---------------------------- network-speed.xyz ----------------------------
A simple script to test network performance using speedtest-cli
Version : v2023.09.22
Global Speedtest : wget -qO- network-speed.xyz | bash
Region Speedtest : wget -qO- network-speed.xyz | bash -s -- -r
Basic System Info
CPU Model : AMD EPYC 7551P 32-Core Processor
CPU Cores : 2 @ 1999.999 MHz
CPU Cache : 512 KB
AES-NI : ✔ Enabled
Total Disk : 1.8 TB (1.1 TB Used)
Total RAM : 1.9 GB (454.4 MB Used)
Total Swap : 2.0 GB (0 Used)
System uptime : 2 days, 15 hour 38 min
Load average : 0.00, 0.00, 0.00
OS : Debian GNU/Linux 11
Arch : x86_64 (64 Bit)
Kernel : 5.10.0-25-amd64
Virtualization : KVM
Basic Network Info
Primary Network : IPv4
ISP : HostHatch
ASN : AS63473 HostHatch, LLC
Host : HostHatch LLC
Speedtest.net (Region: INDONESIA)
Location Latency Loss DL Speed UP Speed Server
ISP: HostHatch
Nearest 1.15 ms N/A 7706.02 Mbps 9257.77 Mbps NORDUnet A/S - Stockholm
Jakarta 207.86 ms 0.0% 839.53 Mbps 201.48 Mbps Hutchison 3 Indonesia CGK-MM - Jakarta
Jakarta 266.22 ms 0.3% 480.98 Mbps 8.04 Mbps DomaiNesia - Jakarta
Jakarta 227.51 ms 0.3% 3552.50 Mbps 248.42 Mbps PT. Telekomunikasi Indonesia - Jakarta
Jakarta 202.85 ms 0.0% 3180.49 Mbps 310.93 Mbps PT Indosat Tbk - Jakarta
Jakarta 199.17 ms 0.0% 1070.58 Mbps 387.53 Mbps MyRepublic Indonesia - South Jakarta
Bandung 224.34 ms N/A 169.81 Mbps 58.08 Mbps HYPERNET - Bandung
Bekasi 182.93 ms 0.0% 681.52 Mbps 156.18 Mbps PT Lintas Jaringan Nusantara - Bekasi
Bogor 265.70 ms 1.7% 190.44 Mbps 37.96 Mbps PT. Java Digital Nusantara - Bogor
Malang 203.03 ms 0.0% 938.49 Mbps 322.89 Mbps GlobalXtreme - Malang
Semarang 207.52 ms N/A 3701.17 Mbps 446.88 Mbps PT. Indonesia Comnets Plus - Semarang
Surabaya 200.38 ms N/A 3080.68 Mbps 432.42 Mbps PT. Indonesia Comnets Plus - Surabaya
Yogyakarta 237.93 ms 0.3% 834.93 Mbps 98.38 Mbps PT Union Routelink Communication - Yogyakarta
Banda Aceh 211.40 ms 0.0% 3671.95 Mbps 261.96 Mbps PT. Telekomunikasi Indonesia - Banda Aceh
Medan FAILED
Palembang 195.95 ms N/A 937.96 Mbps 158.04 Mbps PT. Sakti Putra Mandiri - Palembang
Pekanbaru 203.35 ms 0.3% 596.46 Mbps 84.82 Mbps PT Hexa Media Sarana - Pekanbaru
Bali 206.59 ms 0.0% 2068.26 Mbps 447.36 Mbps Biznet Networks - Bali
Makassar 239.61 ms 0.0% 189.72 Mbps 128.84 Mbps Biznet Networks - Makassar
Depok 211.24 ms 1.0% 878.41 Mbps 32.90 Mbps ADI - Depok
Tangerang 192.29 ms 6.0% 864.49 Mbps 1.39 Mbps PT. Java Medianet Tekhnologi - Tangerang
Avg DL Speed : 1781.72 Mbps
Avg UL Speed : 654.12 Mbps
Total DL Data : 49.83 GB
Total UL Data : 21.71 GB
Total Data : 71.54 GB
Duration : 11 min 51 sec
System Time : 22/09/2023 - 15:21:10 UTC
Total Script Runs : 23828
Result : https://result.network-speed.xyz/r/1695396076_YEA312_INDONESIA.txt
Basic System Info
CPU Model : Intel(R) Xeon(R) CPU E5-2683 v4 @ 2.10GHz
CPU Cores : 1 @ 2095.310 MHz
CPU Cache : 40960 KB
AES-NI : ✔ Enabled
Total Disk : 10.0 GB (1.6 GB Used)
Total RAM : 437.5 MB (131.1 MB Used)
System uptime : 37 days, 20 hour 54 min
Kernel : 5.10.0-20-amd64
Basic Network Info
Primary Network : IPv6
ISP : Redoubt Networks
ASN : AS400304 REDOUBT NETWORKS
Host : Redoubt Networks
ISP: Redoubt Networks LLC
Nearest 11.07 ms 0.0% 95.60 Mbps 98.93 Mbps Intechtel - Managed IT Services - Coeur d'Alene, ID
Jakarta 182.50 ms 0.0% 100.00 Mbps 103.76 Mbps Hutchison 3 Indonesia CGK-MM - Jakarta
Jakarta 219.27 ms 0.0% 96.11 Mbps 52.76 Mbps DomaiNesia - Jakarta
Jakarta 201.28 ms 0.0% 95.40 Mbps 98.85 Mbps PT. Telekomunikasi Indonesia - Jakarta
Jakarta 190.00 ms 0.0% 97.37 Mbps 102.05 Mbps PT Indosat Tbk - Jakarta
Jakarta 183.71 ms 3.0% 53.01 Mbps 28.65 Mbps MyRepublic Indonesia - South Jakarta
