Hosteons - $2/mo KVM VPS / 1 vCore / 1GB RAM / 15GB SSD / 1 IPv4 / IPv6 / 4 TB BW / 10G Port -Oct Sp
hostEONShostEONS Hosting ProviderOG
edited October 2023 in Offers
October Special for KVM SSD VPS on 10G Port (Shared)
A deal like never before, no gimmick to pay annually, pay monthly as low as $2
**Locations: Salt Lake City
Looking Glass : https://lg.slc2.hosteons.com
Based on Intel Xeon E5-2650 v4 or similar
1GB VPS:
CPU: 1 vCore (Fair Share)
RAM: 1GB
RAID10 SSD: 15 GB
OS: Linux
IPv4: 1
IPv6: /64
BW: 2 TB - 4 TB
Network Port: 10 Gbps
Backup: 1 Click Backup or Snapshot
Only $2/mo
Order Link: https://my.hosteons.com/store/vps-special-deals
2GB VPS:
CPU: 2 vCore (Fair Share)
RAM: 2GB
RAID10 SSD: 20 GB
OS: Linux
IPv4: 1
IPv6: /64
BW: 4 TB - 8 TB
Only $3.5/mo
3GB VPS:
CPU: 3 vCore (Fair Share)
RAM: 3GB
RAID10 SSD: 30 GB
OS: Linux/Windows
IPv4: 1
IPv6: /64
BW: 6 TB - 12 TB
Only $4.5/mo
4GB VPS:
CPU: 4 vCore (Fair Share)
RAM: 4GB
RAID10 SSD: 40 GB
OS: Linux/Windows
IPv4: 1
IPv6: /64
BW: 8 TB - 16 TB
Only $5.5/mo
How to get Double Bandwidth ?
Just reply in comment with your invoice number we will double your Bandwidth
Please note this offer is setup at minimal margin, hardly even reaching breakeven, so don't expect much support for it, these are unamanged VPS
Regarding CPU FAIR Share we have setup CPU Threshold in Control panel if more then 25% of CPU used for more then 30 minutes at a time then your VPS will be suspended, you will need to submit a support ticket to reactivate it, but if it keeps happening at regular interval, then we will CAP your CPU at 25%
Also 30 minutes is enough, i ran YABS, network speed benchmarks etc... all of it worked fine
Looking for Ryzen Promo: https://lowendspirit.com/discussion/6517/ryzen-clearance-special-salt-lake-city-starts-3-1core-1gb-20gb-nvme-4tb-tran-10g-port-1-ipv4
Looking for VDS or Dedicated Resources check out: https://lowendspirit.com/discussion/6525/hosteons-com-ryzen-vds-8-99-2-vcore-8-gb-ram-100-gb-nvme-30tb-10g-port-les-excl
hostEONS.com - 9 Locations for VPS (US and EU).. Free Blesta License, Free Windows 2019 License and more. Shared DA Hosting. AS142036 .. Ryzen 7950X Based VDS in SLC, LA and Dallas
Thanked by (3)FrankZ sh97 kidoh
  • hostEONShostEONS Hosting ProviderOG
    root@test:~# curl -s https://raw.githubusercontent.com/masonr/yet-another-bench-script/master/yabs.sh | bash
    Yet-Another-Bench-Script
    v2023-09-06
    Fri Oct 6 00:06:42 EDT 2023
    Uptime : 0 days, 0 hours, 1 minutes
    Processor : Intel(R) Xeon(R) CPU E5-2695 v2 @ 2.40GHz
    CPU cores : 1 @ 2399.998 MHz
    AES-NI : ✔ Enabled
    RAM : 987.3 MiB
    Swap : 256.0 MiB
    Disk : 14.4 GiB
    Distro : Debian GNU/Linux 10 (buster)
    Kernel : 4.19.0-24-amd64
    VM Type : KVM
    ISP : Hosteons Pte. Ltd.
    ASN : AS142036 Hosteons Pte. Ltd.
