Updated to v2023.09.30
* Fix a major bug - ip6.me, which was used for determining the IP address was down, and there was no timeout, which meant the script would never start working (stuck at Basic Network Info). Thanks to my bro @febryanvaldo for notifying me about this issue.
* Add v4/v6 checker (copied shamelessly from YABS)
* Updated Asia Region tests/servers.
---------------------------- network-speed.xyz ----------------------------
A simple script to test network performance using speedtest-cli
Version : v2023.09.30
Global Speedtest : wget -qO- network-speed.xyz | bash
Region Speedtest : wget -qO- network-speed.xyz | bash -s -- -r <region>
Basic System Info
CPU Model : Intel(R) Xeon(R) CPU E5-2698 v4 @ 2.20GHz
CPU Cores : 4 @ 2199.986 MHz
CPU Cache : 16384 KB
AES-NI : ✔ Enabled
Total Disk : 55.1 GB (33.2 GB Used)
Total RAM : 7.8 GB (487.0 MB Used)
Total Swap : 4.0 GB (0 Used)
System uptime : 30 days, 4 hour 42 min
Load average : 0.16, 0.24, 0.16
OS : Ubuntu 22.04.3 LTS
Arch : x86_64 (64 Bit)
Kernel : 5.15.0-82-generic
Virtualization : KVM
Basic Network Info
IPv6 Access : ✔ Online
IPv4 Access : ✔ Online
ISP : Leaseweb Singapore
ASN : AS59253 Leaseweb Asia Pacific pte. ltd.
Host : Leaseweb Asia Pacific pte. ltd
Speedtest.net (Region: ASIA)
Location Latency Loss DL Speed UP Speed Server
ISP: Leaseweb Asia
Nearest 0.70 ms N/A 5660.68 Mbps 8041.36 Mbps fdcservers.net - Singapore
Tokyo, JP 75.68 ms 0.0% 3219.01 Mbps 523.61 Mbps Rakuten Mobile, Inc - Tokyo
Tapei, TW 187.84 ms N/A 3310.29 Mbps 529.48 Mbps Chunghwa Mobile - Taipei
China Telecom 348.26 ms 0.0% 1334.23 Mbps 89.36 Mbps China Telecom JiangSu 5G - Nanjing
China Unicom 335.01 ms 0.0% 594.66 Mbps 326.76 Mbps China Unicom 5G - Shanghai
China Mobile 684.96 ms 0.7% 172.33 Mbps 12.49 Mbps China Mobile Henan 5G - Zhengzhou
Hong Kong, CN 36.78 ms 0.0% 3869.51 Mbps 2366.38 Mbps i3D.net - Hong Kong
Ho Chi Minh, VN 66.05 ms N/A 926.34 Mbps 274.45 Mbps Vietnamobile - Ho Chi Minh
Hanoi, VN 131.70 ms N/A 451.82 Mbps 353.48 Mbps Viettel IDC - Hanoi
Bangkok, TH 25.39 ms 0.0% 3444.71 Mbps 2461.28 Mbps 3BB - Bangkok
Manila, PH 80.40 ms 1.5% 3969.68 Mbps 5.73 Mbps PLDT - Manila
Singapore, SG 0.74 ms 0.0% 5589.92 Mbps 8729.13 Mbps MyRepublic Singapore - Singapore
Singapore, SG 1.36 ms N/A 8951.48 Mbps 6800.06 Mbps StarHub Ltd - Singapore
Jakarta, ID 12.63 ms 0.0% 2790.86 Mbps 4807.15 Mbps Biznet Networks - Jakarta
Surabaya, ID 24.66 ms N/A 3055.41 Mbps 2614.72 Mbps PT. Indonesia Comnets Plus - Surabaya
Kuala Lum, MY 8.21 ms 0.0% 6269.71 Mbps 5808.42 Mbps Telekom Malaysia Berhad - Kuala Lumpur
Mumbai, IN 64.82 ms 0.0% 5154.49 Mbps 1038.72 Mbps i3D.net - Mumbai
Chennai, IN 33.87 ms N/A 3334.49 Mbps 2286.35 Mbps Jio - Chennai
Bangalore, IN 170.57 ms 0.0% 2832.45 Mbps 523.63 Mbps Bharti Airtel Ltd - Bangalore
Karachi, PK 76.83 ms 0.0% 1985.01 Mbps 619.31 Mbps JAZZ - Karachi
Lahore, PK 97.22 ms N/A 4101.11 Mbps 485.28 Mbps Telenor Pakistan - Lahore
Kathmandu, NP 224.65 ms 0.0% 927.72 Mbps 154.18 Mbps Nepal Telecom - Hetauda
Colombo, SL 49.27 ms N/A 3247.78 Mbps 2315.84 Mbps Airtel Lanka - Colombo
Dhaka, BD 50.67 ms N/A 3923.76 Mbps 1702.40 Mbps Grameenphone Ltd - Dhaka
Novosibirsk, RU 233.33 ms 0.0% 2545.23 Mbps 487.77 Mbps MegaFon - Novosibirsk
Almaty, KZ 172.20 ms 0.0% 1948.66 Mbps 494.66 Mbps Kazakhtelecom - Almaty
Tehran, IR 388.22 ms 3.3% 975.32 Mbps 20.25 Mbps Irancell - Tehran
Dubai, AE 76.46 ms N/A 4456.56 Mbps 332.42 Mbps ETISALAT-UAE - Dubai
Jeddah, SA 109.68 ms 0.0% 3140.23 Mbps 473.58 Mbps Mobily - Jeddah
Istanbul, TR 284.38 ms 0.0% 2085.13 Mbps 301.16 Mbps Turkcell - Istanbul
Avg DL Speed : 3142.28 Mbps
Avg UL Speed : 1832.65 Mbps
Total DL Data : 129.44 GB
Total UL Data : 67.24 GB
Total Data : 196.68 GB
Duration : 15 min 46 sec
System Time : 30/09/2023 - 17:30:11 IST
Total Script Runs : 24438
Result : https://result.network-speed.xyz/r/1696075077_ATBR3V_ASIA.txt
Basic System Info
CPU Model : AMD Ryzen 9 7950X 16-Core Processor
CPU Cores : 1 @ 4499.996 MHz
CPU Cache : 1024 KB
AES-NI : ✔ Enabled
Total Disk : 9.9 GB (1.9 GB Used)
Total RAM : 422.9 MB (149.3 MB Used)
System uptime : 0 days, 2 hour 0 min
Load average : 0.00, 0.00, 0.00
OS : Debian GNU/Linux 12
Kernel : 6.1.0-9-amd64
Basic Network Info
ISP : Layer Marketing Services L.L.C
ASN : AS216382 LAYER MARKETING SERVICES L.L.C
Host : Layer
Speedtest.net (Region: INDONESIA)
ISP: Layer Marketing Services L.L.C
Nearest 0.17 ms 0.0% 9238.18 Mbps 8808.10 Mbps Crunchbits - Spokane, WA
Jakarta 181.22 ms 0.0% 937.19 Mbps 215.38 Mbps Hutchison 3 Indonesia CGK-MM - Jakarta
Jakarta 196.49 ms 0.0% 1804.48 Mbps 78.09 Mbps DomaiNesia - Jakarta
Jakarta 200.28 ms 0.0% 1844.23 Mbps 92.40 Mbps PT. Telekomunikasi Indonesia - Jakarta
Jakarta 195.10 ms 0.0% 2033.76 Mbps 142.95 Mbps PT Indosat Tbk - Jakarta
Jakarta 182.79 ms 0.0% 1092.22 Mbps 305.14 Mbps MyRepublic Indonesia - South Jakarta
Bandung 200.63 ms N/A 299.23 Mbps 42.68 Mbps HYPERNET - Bandung
Bekasi 186.95 ms 0.7% 330.33 Mbps 151.50 Mbps PT Lintas Jaringan Nusantara - Bekasi
Bogor 194.59 ms 0.0% 927.58 Mbps 220.53 Mbps PT. Java Digital Nusantara - Bogor
Malang 347.36 ms 0.0% 1210.62 Mbps 249.83 Mbps GlobalXtreme - Malang
Semarang 194.07 ms N/A 2039.35 Mbps 373.23 Mbps PT. Indonesia Comnets Plus - Semarang
Surabaya 193.54 ms N/A 2006.16 Mbps 366.49 Mbps PT. Indonesia Comnets Plus - Surabaya
Yogyakarta 208.74 ms 0.0% 784.07 Mbps 75.33 Mbps PT Union Routelink Communication - Yogyakarta
Banda Aceh 204.11 ms 0.0% 1880.19 Mbps 332.99 Mbps PT. Telekomunikasi Indonesia - Banda Aceh
Medan 182.19 ms 0.0% 2145.55 Mbps 379.53 Mbps Biznet Networks - Medan
Palembang 224.58 ms N/A 492.94 Mbps 1.85 Mbps PT. Sakti Putra Mandiri - Palembang
Pekanbaru 215.97 ms 2.0% 423.82 Mbps 70.07 Mbps PT Hexa Media Sarana - Pekanbaru
Bali 205.77 ms 0.0% 1851.30 Mbps 344.47 Mbps Biznet Networks - Bali
Makassar 234.53 ms 0.0% 444.69 Mbps 256.24 Mbps Biznet Networks - Makassar
Depok 235.82 ms 0.0% 0.54 Mbps 123.62 Mbps ADI - Depok
Tangerang 200.85 ms 0.0% 935.39 Mbps 7.53 Mbps PT. Java Medianet Tekhnologi - Tangerang
Avg DL Speed : 1558.18 Mbps
Avg UL Speed : 601.80 Mbps
Total DL Data : 39.25 GB
Total UL Data : 12.71 GB
Total Data : 51.96 GB
Duration : 11 min 19 sec
System Time : 07/10/2023 - 21:38:36 WIB
Total Script Runs : 24840
Result : https://result.network-speed.xyz/r/1696689353_PS2K6I_INDONESIA.txt
Basic System Info
CPU Model : Common KVM processor
CPU Cores : 2 @ 3392.282 MHz
