2 vCPU 8GB RAM 10 Gbit $4/mo + Question
2
  • AdvinAdvin Hosting Provider
    @sayyiku said:
    Will 7950x vds in nl get a major restock?
    Maybe, don't know yet
  • Install failed
    Your server failed to install. Please contact your administrator.
  • Will 2 vCPU 8GB RAM 10 Gbit $4/mo restock?
    Thanked by (1)archives
  • out of stock
    Should be restocked now!
    Install failed
  • Invoice #28909
    We were unable to locate your VPS. If this is your first time accessing your VPS, please try refreshing this page. If refreshing the page does not fix this issue, please open a ticket through our client area and our support members will assist you. >
  • @Advin UUID: e0c72409 Install failed
    Please open a ticket, I cannot assist you here
  • Nice to see you back. Is there any snapshot/ backup feature added? And is custom ISO installation easy now? Abd still using RAID-0 for some nodes?
    I used your service last time and performance was good, so wanted to give another try
  • **solid! **
    diskspeed is noticeably slower than here in this test:
    https://lowendspirit.com/discussion/comment/152044/#Comment_152044
    @Advin
    #                     v2023-09-06                    #
    Sun 01 Oct 2023 07:32:32 AM UTC
    Uptime     : 0 days, 5 hours, 23 minutes
    Processor  : AMD EPYC 7B13 64-Core Processor
    CPU cores  : 2 @ 2249.998 MHz
    RAM        : 7.8 GiB
    Swap       : 0.0 KiB
    Disk       : 59.0 GiB
    Kernel     : 5.10.0-21-amd64
    ISP        : Advin Services LLC
    ASN        : AS206216 Advin Services LLC
    Host       : MB \Lirutis\
    Country    : Netherlands
    Read       | 188.25 MB/s  (47.0k) | 397.87 MB/s   (6.2k)
    Write      | 188.75 MB/s  (47.1k) | 399.97 MB/s   (6.2k)
    Total      | 377.01 MB/s  (94.2k) | 797.85 MB/s  (12.4k)
    Read       | 1.12 GB/s     (2.1k) | 419.33 MB/s    (409)
    Write      | 1.18 GB/s     (2.3k) | 447.25 MB/s    (436)
    Total      | 2.30 GB/s     (4.5k) | 866.59 MB/s    (845)
    Clouvider       | London, UK (10G)          | 6.17 Gbits/sec  | 6.93 Gbits/sec  | 22.5 ms
    Scaleway        | Paris, FR (10G)           | 6.43 Gbits/sec  | 5.94 Gbits/sec  | 17.8 ms
    NovoServe       | North Holland, NL (40G)   | 6.33 Gbits/sec  | 10.7 Gbits/sec  | 15.0 ms
    Uztelecom       | Tashkent, UZ (10G)        | 1.67 Gbits/sec  | 1.99 Gbits/sec  | 94.0 ms
    Clouvider       | NYC, NY, US (10G)         | 1.77 Gbits/sec  | busy            | 92.5 ms
    Clouvider       | Dallas, TX, US (10G)      | 1.25 Gbits/sec  | 1.32 Gbits/sec  | 131 ms
    Clouvider       | Los Angeles, CA, US (10G) | 880 Mbits/sec   | 1.05 Gbits/sec  | 164 ms
    Single Core     | 1296
    Multi Core      | 2352
    YABS completed in 11 min 34 sec
    edited October 2023
    @lapua said:
    **solid! **
    Disk speeds can sometimes vary depending on the host node that you are placed on, sometimes we use Gen4 and sometimes we use Gen3, almost always enterprise drives. I would try and run that test again, perhaps someone else was running a disk benchmark or a Yabs or maybe the IO activity on the node was (for some reason) abnormally higher than normal, given that we started onboarding a lot of new VPS's.
    Thanked by (1)lapua
    edited October 2023
    Backups/snapshots are not available still unfortunately, it's a bit of a logistical challenge to do without having issues. Sadly we still require a ticket for custom ISO mounting.
    We have some legacy nodes with no RAID or RAID0, but our newer nodes are usually RAID5/RAID10 and we are working on completely phasing out the old nodes. All drives are enterprise drives, typically Kioxia CD-6 or Intel P4510.
  • out of stock😣
    hellyeah.
    i only realised now that you run frocdn. good thing i snapped up the offer this time. :)
    @lapua said:
    hellyeah.
    edited October 2023
    We will be receiving a shipment of another 2TB of RAM tomorrow, will evaluate where to send it to. Maybe Singapore, Los Angeles, or Nuremberg, should keep stock for at least 3-4 weeks =)
    Also saw that Tokyo was popular in the poll, will have to see, currently we are with HostUniversal but we haven't really done colo with them in Tokyo - will have to see if there is availability and at what cost for future expansion. Nuremberg or Los Angeles might especially be ideal because we have transit directly and space with the DC directly rather than working with a reseller.
  • Seem like LA is out of stock. Will it be restocked anytime soon?
  • edited October 2023
    Install failed
    821215 It hasn't been processed all afternoon. I've re-issued a work order. Can it be processed quickly?
    @muliu said:
    Install failed
    I'm the same. No one has dealt with the work order.
  • Can I use ~25TB outbound at KVM Standard XS Nuremberg?
    same issue, install failed, been waiting to be dealt with for a long time...
  • JabJab Senpai
    You guys aware it's fucking Sunday? :D
    Thanked by (3)FrankZ ehab terrorgen
  • In certain countries, there is no weekend. =)
    Thanked by (1)ehab
    Shouldn't the server provider have someone on duty around the clock? My understanding is this. If something happens, it can be solved in time, otherwise it will cause greater losses. Do you think this is how it should be?
  • FrankZFrankZ ModeratorOG
    Yes, there are providers that do this as long as you are willing to pay them enough to hire people to provide this service. The LE market requires an understanding that work orders may take a little longer.
    Well, the server merchant I bought from basically has people online handling work orders every day, and the same is true on weekends.
    Why don't you buy from the same merchant, for the discount correct?
    I'm sure @Advin can do the same if you are willing to pay for it.
    Thanked by (2)FrankZ terrorgen
  • I see 3 interesting locations: Nuremberg, DE, Singapore, SG and Tokyo, JP.
    edited October 2023
    Server deployment problems are typically a much lower priority than other tickets. We generally do have someone online and we do work weekends, but unfortunately we have been busy due to a separate incident in Los Angeles where we had a hardware failure (which is related to these issues in server deployment).
    All tickets about server deployment problems should be cleared up by today.