Bandung 200.91 ms N/A 97.19 Mbps 24.74 Mbps HYPERNET - Bandung
Bekasi 189.16 ms 0.0% 95.52 Mbps 97.74 Mbps PT Lintas Jaringan Nusantara - Bekasi
Bogor 189.07 ms 0.0% 96.59 Mbps 99.17 Mbps PT. Java Digital Nusantara - Bogor
Malang 201.47 ms 0.0% 96.64 Mbps 97.25 Mbps GlobalXtreme - Malang
Semarang 184.81 ms N/A 97.43 Mbps 101.73 Mbps PT. Indonesia Comnets Plus - Semarang
Surabaya 197.12 ms N/A 99.34 Mbps 101.34 Mbps PT. Indonesia Comnets Plus - Surabaya
Yogyakarta 272.33 ms 0.0% 97.23 Mbps 57.71 Mbps PT Union Routelink Communication - Yogyakarta
Banda Aceh 203.27 ms 0.0% 95.15 Mbps 103.23 Mbps PT. Telekomunikasi Indonesia - Banda Aceh
Medan 182.66 ms 0.3% 97.38 Mbps 74.13 Mbps Biznet Networks - Medan
Palembang 213.02 ms N/A 92.20 Mbps 4.59 Mbps PT. Sakti Putra Mandiri - Palembang
Pekanbaru 204.10 ms 1.7% 87.25 Mbps 73.95 Mbps PT Hexa Media Sarana - Pekanbaru
Bali 201.98 ms 19.0% 98.43 Mbps 0.65 Mbps Biznet Networks - Bali
Makassar 238.79 ms 11.5% 95.53 Mbps 1.17 Mbps Biznet Networks - Makassar
Depok 191.24 ms 6.6% 93.25 Mbps 1.42 Mbps ADI - Depok
Tangerang 193.77 ms 0.0% 98.77 Mbps 16.69 Mbps PT. Java Medianet Tekhnologi - Tangerang
Avg DL Speed : 94.07 Mbps
Avg UL Speed : 63.83 Mbps
Total DL Data : 2.98 GB
Total UL Data : 1.69 GB
Total Data : 4.67 GB
Duration : 11 min 1 sec
System Time : 22/09/2023 - 22:15:49 WIB
Total Script Runs : 23827
Result : https://result.network-speed.xyz/r/1695396050_KM03BR_INDONESIA.txt
Basic System Info
CPU Model : Intel(R) Xeon(R) CPU E5-2630 v2 @ 2.60GHz
CPU Cores : 1 @ 2599.998 MHz
CPU Cache : 16384 KB
AES-NI : ✔ Enabled
Total Disk : 23.5 GB (7.3 GB Used)
Total RAM : 964.6 MB (201.1 MB Used)
Total Swap : 975.0 MB (791.9 MB Used)
System uptime : 38 days, 12 hour 15 min
Kernel : 5.10.0-24-amd64
Basic Network Info
ISP : SkyLink Data Center BV
ASN : AS44592 SkyLink Data Center BV
Host : Sascha Haendler
ISP: SkyLink Data Center BV
Nearest 3.60 ms 0.0% 120.11 Mbps 124.26 Mbps FastLayer - Kerkrade
Jakarta 178.52 ms 0.0% 129.23 Mbps 95.07 Mbps Hutchison 3 Indonesia CGK-MM - Jakarta
Jakarta 185.30 ms 0.0% 122.74 Mbps 110.99 Mbps DomaiNesia - Jakarta
Jakarta 177.13 ms 0.0% 124.15 Mbps 60.47 Mbps PT. Telekomunikasi Indonesia - Jakarta
Jakarta 187.19 ms 0.0% 122.71 Mbps 115.01 Mbps PT Indosat Tbk - Jakarta
Jakarta 171.77 ms 0.0% 122.49 Mbps 117.72 Mbps MyRepublic Indonesia - South Jakarta
Bandung 189.85 ms N/A 123.72 Mbps 72.03 Mbps HYPERNET - Bandung
Bekasi 166.39 ms 0.0% 122.82 Mbps 86.18 Mbps PT Lintas Jaringan Nusantara - Bekasi
Bogor 166.07 ms 0.0% 121.97 Mbps 112.23 Mbps PT. Java Digital Nusantara - Bogor
Malang 188.99 ms 0.0% 124.28 Mbps 91.19 Mbps GlobalXtreme - Malang
Semarang 184.67 ms N/A 126.77 Mbps 94.84 Mbps PT. Indonesia Comnets Plus - Semarang
Surabaya 208.17 ms N/A 125.37 Mbps 91.45 Mbps PT. Indonesia Comnets Plus - Surabaya
Yogyakarta 181.17 ms 0.0% 125.07 Mbps 94.66 Mbps PT Union Routelink Communication - Yogyakarta
Banda Aceh 179.88 ms 0.0% 124.75 Mbps 99.82 Mbps PT. Telekomunikasi Indonesia - Banda Aceh
Medan 185.12 ms 0.7% 126.23 Mbps 6.07 Mbps Biznet Networks - Medan
Palembang 171.06 ms N/A 124.85 Mbps 106.77 Mbps PT. Sakti Putra Mandiri - Palembang
Pekanbaru 177.91 ms 0.0% 124.26 Mbps 81.54 Mbps PT Hexa Media Sarana - Pekanbaru
Bali 227.46 ms 1.3% 122.43 Mbps 6.36 Mbps Biznet Networks - Bali
Makassar 195.67 ms 0.0% 124.68 Mbps 93.07 Mbps Biznet Networks - Makassar
Depok 188.32 ms 0.0% 121.86 Mbps 18.88 Mbps ADI - Depok
Tangerang 166.07 ms 0.0% 123.14 Mbps 62.01 Mbps PT. Java Medianet Tekhnologi - Tangerang
Avg DL Speed : 123.98 Mbps
Avg UL Speed : 82.89 Mbps
Total DL Data : 3.65 GB
Total UL Data : 2.64 GB
