Comprehensive Speedtest Script | network-speed.xyz | Share your bench
178101213
  • One from GreenCloud. Can you integrate I/O disk testing?
    ---------------------------- network-speed.xyz ----------------------------
          A simple script to test network performance using speedtest-cli
     Version            : v2023.10.24
     Global Speedtest   : wget -qO- network-speed.xyz | bash
     Region Speedtest   : wget -qO- network-speed.xyz | bash -s -- -r <region>
     Basic System Info
     CPU Model          : Intel(R) Xeon(R) CPU E5-2698 v4 @ 2.20GHz
     CPU Cores          : 9 @ 2199.982 MHz
     CPU Cache          : 16384 KB
     AES-NI             : ✔ Enabled
     VM-x/AMD-V         : ✔ Enabled
     Total Disk         : 96.5 GB (18.9 GB Used)
     Total RAM          : 8.7 GB (545.7 MB Used)
     Total Swap         : 5.0 GB (3.3 MB Used)
     System uptime      : 0 days, 23 hour 19 min
     Load average       : 0.01, 0.00, 0.00
     OS                 : Ubuntu 20.04 LTS
     Arch               : x86_64 (64 Bit)
     Kernel             : 5.4.0-28-generic
     Virtualization     : KVM
     Basic Network Info
     Primary Network    : IPv6
     IPv6 Access        : ✔ Online
     IPv4 Access        : ✔ Online
     ISP                : Leaseweb Asia Pacific pte. ltd.
     ASN                : AS133752 Leaseweb Asia Pacific pte. ltd.
     Host               : Leaseweb Hong Kong Limited
     Location           : Hong Kong, Central and Western District-HCW, Hong Kong
     Location         Latency     Loss    DL Speed       UP Speed       Server
     ISP: Leaseweb Asia Pacific pte.
     Nearest          2.13 ms     0.0%    912.67 Mbps    5590.95 Mbps   HKIX - Hong Kong
     Kochi, IN        79.96 ms    0.0%    4112.45 Mbps   434.88 Mbps    Asianet Broadband - Cochin
     Bangalore, IN    360.72 ms   0.0%    1491.12 Mbps   338.60 Mbps    Bharti Airtel Ltd - Bangalore
     Chennai, IN      65.98 ms    N/A     4738.31 Mbps   1191.79 Mbps   Jio - Chennai
     Mumbai, IN       92.63 ms    0.0%    3792.82 Mbps   572.22 Mbps    i3D.net - Mumbai
     Delhi, IN        117.53 ms   0.0%    2428.92 Mbps   701.21 Mbps    Tata Teleservices Ltd - New Delhi
     Seattle, US      153.66 ms   N/A     3589.03 Mbps   559.15 Mbps    Comcast - Seattle, WA
     Los Angeles, US  143.21 ms   0.0%    3504.19 Mbps   584.66 Mbps    ReliableSite Hosting - Los Angeles, CA
     Dallas, US       192.24 ms   0.0%    0.38 Mbps      208.45 Mbps    Hivelocity - Dallas, TX
     Miami, US        240.26 ms   0.0%    1090.01 Mbps   245.83 Mbps    AT&T - Miami, FL
     New York, US     220.91 ms   0.0%    1290.18 Mbps   525.05 Mbps    GSL Networks - New York, NY
     Toronto, CA      225.44 ms   0.0%    2990.11 Mbps   365.99 Mbps    Rogers - Toronto, ON
