Any Budget KVM / NAT VPS for Poland or Romania with IPv4 support
I have been search for 2 days now for providers with Poland or Romania server but i can't find any under $20 annually. Is there nothing else to do but wait for deals? I was planning to use it primarily for twitch proxy and personal wg server. I availed one in Russia but it was too slow. Got 1 Japan KVM from natvps.net and it was really fast, wanted to avail Poland from them but there's no slot available.
https://www.hosteroid.uk
Contact them for dealz.
Tell them I referred you, so I remain in their good list.
vps9
hostname is available. affbrrInterested too if you find one, I was looking for that, with personal requirements that it would be KVM and custom-iso-friendly.
Same use-case, but want to install my own customized iso with disk encryption.
contacted them and told that you referred me. linked your profile to the ticket as well
edit: i can't find any reviews of this provider in this site
Never tried personally, but check
https://www.hostclean.net/openvz
read comments for this provider in this site. their rep is suspicious so i stayed away from that provider.
thanks anyways
Can vouch for Hosteroid. Guy running it is very nice and server has been rock solid.
M247 Network (one of the best you can get in Romania really)
For Poland I'm personally using https://hosting.gullo.me (NAT) & @skhron. Though keep in mind Twitch will identify you as being from the UK if you use Skhron but Poland if you use gullo (OVH Network but server is crashing all the time for some reason).
For Romania apart of Hosteroid, you can go with LayerBridge (and you can use my "referral" discount code for 10%: ZGATO10 for this yearly deal. Server won't be super fast (HDD) but network is amazing.
I remember that I saw an offering from webhosting1st in LET a while back and their servers were in Poland.
Yoo, i think it's your guide that i read in github for this!
thanks for making that guide
will check out those providers you mentioned
they have cheap plans but had low bandwidth limits> @yusra said:
they had cheap servers for yearly subscription but the bandwidth is too low.
I ended up with hosteroid.uk
their support was helpful and got a good deal for what i was looking for
How come there's no reviews for this provider here?
@Abdullah
Rapiddc.pl
wouldn't recommend it, a lot of down times support is very bad... sometimes not answer for week, need to contact them also over facebook
Heeey, I just created account here, i guess you can be the first one to make us an review? 😇
Thank you guys @yoursunny @zgato ❤️
forgot to actually post this
i don't know if it's going to be useful for someone since this is plenty enough for my use case
but here's the yabs result
Yet-Another-Bench-Script
v2023-09-06
Sat Oct 21 02:46:00 PM UTC 2023
Uptime : 0 days, 0 hours, 38 minutes
Processor : Intel(R) Xeon(R) CPU E5-2690 v4 @ 2.60GHz
CPU cores : 2 @ 2599.972 MHz
AES-NI : ✔ Enabled
RAM : 1.9 GiB
Swap : 2.0 GiB
Disk : 27.5 GiB
Distro : Ubuntu 22.04.1 LTS
Kernel : 5.15.0-46-generic
VM Type : KVM
ISP : M247 Europe SRL
ASN : AS9009 M247 Europe SRL
Host : Hosteroid
Country : Romania
Test | Value
Single Core | 1065
Multi Core | 1888
Full Test | https://browser.geekbench.com/v6/cpu/3184523
YABS completed in 15 min 56 sec
happy with what i got since this is faster than my surfshark wg server in romania
they also offered me a 10Gbps NVMe VPS but was out of my budget so i settled with this.
what dealz will LES be getting?
Not sure yet, probably similar to LET