Total Data : 6.29 GB
Duration : 11 min 4 sec
System Time : 22/09/2023 - 22:42:53 WIB
Total Script Runs : 23829
Result : https://result.network-speed.xyz/r/1695397374_P9DYIL_INDONESIA.txt
Basic System Info
CPU Model : Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz
CPU Cores : 1 @ 1601.900 MHz
CPU Cache : 8192 KB
AES-NI : ✔ Enabled
Total Disk : 45.7 GB (490.4 MB Used)
Total RAM : 488.3 MB (50.6 MB Used)
System uptime : 74 days, 20 hour 44 min
Load average : 0.29, 0.21, 0.13
Kernel : 5.4.0-152-generic
Virtualization : LXC
Basic Network Info
ISP : TerraHost AS
ASN : AS56655 TerraHost AS
Host : Terrahost V6net
Location (IPv4) : Oslo, Oslo, NO
ISP: TerraHost
Nearest 0.22 ms 0.0% 49.46 Mbps 50.44 Mbps Terrahost AS - Sandefjord
Jakarta 186.94 ms 0.0% 53.47 Mbps 50.12 Mbps Hutchison 3 Indonesia CGK-MM - Jakarta
Jakarta 184.26 ms 0.0% 48.37 Mbps 50.39 Mbps DomaiNesia - Jakarta
Jakarta 188.38 ms 0.0% 48.27 Mbps 42.96 Mbps PT. Telekomunikasi Indonesia - Jakarta
Jakarta 201.34 ms 0.0% 49.63 Mbps 48.95 Mbps PT Indosat Tbk - Jakarta
Jakarta 181.21 ms 0.0% 48.98 Mbps 51.06 Mbps MyRepublic Indonesia - South Jakarta
Bandung 185.72 ms N/A 48.92 Mbps 38.88 Mbps HYPERNET - Bandung
Bekasi 183.44 ms 0.0% 48.05 Mbps 49.18 Mbps PT Lintas Jaringan Nusantara - Bekasi
Bogor 181.03 ms 0.0% 49.62 Mbps 49.82 Mbps PT. Java Digital Nusantara - Bogor
Malang 195.76 ms 0.0% 48.97 Mbps 49.68 Mbps GlobalXtreme - Malang
Semarang 189.33 ms N/A 48.02 Mbps 49.45 Mbps PT. Indonesia Comnets Plus - Semarang
Surabaya 193.80 ms N/A 48.29 Mbps 50.33 Mbps PT. Indonesia Comnets Plus - Surabaya
Yogyakarta 192.48 ms 0.0% 48.33 Mbps 43.68 Mbps PT Union Routelink Communication - Yogyakarta
Banda Aceh 187.68 ms 0.0% 48.34 Mbps 50.51 Mbps PT. Telekomunikasi Indonesia - Banda Aceh
Medan 181.09 ms 0.0% 47.75 Mbps 50.15 Mbps Biznet Networks - Medan
Palembang 269.46 ms N/A 47.24 Mbps 25.37 Mbps PT. Sakti Putra Mandiri - Palembang
Pekanbaru 443.36 ms 0.0% 20.20 Mbps 22.15 Mbps PT Hexa Media Sarana - Pekanbaru
Bali 202.91 ms 50.26 Mbps FAILED Biznet Networks - Bali
Makassar 230.23 ms 11.0% 48.31 Mbps 0.54 Mbps Biznet Networks - Makassar
Depok 186.00 ms 0.0% 48.41 Mbps 36.05 Mbps ADI - Depok
Tangerang 228.45 ms 0.0% 49.16 Mbps 39.32 Mbps PT. Java Medianet Tekhnologi - Tangerang
Avg DL Speed : 47.53 Mbps
Avg UL Speed : 40.43 Mbps
Total DL Data : 1.37 GB
Total UL Data : 1.95 GB
Total Data : 3.32 GB
Duration : 10 min 58 sec
System Time : 22/09/2023 - 15:57:04 UTC
Total Script Runs : 23831
curl is not installed, Unable to share result online
Result stored locally in //network-speed.txt
Basic System Info
CPU Model : AMD EPYC 7B13 64-Core Processor
CPU Cores : 2 @ 2245.780 MHz
CPU Cache : 512 KB
AES-NI : ✔ Enabled
Total Disk : 59.9 GB (2.2 GB Used)
Total RAM : 3.8 GB (364.4 MB Used)
System uptime : 0 days, 0 hour 36 min
OS : Debian GNU/Linux 12
Kernel : 6.1.0-9-amd64
Basic Network Info
ISP : WebHorizon Internet Services
ASN : AS149020 WebHorizon Internet Services
Host : WebHorizon
ISP: WebHorizon Internet Services
Nearest 0.26 ms 0.0% 4915.13 Mbps 3647.92 Mbps PT FirstMedia - Singapore
Jakarta 14.67 ms 0.0% 863.03 Mbps 902.59 Mbps Hutchison 3 Indonesia CGK-MM - Jakarta
Jakarta 15.01 ms 0.0% 4150.09 Mbps 243.04 Mbps DomaiNesia - Jakarta
Jakarta 16.06 ms 0.0% 1759.12 Mbps 431.09 Mbps PT. Telekomunikasi Indonesia - Jakarta
Jakarta 13.23 ms 0.0% 2093.69 Mbps 6471.44 Mbps PT Indosat Tbk - Jakarta
Jakarta 14.72 ms 0.0% 2052.07 Mbps 4559.06 Mbps MyRepublic Indonesia - South Jakarta
Bandung 16.99 ms N/A 444.35 Mbps 278.21 Mbps HYPERNET - Bandung
Bekasi 13.39 ms 0.0% 860.97 Mbps 907.07 Mbps PT Lintas Jaringan Nusantara - Bekasi