AES-NI : ❌ Disabled
VM-x/AMD-V : ❌ Disabled
Total Disk : 9.8 GB (3.7 GB Used)
Total RAM : 214.6 MB (158.6 MB Used)
System uptime : 184 days, 5 hour 37 min
Load average : 2.49, 1.12, 0.42
OS : Ubuntu 22.04.1 LTS
Kernel : 5.15.0-58-generic
Basic Network Info
IPv6 Access : ❌ Offline
ISP : TerraHost AS
ASN : AS56655 TerraHost AS
Location (IPv4) : Oslo, Oslo, NO
ISP: TerraHost
Nearest 0.17 ms 0.0% 151.88 Mbps 83.85 Mbps Terrahost AS - Sandefjord
Kochi, IN 176.78 ms 0.0% 148.85 Mbps 96.50 Mbps Asianet Broadband - Cochin
Bangalore, IN 155.10 ms 0.0% 154.05 Mbps 79.85 Mbps Bharti Airtel Ltd - Bangalore
Chennai, IN 167.34 ms N/A 153.40 Mbps 14.23 Mbps Jio - Chennai
Mumbai, IN 150.15 ms 0.0% 153.05 Mbps 126.21 Mbps i3D.net - Mumbai
Delhi, IN 167.91 ms 0.0% 153.14 Mbps 96.31 Mbps Tata Teleservices Ltd - New Delhi
Seattle, US 143.56 ms 0.0% 145.35 Mbps 97.77 Mbps Ziply Fiber - Seattle, WA
Los Angeles, US 152.82 ms 0.0% 151.70 Mbps 129.44 Mbps ReliableSite Hosting - Los Angeles, CA
Dallas, US 140.51 ms 0.0% 151.49 Mbps 107.11 Mbps Hivelocity - Dallas, TX
Miami, US 120.11 ms 0.0% 152.69 Mbps 142.66 Mbps AT&T - Miami, FL
New York, US 91.09 ms 0.0% 150.67 Mbps 152.80 Mbps GSL Networks - New York, NY
Toronto, CA 101.35 ms 0.0% 152.61 Mbps 141.73 Mbps Rogers - Toronto, ON
London, UK 25.98 ms 0.0% 152.15 Mbps 156.03 Mbps VeloxServ Communications - London
Amsterdam, NL 19.86 ms 0.0% 152.32 Mbps 157.53 Mbps 31173 Services AB - Amsterdam
Paris, FR 32.33 ms N/A 152.25 Mbps 156.81 Mbps Axione - Paris
Frankfurt, DE 25.07 ms 0.0% 152.61 Mbps 156.67 Mbps 23M GmbH - Frankfurt am Main
Warsaw, PL 28.76 ms 0.0% 152.49 Mbps 155.97 Mbps UPC Polska - Warszawa
Bucharest, RO 53.31 ms 0.0% 152.83 Mbps 153.95 Mbps Vodafone Romania Fixed – Bucharest - Bucharest
Jeddah, SA 88.08 ms 0.0% 143.71 Mbps 150.32 Mbps Saudi Telecom Company
Dubai, AE 139.60 ms 0.0% 155.84 Mbps 105.61 Mbps du - Dubai
Fujairah, AE 133.05 ms 0.0% 129.46 Mbps 123.91 Mbps ETISALAT-UAE - Fujairah
Tokyo, JP 235.38 ms N/A 112.48 Mbps 68.62 Mbps fdcservers.net - Tokyo
Shanghai, CU-CN 323.68 ms 0.0% 154.18 Mbps 55.67 Mbps China Unicom 5G - Shanghai
Nanjing, CT-CN 243.42 ms 0.0% 145.14 Mbps 21.44 Mbps China Telecom JiangSu 5G - Nanjing
Hong Kong, CN 204.31 ms N/A 154.79 Mbps 91.30 Mbps STC - Hong Kong
Singapore, SG 170.15 ms 0.0% 156.67 Mbps 83.43 Mbps i3D.net - Singapore
Jakarta, ID 225.50 ms 0.0% 155.61 Mbps 30.49 Mbps PT. Telekomunikasi Indonesia - Jakarta
Avg DL Speed : 149.68 Mbps
Avg UL Speed : 108.75 Mbps
Total DL Data : 5.74 GB
Total UL Data : 3.91 GB
Total Data : 9.65 GB
Duration : 14 min 12 sec
System Time : 11/10/2023 - 16:28:50 UTC
Total Script Runs : 25065
Result : https://result.network-speed.xyz/r/1697041500_WK0ZRB_GLOBAL.txt
Basic System Info
CPU Model : AMD EPYC-Rome Processor
CPU Cores : 1 @ 2799.974 MHz
CPU Cache : 512 KB
AES-NI : ✔ Enabled
Total Disk : 19.3 GB (2.6 GB Used)
Total RAM : 957.5 MB (144.5 MB Used)
Total Swap : 1024.0 MB (18.6 MB Used)
System uptime : 0 days, 0 hour 10 min
Load average : 0.24, 0.35, 0.19
Kernel : 5.15.0-86-generic
Basic Network Info
ISP : HIVELOCITY, Inc.
ASN : AS29802 HIVELOCITY, Inc.
Host : HIVELOCITY, Inc.
Location (IPv4) : Tampa, Florida, US
ISP: HIVELOCITY
Nearest 31.59 ms 0.0% 967.90 Mbps 987.89 Mbps Ideatek Telcom - Wichita, KS
Kochi, IN 264.72 ms 0.0% 767.87 Mbps 302.98 Mbps Asianet Broadband - Cochin
Bangalore, IN 199.40 ms 0.0% 921.03 Mbps 432.21 Mbps Bharti Airtel Ltd - Bangalore
Chennai, IN 229.71 ms N/A 867.02 Mbps 350.16 Mbps Jio - Chennai
Mumbai, IN 220.08 ms 0.0% 947.63 Mbps 306.32 Mbps i3D.net - Mumbai
Delhi, IN 244.25 ms 0.0% 736.35 Mbps 324.36 Mbps Tata Teleservices Ltd - New Delhi
Seattle, US 56.20 ms 0.0% 967.74 Mbps 940.65 Mbps Ziply Fiber - Seattle, WA
Los Angeles, US 60.78 ms 0.0% 968.07 Mbps 480.45 Mbps ReliableSite Hosting - Los Angeles, CA
Dallas, US 33.72 ms 0.0% 966.94 Mbps 976.01 Mbps Hivelocity - Dallas, TX
Miami, US 36.65 ms 0.0% 978.61 Mbps 998.76 Mbps AT&T - Miami, FL
New York, US 8.76 ms 0.0% 528.52 Mbps 991.54 Mbps GSL Networks - New York, NY
Toronto, CA 18.06 ms 0.0% 966.39 Mbps 1038.92 Mbps Rogers - Toronto, ON
London, UK 67.11 ms 0.0% 975.59 Mbps 1023.95 Mbps VeloxServ Communications - London
Amsterdam, NL 78.78 ms 0.0% 976.98 Mbps 1097.02 Mbps 31173 Services AB - Amsterdam
Paris, FR 80.55 ms N/A 974.89 Mbps 855.48 Mbps Axione - Paris
Frankfurt, DE 81.32 ms 0.0% 976.20 Mbps 742.05 Mbps 23M GmbH - Frankfurt am Main
Warsaw, PL 95.71 ms 0.0% 891.95 Mbps 567.48 Mbps UPC Polska - Warszawa
Bucharest, RO 113.03 ms 0.0% 982.08 Mbps 742.66 Mbps Vodafone Romania Fixed – Bucharest - Bucharest
Jeddah, SA 142.07 ms 0.3% 807.09 Mbps 640.32 Mbps Saudi Telecom Company
Dubai, AE 190.03 ms 0.0% 970.03 Mbps 559.47 Mbps du - Dubai
Fujairah, AE 199.62 ms 0.0% 698.54 Mbps 534.48 Mbps ETISALAT-UAE - Fujairah
Tokyo, JP FAILED
Shanghai, CU-CN 274.73 ms 5.7% 529.14 Mbps 361.90 Mbps China Unicom 5G - Shanghai
Nanjing, CT-CN 213.48 ms 31.4% 721.75 Mbps 1.76 Mbps China Telecom JiangSu 5G - Nanjing
Hong Kong, CN 212.74 ms N/A 785.99 Mbps 420.32 Mbps STC - Hong Kong
Singapore, SG 204.45 ms 0.0% 779.93 Mbps 424.46 Mbps i3D.net - Singapore
Jakarta, ID 219.55 ms 0.0% 599.72 Mbps 140.72 Mbps PT. Telekomunikasi Indonesia - Jakarta
Avg DL Speed : 855.92 Mbps
Avg UL Speed : 624.71 Mbps
Total DL Data : 32.52 GB
Total UL Data : 22.11 GB
Total Data : 54.63 GB
Duration : 13 min 1 sec
System Time : 12/10/2023 - 17:20:13 UTC
Total Script Runs : 25121
Result : https://result.network-speed.xyz/r/1697130973_5W0W5R_GLOBAL.txt
Advin Servers - Los Angeles - KVM Standard VPS - KVM Standard XS
Basic System Info
CPU Model : AMD EPYC 7B13 64-Core Processor
CPU Cores : 2 @ 2249.998 MHz
CPU Cache : 512 KB
AES-NI : ✔ Enabled
Total Disk : 54.0 GB (4.3 GB Used)
Total RAM : 7.8 GB (224.4 MB Used)
System uptime : 0 days, 5 hour 5 min
Load average : 21.72, 11.95, 6.13
Kernel : 5.15.0-69-generic
Basic Network Info
ISP : Advin Services LLC
ASN : AS206216 Advin Services LLC
ASN (IPv4) : AS23470 ReliableSite.Net LLC
Host : Advin Services LLC
Speedtest.net (Region: NORTH AMERICA)
ISP: ReliableSite.Net LLC
Nearest 0.51 ms 0.0% 7863.40 Mbps 1611.19 Mbps Race Communications - Los Angeles, CA
Vancouver, BC 35.22 ms N/A 5142.77 Mbps 2316.04 Mbps TELUS - Vancouver, BC
Calgary, AB 54.73 ms N/A 7719.12 Mbps 1539.41 Mbps Shaw Communications - Calgary, AB
Winnipeg, MB 71.64 ms 0.0% 5011.47 Mbps 1113.65 Mbps Voyageur Internet - Winnipeg, MB
