60 Mbps Asianet Broadband - Cochin
Bangalore, IN 157.27 ms 0.0% 4269.84 Mbps 555.45 Mbps Bharti Airtel Ltd - Bangalore
Chennai, IN 149.76 ms N/A 4525.62 Mbps 537.38 Mbps Jio - Chennai
Mumbai, IN 152.70 ms 0.0% 3183.11 Mbps 483.22 Mbps i3D.net - Mumbai
Delhi, IN 166.55 ms 0.0% 2386.76 Mbps 538.21 Mbps Tata Teleservices Ltd - New Delhi
Seattle, US 160.88 ms 0.0% 2114.56 Mbps 691.41 Mbps Ziply Fiber - Seattle, WA
Los Angeles, US 160.20 ms 0.0% 2516.21 Mbps 442.35 Mbps ReliableSite Hosting - Los Angeles, CA
Dallas, US 133.10 ms 0.0% 3780.79 Mbps 567.07 Mbps Hivelocity - Dallas, TX
Miami, US 128.19 ms 6.0% 2017.95 Mbps 3.27 Mbps AT&T - Miami, FL
New York, US 97.69 ms 0.0% 6205.68 Mbps 1135.34 Mbps GSL Networks - New York, NY
Toronto, CA 120.76 ms 0.0% 6601.93 Mbps 781.37 Mbps Rogers - Toronto, ON
London, UK 28.41 ms 0.0% 6524.53 Mbps 3579.08 Mbps VeloxServ Communications - London
Amsterdam, NL 25.97 ms 0.0% 5336.11 Mbps 2836.83 Mbps 31173 Services AB - Amsterdam
Paris, FR 37.62 ms N/A 3725.22 Mbps 849.03 Mbps Axione - Paris
Frankfurt, DE 18.46 ms 0.0% 4379.59 Mbps 3510.33 Mbps 23M GmbH - Frankfurt am Main
Warsaw, PL 38.16 ms 1.1% 4081.53 Mbps 2325.22 Mbps UPC Polska - Warszawa
Bucharest, RO 53.56 ms 0.0% 4988.48 Mbps 1630.87 Mbps Vodafone Romania Fixed – Bucharest - Bucharest
Jeddah, SA 90.62 ms 0.0% 4786.41 Mbps 1178.51 Mbps Saudi Telecom Company
Dubai, AE 147.82 ms 0.0% 3991.91 Mbps 729.28 Mbps du - Dubai
Fujairah, AE 137.75 ms 0.0% 4130.51 Mbps 794.62 Mbps ETISALAT-UAE - Fujairah
Tokyo, JP 267.73 ms N/A 1947.21 Mbps 90.19 Mbps fdcservers.net - Tokyo
Shanghai, CU-CN 256.83 ms 0.0% 2009.09 Mbps 398.73 Mbps China Unicom 5G - Shanghai
Nanjing, CT-CN 246.91 ms 0.0% 1459.67 Mbps 21.80 Mbps China Telecom JiangSu 5G - Nanjing
Hong Kong, CN 176.75 ms N/A 2840.21 Mbps 525.57 Mbps STC - Hong Kong
Singapore, SG 223.52 ms 0.0% 3393.19 Mbps 428.32 Mbps i3D.net - Singapore
Jakarta, ID 212.10 ms 0.0% 3463.22 Mbps 76.31 Mbps PT. Telekomunikasi Indonesia - Jakarta
Avg DL Speed : 3865.19 Mbps
Avg UL Speed : 1276.82 Mbps
Total DL Data : 146.80 GB
Total UL Data : 45.67 GB
Total Data : 192.47 GB
Duration : 14 min 41 sec
System Time : 20/09/2023 - 03:00:55 UTC
Total Script Runs : 23655
Result : https://result.network-speed.xyz/r/1695178862_INCAYH_GLOBAL.txt
Basic System Info
CPU Cores : 1 @ 3799.948 MHz
CPU Cache : 512 KB
AES-NI : ✔ Enabled
Total Disk : 913.4 GB (769.8 GB Used)
Total RAM : 976.4 MB (398.4 MB Used)
Total Swap : 975.0 MB (709.2 MB Used)
System uptime : 9 days, 0 hour 41 min
Load average : 0.00, 0.05, 0.17
Kernel : 5.10.0-16-amd64
Basic Network Info
ISP : WorldStream B.V.