Bogor 14.35 ms 0.0% 921.44 Mbps 803.03 Mbps PT. Java Digital Nusantara - Bogor
Malang 24.16 ms 0.0% 2530.19 Mbps 436.33 Mbps GlobalXtreme - Malang
Semarang 21.29 ms N/A 4779.51 Mbps 3981.54 Mbps PT. Indonesia Comnets Plus - Semarang
Surabaya 26.00 ms N/A 5009.89 Mbps 3358.53 Mbps PT. Indonesia Comnets Plus - Surabaya
Yogyakarta 22.70 ms 0.0% 781.00 Mbps 227.61 Mbps PT Union Routelink Communication - Yogyakarta
Banda Aceh 18.24 ms 0.0% 4324.44 Mbps 560.96 Mbps PT. Telekomunikasi Indonesia - Banda Aceh
Medan 12.91 ms 0.0% 2821.18 Mbps 600.19 Mbps Biznet Networks - Medan
Palembang 21.50 ms N/A 928.05 Mbps 678.01 Mbps PT. Sakti Putra Mandiri - Palembang
Pekanbaru 24.45 ms 0.0% 151.42 Mbps 351.83 Mbps PT Hexa Media Sarana - Pekanbaru
Bali 34.17 ms 0.9% 1915.98 Mbps 2.00 Mbps Biznet Networks - Bali
Makassar 57.67 ms 11.0% 1972.77 Mbps 2.53 Mbps Biznet Networks - Makassar
Depok 17.75 ms 0.0% 458.97 Mbps 78.38 Mbps ADI - Depok
Tangerang 12.67 ms 0.0% 938.26 Mbps 258.39 Mbps PT. Java Medianet Tekhnologi - Tangerang
Avg DL Speed : 2127.22 Mbps
Avg UL Speed : 1370.46 Mbps
Total DL Data : 56.63 GB
Total UL Data : 37.24 GB
Total Data : 93.88 GB
Duration : 8 min 53 sec
System Time : 22/09/2023 - 17:10:55 BST
Total Script Runs : 23832
Result stored locally in /root/network-speed.txt
Region Speedtest : wget -qO- network-speed.xyz | bash -s -- -r <region>
Basic System Info
CPU Model : AMD EPYC-Rome Processor
CPU Cores : 1 @ 2349.998 MHz
CPU Cache : 512 KB
AES-NI : ✔ Enabled
VM-x/AMD-V : ❌ Disabled
Total Disk : 39.3 GB (2.5 GB Used)
Total RAM : 1.9 GB (178.1 MB Used)
System uptime : 4 days, 6 hour 40 min
Kernel : 5.10.0-21-amd64
Basic Network Info
ISP : GoDaddy.com, LLC
ASN : AS26496 GoDaddy.com, LLC
ASN (IPv4) : AS398791 GoDaddy.com, LLC
Host : Godaddy.com
Location (IPv4) : Mumbai, Maharashtra, IN
ISP: GoDaddy.com, LLC
Nearest 1.96 ms 0.0% 976.93 Mbps 8701.94 Mbps Tata Play Fiber - Mumbai
Jakarta 66.36 ms 0.0% 228.54 Mbps 666.23 Mbps Hutchison 3 Indonesia CGK-MM - Jakarta
Jakarta 186.11 ms 0.0% 969.07 Mbps 396.65 Mbps DomaiNesia - Jakarta
Jakarta 193.78 ms 0.0% 1010.97 Mbps 364.28 Mbps PT. Telekomunikasi Indonesia - Jakarta
Jakarta 175.54 ms 0.0% 865.43 Mbps 405.11 Mbps PT Indosat Tbk - Jakarta
Jakarta 140.23 ms 0.0% 178.82 Mbps 570.46 Mbps MyRepublic Indonesia - South Jakarta
Bandung 160.27 ms N/A 24.43 Mbps 272.39 Mbps HYPERNET - Bandung
Bekasi 159.61 ms 0.8% 702.87 Mbps 426.60 Mbps PT Lintas Jaringan Nusantara - Bekasi
Bogor 156.44 ms 0.0% 683.34 Mbps 504.78 Mbps PT. Java Digital Nusantara - Bogor
Malang 80.21 ms 0.0% 120.89 Mbps 657.75 Mbps GlobalXtreme - Malang
Semarang 77.41 ms N/A 868.05 Mbps 1007.38 Mbps PT. Indonesia Comnets Plus - Semarang
Surabaya 73.38 ms N/A 172.42 Mbps 1082.82 Mbps PT. Indonesia Comnets Plus - Surabaya
Yogyakarta 278.77 ms 0.7% 705.29 Mbps 111.80 Mbps PT Union Routelink Communication - Yogyakarta
Banda Aceh 173.33 ms 0.0% 999.40 Mbps 439.76 Mbps PT. Telekomunikasi Indonesia - Banda Aceh
Medan 172.16 ms 0.0% 818.48 Mbps 482.82 Mbps Biznet Networks - Medan
Palembang 260.54 ms N/A 928.06 Mbps 295.75 Mbps PT. Sakti Putra Mandiri - Palembang
Pekanbaru 81.98 ms 0.0% 173.01 Mbps 393.50 Mbps PT Hexa Media Sarana - Pekanbaru
Bali 194.75 ms 19.4% 991.68 Mbps 16.79 Mbps Biznet Networks - Bali
Makassar 209.39 ms 6.3% 508.01 Mbps 12.16 Mbps Biznet Networks - Makassar
Depok 79.69 ms 0.0% 485.79 Mbps 401.32 Mbps ADI - Depok
Tangerang 154.66 ms 0.0% 942.82 Mbps 457.53 Mbps PT. Java Medianet Tekhnologi - Tangerang
Avg DL Speed : 635.92 Mbps
Avg UL Speed : 841.32 Mbps
Total DL Data : 19.28 GB
Total UL Data : 23.89 GB
Total Data : 43.18 GB
Duration : 11 min 6 sec