Toronto, ON 74.76 ms 0.0% 7757.77 Mbps 1079.82 Mbps Bell Canada - Toronto, ON
Montreal, QC 74.76 ms 0.0% 7210.17 Mbps 1086.69 Mbps Rogers Wireless - Montréal, QC
New York, NY 72.68 ms 0.0% 3383.09 Mbps 1120.14 Mbps Surfshark Ltd - New York, NY
Ashburn, VA 67.99 ms 0.0% 4896.27 Mbps 1180.14 Mbps Rackdog - Ashburn, VA
Charlotte, NC 64.49 ms 0.0% 3345.26 Mbps 1238.53 Mbps Windstream - Charlotte, NC
Atlanta, GA 50.75 ms 0.0% 8102.37 Mbps 1619.68 Mbps i3D.net - Atlanta, GA
Miami, FL 60.74 ms 0.0% 3353.58 Mbps 1378.91 Mbps AT&T - Miami, FL
Dallas, TX 42.48 ms 0.0% 4927.15 Mbps 1695.18 Mbps Hivelocity - Dallas, TX
Houston, TX 39.53 ms 0.0% 6648.62 Mbps 2080.39 Mbps Ezee Fiber - Houston, TX
Kansas, MO 47.17 ms 0.0% 3371.25 Mbps 1292.25 Mbps Xiber LLC - Kansas City, MO
Minneapolis, MN 66.34 ms 0.0% 7537.45 Mbps 1276.52 Mbps US Internet - Minneapolis, MN
Chicago, IL 56.78 ms 0.0% 7888.13 Mbps 1439.86 Mbps Enzu.com - Chicago, IL
Cleveland, OH 72.49 ms 0.0% 6146.80 Mbps 1138.13 Mbps Windstream - Cleveland, OH
Albuquerque, NM 32.01 ms N/A 5804.59 Mbps 2596.54 Mbps Comcast - Albuquerque, NM
Denver, CO 29.74 ms 0.0% 6542.88 Mbps 2764.07 Mbps T-Mobile Fiber | Intrepid - Denver, CO
Portland, OR 28.93 ms N/A 8076.82 Mbps 2876.81 Mbps CenturyLink - Portland, OR
Las Vegas, NV 6.10 ms N/A 5306.99 Mbps 7583.28 Mbps Dish Wireless - Las Vegas, NV
Salt Lake, UT 29.50 ms N/A 3216.93 Mbps 2819.15 Mbps Novva Data Centers - Salt Lake City, UT
Phoenix, AZ 12.71 ms 0.0% 6998.24 Mbps 6280.85 Mbps Xiber LLC - Phoenix, AZ
Los Angeles, CA 0.54 ms 0.0% 7831.18 Mbps 9356.22 Mbps ReliableSite Hosting - Los Angeles, CA
San Jose, CA 13.22 ms 0.0% 7282.77 Mbps 5878.80 Mbps Misaka Network, Inc. - San Jose, CA
Seattle, WA 32.14 ms 0.0% 6814.44 Mbps 2562.33 Mbps Misaka Network, Inc. - Seattle, WA
Hermosillo, MX 52.46 ms 0.0% 5799.71 Mbps 1692.91 Mbps Megacable - Hermosillo
Guadalajara, MX 64.16 ms 0.0% 1465.83 Mbps 1013.45 Mbps AT&T México - Guadalajara
Mexico City, MX 51.19 ms N/A 4838.99 Mbps 1590.47 Mbps INFINITUM - Mexico City
Merida, MX FAILED
Avg DL Speed : 5871.90 Mbps
Avg UL Speed : 2455.91 Mbps
Total DL Data : 225.40 GB
Total UL Data : 83.70 GB
Total Data : 309.10 GB
Duration : 18 min 6 sec
System Time : 17/10/2023 - 13:16:08 WIB
Total Script Runs : 25423
Result : https://paste.kangserver.id/view/rQgyVo8
Global Speedtest
Basic Network Info
Nearest 0.50 ms 0.0% 7648.10 Mbps 2077.48 Mbps Race Communications - Los Angeles, CA
Kochi, IN 216.69 ms 0.0% 3136.97 Mbps 338.39 Mbps Asianet Broadband - Cochin
Bangalore, IN 204.06 ms 0.0% 2630.67 Mbps 338.42 Mbps Bharti Airtel Ltd - Bangalore
Chennai, IN 207.68 ms N/A 3012.91 Mbps 373.62 Mbps Jio - Chennai
Mumbai, IN 238.88 ms 0.0% 2688.80 Mbps 333.34 Mbps i3D.net - Mumbai
Delhi, IN 262.79 ms 0.0% 2206.77 Mbps 303.17 Mbps Tata Teleservices Ltd - New Delhi
Seattle, US FAILED
Los Angeles, US 0.55 ms 0.0% 8314.35 Mbps 9343.60 Mbps ReliableSite Hosting - Los Angeles, CA
Dallas, US 58.27 ms 0.0% 4447.38 Mbps 1847.26 Mbps Hivelocity - Dallas, TX
Miami, US 59.99 ms 0.0% 3312.22 Mbps 1354.32 Mbps AT&T - Miami, FL
New York, US 63.70 ms 0.0% 5519.12 Mbps 1319.98 Mbps GSL Networks - New York, NY
Toronto, CA 68.69 ms 0.0% 6430.63 Mbps 1183.21 Mbps Rogers - Toronto, ON
London, UK 138.08 ms 0.0% 4646.82 Mbps 596.88 Mbps VeloxServ Communications - London
Amsterdam, NL 158.63 ms 0.0% 4137.91 Mbps 539.64 Mbps 31173 Services AB - Amsterdam
Paris, FR 144.60 ms N/A 5045.36 Mbps 563.09 Mbps Axione - Paris
Frankfurt, DE 150.48 ms 0.0% 4407.58 Mbps 537.82 Mbps 23M GmbH - Frankfurt am Main
Warsaw, PL 182.98 ms 0.0% 4189.22 Mbps 431.51 Mbps UPC Polska - Warszawa
Bucharest, RO 183.34 ms 0.0% 1725.01 Mbps 385.59 Mbps Vodafone Romania Fixed – Bucharest - Bucharest
Jeddah, SA 196.15 ms 0.0% 4078.00 Mbps 411.73 Mbps Saudi Telecom Company
Dubai, AE 271.69 ms 0.0% 2980.55 Mbps 288.68 Mbps du - Dubai
Fujairah, AE 261.81 ms N/A 3033.62 Mbps 307.56 Mbps ETISALAT-UAE - Fujairah
Tokyo, JP 150.40 ms N/A 3235.46 Mbps 529.03 Mbps fdcservers.net - Tokyo
Shanghai, CU-CN 177.08 ms 0.0% 2092.76 Mbps 433.40 Mbps China Unicom 5G - Shanghai
Nanjing, CT-CN 176.21 ms 1.7% 2206.57 Mbps 413.47 Mbps China Telecom JiangSu 5G - Nanjing
Hong Kong, CN 186.66 ms N/A 3892.93 Mbps 431.56 Mbps STC - Hong Kong
Singapore, SG 212.56 ms 0.0% 3767.49 Mbps 383.82 Mbps i3D.net - Singapore
Jakarta, ID 180.75 ms 0.0% 3899.82 Mbps 394.76 Mbps PT. Telekomunikasi Indonesia - Jakarta
Avg DL Speed : 4485.93 Mbps
Avg UL Speed : 1342.61 Mbps
Total DL Data : 147.30 GB
Total UL Data : 28.98 GB
Total Data : 175.28 GB
Duration : 13 min 31 sec
System Time : 17/10/2023 - 09:39:16 WIB
Total Script Runs : 25411
Result : https://paste.kangserver.id/view/iKGfamQ
Basic Network Info
ISP : Lowhosting services of Davide Gennari
ASN : AS212508 Lowhosting services of Davide Gennari
Host : LowHosting Services
ISP: Lowhosting services of Davide Gennari
Nearest 11.24 ms 0.0% 922.33 Mbps 917.34 Mbps Michael Stapelberg - Zurich
Kochi, IN 192.99 ms 0.0% 669.74 Mbps 469.04 Mbps Asianet Broadband - Cochin
Bangalore, IN 179.66 ms 0.0% 722.50 Mbps 341.45 Mbps Bharti Airtel Ltd - Bangalore
Chennai, IN 171.38 ms N/A 175.19 Mbps 158.32 Mbps Jio - Chennai
Mumbai, IN 118.02 ms 0.0% 892.57 Mbps 715.15 Mbps i3D.net - Mumbai
Delhi, IN 137.16 ms 0.0% 798.05 Mbps 621.95 Mbps Tata Teleservices Ltd - New Delhi
Seattle, US 156.80 ms N/A 815.20 Mbps 564.61 Mbps Comcast - Seattle, WA
Los Angeles, US 157.43 ms 0.0% 652.42 Mbps 387.63 Mbps ReliableSite Hosting - Los Angeles, CA
Dallas, US 125.80 ms 0.0% 662.85 Mbps 691.68 Mbps Hivelocity - Dallas, TX
Miami, US 120.53 ms 0.8% 738.61 Mbps 705.02 Mbps AT&T - Miami, FL
New York, US 86.21 ms 0.3% 948.80 Mbps 600.34 Mbps GSL Networks - New York, NY
Toronto, CA 130.87 ms 0.3% 861.10 Mbps 647.21 Mbps Rogers - Toronto, ON
London, UK 16.83 ms 0.0% 927.50 Mbps 913.70 Mbps VeloxServ Communications - London
Amsterdam, NL 13.20 ms 0.0% 935.44 Mbps 931.10 Mbps 31173 Services AB - Amsterdam
Paris, FR 16.40 ms N/A 940.25 Mbps 925.58 Mbps Axione - Paris
Frankfurt, DE 6.02 ms 0.0% 921.91 Mbps 919.89 Mbps 23M GmbH - Frankfurt am Main
Warsaw, PL 25.28 ms 0.0% 920.83 Mbps 898.03 Mbps UPC Polska - Warszawa
Bucharest, RO 32.92 ms 0.0% 933.80 Mbps 902.13 Mbps Vodafone Romania Fixed – Bucharest - Bucharest
Jeddah, SA 80.02 ms 0.0% 944.31 Mbps 839.52 Mbps Saudi Telecom Company
Dubai, AE FAILED
Fujairah, AE 115.96 ms 0.0% 932.89 Mbps 728.10 Mbps ETISALAT-UAE - Fujairah