     London, UK       186.40 ms   0.0%    2510.06 Mbps   601.94 Mbps    VeloxServ Communications - London
     Amsterdam, NL    190.07 ms   0.0%    1493.52 Mbps   478.04 Mbps    31173 Services AB - Amsterdam
     Paris, FR        274.19 ms   N/A     1864.55 Mbps   330.24 Mbps    Axione - Paris
     Frankfurt, DE    295.07 ms   0.0%    1931.78 Mbps   213.00 Mbps    23M GmbH - Frankfurt am Main
     Warsaw, PL       269.95 ms   0.0%    1789.29 Mbps   344.73 Mbps    UPC Polska - Warszawa
     Bucharest, RO    215.76 ms   0.0%    1933.50 Mbps   146.76 Mbps    Vodafone Romania Fixed – Bucharest - Bucharest
     Jeddah, SA       217.86 ms   N/A     7.61 Mbps      0.47 Mbps      Saudi Telecom Company
     Dubai, AE        120.26 ms   0.0%    3725.99 Mbps   830.66 Mbps    du - Dubai
     Fujairah, AE     123.04 ms   0.0%    1857.98 Mbps   814.63 Mbps    ETISALAT-UAE - Fujairah
     Tokyo, JP        55.20 ms    N/A     1456.05 Mbps   897.07 Mbps    fdcservers.net - Tokyo
     Shanghai, CU-CN  361.88 ms   1.0%    625.30 Mbps    174.31 Mbps    China Unicom 5G - Shanghai
     Nanjing, CT-CN   FAILED
     Hong Kong, CN    2.36 ms     N/A     4047.74 Mbps   6105.47 Mbps   STC - Hong Kong
     Singapore, SG    37.01 ms    0.0%    4354.20 Mbps   2177.38 Mbps   i3D.net - Singapore
     Jakarta, ID      47.33 ms    0.0%    5119.69 Mbps   255.95 Mbps    PT. Telekomunikasi Indonesia - Jakarta
     Avg DL Speed       : 2409.90 Mbps
     Avg UL Speed       : 949.60 Mbps
     Total DL Data      : 82.61 GB
     Total UL Data      : 25.83 GB
     Total Data         : 108.44 GB
     Duration           : 14 min 16 sec
     System Time        : 28/10/2023 - 20:39:22 +07
     Total Script Runs  : 26147
  • edited October 2023
    @sh97 said:
    @lapua said:
    whats wrong here?
    > > 111@lapuamagnum:~# curl -sL network-speed.xyz | bash -s -- -r eu
    > > bash: line 1: syntax error near unexpected token `<'
    > > bash: line 1: `<!DOCTYPE html>Just a moment...
    Distro : Debian GNU/Linux 10 (buster)
    Kernel : 4.19.0-25-amd64
    VM Type : KVM
    @sh97
    Looks like a Cloudflare block.
    I haven't changed the settings yet, will do it one of these days.
    strange. the error only occurs when i want to run your script on a vps of @Labze (HostBRR, VPS Hetzner in Falkenstein)!
    @sh97: are this specs a problem?
    Processor  : Intel(R) Xeon(R) Gold 5412U
    CPU cores  : 2 @ 2100.000 MHz
    RAM        : 1.9 GiB
    Swap       : 1024.0 MiB
    Disk       : 20.0 GiB
    Kernel     : 5.10.0-0.deb10.26-rt-amd64
  • edited November 2023
    @lapua specs are fine. The 'Bot Fight Mode' of CF WAF seems to be blocking a lot of hetzner, ovh, aws etc IPs.
    I have disabled it for now and confirmed it's currently working on OVH and Hetzner.