ASN : AS212477 RoyaleHosting BV
Host : Sheimo Scorpion Data AB
Location (IPv4) : Los Angeles, California, US
ISP: WorldStream B.V.
Nearest 88.44 ms 0.0% 2507.31 Mbps 887.96 Mbps Telenor AB - Stockholm
Kochi, IN 246.24 ms 0.0% 1166.30 Mbps 311.71 Mbps Asianet Broadband - Cochin
Bangalore, IN 210.86 ms 0.0% 1164.58 Mbps 402.63 Mbps Bharti Airtel Ltd - Bangalore
Chennai, IN 213.66 ms N/A 1197.81 Mbps 391.89 Mbps Jio - Chennai
Mumbai, IN 216.77 ms 0.0% 1074.82 Mbps 291.60 Mbps i3D.net - Mumbai
Delhi, IN 241.15 ms 0.0% 1471.33 Mbps 360.86 Mbps Tata Teleservices Ltd - New Delhi
Seattle, US 71.13 ms 0.0% 3327.81 Mbps 852.83 Mbps Ziply Fiber - Seattle, WA
Los Angeles, US 54.37 ms 0.0% 2798.40 Mbps 882.73 Mbps ReliableSite Hosting - Los Angeles, CA
Dallas, US 34.38 ms 0.0% 3157.76 Mbps 918.12 Mbps Hivelocity - Dallas, TX
Miami, US 43.06 ms 0.0% 3092.45 Mbps 907.59 Mbps AT&T - Miami, FL
New York, US 0.20 ms 0.0% 1875.81 Mbps 939.60 Mbps GSL Networks - New York, NY
Toronto, CA 19.40 ms 0.0% 3555.93 Mbps 930.63 Mbps Rogers - Toronto, ON
London, UK 66.70 ms 0.0% 2522.52 Mbps 817.49 Mbps VeloxServ Communications - London
Amsterdam, NL 72.08 ms 0.0% 2538.48 Mbps 870.36 Mbps 31173 Services AB - Amsterdam
Paris, FR FAILED
Frankfurt, DE 77.12 ms 0.0% 1758.21 Mbps 838.36 Mbps 23M GmbH - Frankfurt am Main
Warsaw, PL 94.19 ms 0.0% 1981.14 Mbps 868.12 Mbps UPC Polska - Warszawa
Bucharest, RO 109.10 ms 0.0% 1680.96 Mbps 663.54 Mbps Vodafone Romania Fixed – Bucharest - Bucharest
Jeddah, SA 141.81 ms 0.0% 1936.94 Mbps 623.26 Mbps Saudi Telecom Company
Dubai, AE 188.35 ms 0.0% 1443.59 Mbps 472.73 Mbps du - Dubai
Fujairah, AE 246.59 ms 0.0% 2059.15 Mbps 402.63 Mbps ETISALAT-UAE - Fujairah
Tokyo, JP 156.86 ms N/A 1161.31 Mbps 529.39 Mbps fdcservers.net - Tokyo
Shanghai, CU-CN 297.86 ms 0.0% 24.98 Mbps 245.40 Mbps China Unicom 5G - Shanghai
Nanjing, CT-CN 227.31 ms 41.7% 1557.99 Mbps 82.10 Mbps China Telecom JiangSu 5G - Nanjing
Hong Kong, CN 222.94 ms N/A 667.18 Mbps 394.54 Mbps STC - Hong Kong
Singapore, SG 219.69 ms 0.0% 1177.89 Mbps 391.88 Mbps i3D.net - Singapore
Jakarta, ID 250.43 ms 0.0% 931.81 Mbps 122.48 Mbps PT. Telekomunikasi Indonesia - Jakarta
Avg DL Speed : 1839.71 Mbps
Avg UL Speed : 592.32 Mbps
Total DL Data : 68.90 GB
Total UL Data : 20.67 GB
Total Data : 89.56 GB
Duration : 13 min 39 sec
System Time : 20/09/2023 - 12:06:24 WIB
Total Script Runs : 23659
Result : https://result.network-speed.xyz/r/1695186386_AH8MKH_GLOBAL.txt
Updated to v2023.09.22
* Update broken servers
* Add new region: Indonesia
Version : v2023.09.22
Basic System Info
CPU Model : Intel(R) Xeon(R) CPU E5-2698 v4 @ 2.20GHz
CPU Cores : 4 @ 2199.986 MHz
AES-NI : ✔ Enabled
Total Disk : 55.1 GB (33.2 GB Used)
Total RAM : 7.8 GB (498.8 MB Used)
Total Swap : 4.0 GB (0 Used)
System uptime : 22 days, 7 hour 19 min
Load average : 0.38, 0.29, 0.17
Kernel : 5.15.0-82-generic
Basic Network Info
ISP : Leaseweb Singapore
ASN : AS59253 Leaseweb Asia Pacific pte. ltd.