System Time : 22/09/2023 - 16:15:43 UTC
Total Script Runs : 23833
Result : https://result.network-speed.xyz/r/1695399346_WCAH5A_INDONESIA.txt
I just wanted to give a shout-out and HUGE THANKS to @crunchbits for sponsoring a VPS.
This will now be hosting everything related to network-speed (Nginx, flask apps, results storage etc.)
I was hosting everything on my own VPSs', but recently it has been unstable for a while (thankfully, no one seems to have noticed it). It was first on Virmach Seattle, which was fine till the IP fiasco happened, and then I moved over to LittleCreek but again they had lots of network-related issues, switched back to Virmach SEA till it went dead, moved to Limewave - but they were oversold and had intermittent issues...
Anyways, Crunchbits is prem, so I do not expect any more issues in the future
Also, I forgot about this yesterday, but shout-out to my bro @febryanvaldo for helping me pick some locations for the Indonesia Speedtest!
Basic System Info
CPU Model : Intel(R) Xeon(R) CPU E5-2680 v2 @ 2.80GHz
CPU Cores : 1 @ 2799.998 MHz
AES-NI : ✔ Enabled
Total Disk : 23.5 GB (5.7 GB Used)
Total RAM : 969.4 MB (859.0 MB Used)
Total Swap : 1024.0 MB (308.7 MB Used)
System uptime : 0 days, 3 hour 16 min
Load average : 0.92, 0.96, 0.74
OS : Ubuntu 22.04.2 LTS
Kernel : 5.15.0-70-generic
Basic Network Info
ISP : ColoCrossing
ASN : AS36352 ColoCrossing
Host : ColoCrossing
Location (IPv4) : San Jose, California, US
ISP: ColoCrossing
Nearest 63.82 ms 0.0% 601.41 Mbps 830.27 Mbps WebNX Inc - New York, NY
Jakarta 197.65 ms 0.0% 867.30 Mbps 328.92 Mbps Hutchison 3 Indonesia CGK-MM - Jakarta
Jakarta 194.09 ms 0.0% 456.83 Mbps 297.60 Mbps DomaiNesia - Jakarta
Jakarta 209.49 ms 0.0% 526.33 Mbps 283.40 Mbps PT. Telekomunikasi Indonesia - Jakarta
Jakarta 267.43 ms 0.0% 508.55 Mbps 202.15 Mbps PT Indosat Tbk - Jakarta
Jakarta 192.82 ms 0.0% 313.44 Mbps 464.61 Mbps MyRepublic Indonesia - South Jakarta
Bandung 198.32 ms N/A 269.18 Mbps 69.20 Mbps HYPERNET - Bandung
Bekasi 191.43 ms 0.0% 737.55 Mbps 425.33 Mbps PT Lintas Jaringan Nusantara - Bekasi
Bogor 198.18 ms 0.7% 197.94 Mbps 427.66 Mbps PT. Java Digital Nusantara - Bogor
Malang 200.18 ms 0.0% 663.44 Mbps 449.24 Mbps GlobalXtreme - Malang
Semarang 200.92 ms N/A 566.63 Mbps 439.99 Mbps PT. Indonesia Comnets Plus - Semarang
Surabaya 200.36 ms N/A 511.40 Mbps 463.22 Mbps PT. Indonesia Comnets Plus - Surabaya
Yogyakarta FAILED
Banda Aceh 203.39 ms 0.0% 528.47 Mbps 443.14 Mbps PT. Telekomunikasi Indonesia - Banda Aceh
Medan 193.47 ms 0.0% 593.90 Mbps 487.15 Mbps Biznet Networks - Medan
Palembang 194.64 ms N/A 765.04 Mbps 372.11 Mbps PT. Sakti Putra Mandiri - Palembang
Pekanbaru 192.37 ms 0.3% 547.04 Mbps 42.76 Mbps PT Hexa Media Sarana - Pekanbaru
Bali 245.84 ms 0.0% 501.54 Mbps 379.56 Mbps Biznet Networks - Bali
Makassar 257.05 ms 0.0% 158.89 Mbps 334.90 Mbps Biznet Networks - Makassar
Depok 187.26 ms 1.0% 859.30 Mbps 50.51 Mbps ADI - Depok
Tangerang 194.66 ms 0.0% 817.25 Mbps 175.82 Mbps PT. Java Medianet Tekhnologi - Tangerang
Avg DL Speed : 549.58 Mbps
Avg UL Speed : 348.38 Mbps
Total DL Data : 16.30 GB
Total UL Data : 10.40 GB
Total Data : 26.70 GB
Duration : 11 min 5 sec
System Time : 23/09/2023 - 17:24:53 UTC
Result : https://result.network-speed.xyz/r/1695489818_CZYS4H_INDONESIA.txt
creates internal doc to make every tech randomly start/stop your VM throughout their shift
I ran only 2 tests and speedtest has rate limited my IP @sh97
[2023-09-28 14:53:46.475] [error] Limit reached:
Speedtest CLI. Too many requests received. To maintain a fair and stable environment, please review and adjust the frequency of your requests.
