@Calin said:
Hello @karlo we have 300+ tickets opened
@mee2 in last week we migrate 50% from all NAT VPS to new hardware
Regards
By all respect, when it goes by this time, my subscription will end before i can use anything again on your Plattform. This is unusable for a long time...
@karlo said: By all respect, when it goes by this time, my subscription will end before i can use anything again on your Plattform. This is unusable for a long time...
Hello , check now please we replayed on 99% tickets
If you are on IP 109.122.221.169 it's on migration , IP 109.122.221.69 migration finish , and we view more good results on beenkmarcks
Regards,
Calin
Its not the one or the other, its different node.
See, i am waiting now for 9 weeks for service and until then the service where down often, too. When you dont inform your Clients about the fact, that they dont can use theyr products for severel Months, what is the case, then this is maybe a case for refunding over payment service... . I had better experience with coucio.
@ccc said: Since NAT migrated, it's unable to use after re-provison from ihostart.micronode.uk
Hello if you have IP 103.212.81.169 it's not finished migrate
Regards
It's 109.122.221.32
After migrated it's able to use, however it's unable to access SSH after re-install.
Tried many times, installed different systems, can confirm the issue.
Dies ihostart.micronode.uk re-installed the corrected Node?
Please help check, thanks.
109.122.221.33 is coming back.
It is even slower than previous.
In the previous node, I can establish an SSH connection (up to bash prompt appearing) in 2~3 minutes.
After the so-called migration, it's taking nearly 5 minutes.
Hello , yes we start lot of VMs and that it's cause , coming soon fixed , we finish 95% migration
Hello , all nat VPS finish migrate , any feedback it's very appreciate about performance , speed network etc..
Regards
When my data will be migrated?
I am now waiting over 9 weeks for service!
Aviable images for reinstalling on node doesnt work well...
So its seems official!
My data cant be migrated anymore!
Why? Couse you only got 2 weeks after node transfer to initiate data transfer.
How you can initiate this data transfer, i dont know... I tryd to do this. And after i cant find any possibiltys on the panels, i opened a tixket. But with response time about 14 days, and not the will to lead to an result, jes, i need to say, all my data is lost!
//edit
Its now 10 weeks with no functionaly service, my vps went down From one day to another and never get up again...
@karlo said: Its now 10 weeks with no functionaly service, my vps went down From one day to another and never get up again...
I'm checked and I'm don t know what ticket you have OPENED , write me on PM you email address and give you refund
Regards
Problem here is that you are not able to restore my data and instead of response on that Problem you are reffering me on refund, thats service at its best.
I guess he had enough. Got this email now. It was actually working better after the migration to newer hardware (from <1Mbps to ~50Mbps)
Hello dear customers,
due to repeated and endless problems with NAT services, we would like to inform you that these services will be closed at the end of the billing period, please cancel your paypal subscription whenever and if you receive invoices for these services, just ignore them and you don't pay them, your service will end automatically at the end of the billing period, we do this because a lot of people abuse a service of only 0.50 cents/month and received a lot of problems/complaints related to the operation of these VPS- uri, NAT VPSs are an abandoned project for us in future services
Thanks for you understand
Regards
Regards,
Calin
109.122.221.33 what time can finished the migration work??
Downtime started Oct 07.
Two weeks without television isn't good life.
Regards
It's 109.122.221.32
Is this completed now?
Old IP > 103.212.81.169 > NEW IP 109.122.221.33
109.122.221.32 down again?
Regards
what about ipv6, it works now?
When new IP showing up in MicroNode panel?
Also, reboot button in MicroNode panel doesn't seem to have any effect.
Still unable to connect after re-provision from panel ihostart.micronode.uk
Oh I'm able to connect but it took 2 minutes.
Extremely low performance.
nat vps down again. micronode.uk reboot fail
Hello , back to work
Regards
Performance getting much better now, nice work.
the performance of this nat vps after migrate is soooo low, very slow now
Affirmative, the load is about 7.00 and it took several minutes to SSH into the system.
Someone may abusing their VPS, monitor and suspend frequently may help.
//edit
Regards
Waiting for refugee offers.