Host : Leaseweb Asia Pacific pte. ltd
Speedtest.net (Region: INDONESIA)
ISP: Leaseweb Asia
Nearest 0.84 ms 0.0% 5849.82 Mbps 8091.28 Mbps MyRepublic Singapore - Singapore
Jakarta 46.32 ms 0.0% 856.38 Mbps 301.16 Mbps Hutchison 3 Indonesia CGK-MM - Jakarta
Jakarta 13.10 ms 0.0% 2331.45 Mbps 221.71 Mbps DomaiNesia - Jakarta
Jakarta 16.30 ms 0.0% 2591.35 Mbps 703.08 Mbps PT. Telekomunikasi Indonesia - Jakarta
Jakarta 12.30 ms 0.0% 3331.01 Mbps 4519.83 Mbps PT Indosat Tbk - Jakarta
Jakarta 17.60 ms 0.0% 1341.44 Mbps 3725.87 Mbps MyRepublic Indonesia - South Jakarta
Bandung 17.58 ms N/A 270.68 Mbps 231.93 Mbps HYPERNET - Bandung
Bekasi 13.41 ms 0.0% 889.68 Mbps 537.63 Mbps PT Lintas Jaringan Nusantara - Bekasi
Bogor 14.42 ms 0.0% 930.01 Mbps 383.15 Mbps PT. Java Digital Nusantara - Bogor
Malang 25.44 ms 0.0% 1299.41 Mbps 813.30 Mbps GlobalXtreme - Malang
Semarang 21.36 ms N/A 7616.98 Mbps 3287.08 Mbps PT. Indonesia Comnets Plus - Semarang
Surabaya 24.59 ms N/A 3092.44 Mbps 2704.08 Mbps PT. Indonesia Comnets Plus - Surabaya
Yogyakarta 23.63 ms 0.6% 762.81 Mbps 149.85 Mbps PT Union Routelink Communication - Yogyakarta
Banda Aceh 18.43 ms 0.0% 2863.06 Mbps 726.63 Mbps PT. Telekomunikasi Indonesia - Banda Aceh
Medan 13.40 ms 3.2% 3871.59 Mbps 125.65 Mbps Biznet Networks - Medan
Palembang 11.51 ms N/A 657.00 Mbps 601.05 Mbps PT. Sakti Putra Mandiri - Palembang
Pekanbaru 28.68 ms 0.0% 566.86 Mbps 95.70 Mbps PT Hexa Media Sarana - Pekanbaru
Bali 32.22 ms 0.0% 2930.45 Mbps 2605.09 Mbps Biznet Networks - Bali
Makassar 57.90 ms 25.4% 754.02 Mbps 0.72 Mbps Biznet Networks - Makassar
Depok 18.19 ms 19.1% 523.84 Mbps 4.51 Mbps ADI - Depok
Tangerang 12.88 ms 0.0% 891.87 Mbps 103.94 Mbps PT. Java Medianet Tekhnologi - Tangerang
Avg DL Speed : 2105.81 Mbps
Avg UL Speed : 1425.39 Mbps
Total DL Data : 56.82 GB
Total UL Data : 33.89 GB
Total Data : 90.70 GB
System Time : 22/09/2023 - 20:00:39 IST
Total Script Runs : 23823
Result : https://result.network-speed.xyz/r/1695393041_9GD26Z_INDONESIA.txt
Basic System Info
AES-NI : ✔ Enabled
Total Disk : 125.0 GB (9.4 GB Used)
Total RAM : 4.3 GB (1.2 GB Used)
Total Swap : 2.0 GB (117.8 MB Used)
System uptime : 5 days, 7 hour 13 min
Basic Network Info
Nearest 10.39 ms 0.0% 949.60 Mbps 1008.43 Mbps Intechtel - Managed IT Services - Coeur d'Alene, ID
Jakarta 179.23 ms 0.0% 941.27 Mbps 217.74 Mbps Hutchison 3 Indonesia CGK-MM - Jakarta
Jakarta 219.75 ms 0.0% 795.81 Mbps 71.23 Mbps DomaiNesia - Jakarta