     Basic System Info
     CPU Model          : Intel(R) Xeon(R) E-2136 CPU @ 3.30GHz
     CPU Cores          : 2 @ 3311.998 MHz
     CPU Cache          : 12288 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 34.3 GB (2.0 GB Used)
     Total RAM          : 1.9 GB (234.9 MB Used)
     System uptime      : 22 days, 20 hour 20 min
     Load average       : 0.06, 0.02, 0.00
     OS                 : Debian GNU/Linux 12
     Kernel             : 6.1.0-12-amd64
     Basic Network Info
     Primary Network    : IPv4
     IPv6 Access        : ❌ Offline
     ISP                : OVH SAS
     ASN                : AS16276 OVH SAS
     Host               : OVH Singapore PTE. LTD
     ISP: OVH Hosting
     Nearest          0.88 ms     0.0%    495.88 Mbps    866.88 Mbps    ViewQwest - Singapore
     Kochi, IN        50.12 ms    0.0%    684.84 Mbps    476.63 Mbps    Asianet Broadband - Cochin
     Bangalore, IN    37.56 ms    0.0%    641.08 Mbps    510.34 Mbps    Bharti Airtel Ltd - Bangalore
     Chennai, IN      33.47 ms    N/A     680.05 Mbps    510.68 Mbps    Jio - Chennai
     Mumbai, IN       57.49 ms    0.0%    611.70 Mbps    465.22 Mbps    i3D.net - Mumbai
     Delhi, IN        75.86 ms    0.0%    717.65 Mbps    370.00 Mbps    Tata Teleservices Ltd - New Delhi
     Seattle, US      180.09 ms   N/A     578.54 Mbps    253.03 Mbps    Comcast - Seattle, WA
     Los Angeles, US  175.84 ms   0.0%    607.53 Mbps    290.87 Mbps    ReliableSite Hosting - Los Angeles, CA
     Dallas, US       213.78 ms   0.0%    817.85 Mbps    189.08 Mbps    Hivelocity - Dallas, TX
     Miami, US        232.06 ms   0.0%    563.80 Mbps    224.83 Mbps    AT&T - Miami, FL
     New York, US     228.42 ms   0.0%    859.37 Mbps    171.36 Mbps    GSL Networks - New York, NY
     Toronto, CA      243.55 ms   0.0%    615.49 Mbps    202.55 Mbps    Rogers - Toronto, ON
     London, UK       160.70 ms   0.0%    914.66 Mbps    264.14 Mbps    VeloxServ Communications - London
     Amsterdam, NL    164.49 ms   0.0%    887.97 Mbps    298.71 Mbps    31173 Services AB - Amsterdam
     Paris, FR        153.09 ms   N/A     891.76 Mbps    259.95 Mbps    Axione - Paris
     Frankfurt, DE    164.21 ms   0.0%    730.36 Mbps    253.01 Mbps    23M GmbH - Frankfurt am Main
     Warsaw, PL       186.16 ms   0.0%    605.04 Mbps    267.43 Mbps    UPC Polska - Warszawa
     Bucharest, RO    181.17 ms   0.0%    596.41 Mbps    199.68 Mbps    Vodafone Romania Fixed – Bucharest - Bucharest
     Jeddah, SA       97.73 ms    0.0%    886.69 Mbps    309.10 Mbps    Saudi Telecom Company
     Dubai, AE        83.34 ms    0.0%    690.84 Mbps    324.25 Mbps    du - Dubai
     Fujairah, AE     87.10 ms    0.0%    862.72 Mbps    359.74 Mbps    ETISALAT-UAE - Fujairah
     Tokyo, JP        313.50 ms   N/A     434.18 Mbps    127.45 Mbps    fdcservers.net - Tokyo
     Shanghai, CU-CN  233.30 ms   0.0%    490.64 Mbps    167.16 Mbps    China Unicom 5G - Shanghai
     Hong Kong, CN    35.18 ms    N/A     498.63 Mbps    402.20 Mbps    STC - Hong Kong
     Singapore, SG    10.82 ms    0.0%    582.30 Mbps    805.46 Mbps    i3D.net - Singapore
     Jakarta, ID      192.40 ms   0.0%    552.20 Mbps    163.94 Mbps    PT. Telekomunikasi Indonesia - Jakarta
     Avg DL Speed       : 673.00 Mbps
     Avg UL Speed       : 335.91 Mbps
     Total DL Data      : 26.96 GB
     Total UL Data      : 11.16 GB
     Total Data         : 38.12 GB
     Duration           : 13 min 48 sec
     System Time        : 02/11/2023 - 06:28:37 EDT
     Total Script Runs  : 26400
     Result             : https://result.network-speed.xyz/r/1698920498_B1G4S9_GLOBAL.txt
    Thanked by (1)lapua
  • IncogNET NL
     Basic System Info