Tokyo, JP 254.00 ms N/A 627.98 Mbps 0.78 Mbps fdcservers.net - Tokyo
Shanghai, CU-CN 176.72 ms 0.0% 554.60 Mbps 510.93 Mbps China Unicom 5G - Shanghai
Nanjing, CT-CN 176.78 ms 0.0% 484.85 Mbps 454.46 Mbps China Telecom JiangSu 5G - Nanjing
Hong Kong, CN 238.18 ms N/A 594.17 Mbps 370.89 Mbps STC - Hong Kong
Singapore, SG 160.63 ms 0.0% 3.23 Mbps 257.01 Mbps i3D.net - Singapore
Jakarta, ID 192.61 ms 0.0% 613.97 Mbps 313.63 Mbps PT. Telekomunikasi Indonesia - Jakarta
Avg DL Speed : 738.27 Mbps
Avg UL Speed : 607.13 Mbps
Total DL Data : 26.89 GB
Total UL Data : 20.29 GB
Total Data : 47.18 GB
It might be useful to print datetimes in UTC. Rather than date '+%d/%m/%Y - %H:%M:%S %Z', date -u '+%d/%m/%Y - %H:%M:%S %Z', to make it easier to understand for people who don't know mysterious timezone abbreviations.
HostEONS Ryzen 7950X Hybrid Server - US - North America Speedtest.
Basic System Info
CPU Cores : 2 @ 4499.952 MHz
CPU Cache : 1024 KB
AES-NI : ✔ Enabled
Total Disk : 48.1 GB (5.1 GB Used)
Total RAM : 7.8 GB (178.7 MB Used)
Total Swap : 1024.0 MB (0 Used)
System uptime : 0 days, 0 hour 28 min
Load average : 0.19, 0.95, 0.82
Basic Network Info
ISP : Ipxo LLC
ASN : AS60721 Bursabil Teknoloji A.S.
ASN (IPv4) : AS142036 Hosteons Pte. Ltd.
Host : Hosteons Pte. Ltd
Location (IPv4) : Salt Lake City, Utah, US
ISP: Deft Hosting
Nearest 0.92 ms 0.0% 6475.37 Mbps 7730.19 Mbps Sumo Fiber - Salt Lake City, UT
Vancouver, BC 23.92 ms N/A 6884.07 Mbps 3389.69 Mbps TELUS - Vancouver, BC
Calgary, AB 49.67 ms N/A 6488.56 Mbps 1634.99 Mbps Shaw Communications - Calgary, AB
Winnipeg, MB 37.38 ms 0.0% 7005.16 Mbps 2266.84 Mbps Voyageur Internet - Winnipeg, MB
Toronto, ON 57.14 ms 0.0% 6911.27 Mbps 1445.65 Mbps Bell Canada - Toronto, ON
Montreal, QC 54.29 ms 0.0% 7122.33 Mbps 1526.99 Mbps Rogers Wireless - Montréal, QC
New York, NY 53.30 ms 0.0% 8201.49 Mbps 1588.51 Mbps Surfshark Ltd - New York, NY
Ashburn, VA 44.90 ms 0.0% 6682.28 Mbps 1678.82 Mbps Rackdog - Ashburn, VA
Charlotte, NC 55.05 ms 0.0% 6525.10 Mbps 1464.92 Mbps Windstream - Charlotte, NC
Atlanta, GA 44.73 ms 0.0% 6937.38 Mbps 1824.21 Mbps i3D.net - Atlanta, GA
Miami, FL 74.28 ms 0.0% 6956.31 Mbps 1114.70 Mbps AT&T - Miami, FL
Dallas, TX 61.83 ms 0.0% 6441.09 Mbps 1332.61 Mbps Hivelocity - Dallas, TX
Houston, TX 34.27 ms 0.0% 5818.94 Mbps 2411.81 Mbps Ezee Fiber - Houston, TX
Kansas, MO 22.74 ms 0.0% 6209.51 Mbps 3687.80 Mbps Xiber LLC - Kansas City, MO
Minneapolis, MN 34.45 ms 0.0% 7032.90 Mbps 2481.59 Mbps US Internet - Minneapolis, MN
Chicago, IL 34.91 ms 0.0% 8330.82 Mbps 2373.19 Mbps Enzu.com - Chicago, IL
Cleveland, OH 68.03 ms 0.0% 3603.02 Mbps 1196.11 Mbps Windstream - Cleveland, OH
Albuquerque, NM 20.46 ms N/A 6891.57 Mbps 4038.76 Mbps Comcast - Albuquerque, NM
Denver, CO 12.15 ms 0.0% 8508.77 Mbps 6448.51 Mbps T-Mobile Fiber | Intrepid - Denver, CO
Portland, OR 34.24 ms N/A 8604.18 Mbps 2458.56 Mbps CenturyLink - Portland, OR
Las Vegas, NV 25.53 ms N/A 6670.67 Mbps 3215.69 Mbps Dish Wireless - Las Vegas, NV
Salt Lake, UT 1.72 ms N/A 7179.58 Mbps 8239.18 Mbps Novva Data Centers - Salt Lake City, UT
Phoenix, AZ 29.56 ms 0.0% 6084.91 Mbps 2852.93 Mbps Xiber LLC - Phoenix, AZ
Los Angeles, CA 28.69 ms 0.0% 6655.12 Mbps 5017.02 Mbps ReliableSite Hosting - Los Angeles, CA
San Jose, CA 18.82 ms 0.0% 6448.14 Mbps 3843.35 Mbps Misaka Network, Inc. - San Jose, CA
Seattle, WA 20.82 ms 0.0% 6291.90 Mbps 3825.24 Mbps Misaka Network, Inc. - Seattle, WA
Hermosillo, MX 67.26 ms 0.0% 4874.28 Mbps 1261.67 Mbps Megacable - Hermosillo
Guadalajara, MX 57.00 ms 0.0% 1877.02 Mbps 1368.35 Mbps AT&T México - Guadalajara
Mexico City, MX 65.85 ms N/A 7995.39 Mbps 1239.33 Mbps INFINITUM - Mexico City
Merida, MX FAILED
Avg DL Speed : 6610.62 Mbps
Avg UL Speed : 2860.60 Mbps
Total DL Data : 251.30 GB
Total UL Data : 95.50 GB
Total Data : 346.80 GB
Duration : 11 min 53 sec
System Time : 19/10/2023 - 11:00:45 WIB
Total Script Runs : 25551
Result : https://paste.kangserver.id/view/FLjVftM
Global Speedtest
Basic Network Info
ISP : Ipxo LLC
ISP: Deft Hosting
Nearest 0.97 ms 0.0% 9117.76 Mbps 7272.33 Mbps Sumo Fiber - Salt Lake City, UT
Kochi, IN 274.90 ms 0.0% 3601.17 Mbps 304.80 Mbps Asianet Broadband - Cochin
Bangalore, IN 255.13 ms 0.0% 2358.73 Mbps 331.61 Mbps Bharti Airtel Ltd - Bangalore
Chennai, IN 262.71 ms N/A 3912.06 Mbps 524.74 Mbps Jio - Chennai
Mumbai, IN 263.62 ms 0.0% 3056.53 Mbps 315.75 Mbps i3D.net - Mumbai
Delhi, IN 295.45 ms 0.0% 2046.36 Mbps 310.82 Mbps Tata Teleservices Ltd - New Delhi
Seattle, US 29.06 ms N/A 9310.25 Mbps 2905.86 Mbps Comcast - Seattle, WA
Los Angeles, US 15.06 ms 0.0% 8926.89 Mbps 5020.45 Mbps ReliableSite Hosting - Los Angeles, CA
Dallas, US 66.56 ms 0.0% 9182.38 Mbps 2975.19 Mbps Hivelocity - Dallas, TX
Miami, US FAILED
New York, US 61.38 ms 0.0% 7905.93 Mbps 3881.42 Mbps GSL Networks - New York, NY
Toronto, CA 46.75 ms 0.0% 8079.61 Mbps 1830.51 Mbps Rogers - Toronto, ON
London, UK 117.43 ms 0.0% 9337.17 Mbps 2128.13 Mbps VeloxServ Communications - London
Amsterdam, NL 178.70 ms 0.0% 4862.39 Mbps 960.83 Mbps 31173 Services AB - Amsterdam
Paris, FR 123.24 ms N/A 8369.27 Mbps 1344.57 Mbps Axione - Paris
Frankfurt, DE 137.97 ms 0.0% 5628.74 Mbps 636.93 Mbps 23M GmbH - Frankfurt am Main
Warsaw, PL 174.47 ms 0.0% 4786.42 Mbps 515.10 Mbps UPC Polska - Warszawa
Bucharest, RO 172.12 ms 0.0% 4828.47 Mbps 456.05 Mbps Vodafone Romania Fixed – Bucharest - Bucharest
Jeddah, SA 183.06 ms 0.0% 9364.42 Mbps 1364.37 Mbps Saudi Telecom Company
Dubai, AE 237.34 ms 0.0% 5354.81 Mbps 821.61 Mbps du - Dubai
Fujairah, AE 249.78 ms 0.0% 7918.60 Mbps 971.23 Mbps ETISALAT-UAE - Fujairah
Tokyo, JP 122.44 ms N/A 1216.11 Mbps 1325.43 Mbps fdcservers.net - Tokyo
Shanghai, CU-CN 190.66 ms 0.0% 8154.70 Mbps 769.07 Mbps China Unicom 5G - Shanghai
Nanjing, CT-CN 158.90 ms 5.7% 3581.66 Mbps 73.87 Mbps China Telecom JiangSu 5G - Nanjing
Hong Kong, CN 154.17 ms N/A 5845.97 Mbps 579.74 Mbps STC - Hong Kong
Singapore, SG 188.58 ms 0.0% 1774.86 Mbps 467.25 Mbps i3D.net - Singapore
Jakarta, ID 201.53 ms 0.0% 3335.84 Mbps 400.84 Mbps PT. Telekomunikasi Indonesia - Jakarta
Avg DL Speed : 5840.69 Mbps
Avg UL Speed : 1480.32 Mbps
Total DL Data : 209.10 GB
Total UL Data : 51.76 GB
Total Data : 260.86 GB
Duration : 13 min 29 sec
System Time : 19/10/2023 - 12:59:29 WIB
Total Script Runs : 25558
Result : https://paste.kangserver.id/view/oI9oXhU
mikewazar probably ran into the same problem I did once with your script.