Yes, Ookla started rate limiting in July.
Wait for an hour, it will be back to normal.
We can only run max 30 tests in an hour.
Basic System Info
CPU Model : AMD EPYC 7713 64-Core Processor
CPU Cores : 1 @ 2000.000 MHz
CPU Cache : 512 KB
AES-NI : ✔ Enabled
Total Disk : 24.0 GB (1.7 GB Used)
Total RAM : 964.6 MB (101.6 MB Used)
Total Swap : 512.0 MB (512.0 KB Used)
System uptime : 0 days, 21 hour 40 min
Basic Network Info
ISP : Akamai Technologies, Inc.
ASN : AS63949 Akamai Connected Cloud
Host : Linode
ISP: Akamai Connected Cloud
Nearest 0.81 ms 0.0% 4824.64 Mbps 999.04 Mbps TIM Brasil - São Paulo
Kochi, IN 363.33 ms 0.0% 2139.82 Mbps 207.92 Mbps Asianet Broadband - Cochin
Bangalore, IN 342.60 ms 0.0% 2304.03 Mbps 239.64 Mbps Bharti Airtel Ltd - Bangalore
Chennai, IN 395.46 ms N/A 598.47 Mbps 175.77 Mbps Jio - Chennai
Mumbai, IN 367.95 ms 0.0% 2077.16 Mbps 202.89 Mbps i3D.net - Mumbai
Delhi, IN 390.21 ms 0.0% 1518.97 Mbps 189.16 Mbps Tata Teleservices Ltd - New Delhi
Seattle, US 181.84 ms 0.0% 3975.21 Mbps 456.56 Mbps Ziply Fiber - Seattle, WA
Los Angeles, US 186.86 ms 0.0% 3849.44 Mbps 436.97 Mbps ReliableSite Hosting - Los Angeles, CA
Dallas, US 141.36 ms 0.0% 5563.61 Mbps 602.98 Mbps Hivelocity - Dallas, TX
Miami, US 131.12 ms 0.0% 4957.02 Mbps 617.15 Mbps AT&T - Miami, FL
New York, US 124.75 ms 0.0% 4207.88 Mbps 654.31 Mbps GSL Networks - New York, NY
Toronto, CA 125.36 ms 0.0% 6088.72 Mbps 634.08 Mbps Rogers - Toronto, ON
London, UK 178.89 ms 0.0% 4433.51 Mbps 466.67 Mbps VeloxServ Communications - London
Amsterdam, NL 204.35 ms 0.0% 3865.89 Mbps 403.23 Mbps 31173 Services AB - Amsterdam
Paris, FR 228.20 ms N/A 3287.95 Mbps 355.29 Mbps Axione - Paris
Frankfurt, DE 191.94 ms 0.0% 4058.94 Mbps 416.90 Mbps 23M GmbH - Frankfurt am Main
Warsaw, PL 240.91 ms 0.0% 3254.91 Mbps 333.60 Mbps UPC Polska - Warszawa
Bucharest, RO 245.71 ms 0.0% 3215.26 Mbps 332.00 Mbps Vodafone Romania Fixed – Bucharest - Bucharest
Jeddah, SA 247.85 ms 0.0% 2722.38 Mbps 333.50 Mbps Saudi Telecom Company
Dubai, AE 338.31 ms 0.0% 2380.66 Mbps 252.32 Mbps du - Dubai
Fujairah, AE 322.08 ms 0.0% 2438.31 Mbps 248.71 Mbps ETISALAT-UAE - Fujairah
Tokyo, JP 278.44 ms N/A 2827.14 Mbps 294.92 Mbps fdcservers.net - Tokyo
Shanghai, CU-CN 364.43 ms 0.7% 50.26 Mbps 172.98 Mbps China Unicom 5G - Shanghai
Nanjing, CT-CN 381.88 ms 0.0% 1156.85 Mbps 59.87 Mbps China Telecom JiangSu 5G - Nanjing
Hong Kong, CN 330.74 ms N/A 2385.11 Mbps 237.60 Mbps STC - Hong Kong
Singapore, SG 349.61 ms 0.0% 1912.80 Mbps 209.39 Mbps i3D.net - Singapore
Jakarta, ID 386.66 ms 0.0% 1773.99 Mbps 129.19 Mbps PT. Telekomunikasi Indonesia - Jakarta
Avg DL Speed : 3032.18 Mbps
Avg UL Speed : 357.88 Mbps
Total DL Data : 112.79 GB
Total UL Data : 13.78 GB
Total Data : 126.58 GB
Duration : 15 min 52 sec
System Time : 28/09/2023 - 14:15:40 UTC
Total Script Runs : 24342
Result : https://result.network-speed.xyz/r/1695910423_TKOFM5_GLOBAL.txt
Basic System Info