     CPU Model          : AMD EPYC 7402P 24-Core Processor
     CPU Cores          : 1 @ 2794.748 MHz
     CPU Cache          : 512 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 19.6 GB (3.3 GB Used)
     Total RAM          : 457.4 MB (89.6 MB Used)
     Total Swap         : 1024.0 MB (50.0 MB Used)
     System uptime      : 0 days, 6 hour 58 min
     Load average       : 0.12, 0.31, 0.16
     Kernel             : 6.1.0-13-amd64
     Basic Network Info
     ISP                : IncogNET LLC
     ASN                : AS210630 IncogNET LLC
     Host               : IncogNET LLC
     Location (IPv4)    : Zaandam, North Holland, NL
     ISP: IncogNET
     Nearest          0.24 ms     0.0%    4276.87 Mbps   3943.59 Mbps   WorldStream B.V. - Naaldwijk
     Kochi, IN        171.99 ms   0.0%    2037.89 Mbps   433.60 Mbps    Asianet Broadband - Cochin
     Bangalore, IN    135.01 ms   0.0%    2703.43 Mbps   423.89 Mbps    Bharti Airtel Ltd - Bangalore
     Chennai, IN      167.20 ms   N/A     2436.68 Mbps   346.89 Mbps    Jio - Chennai
     Mumbai, IN       121.58 ms   0.0%    3365.18 Mbps   207.57 Mbps    i3D.net - Mumbai
     Delhi, IN        137.12 ms   0.0%    2185.87 Mbps   190.09 Mbps    Tata Teleservices Ltd - New Delhi
     Seattle, US      167.85 ms   N/A     1980.26 Mbps   446.91 Mbps    Comcast - Seattle, WA
     Los Angeles, US  138.91 ms   0.0%    2748.43 Mbps   491.62 Mbps    ReliableSite Hosting - Los Angeles, CA
     Dallas, US       116.74 ms   0.0%    3621.08 Mbps   536.22 Mbps    Hivelocity - Dallas, TX
     Miami, US        118.16 ms   0.0%    2021.70 Mbps   391.12 Mbps    AT&T - Miami, FL
     New York, US     73.03 ms    0.0%    3221.49 Mbps   508.01 Mbps    GSL Networks - New York, NY
     Toronto, CA      85.37 ms    0.0%    3440.43 Mbps   633.72 Mbps    Rogers - Toronto, ON
     London, UK       23.97 ms    0.0%    3646.47 Mbps   1337.09 Mbps   VeloxServ Communications - London
     Amsterdam, NL    1.62 ms     0.0%    4242.51 Mbps   4578.14 Mbps   31173 Services AB - Amsterdam
     Paris, FR        19.36 ms    N/A     3783.18 Mbps   1442.61 Mbps   Axione - Paris
     Frankfurt, DE    8.21 ms     0.0%    3585.46 Mbps   2437.23 Mbps   23M GmbH - Frankfurt am Main
     Warsaw, PL       22.92 ms    0.0%    3598.13 Mbps   1362.17 Mbps   UPC Polska - Warszawa
     Bucharest, RO    35.99 ms    0.0%    3944.62 Mbps   938.28 Mbps    Vodafone Romania Fixed – Bucharest - Bucharest
     Jeddah, SA       83.68 ms    0.0%    3272.42 Mbps   514.05 Mbps    Saudi Telecom Company
     Dubai, AE        131.91 ms   0.0%    2849.25 Mbps   488.57 Mbps    du - Dubai
     Fujairah, AE     115.48 ms   0.0%    3493.01 Mbps   544.97 Mbps    ETISALAT-UAE - Fujairah
     Tokyo, JP        275.18 ms   N/A     1523.24 Mbps   265.12 Mbps    fdcservers.net - Tokyo
     Shanghai, CU-CN  175.83 ms   0.0%    1219.00 Mbps   399.47 Mbps    China Unicom 5G - Shanghai
     Nanjing, CT-CN   263.51 ms   0.0%    1683.48 Mbps   37.92 Mbps     China Telecom JiangSu 5G - Nanjing
     Hong Kong, CN    244.82 ms   N/A     1609.38 Mbps   297.10 Mbps    STC - Hong Kong
     Singapore, SG    161.89 ms   0.0%    1289.86 Mbps   451.50 Mbps    i3D.net - Singapore
     Jakarta, ID      170.58 ms   0.0%    1870.95 Mbps   74.41 Mbps     PT. Telekomunikasi Indonesia - Jakarta
     Avg DL Speed       : 2801.86 Mbps
     Avg UL Speed       : 878.59 Mbps
     Total DL Data      : 99.70 GB
     Total UL Data      : 27.67 GB
     Total Data         : 127.37 GB
     Duration           : 13 min 40 sec
     System Time        : 05/11/2023 - 00:54:24 IST
     Total Script Runs  : 26510
     Result             : https://result.network-speed.xyz/r/1699125423_DPE457_GLOBAL.txt
    it seems to work now.