If you try to download and start it via your wget -qO- network-speed.xyz | bash you might get hit by the Cloudflare interception asking you for a captcha to solve. But as you don't access that resource via browser but load it via wget, the html page of Cloudflares captcha interception gets downloaded and executed via the bash command resulting in an empty return. So no bash script is downloaded by wget but the cloudflare blocker.
This may happen to one ip while the vps sitting next to your vps does not run into this problem.
Anyone that runs into this problem should download the script directly from github and than execute it locally.
Yes, this happens on OVH and Hetzener mainly. I had a bunch of "attacks" and rogue crons from these networks, so I had increased CF sensitivity then.
Maybe I'll tone down the protection and see.
IncogNET 10Gbps in the Netherlands? 🤫
[ IncogNET LLC ] - Since 2020
Virmach after migration (SEA->LAX)
---------------------------- network-speed.xyz ---------------------------- A simple script to test network performance using speedtest-cli --------------------------------------------------------------------------- Version : v2023.09.30 Global Speedtest : wget -qO- network-speed.xyz | bash Region Speedtest : wget -qO- network-speed.xyz | bash -s -- -r --------------------------------------------------------------------------- Basic System Info --------------------------------------------------------------------------- CPU Model : AMD EPYC 7B13 64-Core Processor CPU Cores : 2 @ 2249.998 MHz CPU Cache : 512 KB AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled Total Disk : 59.0 GB (1.8 GB Used) Total RAM : 7.8 GB (353.8 MB Used) System uptime : 2 days, 0 hour 34 min Load average : 0.00, 0.07, 0.22 OS : Debian GNU/Linux 12 Arch : x86_64 (64 Bit) Kernel : 6.1.0-12-amd64 Virtualization : KVM --------------------------------------------------------------------------- Basic Network Info --------------------------------------------------------------------------- IPv6 Access : ❌ Offline IPv4 Access : ✔ Online ISP : Advin Services LLC ASN : AS206216 Advin Services LLC Host : MB \ Location : Kerkrade, Limburg-LI, Netherlands --------------------------------------------------------------------------- Speedtest.net (Region: EUROPE) --------------------------------------------------------------------------- Location Latency Loss DL Speed UP Speed Server ISP: Advin Services LLC Nearest 11.44 ms 0.0% 5704.78 Mbps 7333.46 Mbps Händle & Korte GmbH - Dusseldorf London, UK 20.89 ms 0.0% 4788.71 Mbps 3937.25 Mbps M247 Ltd - London Edinburgh, UK 32.35 ms N/A 6086.41 Mbps 2713.74 Mbps Vodafone UK - Edinburgh Dublin, IE 30.00 ms 0.0% 6710.23 Mbps 2823.84 Mbps Three Ireland - Dublin Amsterdam, NL 14.36 ms 0.0% 8602.53 Mbps 5052.16 Mbps GSL Networks - Amsterdam Dronten, NL 16.78 ms 0.0% 6895.55 Mbps 4111.42 Mbps Serverius Connectivity - Amsterdam Paris, FR 18.62 ms 0.0% 6792.51 Mbps 3592.03 Mbps ORANGE FRANCE - Paris Marseille, FR 21.46 ms 0.0% 8556.05 Mbps 3546.77 Mbps GSL Networks - Marseille Madrid, ES 39.33 ms 0.0% 6911.36 Mbps 2508.17 Mbps Orange - Jazztel - Madrid Barcelona, ES 27.27 ms 0.0% 6241.64 Mbps 2919.31 Mbps Adamo - Barcelona Lisbon, PT 46.81 ms 0.0% 8698.97 Mbps 1905.36 Mbps Edgoo Networks - Lisbon Rome, IT 32.30 ms 0.0% 7072.48 Mbps 2297.56 Mbps TIM SpA - Rome Milan, IT 17.53 ms 0.0% 7114.11 Mbps 5101.53 Mbps Fastweb SpA - Milan Zurich, CH 12.86 ms 0.0% 2915.99 Mbps 1607.58 Mbps Sunrise Communication AG - Zurich Frankfurt, DE 8.33 ms 0.0% 4841.15 Mbps 6894.39 Mbps 23M GmbH - Frankfurt am Main Berlin, DE FAILED Vienna, AT 14.01 ms 0.0% 6752.55 Mbps 6043.78 Mbps A1 Telekom Austria AG - Vienna Budapest, HU 18.03 ms 0.0% 8918.36 Mbps 3643.70 Mbps ATW Internet Kft. - Budapest Gdansk, PL 29.83 ms 0.0% 3434.88 Mbps 2111.70 Mbps T-Mobile Polska S.A. - Gdańsk Warsaw, PL 25.70 ms 0.0% 1301.34 Mbps 3445.70 Mbps Orange Polska S.A. - Warsaw Lviv, UA 33.94 ms 0.0% 6829.33 Mbps 1519.12 Mbps Kyivstar - Lviv Kyiv, UA 26.24 ms 0.0% 6542.54 Mbps 846.93 Mbps o3 - Kyiv Minsk, BY 55.14 ms 0.0% 5774.67 Mbps 1417.91 Mbps A1 - Minsk Bucharest, RO 29.52 ms 0.0% 6152.12 Mbps 1065.05 Mbps Orange Romania Communications - Bucharest Iasi, RO 38.17 ms 0.0% 7245.96 Mbps 1962.51 Mbps Digi Helsinki, FI 29.07 ms 0.0% 8209.37 Mbps 3041.72 Mbps Elisa Oyj - Helsinki Stockholm, SE 32.19 ms 0.0% 7883.80 Mbps 2719.65 Mbps i3D.net - Stockholm Oslo, NO 35.44 ms 0.0% 5909.03 Mbps 1952.36 Mbps Speedtest.net - Oslo Moscow, RU 40.77 ms 0.0% 6555.37 Mbps 2443.44 Mbps Rostelecom - Moscow Petersburg, RU 47.86 ms 0.0% 3404.79 Mbps 1864.68 Mbps MTS OJSC - Saint Petersburg Istanbul, TR 40.44 ms 0.0% 6428.50 Mbps 1935.34 Mbps Turkcell - Istanbul Tbilisi, GE 69.81 ms N/A 5905.92 Mbps 1197.33 Mbps Silknet JSC - Tbilisi --------------------------------------------------------------------------- Avg DL Speed : 6296.13 Mbps Avg UL Speed : 3017.91 Mbps Total DL Data : 268.90 GB Total UL Data : 112.08 GB Total Data : 380.98 GB --------------------------------------------------------------------------- Duration : 19 min 7 sec System Time : 03/10/2023 - 11:07:49 UTC Total Script Runs : 24611 ------------------------------------------------------------------------------------------------------- network-speed.xyz ---------------------------- A simple script to test network performance using speedtest-cli --------------------------------------------------------------------------- Version : v2023.09.30 Global Speedtest : wget -qO- network-speed.xyz | bash Region Speedtest : wget -qO- network-speed.xyz | bash -s -- -r --------------------------------------------------------------------------- Basic System Info --------------------------------------------------------------------------- CPU Model : AMD Ryzen 9 7950X3D 16-Core Processor CPU Cores : 1 @ 4199.996 MHz CPU Cache : 1024 KB AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled Total Disk : 14.9 GB (3.9 GB Used) Total RAM : 926.2 MB (228.3 MB Used) Total Swap : 2.0 GB (19.9 MB Used) System uptime : 0 days, 0 hour 41 min Load average : 0.02, 0.30, 0.26 OS : Debian GNU/Linux 12 Arch : x86_64 (64 Bit) Kernel : 6.1.0-9-amd64 Virtualization : KVM --------------------------------------------------------------------------- Basic Network Info --------------------------------------------------------------------------- IPv6 Access : ❌ Offline IPv4 Access : ✔ Online ISP : Aaron Smith ASN : AS203758 Aaron Smith Host : Mohammad Booroumandfar Location : London, England-ENG, United Kingdom Location (IPv4) : Frankfurt am Main, Hesse, DE --------------------------------------------------------------------------- Speedtest.net (Region: EUROPE) --------------------------------------------------------------------------- Location Latency