Jakarta 200.84 ms 0.0% 519.11 Mbps 195.66 Mbps PT. Telekomunikasi Indonesia - Jakarta
Jakarta 187.93 ms 0.0% 614.11 Mbps 363.16 Mbps PT Indosat Tbk - Jakarta
Jakarta 218.57 ms 0.3% 640.73 Mbps 46.84 Mbps MyRepublic Indonesia - South Jakarta
Bandung 201.12 ms N/A 256.47 Mbps 30.88 Mbps HYPERNET - Bandung
Bekasi 190.97 ms 0.0% 696.64 Mbps 201.47 Mbps PT Lintas Jaringan Nusantara - Bekasi
Bogor 197.41 ms 0.6% 21.30 Mbps 248.48 Mbps PT. Java Digital Nusantara - Bogor
Malang 209.90 ms 0.0% 834.74 Mbps 263.06 Mbps GlobalXtreme - Malang
Semarang 184.05 ms N/A 796.34 Mbps 487.66 Mbps PT. Indonesia Comnets Plus - Semarang
Surabaya 211.94 ms N/A 955.34 Mbps 460.17 Mbps PT. Indonesia Comnets Plus - Surabaya
Yogyakarta 262.05 ms 0.3% 684.40 Mbps 85.15 Mbps PT Union Routelink Communication - Yogyakarta
Banda Aceh 203.89 ms 0.0% 701.19 Mbps 440.94 Mbps PT. Telekomunikasi Indonesia - Banda Aceh
Medan 182.10 ms 1.3% 818.12 Mbps 26.03 Mbps Biznet Networks - Medan
Palembang 218.60 ms N/A 338.26 Mbps 7.93 Mbps PT. Sakti Putra Mandiri - Palembang
Pekanbaru 189.28 ms 3.4% 451.81 Mbps 39.69 Mbps PT Hexa Media Sarana - Pekanbaru
Bali 207.62 ms N/A 895.26 Mbps 0.53 Mbps Biznet Networks - Bali
Makassar 241.44 ms N/A 27.76 Mbps 0.57 Mbps Biznet Networks - Makassar
Depok 197.05 ms 9.7% 483.11 Mbps 3.06 Mbps ADI - Depok
Tangerang 200.85 ms 0.0% 930.88 Mbps 72.51 Mbps PT. Java Medianet Tekhnologi - Tangerang
Avg DL Speed : 635.83 Mbps
Avg UL Speed : 203.39 Mbps
Total DL Data : 19.25 GB
Total UL Data : 7.87 GB
Total Data : 27.12 GB
Duration : 11 min 22 sec
System Time : 22/09/2023 - 22:04:20 WIB
Total Script Runs : 23825
Result : https://result.network-speed.xyz/r/1695395060_N5BM87_INDONESIA.txt
Basic System Info
CPU Cache : 512 KB
AES-NI : ✔ Enabled
Total RAM : 976.4 MB (367.3 MB Used)
Total Swap : 975.0 MB (720.7 MB Used)
System uptime : 11 days, 10 hour 56 min
Load average : 0.13, 0.41, 0.33
Basic Network Info
Nearest 88.47 ms 0.0% 2391.63 Mbps 895.69 Mbps Telenor AB - Stockholm
Jakarta 231.49 ms 0.0% 905.87 Mbps 381.29 Mbps Hutchison 3 Indonesia CGK-MM - Jakarta
Jakarta 237.54 ms 0.7% 451.80 Mbps 63.70 Mbps DomaiNesia - Jakarta
Jakarta 258.92 ms 0.0% 1182.44 Mbps 165.62 Mbps PT. Telekomunikasi Indonesia - Jakarta
Jakarta 249.54 ms 0.0% 1036.18 Mbps 107.35 Mbps PT Indosat Tbk - Jakarta
Jakarta 337.45 ms 0.0% 722.12 Mbps 335.17 Mbps MyRepublic Indonesia - South Jakarta
Bandung 239.16 ms N/A 250.07 Mbps 32.19 Mbps HYPERNET - Bandung