  • ---------------------------- network-speed.xyz ----------------------------
     Basic System Info
     CPU Model          : 12th Gen Intel(R) Core(TM) i9-12900K
     CPU Cores          : 1 @ 3187.200 MHz
     CPU Cache          : 30720 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 59.9 GB (2.9 GB Used)
     Total RAM          : 1.9 GB (303.3 MB Used)
     Total Swap         : 1024.0 MB (2.2 MB Used)
     System uptime      : 3 days, 22 hour 51 min
     Load average       : 0.04, 0.01, 0.00
     Basic Network Info
     ISP                : Hetzner Online GmbH
     ASN                : AS24940 Hetzner Online GmbH
     Speedtest.net (Region: EUROPE)
     ISP: Hetzner Online
     Nearest          3.15 ms     0.0%    616.68 Mbps    688.06 Mbps    Jonas de Vries
     London, UK       17.55 ms    0.0%    780.67 Mbps    818.94 Mbps    M247 Ltd - London
     Edinburgh, UK    34.73 ms    N/A     658.65 Mbps    812.78 Mbps    Vodafone UK - Edinburgh
     Dublin, IE       26.29 ms    0.0%    898.93 Mbps    810.61 Mbps    Three Ireland - Dublin
     Amsterdam, NL    12.30 ms    0.0%    880.22 Mbps    837.89 Mbps    Melbicom - Amsterdam
     Eygelshoen, NL   14.55 ms    0.0%    843.67 Mbps    854.15 Mbps    SkyLink Data Center BV - Eygelshoven
     Paris, FR        15.78 ms    0.0%    904.65 Mbps    824.47 Mbps    ORANGE - Paris
     Marseille, FR    20.58 ms    0.0%    904.18 Mbps    804.03 Mbps    GSL Networks - Marseille
     Madrid, ES       37.99 ms    0.0%    912.56 Mbps    810.42 Mbps    Orange - Jazztel - Madrid
     Barcelona, ES    26.12 ms    0.0%    847.16 Mbps    523.27 Mbps    Adamo - Barcelona
     Lisbon, PT       41.98 ms    0.0%    828.21 Mbps    489.64 Mbps    Edgoo Networks - Lisbon
     Rome, IT         29.85 ms    0.0%    922.08 Mbps    828.73 Mbps    TIM SpA - Rome
     Milan, IT        14.33 ms    0.0%    889.37 Mbps    807.81 Mbps    Fastweb SpA - Milan
     Zurich, CH       10.13 ms    0.0%    839.15 Mbps    818.65 Mbps    Sunrise Communication AG - Zurich
     Frankfurt, DE    5.42 ms     0.0%    873.20 Mbps    819.29 Mbps    23M GmbH - Frankfurt am Main
     Berlin, DE       11.93 ms    0.0%    796.39 Mbps    626.47 Mbps    Misaka Network, Inc. - Berlin
     Vienna, AT       11.60 ms    0.0%    869.11 Mbps    833.27 Mbps    A1 Telekom Austria AG - Vienna
     Budapest, HU     18.55 ms    0.0%    763.26 Mbps    805.17 Mbps    ATW Internet Kft. - Budapest
     Gdansk, PL       25.16 ms    0.0%    799.20 Mbps    817.06 Mbps    T-Mobile Polska S.A. - Gdańsk
     Warsaw, PL       23.63 ms    0.0%    841.86 Mbps    830.31 Mbps    Orange Polska S.A. - Warsaw
     Lviv, UA         26.83 ms    0.0%    837.90 Mbps    794.64 Mbps    Kyivstar - Lviv
