WebHorizon's NAT VPS Services: Changes upcoming, Migration to HostBill!
13
  • rskrsk Hosting Provider
    I really wonder how you manage all the different types of abuse with a single ipv4? Some people take advantage of this, and this whole whack-a-mole thing takes a lot of time from sysadmins.
  • @flo82 said:
    I noticed the following limitations after the migration:
    • No more domain forwarding via ipv4 (only ipv6 works)
    • no more unlimited traffic with reduced speeds (Machine is cut off after included bandwidth has been used)
    • All migrated services are merged to one billed entity (See calculations proposed above)
    • no more email notifications (support reply, bandwidth etc)
    • Stopping/starting VPS from the panel does not work and needs manual intervention from support
    • Reinstalling VPS does not work. Support can only install AlmaLinux 9 manually which works great on a 256MB VPS
    Thanked by (3)FrankZ admax fluttershy
    @Brueggus - thanks for sharing those last two very important points. :+1:
  • edited September 2023
    I want to know if there is a new promo plan?
    The migration was well done, and I really appreciate support person of Web Horizon for his / her kindness, diligence, and professionalism.
    Excuse me, but I've encountered some minor problems, and maybe someone could guide me through.
    • Modification of host name is reset after reboot.
      Usually I can change host name by modifying the content of /etc/hostname, but now the change can't resist a system reboot, and will be restored thereafter.
      So can I disable something like automatic start-up initialisation to prevent this?
    • Cannot append IPv6 addresses in the control panel.
      It's easy to append some IPv6s within the /80 prefix in the old panel, but now there seems no way to do that in the new one.
      Or in other VPS, just modify the content of /etc/systemd/network/20-wired.network or /etc/network/interfaces, but here I'm told
      # This configuration file is auto-generated.
      # WARNING: Do not edit this file, otherwise your changes will be lost.
      # Please edit template /etc/network/interfaces.template instead.
    But the template doesn't exist. What should I do?
    Thank you very much.
    Yes we discontinued domain forwarding, kept breaking and takes time. Then I also got few tickets asking how to setup v2ray ss proxy and left bad reviews when I didn't install it for them . Had we not done that things would have turned worse and I'll have to discontinue nat services altogether. After deducting costs, it does not leave enough to appoint a good full time staff who can take care of everything without my intervention.
    I did not want to discontinue NAT, because, that's how I started in this business, gaining experience and learning in the process.
    It's a limitation of the new control panel implementation, sorry can't be unlimited anymore for nat services.
    Only for migrated services, again it was a limitation of the new control panel import function.
    fixed.
    fixed.
    fixed.
    Thanked by (2)FrankZ Ayyub
    I will do something LES exclusive soon. :)
    On OVZ7, It restores to default service name used in panel. Maybe we can add a function to change the service name in panel so it can change the hostname in vps aswell. I will look into if it is achievable easily.
    Please make a ticket asking to add more individual ipv6 address on your vps.
    This can be automated from panel in future, I will look into the possibilities.
    Thanked by (2)FrankZ bliss
    @Abdullah said: Then I also got few tickets asking how to setup v2ray ss proxy and left bad reviews when I didn't install it for them .
    I know for sure there was an article in the knowledge base clearly demonstrating how to install and config ss or v2ray, which surprised me a little then since most providers avoid it.
    I'm sorry but some customers just bite the hand that feeds them. How could the customers blame the provider because of their own inability? This is not a managed service, nor is technical support included.
    @Abdullah said: This can be automated from panel in future, I will look into the possibilities.
    No problem, these are just trivial problems.
    Thanked by (2)sh97 Abdullah
    I can't wait to make it come faster. :p
    My legacy products are gone and every NAT VPS is a separate product now which makes things a lot easier. All of them renew at $7/year, but I suspect that will need to be corrected manually to match the old pricing?
    @Abdullah said: no more email notifications (support reply, bandwidth etc)
    fixed.
    I still don't get any email notifications for ticket updates although the box is ticked in my account settings. There's still no option to set the hostname and to set IPv6 addresses.
    Most of my VPS are running fine, though. Only Los Angeles has broken IPv6 for two weeks now. Support says it's an upstream issue (Shock Hosting iirc)
    So all in all it's the typical Webhorizon experience and things kind of work. Let's see what their next migration holds for us. :#
    Thanked by (2)yoursunny admax
  • @Brueggus said: My legacy products are gone and every NAT VPS is a separate product now which makes things a lot easier. All of them renew at $7/year, but I suspect that will need to be corrected manually to match the old pricing?