    Host : Hosteons Pte. Ltd
    Country : United States
    Read 80.34 MB/s (20.0k) 605.22 MB/s (9.4k)
    Write 80.55 MB/s (20.1k) 608.40 MB/s (9.5k)
    Total 160.89 MB/s (40.2k) 1.21 GB/s (18.9k)
    Read 688.99 MB/s (1.3k) 729.27 MB/s (712)
    Write 725.60 MB/s (1.4k) 777.84 MB/s (759)
    Total 1.41 GB/s (2.7k) 1.50 GB/s (1.4k)
    Provider Location (Link) Send Speed Recv Speed Ping
    Clouvider London, UK (10G) 361 Mbits/sec 1.29 Gbits/sec 114 ms
    Scaleway Paris, FR (10G) 1.48 Gbits/sec 975 Mbits/sec 151 ms
    NovoServe North Holland, NL (40G) 1.35 Gbits/sec 1.44 Gbits/sec 149 ms
    Uztelecom Tashkent, UZ (10G) 961 Mbits/sec 792 Mbits/sec 212 ms
    Clouvider NYC, NY, US (10G) 3.44 Gbits/sec 3.46 Gbits/sec 48.6 ms
    Clouvider Dallas, TX, US (10G) 6.03 Gbits/sec 5.65 Gbits/sec 31.0 ms
    Clouvider Los Angeles, CA, US (10G) 3.23 Gbits/sec 5.94 Gbits/sec 36.0 ms
    Clouvider London, UK (10G) 171 Mbits/sec 1.58 Gbits/sec 114 ms
    Scaleway Paris, FR (10G) 1.72 Gbits/sec 1.41 Gbits/sec 129 ms
    NovoServe North Holland, NL (40G) 331 Mbits/sec 1.48 Gbits/sec 120 ms
    Uztelecom Tashkent, UZ (10G) 910 Mbits/sec 516 Mbits/sec 212 ms
    Clouvider NYC, NY, US (10G) 462 Mbits/sec 3.81 Gbits/sec 48.9 ms
    Clouvider Dallas, TX, US (10G) 5.72 Gbits/sec 4.97 Gbits/sec 31.0 ms
    Clouvider Los Angeles, CA, US (10G) 5.98 Gbits/sec 5.82 Gbits/sec 26.4 ms
    Geekbench test failed and low memory was detected. Add at least 1GB of SWAP or use GB4 instead (higher compatibility with low memory systems).
    YABS completed in 12 min 42 sec
    root@test:~#
    ---------------------------- network-speed.xyz ----------------------------
    A simple script to test network performance using speedtest-cli
    Version : v2023.09.30
    Global Speedtest : wget -qO- network-speed.xyz | bash
    Region Speedtest : wget -qO- network-speed.xyz | bash -s -- -r
    Basic System Info
    CPU Model : Intel(R) Xeon(R) CPU E5-2695 v2 @ 2.40GHz
    CPU Cores : 1 @ 2399.998 MHz
    CPU Cache : 30720 KB
    AES-NI : ✔ Enabled
    Total Disk : 14.4 GB (1.2 GB Used)
    Total RAM : 987.3 MB (49.9 MB Used)
    Total Swap : 256.0 MB (13.5 MB Used)
    System uptime : 0 days, 1 hour 56 min
    Load average : 0.00, 0.00, 0.00
    OS : Debian GNU/Linux 10
    Arch : x86_64 (64 Bit)
    Virtualization : KVM
    Basic Network Info
    IPv6 Access : ✔ Online
    IPv4 Access : ✔ Online
    Location (IPv4) : Los Angeles, California, US
    Location Latency Loss DL Speed UP Speed Server
    ISP: Hosteons
    Nearest 1.45 ms 0.0% 6102.64 Mbps 6750.19 Mbps Sumo Fiber - Salt Lake City, UT
    Kochi, IN 264.02 ms 0.0% 3213.58 Mbps 328.91 Mbps Asianet Broadband - Cochin
    Bangalore, IN 252.09 ms 0.0% 3107.91 Mbps 295.07 Mbps Bharti Airtel Ltd - Bangalore
    Chennai, IN 252.25 ms N/A 2919.29 Mbps 431.64 Mbps Jio - Chennai
    Mumbai, IN 267.08 ms 0.0% 3066.14 Mbps 293.76 Mbps i3D.net - Mumbai
    Delhi, IN 277.05 ms 0.0% 2206.02 Mbps 326.32 Mbps Tata Teleservices Ltd - New Delhi
