Good Morning all, if you are looking to purchase a VPS this weekend use code LES23 at checkout. As of this morning, there are 10 uses left of the coupon. I won't be able to immediately respond to everyone over the weekend. If you run into issues with your order send a DM. You must complete the verification process for your order to deploy.
Surprised dedicated servers still have 20TB/mo when the $4 VPS have 20TB/m. Nice to see the higher end servers getting 100TB though, bandwidth pricing was one reason I left originally.
There is no throttling past 10GB. You can use as much as you like. There is just an overage charge (one penny) for every GB over.
I couldn't pass the verification because I used a virtual VISA card. I'm giving up, but $2 for first 3 months is good
The system still requires verification with a PayPal payment. Shouldn't that be sufficient?
YABS for Intel 1GB in LAX2.
Well, fine
Végre nem butulok tovább
expensive, it is unclear how stable it is
Did you try to verify using Paypal?
Hi, did you try our coupon code LES23?