Loss DL Speed UP Speed Server ISP: Aaron Smith Nearest 187.13 ms N/A 493.68 Mbps 195.66 Mbps LINKCHINA - Hong Kong London, UK 12.34 ms 0.0% 3139.44 Mbps 1691.88 Mbps M247 Ltd - London Edinburgh, UK 26.27 ms N/A 3777.43 Mbps 973.71 Mbps Vodafone UK - Edinburgh Dublin, IE 25.74 ms 0.0% 3773.55 Mbps 1056.76 Mbps Three Ireland - Dublin Amsterdam, NL 6.47 ms 0.0% 4293.37 Mbps 3514.12 Mbps GSL Networks - Amsterdam Dronten, NL 14.23 ms 0.0% 3353.40 Mbps 2014.61 Mbps Serverius Connectivity - Amsterdam Paris, FR 15.30 ms 0.0% 4485.92 Mbps 1949.35 Mbps ORANGE FRANCE - Paris Marseille, FR 16.14 ms 17.3% 2686.22 Mbps 1323.05 Mbps GSL Networks - Marseille Madrid, ES 29.35 ms 0.3% 3190.93 Mbps 1171.13 Mbps Orange - Jazztel - Madrid Barcelona, ES 27.54 ms 0.0% 1922.65 Mbps 938.97 Mbps Adamo - Barcelona Lisbon, PT 47.13 ms 0.0% 2126.48 Mbps 802.15 Mbps Edgoo Networks - Lisbon Rome, IT 22.97 ms 0.0% 3529.22 Mbps 1042.01 Mbps TIM SpA - Rome Milan, IT 15.74 ms 0.0% 4080.12 Mbps 1631.77 Mbps Fastweb SpA - Milan Zurich, CH 8.35 ms 0.6% 2530.74 Mbps 857.48 Mbps Sunrise Communication AG - Zurich Frankfurt, DE 1.41 ms 0.0% 2545.66 Mbps 3809.25 Mbps 23M GmbH - Frankfurt am Main Berlin, DE 8.25 ms 0.6% 3760.17 Mbps 2138.86 Mbps Misaka Network, Inc. - Berlin Vienna, AT 12.66 ms 0.0% 2978.31 Mbps 1625.74 Mbps A1 Telekom Austria AG - Vienna Budapest, HU 16.25 ms 0.4% 2291.02 Mbps 1250.18 Mbps ATW Internet Kft. - Budapest Gdansk, PL 27.98 ms 0.0% 2231.70 Mbps 949.41 Mbps T-Mobile Polska S.A. - Gdańsk Warsaw, PL 19.40 ms 0.0% 1776.84 Mbps 811.99 Mbps Orange Polska S.A. - Warsaw Lviv, UA 26.92 ms 1.3% 3131.34 Mbps 884.64 Mbps Kyivstar - Lviv Kyiv, UA 30.12 ms 0.0% 2647.47 Mbps 790.51 Mbps o3 - Kyiv Minsk, BY 27.57 ms 0.4% 3471.23 Mbps 1334.76 Mbps A1 - Minsk Bucharest, RO 29.17 ms 0.0% 2667.65 Mbps 977.56 Mbps Orange Romania Communications - Bucharest Iasi, RO 36.43 ms 0.0% 3159.06 Mbps 1061.64 Mbps Digi Helsinki, FI 24.64 ms 0.0% 2644.04 Mbps 895.88 Mbps Elisa Oyj - Helsinki Stockholm, SE 34.93 ms 1.1% 1903.65 Mbps 1264.20 Mbps i3D.net - Stockholm Oslo, NO 25.11 ms 0.0% 1379.14 Mbps 986.65 Mbps Speedtest.net - Oslo Moscow, RU 38.45 ms 0.0% 3207.21 Mbps 696.74 Mbps Rostelecom - Moscow Petersburg, RU 41.60 ms 0.0% 2697.02 Mbps 760.78 Mbps MTS OJSC - Saint Petersburg Istanbul, TR FAILED Tbilisi, GE FAILED --------------------------------------------------------------------------- Avg DL Speed : 2862.48 Mbps Avg UL Speed : 1313.39 Mbps Total DL Data : 113.04 GB Total UL Data : 54.27 GB Total Data : 167.30 GB --------------------------------------------------------------------------- Duration : 12 min 57 sec System Time : 03/10/2023 - 12:58:15 CEST Total Script Runs : 24610 ---------------------------------------------------------------------------Atomic Networks CHI-B-KVM-16
Layer Giveaway
---------------------------- network-speed.xyz ---------------------------- A simple script to test network performance using speedtest-cli --------------------------------------------------------------------------- Version : v2023.09.30 Global Speedtest : wget -qO- network-speed.xyz | bash Region Speedtest : wget -qO- network-speed.xyz | bash -s -- -r --------------------------------------------------------------------------- Basic System Info --------------------------------------------------------------------------- CPU Model : AMD Ryzen 9 7950X 16-Core Processor CPU Cores : 1 @ 4499.996 MHz CPU Cache : 1024 KB AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled Total Disk : 9.9 GB (1.9 GB Used) Total RAM : 422.9 MB (149.3 MB Used) System uptime : 0 days, 2 hour 0 min Load average : 0.00, 0.00, 0.00 OS : Debian GNU/Linux 12 Arch : x86_64 (64 Bit) Kernel : 6.1.0-9-amd64 Virtualization : KVM --------------------------------------------------------------------------- Basic Network Info --------------------------------------------------------------------------- IPv6 Access : ✔ Online IPv4 Access : ✔ Online ISP : Layer Marketing Services L.L.C ASN : AS216382 LAYER MARKETING SERVICES L.L.C Host : Layer Location : Spokane, Washington-WA, United States --------------------------------------------------------------------------- Speedtest.net (Region: INDONESIA) --------------------------------------------------------------------------- Location Latency Loss DL Speed UP Speed Server ISP: Layer Marketing Services L.L.C Nearest 0.17 ms 0.0% 9238.18 Mbps 8808.10 Mbps Crunchbits - Spokane, WA Jakarta 181.22 ms 0.0% 937.19 Mbps 215.38 Mbps Hutchison 3 Indonesia CGK-MM - Jakarta Jakarta 196.49 ms 0.0% 1804.48 Mbps 78.09 Mbps DomaiNesia - Jakarta Jakarta 200.28 ms 0.0% 1844.23 Mbps 92.40 Mbps PT. Telekomunikasi Indonesia - Jakarta Jakarta 195.10 ms 0.0% 2033.76 Mbps 142.95 Mbps PT Indosat Tbk - Jakarta Jakarta 182.79 ms 0.0% 1092.22 Mbps 305.14 Mbps MyRepublic Indonesia - South Jakarta Bandung 200.63 ms N/A 299.23 Mbps 42.68 Mbps HYPERNET - Bandung Bekasi 186.95 ms 0.7% 330.33 Mbps 151.50 Mbps PT Lintas Jaringan Nusantara - Bekasi Bogor 194.59 ms 0.0% 927.58 Mbps 220.53 Mbps PT. Java Digital Nusantara - Bogor Malang 347.36 ms 0.0% 1210.62 Mbps 249.83 Mbps GlobalXtreme - Malang Semarang 194.07 ms N/A 2039.35 Mbps 373.23 Mbps PT. Indonesia Comnets Plus - Semarang Surabaya 193.54 ms N/A 2006.16 Mbps 366.49 Mbps PT. Indonesia Comnets Plus - Surabaya Yogyakarta 208.74 ms 0.0% 784.07 Mbps 75.33 Mbps PT Union Routelink Communication - Yogyakarta Banda Aceh 204.11 ms 0.0% 1880.19 Mbps 332.99 Mbps PT. Telekomunikasi Indonesia - Banda Aceh Medan 182.19 ms 0.0% 2145.55 Mbps 379.53 Mbps Biznet Networks - Medan Palembang 224.58 ms N/A 492.94 Mbps 1.85 Mbps PT. Sakti Putra Mandiri - Palembang Pekanbaru 215.97 ms 2.0% 423.82 Mbps 70.07 Mbps PT Hexa Media Sarana - Pekanbaru Bali 205.77 ms 0.0% 1851.30 Mbps 344.47 Mbps Biznet Networks - Bali Makassar 234.53 ms 0.0% 444.69 Mbps 256.24 Mbps Biznet Networks - Makassar Depok 235.82 ms 0.0% 0.54 Mbps 123.62 Mbps ADI - Depok Tangerang 200.85 ms 0.0% 935.39 Mbps 7.53 Mbps PT. Java Medianet Tekhnologi - Tangerang --------------------------------------------------------------------------- Avg DL Speed : 1558.18 Mbps Avg UL Speed : 601.80 Mbps Total DL Data : 39.25 GB Total UL Data : 12.71 GB Total Data : 51.96 GB --------------------------------------------------------------------------- Duration : 11 min 19 sec System Time : 07/10/2023 - 21:38:36 WIB Total Script Runs : 24840 --------------------------------------------------------------------------- Result : https://result.network-speed.xyz/r/1696689353_PS2K6I_INDONESIA.txt ---------------------------------------------------------------------------Sultan Muda - Amazon Store
Xeroz.tech - SG
NanoKVM - Norway
Hivelocity VPS - NYC
microLXC - South Africa
Greencloud 1010 DE
@MallocVoidstar could you do an EU test as well?
