Hosteons - $2/mo KVM VPS / 1 vCore / 1GB RAM / 15GB SSD / 1 IPv4 / IPv6 / 4 TB BW / 10G Port -Oct Sp
October Special for KVM SSD VPS on 10G Port (Shared)
A deal like never before, no gimmick to pay annually, pay monthly as low as $2
**Locations: Salt Lake City
Looking Glass : https://lg.slc2.hosteons.com
Based on Intel Xeon E5-2650 v4 or similar
1GB VPS:
CPU: 1 vCore (Fair Share)
RAM: 1GB
RAID10 SSD: 15 GB
OS: Linux
IPv4: 1
IPv6: /64
BW: 2 TB - 4 TB
Network Port: 10 Gbps
Backup: 1 Click Backup or Snapshot
Only $2/mo
Order Link: https://my.hosteons.com/store/vps-special-deals
2GB VPS:
CPU: 2 vCore (Fair Share)
RAM: 2GB
RAID10 SSD: 20 GB
OS: Linux
IPv4: 1
IPv6: /64
BW: 4 TB - 8 TB
Only $3.5/mo
3GB VPS:
CPU: 3 vCore (Fair Share)
RAM: 3GB
RAID10 SSD: 30 GB
OS: Linux/Windows
IPv4: 1
IPv6: /64
BW: 6 TB - 12 TB
Only $4.5/mo
4GB VPS:
CPU: 4 vCore (Fair Share)
RAM: 4GB
RAID10 SSD: 40 GB
OS: Linux/Windows
IPv4: 1
IPv6: /64
BW: 8 TB - 16 TB
Only $5.5/mo
How to get Double Bandwidth ?
Just reply in comment with your invoice number we will double your Bandwidth
Please note this offer is setup at minimal margin, hardly even reaching breakeven, so don't expect much support for it, these are unamanged VPS
Regarding CPU FAIR Share we have setup CPU Threshold in Control panel if more then 25% of CPU used for more then 30 minutes at a time then your VPS will be suspended, you will need to submit a support ticket to reactivate it, but if it keeps happening at regular interval, then we will CAP your CPU at 25%
Also 30 minutes is enough, i ran YABS, network speed benchmarks etc... all of it worked fine
Looking for Ryzen Promo: https://lowendspirit.com/discussion/6517/ryzen-clearance-special-salt-lake-city-starts-3-1core-1gb-20gb-nvme-4tb-tran-10g-port-1-ipv4
Looking for VDS or Dedicated Resources check out: https://lowendspirit.com/discussion/6525/hosteons-com-ryzen-vds-8-99-2-vcore-8-gb-ram-100-gb-nvme-30tb-10g-port-les-excl
hostEONS.com - 9 Locations for VPS (US and EU).. Free Blesta License, Free Windows 2019 License and more. Shared DA Hosting. AS142036 .. Ryzen 7950X Based VDS in SLC, LA and Dallas
root@test:~# curl -s https://raw.githubusercontent.com/masonr/yet-another-bench-script/master/yabs.sh | bash
Yet-Another-Bench-Script
v2023-09-06
Fri Oct 6 00:06:42 EDT 2023
Uptime : 0 days, 0 hours, 1 minutes
Processor : Intel(R) Xeon(R) CPU E5-2695 v2 @ 2.40GHz
CPU cores : 1 @ 2399.998 MHz
AES-NI : ✔ Enabled
RAM : 987.3 MiB
Swap : 256.0 MiB
Disk : 14.4 GiB
Distro : Debian GNU/Linux 10 (buster)
Kernel : 4.19.0-24-amd64
VM Type : KVM
ISP : Hosteons Pte. Ltd.
ASN : AS142036 Hosteons Pte. Ltd.
Host : Hosteons Pte. Ltd
Country : United States
Geekbench test failed and low memory was detected. Add at least 1GB of SWAP or use GB4 instead (higher compatibility with low memory systems).
