@gritty said:
any process for new ipv4 at laxa007?
Same problem here (stuck with the old dead IP). I opened a ticket 21 hours ago.
I don't expect opening a ticket is going to get you a new IP assigned any faster than the rest of us that are waiting on LAXA007. Just saying.
Well the Network Status page doesn't say anything about LAXA007 still needing IP assignment work, so for some reason that gave me the impression that it was "done" and this would be considered an "unknown issue".
@cornercase said: Well the Network Status page doesn't say anything about LAXA007 still needing IP assignment work, so for some reason that gave me the impression that it was "done" and this would be considered an "unknown issue".
The best way I have found is to ask here if anyone else has the same issue as you. Then you will not feel so alone.
I do have some updates available but I'm not providing them as it's very messy on all sides, more than usual, and won't be valuable outside of confusing everyone. If I had provided updates over the last few days they would've changed several times already.
@duc5e said:
I have 2 ipv4s but when I moved to the new node TPAZ004, I only had 1 ipv4 left. Is there any way that can help me?
Look at the ticket in your account that was sent to notify you of your IP change (if you received one). It will likely say:
This ticket was created to notify you of an upcoming change with your service. We will be changing your server's main IP address and additional IP addresses on Thursday, Maybe Never.
Old IP address(es): xxx.xxx.xxx.xxx, xxx.xxx.xxx.xxx
New IP address(es): xxx.xxx.xxx.xxx
If it shows you had 2 already it will make it easier to prove there was an error. You can open a new ticket and screenshot that to show you should have 2. I'd only do that though once your single "new" IP is working in case you are in the transition process.
@VirMach said: TYOC038 - Royally screwed, anyone who makes a ticket for existing outage report, I'm just moving away from Tokyo. Will update network status page in a moment. Data recovery may not be very easy, but trying. May all have to end up being moved away. And no, not enough space to be moved to Tokyo.
Any news regarding TYOC038?
I don't want to move out of Tokyo. Is it possible to migrate to another node in Tokyo, or if it takes longer to fix, I don't mind waiting. My only requirement is not to move out of Tokyo.
Any update on CHI-Z027 please?
When I am able to VNC into my server in-between long bouts of being unable to due to the timing out issue in my ticket, I can't ping the outside world. The VNC viewer is still showing the old IP in the "address" section.
@lolmi said:
I have a ticket for migration that says it is closed, but I paid $3, what should I do about this?
Can I ask how you were able to request a paid migration through the billing panel ?
I have not seen any locations available in the migration pull down for months on any of the non-special VMs I have.
I just said wrong, it's a Transfer Service, not a migration, sorry.
I expect he means transferring a VPS from one account to another. As I am unaware of any service other than migration without data, or a transfer that costs $3.
This ticket has been marked as "rejected" by a member of our staff. This means either (1) this is something we cannot do either due to policy or not possible, (2) your ticket was not descriptive or created incorrectly or included incorrect information, (3) your issue can be resolved by visiting the knowledgebase, or (4) this was already answered or not part of the support level provided for your account.
If this was a billing request, it most likely means you are not eligible for this being processed. If you were requesting technical support, perhaps you have a limited support plan and your request was outside of what's covered. Your ticket may also be flagged as rejected if you may have already received a resolution in previous responses, as mentioned above, or if we do not discuss what you're requesting as part of the normal level of support we provide (for example, you might be asking us about a promotion or a trial or something we don't offer.)
If you do create a new request, please make sure to first review everything we have mentioned. In most cases, any further requests may also be rejected.
In case I missed it, do we know what happened to the NY storage servers? Went offline day or two ago.
A couple of people have mentioned that it was inaccessible, but there has been no official word, that I have seen, about the cause, or resolution, of the outage.
EDIT: It is on the status page, so VirMach is aware.
Affecting System - NYCB004S
10/06/2023 04:28 Last Updated 10/06/2023 04:28
NYCB004S is offline, and we're looking into the issue. We apologize for not updating you sooner in this case.
You underestimate him.
Yoursunny won't notice, as he has at least /80.
★ 80–85% ↓↓ – NVMe(NL) from 1c EPYC/1G/30G/1T – $12/y (ref), codes: LETMINI80, LETSAILOR80 respectively / SSD(US) from 1c/2x256M/2x10G/256G – $5.4/y (ref), ×2 upg. via ticket, codes: SPECIALMINI85, LETSAILOR85, SEAMANSSD85
Stop being so rational. He's first in line now.
Yeah I think not all are listed as migrated ones ...
I have one migrated on TPAZ005 with 47.87...
I got a SEAZ009 that finished up in TPAZ005 in the same boat.
Are you sure? They only list one on the main screen now but if you click over to Networking I think it shows boths.
Typo fixed.
https://imgur.com/a/Lutti1v
Me too, I can wait but I don't want to move out of Tokyo
@cornercase @gritty and any others waiting on new IPv4 for LAXA007 you might want to check again now.
great! the ipv4 address have been updated!
Should I wipe the server and reinstall?
Thanks, appreciate it.
Finally back online just two days after I celebrated the one month anniversary of this outage.
What do you think runs Yeti Node?
@VirMach
A pick-up service ticket was generated in the background, and I paid $3. About a week later, the service ticket was closed. What should I do?
What is a pick-up service?
