[Done, Over, Finito] Hey LES! Claim your free Uptime Monitors upgrade!
12346»
  • TheDPTheDP OGSenpai
    @hozan said:
    fb70fc2fdec51c5f5231b580354f1765
    Thank you @Andrei, congrats! Please up
    Done.
    Thanked by (2)AlwaysSkint ialexpw
  • skorousskorous OGSenpai
    edited October 2023
    @hozan can you tell me what the title of this thread is?
    EDIT: My apologies. My browser got weird so the title change happened after your post. I am at fault.
  • @Andrei Not sure if the script is broken but I got
    Letting HetrixTools platform know the installation has been completed... ... done. hetrixtools_install.sh: line 194: [: hetrixtools: integer expression expected Starting the agent under the 'hetrixtools' user... ... done. HetrixTools agent installation completed.
    Title was changed/updated yesterday :smiley:
  • FAT32FAT32 OGSenpai
    You need to make your code larger:
    082932aa301597b7ad4d57bd82920b85
    MOARRRR
    Thanked by (2)Wonder_Woman Decicus
    See I thought so! I saw your post and figured it'd just happened. I didn't want to be an asshole without cause. :D
  • mannenmannen Hosting Provider
    Damn missed it but nice giveaway!
    RIPE LIR
  • AndreiAndrei Services Provider
    That shouldn't impair the agent's installation or functionality, but it also shouldn't happen.
    Please open a ticket on our platform so we can look further into this.
    Thanks.
  • a9e24c9c8e0b1bd51c07dc60c5fb5287
    Reading is difficult
  • @bikegremlin said:
    ... but I see no reason to not shamelessly promote my HetrixTools affiliate link: :)
    https://hetrix.tools/u-446651
    Thanks for the additional monitors. :)
    Cloudstorage Filen.io Aff - filelu Aff
    Free Uptime Monitoring HetrixTools Aff
    Note that in order to keep the extra monitors you must log into your HetrixTools account at least once every 30 days.
    They remove the extra monitors from "inactive" accounts.
    Thanked by (2)Wonder_Woman cxg
  • Missed the giveaway ... But will the 1.x script/agent package auto-selfupdate?
    Or do I need to manually update package on my nodes? 😅
    (Manually updated a couple, looks good! :+1: )
    It didn't upgrade between minor versions so I doubt it does major versions.
    Thanked by (1)flips
    Might break the agent on OpenBSD (had some trouble work getting it to run IIRC) ... On FreeBSD I gave up (a good while since I tried). :sunglasses:
    Indeed a shame this is for linux only. I'm using FreeBSD on some boxes too and I run their php agent to monitor it (had to install php anyways). It's just a workaround though, waiting for the day *BSD is supported. ;)
    Thanked by (1)flips
  • @Andrei - looks like these instructions don't work on v2 of the script - https://docs.hetrixtools.com/misconfigured-network-interface-name/
    In v2 NetworkInterfaces was moved to the config file /etc/hetrixtools/hetrixtools.cfg.
    Thanked by (1)bdl
  • Missed the give away!
    Shows up more often at LES so as to not miss more giveaways. :)
    Thanked by (1)DanSummer
    I usually visit 10-15 times a day. But for some strange reason I missed his post.
    I'll do better next time :)