Bekasi 239.30 ms 0.0% 570.55 Mbps 218.28 Mbps PT Lintas Jaringan Nusantara - Bekasi
Bogor 235.32 ms 0.3% 51.23 Mbps 246.86 Mbps PT. Java Digital Nusantara - Bogor
Malang 252.15 ms 0.0% 460.85 Mbps 336.76 Mbps GlobalXtreme - Malang
Semarang 256.61 ms N/A 919.02 Mbps 340.09 Mbps PT. Indonesia Comnets Plus - Semarang
Surabaya 259.73 ms N/A 981.12 Mbps 339.24 Mbps PT. Indonesia Comnets Plus - Surabaya
Yogyakarta 242.62 ms 0.0% 821.04 Mbps 71.73 Mbps PT Union Routelink Communication - Yogyakarta
Banda Aceh 254.41 ms 0.0% 1163.11 Mbps 320.41 Mbps PT. Telekomunikasi Indonesia - Banda Aceh
Medan 251.91 ms 6.7% 1011.20 Mbps 1.01 Mbps Biznet Networks - Medan
Palembang 237.88 ms N/A 941.59 Mbps 358.09 Mbps PT. Sakti Putra Mandiri - Palembang
Pekanbaru 244.76 ms 0.0% 573.56 Mbps 86.92 Mbps PT Hexa Media Sarana - Pekanbaru
Bali 298.72 ms 0.7% 968.90 Mbps 129.00 Mbps Biznet Networks - Bali
Makassar 234.68 ms 0.0% 503.18 Mbps 172.80 Mbps Biznet Networks - Makassar
Depok 243.55 ms 0.0% 269.78 Mbps 22.21 Mbps ADI - Depok
Tangerang 231.83 ms 2.0% 725.60 Mbps 4.71 Mbps PT. Java Medianet Tekhnologi - Tangerang
Avg DL Speed : 804.80 Mbps
Avg UL Speed : 220.43 Mbps
Total DL Data : 23.62 GB
Total UL Data : 6.24 GB
Total Data : 29.86 GB
Duration : 11 min 43 sec
System Time : 22/09/2023 - 22:19:02 WIB
Total Script Runs : 23826
Result : https://result.network-speed.xyz/r/1695395943_ZC1Z7E_INDONESIA.txt
ITS WEDNESDAY MY DUDES
DataWagon LET Offer
1€ IONOS Frankfurt Equinix
@Neoon wow, how much is that godaddy india VPS?
All of them 1.20€/m for the first 12 months.
How? Shows 849 for me?
849€ what?
₹849
Its available for Europe at least for this price.
No one else commented that it wasn't available in other countries.
So no idea.
Same for me too, shows 849 INR/month yearly pay, no discounts.
https://www.godaddy.com/en-in/hosting/vps-hosting
Nah you need to use the other Brand.
https://www.hosteurope.de/en/Server/Virtual-Server/
Crunchbits Yearly KVM SSD VPS - 4.5GB
Sultan Muda - Amazon Store
You guys want Indonesia added as a region? 😄
Hahaha... lets gooooooo![;) ;)](https://lowendspirit.com/plugins/emojiextender/emoji/twitter/wink.png)
Let me see if I can do it over the weekend![:) :)](https://lowendspirit.com/plugins/emojiextender/emoji/twitter/smile.png)
Hosthatch BF2021 Flash — Storage 2TB
Virmach
Selamat malam @nyamenk @Ganonk
Coming in a few hours!
![](https://zip.xbit.win/u/MW0fXB.png)
Lololo ga bahaya ta
Selamat malam juga @sh97
Virmach Free