     Kyiv, UA         30.53 ms    0.0%    790.20 Mbps    818.14 Mbps    o3 - Kyiv
     Minsk, BY        31.92 ms    0.0%    909.39 Mbps    802.20 Mbps    A1 - Minsk
     Bucharest, RO    34.38 ms    0.0%    853.99 Mbps    823.72 Mbps    Orange Romania Communications - Bucharest
     Iasi, RO         47.94 ms    0.0%    809.13 Mbps    814.18 Mbps    Digi
     Helsinki, FI     25.84 ms    0.0%    807.83 Mbps    826.58 Mbps    Elisa Oyj - Helsinki
     Stockholm, SE    54.85 ms    0.0%    729.38 Mbps    740.48 Mbps    i3D.net - Stockholm
     Oslo, NO         29.63 ms    0.0%    872.78 Mbps    831.59 Mbps    Speedtest.net - Oslo
     Moscow, RU       38.33 ms    0.0%    858.52 Mbps    827.26 Mbps    Rostelecom - Moscow
     Petersburg, RU   35.88 ms    0.0%    783.26 Mbps    800.52 Mbps    MTS OJSC - Saint Petersburg
     Istanbul, TR     39.01 ms    0.0%    895.01 Mbps    824.76 Mbps    Turkcell - Istanbul
     Tbilisi, GE      63.95 ms    N/A     769.13 Mbps    731.85 Mbps    Silknet JSC - Tbilisi
     Avg DL Speed       : 830.80 Mbps
     Avg UL Speed       : 784.28 Mbps
     Total DL Data      : 30.83 GB
     Total UL Data      : 28.49 GB
     Total Data         : 59.32 GB
     Duration           : 11 min 53 sec
     System Time        : 04/11/2023 - 21:00:00 GMT
     Total Script Runs  : 26514
    see above
  • Updated to v2023.11.13
    * Updated broken servers
    * GCC Middle East is now Middle East, covering almost the entirety of the region.
     Speedtest.net (Region: MIDDLE EAST | الشرق الأوسط)
     ISP: IncogNET
     Nearest          0.19 ms     0.0%    4252.68 Mbps   3153.49 Mbps   WorldStream B.V. - Naaldwijk
     Abu Dhabi, AE    141.70 ms   0.0%    3094.68 Mbps   442.80 Mbps    du - Abu Dhabi
     Dubai, AE        122.28 ms   0.0%    2541.56 Mbps   475.49 Mbps    i3D.net - Dubai
     Fujairah, AE     116.01 ms   0.0%    3131.21 Mbps   448.19 Mbps    ETISALAT-UAE - Fujairah
     Muscat, OM       124.57 ms   0.0%    1417.72 Mbps   484.18 Mbps    OmanTel - Muscat
     Seeb, OM         124.15 ms   0.0%    3186.79 Mbps   470.85 Mbps    Ooredoo Oman - Seeb
     Sanaa, YE        128.57 ms   0.3%    2496.96 Mbps   252.36 Mbps    Yemen Net - Sanaa
     Doha, QA         128.75 ms   0.0%    2894.15 Mbps   447.06 Mbps    Ooredoo Qatar - Doha
     Rayan, QA        105.56 ms   0.0%    3182.83 Mbps   44.90 Mbps     Vodafone Qatar PQSC - Rayan
     Manama, BH       89.66 ms    0.3%    2866.59 Mbps   367.74 Mbps    ZainBH - Manama
     Rifa, BH         101.00 ms   0.0%    3026.59 Mbps   628.30 Mbps    stc Bahrain - Riffa
     Kuwait, KW       106.17 ms   0.0%    2874.13 Mbps   464.36 Mbps    Zain Kuwait - Kuwait City
     Kuwait, KW       109.85 ms   N/A     3011.74 Mbps   490.27 Mbps    Ooredoo Kuwait - Kuwait City