---------------------------- network-speed.xyz ---------------------------- A simple script to test network performance using speedtest-cli --------------------------------------------------------------------------- Version : v2023.09.30 Global Speedtest : wget -qO- network-speed.xyz | bash Region Speedtest : wget -qO- network-speed.xyz | bash -s -- -r --------------------------------------------------------------------------- Basic System Info --------------------------------------------------------------------------- CPU Model : AMD EPYC 7B13 64-Core Processor CPU Cores : 2 @ 2249.998 MHz CPU Cache : 512 KB AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled Total Disk : 54.0 GB (4.3 GB Used) Total RAM : 7.8 GB (224.4 MB Used) System uptime : 0 days, 5 hour 5 min Load average : 21.72, 11.95, 6.13 OS : Ubuntu 22.04.3 LTS Arch : x86_64 (64 Bit) Kernel : 5.15.0-69-generic Virtualization : KVM --------------------------------------------------------------------------- Basic Network Info --------------------------------------------------------------------------- IPv6 Access : ❌ Offline IPv4 Access : ✔ Online ISP : Advin Services LLC ASN : AS206216 Advin Services LLC ASN (IPv4) : AS23470 ReliableSite.Net LLC Host : Advin Services LLC Location : Los Angeles, California-CA, United States --------------------------------------------------------------------------- Speedtest.net (Region: NORTH AMERICA) --------------------------------------------------------------------------- Location Latency Loss DL Speed UP Speed Server ISP: ReliableSite.Net LLC Nearest 0.51 ms 0.0% 7863.40 Mbps 1611.19 Mbps Race Communications - Los Angeles, CA Vancouver, BC 35.22 ms N/A 5142.77 Mbps 2316.04 Mbps TELUS - Vancouver, BC Calgary, AB 54.73 ms N/A 7719.12 Mbps 1539.41 Mbps Shaw Communications - Calgary, AB Winnipeg, MB 71.64 ms 0.0% 5011.47 Mbps 1113.65 Mbps Voyageur Internet - Winnipeg, MB Toronto, ON 74.76 ms 0.0% 7757.77 Mbps 1079.82 Mbps Bell Canada - Toronto, ON Montreal, QC 74.76 ms 0.0% 7210.17 Mbps 1086.69 Mbps Rogers Wireless - Montréal, QC New York, NY 72.68 ms 0.0% 3383.09 Mbps 1120.14 Mbps Surfshark Ltd - New York, NY Ashburn, VA 67.99 ms 0.0% 4896.27 Mbps 1180.14 Mbps Rackdog - Ashburn, VA Charlotte, NC 64.49 ms 0.0% 3345.26 Mbps 1238.53 Mbps Windstream - Charlotte, NC Atlanta, GA 50.75 ms 0.0% 8102.37 Mbps 1619.68 Mbps i3D.net - Atlanta, GA Miami, FL 60.74 ms 0.0% 3353.58 Mbps 1378.91 Mbps AT&T - Miami, FL Dallas, TX 42.48 ms 0.0% 4927.15 Mbps 1695.18 Mbps Hivelocity - Dallas, TX Houston, TX 39.53 ms 0.0% 6648.62 Mbps 2080.39 Mbps Ezee Fiber - Houston, TX Kansas, MO 47.17 ms 0.0% 3371.25 Mbps 1292.25 Mbps Xiber LLC - Kansas City, MO Minneapolis, MN 66.34 ms 0.0% 7537.45 Mbps 1276.52 Mbps US Internet - Minneapolis, MN Chicago, IL 56.78 ms 0.0% 7888.13 Mbps 1439.86 Mbps Enzu.com - Chicago, IL Cleveland, OH 72.49 ms 0.0% 6146.80 Mbps 1138.13 Mbps Windstream - Cleveland, OH Albuquerque, NM 32.01 ms N/A 5804.59 Mbps 2596.54 Mbps Comcast - Albuquerque, NM Denver, CO 29.74 ms 0.0% 6542.88 Mbps 2764.07 Mbps T-Mobile Fiber | Intrepid - Denver, CO Portland, OR 28.93 ms N/A 8076.82 Mbps 2876.81 Mbps CenturyLink - Portland, OR Las Vegas, NV 6.10 ms N/A 5306.99 Mbps 7583.28 Mbps Dish Wireless - Las Vegas, NV Salt Lake, UT 29.50 ms N/A 3216.93 Mbps 2819.15 Mbps Novva Data Centers - Salt Lake City, UT Phoenix, AZ 12.71 ms 0.0% 6998.24 Mbps 6280.85 Mbps Xiber LLC - Phoenix, AZ Los Angeles, CA 0.54 ms 0.0% 7831.18 Mbps 9356.22 Mbps ReliableSite Hosting - Los Angeles, CA San Jose, CA 13.22 ms 0.0% 7282.77 Mbps 5878.80 Mbps Misaka Network, Inc. - San Jose, CA Seattle, WA 32.14 ms 0.0% 6814.44 Mbps 2562.33 Mbps Misaka Network, Inc. - Seattle, WA Hermosillo, MX 52.46 ms 0.0% 5799.71 Mbps 1692.91 Mbps Megacable - Hermosillo Guadalajara, MX 64.16 ms 0.0% 1465.83 Mbps 1013.45 Mbps AT&T México - Guadalajara Mexico City, MX 51.19 ms N/A 4838.99 Mbps 1590.47 Mbps INFINITUM - Mexico City Merida, MX FAILED --------------------------------------------------------------------------- Avg DL Speed : 5871.90 Mbps Avg UL Speed : 2455.91 Mbps Total DL Data : 225.40 GB Total UL Data : 83.70 GB Total Data : 309.10 GB --------------------------------------------------------------------------- Duration : 18 min 6 sec System Time : 17/10/2023 - 13:16:08 WIB Total Script Runs : 25423 --------------------------------------------------------------------------- Result : https://paste.kangserver.id/view/rQgyVo8 ---------------------------------------------------------------------------Global Speedtest
advin is rock solid!
The baller lowhosting machine.
Team push-ups!
is this script broken
What's up?
1010 SG to India,
Greencloud 1010 DE, EU test
date '+%d/%m/%Y - %H:%M:%S %Z',date -u '+%d/%m/%Y - %H:%M:%S %Z', to make it easier to understand for people who don't know mysterious timezone abbreviations.HostEONS Ryzen 7950X Hybrid Server - US - North America Speedtest.
---------------------------- network-speed.xyz ---------------------------- A simple script to test network performance using speedtest-cli --------------------------------------------------------------------------- Version : v2023.09.30 Global Speedtest : wget -qO- network-speed.xyz | bash Region Speedtest : wget -qO- network-speed.xyz | bash -s -- -r --------------------------------------------------------------------------- Basic System Info --------------------------------------------------------------------------- CPU Model : AMD Ryzen 9 7950X 16-Core Processor CPU Cores : 2 @ 4499.952 MHz CPU Cache : 1024 KB AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled Total Disk : 48.1 GB (5.1 GB Used) Total RAM : 7.8 GB (178.7 MB Used) Total Swap : 1024.0 MB (0 Used) System uptime : 0 days, 0 hour 28 min Load average : 0.19, 0.95, 0.82 OS : Ubuntu 22.04.3 LTS Arch : x86_64 (64 Bit) Kernel : 5.15.0-86-generic Virtualization : KVM --------------------------------------------------------------------------- Basic Network Info --------------------------------------------------------------------------- IPv6 Access : ❌ Offline IPv4 Access : ✔ Online ISP : Ipxo LLC ASN : AS60721 Bursabil Teknoloji A.S. ASN (IPv4) : AS142036 Hosteons Pte. Ltd. Host : Hosteons Pte. Ltd Location : Los Angeles, California-CA, United States Location (IPv4) : Salt Lake City, Utah, US --------------------------------------------------------------------------- Speedtest.net (Region: NORTH AMERICA) --------------------------------------------------------------------------- Location Latency Loss DL Speed UP Speed Server ISP: Deft Hosting Nearest 0.92 ms 0.0% 6475.37 Mbps 7730.19 Mbps Sumo Fiber - Salt Lake City, UT Vancouver, BC 23.92 ms N/A 6884.07 Mbps 3389.69 Mbps TELUS - Vancouver, BC Calgary, AB 49.67 ms N/A 6488.56 Mbps 1634.99 Mbps Shaw Communications - Calgary, AB Winnipeg, MB 37.38 ms 0.0% 7005.16 Mbps 2266.84 Mbps Voyageur Internet - Winnipeg, MB Toronto, ON 57.14 ms 0.0% 6911.27 Mbps 1445.65 Mbps Bell Canada - Toronto, ON Montreal, QC 54.29 ms 0.0% 7122.33 Mbps 1526.99 Mbps Rogers Wireless - Montréal, QC New York, NY 53.30 ms 0.0% 8201.49 Mbps 1588.51 Mbps Surfshark Ltd - New York, NY Ashburn, VA 44.90 ms 0.0% 6682.28 Mbps 1678.82 Mbps Rackdog - Ashburn, VA Charlotte, NC 55.05 ms 0.0% 6525.10 Mbps 1464.92 Mbps Windstream - Charlotte, NC Atlanta, GA 44.73 ms 0.0% 6937.38 Mbps 1824.21 Mbps i3D.net - Atlanta, GA Miami, FL 74.28 ms 0.0% 6956.31 Mbps 1114.70 Mbps AT&T - Miami, FL