    Seattle, US 21.05 ms 0.0% 6082.59 Mbps 4580.38 Mbps Ziply Fiber - Seattle, WA
    Los Angeles, US 15.25 ms 0.3% 5490.54 Mbps 57.65 Mbps ReliableSite Hosting - Los Angeles, CA
    Dallas, US 32.59 ms 0.0% 5323.88 Mbps 3044.06 Mbps Hivelocity - Dallas, TX
    Miami, US 66.67 ms 0.0% 2938.32 Mbps 1434.98 Mbps AT&T - Miami, FL
    New York, US 76.72 ms 0.0% 5937.71 Mbps 209.46 Mbps GSL Networks - New York, NY
    Toronto, CA 43.68 ms 0.0% 6548.05 Mbps 2005.19 Mbps Rogers - Toronto, ON
    London, UK 120.90 ms 0.0% 4827.54 Mbps 854.43 Mbps VeloxServ Communications - London
    Amsterdam, NL 121.11 ms 0.0% 6080.38 Mbps 153.34 Mbps 31173 Services AB - Amsterdam
    Paris, FR 120.60 ms N/A 6080.98 Mbps 111.78 Mbps Axione - Paris
    Frankfurt, DE 135.12 ms 0.0% 3967.77 Mbps 642.71 Mbps 23M GmbH - Frankfurt am Main
    Warsaw, PL 172.73 ms 0.0% 2626.96 Mbps 515.33 Mbps UPC Polska - Warszawa
    Bucharest, RO 171.17 ms 0.0% 4134.50 Mbps 543.92 Mbps Vodafone Romania Fixed – Bucharest - Bucharest
    Jeddah, SA 184.52 ms 0.0% 4241.20 Mbps 131.67 Mbps Saudi Telecom Company
    Dubai, AE 242.54 ms 0.0% 3225.47 Mbps 404.74 Mbps du - Dubai
    Fujairah, AE 250.22 ms 0.0% 3258.63 Mbps 433.62 Mbps ETISALAT-UAE - Fujairah
    Tokyo, JP 112.08 ms N/A 1102.61 Mbps 299.77 Mbps fdcservers.net - Tokyo
    Shanghai, CU-CN 170.35 ms 0.0% 4126.02 Mbps 653.41 Mbps China Unicom 5G - Shanghai
    Nanjing, CT-CN 188.28 ms 0.0% 2787.29 Mbps 46.25 Mbps China Telecom JiangSu 5G - Nanjing
    Hong Kong, CN 154.27 ms N/A 3011.62 Mbps 66.62 Mbps STC - Hong Kong
    Singapore, SG 168.49 ms 0.0% 4276.06 Mbps 164.02 Mbps i3D.net - Singapore
    Jakarta, ID 183.90 ms 0.0% 2870.94 Mbps 34.41 Mbps PT. Telekomunikasi Indonesia - Jakarta
    Avg DL Speed : 4057.59 Mbps
    Avg UL Speed : 919.02 Mbps
    Total DL Data : 148.10 GB
    Total UL Data : 33.27 GB
    Total Data : 181.37 GB
    Duration : 13 min 48 sec
    System Time : 06/10/2023 - 02:16:02 EDT
    Total Script Runs : 24783
    Result : https://result.network-speed.xyz/r/1696572778_ZBZR1E_GLOBAL.txt
    root@test:~#
  • Invoice #130733
    Thanked by (1)hostEONS
  • @hostEONS said: if more then 25% of CPU used for more then 30 minutes
    Tell 'im @FrankZ : what goes in there?
    Than :)
    Thanked by (2)AlwaysSkint hostEONS
    @nic2013 said:
    Invoice #130733
    Thanks for the order BW doubled
  • Invoice #131659
    please double the bandwith
    :3
    @lnstrument said:
    Invoice #131659
    :3
    Welcome to Hosteons
    Bandwidth Doubled
    thanks
  • Invoice #131806
    Thanks
    @raphael said:
    Invoice #131806
    Thanks
    Welcome to Hosteons
    Bandwidth Doubled
    thanks
  • Invoice #134623
    Thanks. I'm new to the forum
  • What happen in the event you use the bandwidth, throttlion or suspension? Tks
    Suspension and reactivate again next month or you can buy additional BW
    @kogeki said:
    Invoice #134623
    Looks like this was already done by our support team