YABS completed in 12 min 42 sec
root@test:~#
---------------------------- network-speed.xyz ----------------------------
A simple script to test network performance using speedtest-cli
Version : v2023.09.30
Global Speedtest : wget -qO- network-speed.xyz | bash
Region Speedtest : wget -qO- network-speed.xyz | bash -s -- -r
Basic System Info
CPU Model : Intel(R) Xeon(R) CPU E5-2695 v2 @ 2.40GHz
CPU Cores : 1 @ 2399.998 MHz
CPU Cache : 30720 KB
AES-NI : ✔ Enabled
Total Disk : 14.4 GB (1.2 GB Used)
Total RAM : 987.3 MB (49.9 MB Used)
Total Swap : 256.0 MB (13.5 MB Used)
System uptime : 0 days, 1 hour 56 min
Load average : 0.00, 0.00, 0.00
OS : Debian GNU/Linux 10
Arch : x86_64 (64 Bit)
Virtualization : KVM
Basic Network Info
IPv6 Access : ✔ Online
IPv4 Access : ✔ Online
Location (IPv4) : Los Angeles, California, US
Location Latency Loss DL Speed UP Speed Server
ISP: Hosteons
Nearest 1.45 ms 0.0% 6102.64 Mbps 6750.19 Mbps Sumo Fiber - Salt Lake City, UT
Kochi, IN 264.02 ms 0.0% 3213.58 Mbps 328.91 Mbps Asianet Broadband - Cochin
Bangalore, IN 252.09 ms 0.0% 3107.91 Mbps 295.07 Mbps Bharti Airtel Ltd - Bangalore
Chennai, IN 252.25 ms N/A 2919.29 Mbps 431.64 Mbps Jio - Chennai
Mumbai, IN 267.08 ms 0.0% 3066.14 Mbps 293.76 Mbps i3D.net - Mumbai
Delhi, IN 277.05 ms 0.0% 2206.02 Mbps 326.32 Mbps Tata Teleservices Ltd - New Delhi
Seattle, US 21.05 ms 0.0% 6082.59 Mbps 4580.38 Mbps Ziply Fiber - Seattle, WA
Los Angeles, US 15.25 ms 0.3% 5490.54 Mbps 57.65 Mbps ReliableSite Hosting - Los Angeles, CA
Dallas, US 32.59 ms 0.0% 5323.88 Mbps 3044.06 Mbps Hivelocity - Dallas, TX
Miami, US 66.67 ms 0.0% 2938.32 Mbps 1434.98 Mbps AT&T - Miami, FL
New York, US 76.72 ms 0.0% 5937.71 Mbps 209.46 Mbps GSL Networks - New York, NY
Toronto, CA 43.68 ms 0.0% 6548.05 Mbps 2005.19 Mbps Rogers - Toronto, ON
London, UK 120.90 ms 0.0% 4827.54 Mbps 854.43 Mbps VeloxServ Communications - London
Amsterdam, NL 121.11 ms 0.0% 6080.38 Mbps 153.34 Mbps 31173 Services AB - Amsterdam
Paris, FR 120.60 ms N/A 6080.98 Mbps 111.78 Mbps Axione - Paris
Frankfurt, DE 135.12 ms 0.0% 3967.77 Mbps 642.71 Mbps 23M GmbH - Frankfurt am Main
Warsaw, PL 172.73 ms 0.0% 2626.96 Mbps 515.33 Mbps UPC Polska - Warszawa
Bucharest, RO 171.17 ms 0.0% 4134.50 Mbps 543.92 Mbps Vodafone Romania Fixed – Bucharest - Bucharest
Jeddah, SA 184.52 ms 0.0% 4241.20 Mbps 131.67 Mbps Saudi Telecom Company
Dubai, AE 242.54 ms 0.0% 3225.47 Mbps 404.74 Mbps du - Dubai
Fujairah, AE 250.22 ms 0.0% 3258.63 Mbps 433.62 Mbps ETISALAT-UAE - Fujairah
Tokyo, JP 112.08 ms N/A 1102.61 Mbps 299.77 Mbps fdcservers.net - Tokyo
Shanghai, CU-CN 170.35 ms 0.0% 4126.02 Mbps 653.41 Mbps China Unicom 5G - Shanghai
Nanjing, CT-CN 188.28 ms 0.0% 2787.29 Mbps 46.25 Mbps China Telecom JiangSu 5G - Nanjing
Hong Kong, CN 154.27 ms N/A 3011.62 Mbps 66.62 Mbps STC - Hong Kong
Singapore, SG 168.49 ms 0.0% 4276.06 Mbps 164.02 Mbps i3D.net - Singapore
Jakarta, ID 183.90 ms 0.0% 2870.94 Mbps 34.41 Mbps PT. Telekomunikasi Indonesia - Jakarta
Avg DL Speed : 4057.59 Mbps
Avg UL Speed : 919.02 Mbps
Total DL Data : 148.10 GB
Total UL Data : 33.27 GB
Total Data : 181.37 GB
Duration : 13 min 48 sec
System Time : 06/10/2023 - 02:16:02 EDT
Total Script Runs : 24783
Result : https://result.network-speed.xyz/r/1696572778_ZBZR1E_GLOBAL.txt
root@test:~#
Invoice #130733
Tell 'im @FrankZ : what goes in there?
Than
Thanks for the order BW doubled
Invoice #131659
please double the bandwith
Welcome to Hosteons
Bandwidth Doubled
thanks
Invoice #131806
Thanks
Welcome to Hosteons
Bandwidth Doubled
thanks
Invoice #134623
Thanks. I'm new to the forum
What happen in the event you use the bandwidth, throttlion or suspension? Tks
Suspension and reactivate again next month or you can buy additional BW
Looks like this was already done by our support team