CPU Cores : 1 @ 1999.998 MHz
CPU Cache : 512 KB
AES-NI : ✔ Enabled
Total RAM : 964.6 MB (147.6 MB Used)
Total Swap : 512.0 MB (256.0 KB Used)
System uptime : 0 days, 22 hour 9 min
Load average : 0.11, 0.04, 0.01
Basic Network Info
Host : Linode
ISP: Akamai Technologies
Nearest 0.62 ms 0.0% 637.36 Mbps 792.96 Mbps Rainbow Communications India Pvt Ltd - Chennai
Kochi, IN 11.37 ms 0.0% 5652.85 Mbps 997.57 Mbps Asianet Broadband - Cochin
Bangalore, IN 5.80 ms 0.0% 5067.40 Mbps 994.42 Mbps Bharti Airtel Ltd - Bangalore
Chennai, IN 1.20 ms N/A 5263.57 Mbps 998.35 Mbps Jio - Chennai
Mumbai, IN 45.77 ms 0.0% 5409.46 Mbps 1005.73 Mbps i3D.net - Mumbai
Delhi, IN 37.09 ms 0.0% 2761.44 Mbps 1016.61 Mbps Tata Teleservices Ltd - New Delhi
Seattle, US 367.02 ms 1.8% 1093.19 Mbps 108.56 Mbps Ziply Fiber - Seattle, WA
Los Angeles, US 276.04 ms 0.0% 29.40 Mbps 257.70 Mbps ReliableSite Hosting - Los Angeles, CA
Dallas, US 284.33 ms 0.0% 1.54 Mbps 288.22 Mbps Hivelocity - Dallas, TX
Miami, US 269.96 ms 0.0% 2940.06 Mbps 307.93 Mbps AT&T - Miami, FL
New York, US 221.66 ms 0.0% 2879.03 Mbps 362.50 Mbps GSL Networks - New York, NY
Toronto, CA 237.20 ms 0.0% 2141.05 Mbps 341.06 Mbps Rogers - Toronto, ON
London, UK 157.98 ms 0.0% 4058.15 Mbps 521.11 Mbps VeloxServ Communications - London
Amsterdam, NL 154.39 ms 0.0% 4618.05 Mbps 532.64 Mbps 31173 Services AB - Amsterdam
Paris, FR 166.27 ms N/A 4778.79 Mbps 493.17 Mbps Axione - Paris
Frankfurt, DE 147.32 ms 0.0% 5279.03 Mbps 551.21 Mbps 23M GmbH - Frankfurt am Main
Warsaw, PL 164.14 ms 0.0% 4747.00 Mbps 512.51 Mbps UPC Polska - Warszawa
Bucharest, RO 176.18 ms 0.0% 4459.20 Mbps 465.84 Mbps Vodafone Romania Fixed – Bucharest - Bucharest
Jeddah, SA 228.21 ms 0.0% 3520.17 Mbps 366.44 Mbps Saudi Telecom Company
Dubai, AE 59.38 ms 0.0% 608.78 Mbps 1078.07 Mbps du - Dubai
Fujairah, AE 65.33 ms 0.0% 6226.61 Mbps 863.73 Mbps ETISALAT-UAE - Fujairah
Tokyo, JP 235.45 ms N/A 3192.57 Mbps 328.06 Mbps fdcservers.net - Tokyo
Shanghai, CU-CN 316.81 ms 0.0% 2056.43 Mbps 216.46 Mbps China Unicom 5G - Shanghai
Nanjing, CT-CN 400.63 ms 0.7% 1578.93 Mbps 177.68 Mbps China Telecom JiangSu 5G - Nanjing
Hong Kong, CN 186.15 ms N/A 2106.27 Mbps 432.93 Mbps STC - Hong Kong
Singapore, SG 449.01 ms 0.0% 673.24 Mbps 93.41 Mbps i3D.net - Singapore
Jakarta, ID 327.02 ms 0.0% 2237.25 Mbps 189.45 Mbps PT. Telekomunikasi Indonesia - Jakarta
Avg DL Speed : 3111.74 Mbps
Avg UL Speed : 529.41 Mbps
Total DL Data : 110.38 GB
Total UL Data : 20.02 GB
Total Data : 130.41 GB
Duration : 14 min 11 sec
System Time : 28/09/2023 - 14:13:30 UTC
Total Script Runs : 24341
Result : https://result.network-speed.xyz/r/1695910293_M1PTTT_GLOBAL.txt
Basic System Info
CPU Cores : 1 @ 1999.999 MHz
CPU Cache : 512 KB
AES-NI : ✔ Enabled
Total Disk : 24.0 GB (1.1 GB Used)
Total RAM : 964.6 MB (54.8 MB Used)
Total Swap : 512.0 MB (0 Used)
System uptime : 0 days, 17 hour 17 min
Basic Network Info
Host : Akamai Technologies, Inc.