Dallas, TX 61.83 ms 0.0% 6441.09 Mbps 1332.61 Mbps Hivelocity - Dallas, TX Houston, TX 34.27 ms 0.0% 5818.94 Mbps 2411.81 Mbps Ezee Fiber - Houston, TX Kansas, MO 22.74 ms 0.0% 6209.51 Mbps 3687.80 Mbps Xiber LLC - Kansas City, MO Minneapolis, MN 34.45 ms 0.0% 7032.90 Mbps 2481.59 Mbps US Internet - Minneapolis, MN Chicago, IL 34.91 ms 0.0% 8330.82 Mbps 2373.19 Mbps Enzu.com - Chicago, IL Cleveland, OH 68.03 ms 0.0% 3603.02 Mbps 1196.11 Mbps Windstream - Cleveland, OH Albuquerque, NM 20.46 ms N/A 6891.57 Mbps 4038.76 Mbps Comcast - Albuquerque, NM Denver, CO 12.15 ms 0.0% 8508.77 Mbps 6448.51 Mbps T-Mobile Fiber | Intrepid - Denver, CO Portland, OR 34.24 ms N/A 8604.18 Mbps 2458.56 Mbps CenturyLink - Portland, OR Las Vegas, NV 25.53 ms N/A 6670.67 Mbps 3215.69 Mbps Dish Wireless - Las Vegas, NV Salt Lake, UT 1.72 ms N/A 7179.58 Mbps 8239.18 Mbps Novva Data Centers - Salt Lake City, UT Phoenix, AZ 29.56 ms 0.0% 6084.91 Mbps 2852.93 Mbps Xiber LLC - Phoenix, AZ Los Angeles, CA 28.69 ms 0.0% 6655.12 Mbps 5017.02 Mbps ReliableSite Hosting - Los Angeles, CA San Jose, CA 18.82 ms 0.0% 6448.14 Mbps 3843.35 Mbps Misaka Network, Inc. - San Jose, CA Seattle, WA 20.82 ms 0.0% 6291.90 Mbps 3825.24 Mbps Misaka Network, Inc. - Seattle, WA Hermosillo, MX 67.26 ms 0.0% 4874.28 Mbps 1261.67 Mbps Megacable - Hermosillo Guadalajara, MX 57.00 ms 0.0% 1877.02 Mbps 1368.35 Mbps AT&T México - Guadalajara Mexico City, MX 65.85 ms N/A 7995.39 Mbps 1239.33 Mbps INFINITUM - Mexico City Merida, MX FAILED --------------------------------------------------------------------------- Avg DL Speed : 6610.62 Mbps Avg UL Speed : 2860.60 Mbps Total DL Data : 251.30 GB Total UL Data : 95.50 GB Total Data : 346.80 GB --------------------------------------------------------------------------- Duration : 11 min 53 sec System Time : 19/10/2023 - 11:00:45 WIB Total Script Runs : 25551 --------------------------------------------------------------------------- Result : https://paste.kangserver.id/view/FLjVftM ---------------------------------------------------------------------------Global Speedtest
Updated to v2023.10.24
* Updated locations/servers
* Asia now uses servers >= 1Gbps
* Shows error on whether being rate limited by Ookla
If you try to download and start it via your resulting in an empty return. So no bash script is downloaded by wget but the cloudflare blocker.
wget -qO- network-speed.xyz | bashyou might get hit by the Cloudflare interception asking you for a captcha to solve. But as you don't access that resource via browser but load it via wget, the html page of Cloudflares captcha interception gets downloaded and executed via the bash commandThis may happen to one ip while the vps sitting next to your vps does not run into this problem.
whats wrong here?
Distro : Debian GNU/Linux 10 (buster)
Kernel : 4.19.0-25-amd64
VM Type : KVM
@sh97
@Advin
solid!
---------------------------- network-speed.xyz ---------------------------- A simple script to test network performance using speedtest-cli --------------------------------------------------------------------------- Version : v2023.10.24 Global Speedtest : wget -qO- network-speed.xyz | bash Region Speedtest : wget -qO- network-speed.xyz | bash -s -- -r --------------------------------------------------------------------------- Basic System Info --------------------------------------------------------------------------- CPU Model : AMD EPYC 7B13 64-Core Processor CPU Cores : 2 @ 2249.998 MHz CPU Cache : 512 KB AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled Total Disk : 59.0 GB (1.4 GB Used) Total RAM : 7.8 GB (347.6 MB Used) System uptime : 17 days, 1 hour 10 min Load average : 0.05, 0.01, 0.00 OS : Debian GNU/Linux 12 Arch : x86_64 (64 Bit) Kernel : 6.1.0-13-amd64 Virtualization : KVM --------------------------------------------------------------------------- Basic Network Info --------------------------------------------------------------------------- Primary Network : IPv4 IPv6 Access : ❌ Offline IPv4 Access : ✔ Online ISP : Advin Services LLC ASN : AS206216 Advin Services LLC Host : MB \ Location : Kerkrade, Limburg-LI, Netherlands --------------------------------------------------------------------------- Speedtest.net (Region: EUROPE) --------------------------------------------------------------------------- Location Latency Loss DL Speed UP Speed Server ISP: Advin Services LLC Nearest 12.74 ms 0.0% 816.56 Mbps 940.87 Mbps NetCologne - Cologne London, UK 20.85 ms 0.0% 3303.84 Mbps 4275.54 Mbps M247 Ltd - London Edinburgh, UK 32.51 ms N/A 5973.35 Mbps 2616.26 Mbps Vodafone UK - Edinburgh Dublin, IE 30.03 ms 0.0% 6266.02 Mbps 2429.12 Mbps Three Ireland - Dublin Amsterdam, NL 15.20 ms 0.0% 6636.06 Mbps 5738.69 Mbps Melbicom - Amsterdam Eygelshoen, NL 18.20 ms 0.0% 7622.07 Mbps 1789.31 Mbps SkyLink Data Center BV - Eygelshoven Paris, FR 18.66 ms 0.0% 5545.09 Mbps 3819.48 Mbps ORANGE FRANCE - Paris Marseille, FR 26.00 ms 0.0% 7570.10 Mbps 3617.16 Mbps GSL Networks - Marseille Madrid, ES 39.22 ms 0.0% 6601.13 Mbps 2548.16 Mbps Orange - Jazztel - Madrid Barcelona, ES 35.79 ms 0.0% 6402.43 Mbps 2046.63 Mbps Adamo - Barcelona Lisbon, PT 46.89 ms 0.0% 7669.07 Mbps 1901.26 Mbps Edgoo Networks - Lisbon Rome, IT 27.47 ms 0.0% 6579.08 Mbps 2853.06 Mbps TIM SpA - Rome Milan, IT 17.67 ms 0.0% 6728.65 Mbps 3294.37 Mbps Fastweb SpA - Milan Zurich, CH 12.85 ms 0.0% 7949.89 Mbps 3733.13 Mbps Sunrise Communication AG - Zurich Frankfurt, DE 8.27 ms 0.0% 5237.52 Mbps 7223.78 Mbps 23M GmbH - Frankfurt am Main Berlin, DE 19.62 ms N/A 6358.60 Mbps 1207.26 Mbps Misaka Network, Inc. - Berlin Vienna, AT 14.02 ms 0.0% 6312.26 Mbps 6131.93 Mbps A1 Telekom Austria AG - Vienna Budapest, HU 16.52 ms 0.0% 8572.53 Mbps 5198.57 Mbps ATW Internet Kft. - Budapest Gdansk, PL 55.22 ms 0.0% 920.25 Mbps 112.37 Mbps T-Mobile Polska S.A. - Gdańsk Warsaw, PL 25.90 ms 0.0% 452.40 Mbps 3434.83 Mbps Orange Polska S.A. - Warsaw Lviv, UA 32.10 ms 0.0% 5979.82 Mbps 1916.35 Mbps Kyivstar - Lviv Kyiv, UA 30.94 ms 0.0% 6957.58 Mbps 993.34 Mbps o3 - Kyiv Minsk, BY 79.91 ms 0.0% 5509.85 Mbps 737.89 Mbps A1 - Minsk Bucharest, RO 31.70 ms 0.0% 5938.34 Mbps 1217.10 Mbps Orange Romania Communications - Bucharest Iasi, RO 56.30 ms 0.0% 6851.68 Mbps 863.22 Mbps Digi Helsinki, FI 29.16 ms 0.0% 6296.26 Mbps 3020.88 Mbps Elisa Oyj - Helsinki Stockholm, SE 32.40 ms 0.0% 7367.48 Mbps 2761.21 Mbps i3D.net - Stockholm Oslo, NO 35.41 ms 0.0% 5245.20 Mbps 1464.11 Mbps Speedtest.net - Oslo Moscow, RU 41.28 ms 0.0% 4269.42 Mbps 2175.73 Mbps Rostelecom - Moscow Petersburg, RU 47.84 ms 0.0% 3763.34 Mbps 1484.75 Mbps MTS OJSC - Saint Petersburg Istanbul, TR 38.87 ms 0.0% 5834.52 Mbps 1944.96 Mbps Turkcell - Istanbul Tbilisi, GE 62.22 ms N/A 4737.57 Mbps 1222.17 Mbps Silknet JSC - Tbilisi --------------------------------------------------------------------------- Avg DL Speed : 5695.88 Mbps Avg UL Speed : 2647.31 Mbps Total DL Data : 241.99 GB Total UL Data : 108.37 GB Total Data : 350.36 GB --------------------------------------------------------------------------- Duration : 19 min 12 sec System Time : 27/10/2023 - 19:17:57 UTC Total Script Runs : 26092 --------------------------------------------------------------------------- Result : see above ---------------------------------------------------------------------------Looks like a Cloudflare block.
I haven't changed the settings yet, will do it one of these days.