    Yes, we implemented that change yesterday. As you said, this will make server recognition and handling much easier and the more important point is that, now we can adjust the billings for each server separately as it was the case in our old billing system.
    The billings will be adjusted in the coming days.
    Thanked by (3)Abdullah Brueggus FrankZ
    I'm a host rep for WebHorizon [AS149020] - VPS, Dedicated Servers, Web & Email Hosting
    Singapore, Japan, India, Netherlands & Norway
  • It says services has been migrated but all my services stay in my.webhorizon.net/client/
    Did you missed something @Abdullah
  • I have a phantom service in Switzerland.
    I used to have a 5-location bundle that includes Switzerland.
    During an outage, I requested to replace this container with another location.
    Subsequently, I transferred the bundle to someone else.
    Miraculously, the Switzerland container came online again after some months.
    It has been working until earlier this month.
    Now it's showing ENOSPC error on disk writes.
    I guess the spectre lost soul will be hunted down soon?
    On the other hand, the Singapore KVM is very fragrant.
    It has good connectivity to Mumbai, Tokyo, Sydney: direct connection, not detour through Europe or North America.
    Thanked by (1)Abdullah
    No hostname left!
  • @yoursunny said: I have a phantom service in Switzerland.
    Relax, man. That will rest in peace soon.
    I made some changes, can you check now ?
    @jarland is the Postmaster General now.
    Thanked by (1)jarland
    That's unfortunate, it seems like an important feature for anyone who wants to serve HTTP from the VPS.
  • That's unfortunate, it seems like an important feature for anyone who wants to serve HTTP from the VPS.
    That wouldn't be a problem unless you want to server HTTP/HTTPS (or any other traffic) directly on the IPv4 itself (which is odd).
    You can use IPv6 and much better option is to have a domain (or a subdomain) and configure it so that incoming traffics to that domain on port 80 or 443 (HTTP and HTTPS ports respectively) automatically gets forwarded to the ports that are available to your Nat server (you can easily achieve that we Cloudflare's Origin Rules)
    No, it's not odd, it's how the Internet is supposed to work.
    Some people may not wish to use Cloudflare for whatever reason.
    Still not working. I do get other emails like "New VPS Account Created" but no message when tickets are updated.
  • jarlandjarland OGServices Provider
    Happy to check on any of this on my side if desired by @Abdullah.
    edited October 2023
    SMTP settings for Support Department were misconfigured. Correcting them has resolved it. Thanks for the help. :3
    Yep, working now.
    @Abdullah are all changes for NAT VPS migration to the new billing panel regarding renewal prices and dates final at this time ?
  • @Brueggus said: Los Angeles has broken IPv6 for two weeks now. Support says it's an upstream issue (Shock Hosting iirc)
    They stopped responding to my ticket so I guess they're unwilling or unable to resolve the issue. To get this sorted, I asked them to redeploy my service in Singapore instead. As far as I know, they're running their own network there, so there shouldn't be any "upstream issues".
    Support responded quickly and I got my service in Singapore - with broken IPv6. sigh
    Thanked by (2)FrankZ yoursunny
    Yes they are final now. :)
  • Has anyone else had their HongKongNAT service disappear since yesterday?
    I haven't heard from them but I think they may be in Migration, I'm going to wait a couple of days and contact support if no one else is in the same situation. ^ฅωฅ^
    ( ๑´•ω•)۶”ฅ^•ﻌ•^ฅ ʕ•̫͡•ʕ•̫͡•ʔ•̫͡•ʔ•̫͡•ʕ•̫͡•ʔ•̫͡•ʕ•̫͡•ʕ•̫͡•ʔ•̫͡•ʔ
    I'm in the same situation, so you are not alone.
    Thanked by (1)Konbu
    Thank you very much. I am relieved to hear that I am not alone.
    Fingers crossed that it will be restored in the next few days.٩(ˊᗜˋ*)و
    edited October 2023
    If I am correct WebHorizon HK NAT is with HostHatch. HH does not have the fastest support response, so I am normally pretty calm when this location goes dark as I am sure Abdullah is on it and it will get taken care of eventually.
    Thanked by (2)Konbu Abdullah