Nearest 0.42 ms 0.0% 3273.71 Mbps 983.92 Mbps CBN - Jakarta
Kochi, IN 59.22 ms 0.0% 2823.91 Mbps 995.93 Mbps Asianet Broadband - Cochin
Bangalore, IN 49.78 ms 0.0% 3026.08 Mbps 1037.05 Mbps Bharti Airtel Ltd - Bangalore
Chennai, IN 121.36 ms N/A 3229.39 Mbps 878.17 Mbps Jio - Chennai
Mumbai, IN 65.10 ms 0.0% 3000.89 Mbps 1033.85 Mbps i3D.net - Mumbai
Delhi, IN 91.38 ms 0.0% 2424.21 Mbps 977.74 Mbps Tata Teleservices Ltd - New Delhi
Seattle, US 206.97 ms 0.0% 1397.04 Mbps 457.70 Mbps Ziply Fiber - Seattle, WA
Los Angeles, US 193.23 ms 0.0% 3283.35 Mbps 242.82 Mbps ReliableSite Hosting - Los Angeles, CA
Dallas, US 209.77 ms 0.0% 1408.33 Mbps 521.51 Mbps Hivelocity - Dallas, TX
Miami, US 250.09 ms 0.0% 1677.19 Mbps 453.71 Mbps AT&T - Miami, FL
New York, US 253.95 ms 0.0% 1114.51 Mbps 452.05 Mbps GSL Networks - New York, NY
Toronto, CA 276.41 ms 0.0% 1125.88 Mbps 352.04 Mbps Rogers - Toronto, ON
London, UK 236.91 ms 0.0% 1336.30 Mbps 455.07 Mbps VeloxServ Communications - London
Amsterdam, NL 253.45 ms 0.0% 1382.85 Mbps 437.47 Mbps 31173 Services AB - Amsterdam
Paris, FR 344.02 ms N/A 1418.35 Mbps 1.55 Mbps Axione - Paris
Frankfurt, DE 262.19 ms 0.0% 2768.60 Mbps 348.14 Mbps 23M GmbH - Frankfurt am Main
Warsaw, PL 369.06 ms 0.0% 2258.41 Mbps 314.82 Mbps UPC Polska - Warszawa
Bucharest, RO 192.60 ms 0.0% 708.32 Mbps 457.07 Mbps Vodafone Romania Fixed – Bucharest - Bucharest
Jeddah, SA 108.93 ms 0.0% 1707.21 Mbps 900.58 Mbps Saudi Telecom Company
Dubai, AE 270.89 ms 0.0% 2758.85 Mbps 419.66 Mbps du - Dubai
Fujairah, AE 160.90 ms 0.0% 1671.03 Mbps 648.28 Mbps ETISALAT-UAE - Fujairah
Tokyo, JP 187.54 ms N/A 1932.29 Mbps 165.63 Mbps fdcservers.net - Tokyo
Shanghai, CU-CN 274.82 ms 20.4% 1199.66 Mbps 0.30 Mbps China Unicom 5G - Shanghai
Nanjing, CT-CN FAILED
Hong Kong, CN 49.04 ms N/A 3129.97 Mbps 945.34 Mbps STC - Hong Kong
Singapore, SG 82.58 ms 0.0% 3201.57 Mbps 1066.41 Mbps i3D.net - Singapore
Jakarta, ID 100.04 ms 0.0% 2756.33 Mbps 361.14 Mbps PT. Telekomunikasi Indonesia - Jakarta
Avg DL Speed : 2154.39 Mbps
Avg UL Speed : 573.38 Mbps
Total DL Data : 77.52 GB
Total UL Data : 21.82 GB
Total Data : 99.34 GB
Duration : 14 min 52 sec
System Time : 28/09/2023 - 14:12:53 UTC
Total Script Runs : 24340
Result : https://result.network-speed.xyz/r/1695910256_RC4N09_GLOBAL.txt
Hosthatch BF2021 Flash — Storage 2TB
Sultan Muda - Amazon Store
FreeVPS
NanoKVM
MicroLXC
https://webhorizon.net
Nice network speed, do you offer free blesta license sir?
No sir
The Ultimate Speedtest Script | Get Instant Alerts on new LES/LET deals | Cheap VPS Deals
Racknerd New Year 2023
NVMe VPS | Ryzen 7950X VDS | Dedicated Servers -- Crunchbits.com
Xeroz.Tech - Mumbai, MH - India - EUR 1.3/month
Linode Chennai,
@dosai how did you get into greenlight?
I pinged a staff on the slack group.
How did you get into their internal slack?
It supposed to be invite only.
It is open https://linodegreenlight.slack.com/
Not really, its not mentioned anywhere on the page.
The only option they give you, is to enter an email and get notified.
Never got a single email.
Yes, that's why I said I pinged a staff on their slack group to get the access.
I just got in, thanks for the tip.
The Beta seems to be even partially free.
@dosai could you also share an Asia speedtest? Interested in seeing the general connectivity.
HostHatch storage Netherlands
