Good Morning all, if you are looking to purchase a VPS this weekend use code LES23 at checkout. As of this morning, there are 10 uses left of the coupon. I won't be able to immediately respond to everyone over the weekend. If you run into issues with your order send a DM. You must complete the verification process for your order to deploy.
Surprised dedicated servers still have 20TB/mo when the $4 VPS have 20TB/m. Nice to see the higher end servers getting 100TB though, bandwidth pricing was one reason I left originally.
There is no throttling past 10GB. You can use as much as you like. There is just an overage charge (one penny) for every GB over.
I couldn't pass the verification because I used a virtual VISA card. I'm giving up, but $2 for first 3 months is good
The system still requires verification with a PayPal payment. Shouldn't that be sufficient?
YABS for Intel 1GB in LAX2.
Well, fine
Végre nem butulok tovább
expensive, it is unclear how stable it is
ExtraVM - High RAM Specials
Yours truly.
Did you try to verify using Paypal?
Hi, did you try our coupon code LES23?