     Riyadh, SA       95.15 ms    0.0%    3363.55 Mbps   664.58 Mbps    Mobily - Riyadh
     Dammam, SA       99.78 ms    0.0%    2803.64 Mbps   548.59 Mbps    Saudi Telecom Company
     Jeddah, SA       85.38 ms    0.0%    3722.88 Mbps   498.35 Mbps    Zain KSA - Jeddah
     Jeddah, SA       84.69 ms    0.0%    2952.94 Mbps   541.71 Mbps    Saudi Telecom Company
     Tehran, IR       112.91 ms   0.0%    3026.78 Mbps   531.70 Mbps    Irancell - Tehran
     Baghdad, IQ      81.55 ms    0.0%    1147.95 Mbps   195.84 Mbps    Al-Jazeera Telecom - Baghdad
     Beirut, LB       69.87 ms    0.0%    2095.38 Mbps   448.25 Mbps    Ogero - Beirut
     Nicosia, CY      58.40 ms    0.0%    3533.40 Mbps   621.01 Mbps    Cyprus Telecommunications Authority - Nicosia
     Tel Aviv, IL     68.64 ms    0.0%    3927.80 Mbps   716.76 Mbps    Bezeq - Tel Aviv
     Amman, JO        71.00 ms    0.0%    3575.92 Mbps   686.94 Mbps    Zain Jordan - Amman
     Cairo, EG        54.95 ms    0.0%    3548.51 Mbps   825.21 Mbps    Etisalat Misr - Cairo
     Cairo, EG        59.79 ms    0.0%    1787.64 Mbps   582.08 Mbps    Vodafone Egypt - Cairo
     Istanbul, TR     49.79 ms    0.0%    2670.73 Mbps   659.68 Mbps    Vodafone TR - Istanbul
     Avg DL Speed       : 2920.56 Mbps
     Avg UL Speed       : 603.49 Mbps
     Total DL Data      : 106.40 GB
     Total UL Data      : 19.62 GB
     Total Data         : 126.02 GB
  • 1€ Netcup
     Version            : v2023.11.13
     Basic System Info
     CPU Model          : QEMU Virtual CPU version 2.5+
     CPU Cores          : 1 @ 2294.608 MHz
     AES-NI             : ✔ Enabled
     VM-x/AMD-V         : ❌ Disabled
     Total Disk         : 29,4 GB (3,5 GB Used)
     Total RAM          : 960,6 MB (327,3 MB Used)
     Total Swap         : 1024,0 MB (7,0 MB Used)
     System uptime      : 0 days, 19 hour 22 min
     Load average       : 0.05, 0.06, 0.05
     Basic Network Info
     ISP                : netcup GmbH
     ASN                : AS197540 netcup GmbH
     Host               : NETCUP-GMBH
     Location (IPv4)    : Großhabersdorf, Bavaria, DE
     ISP: netcup
     Nearest          0.33 ms     0.0%    880.94 Mbps    892.55 Mbps    netcup GmbH - Nuremberg
     London, UK       18.06 ms    0.0%    759.58 Mbps    997.39 Mbps    M247 Ltd - London
     Manchester, UK   21.62 ms    N/A     908.30 Mbps    996.92 Mbps    Vodafone UK - Manchester
     Dublin, IE       21.79 ms    0.0%    959.53 Mbps    990.35 Mbps    Three Ireland - Dublin
     Amsterdam, NL    16.74 ms    0.0%    941.64 Mbps    992.25 Mbps    Melbicom - Amsterdam
    2023 Nov 16 18:27:54 v220231112863243623 fatal: Timeout before authentication for 43.139.179.80 port 55596
     Eygelshoen, NL   25.25 ms    0.0%    804.51 Mbps    891.34 Mbps    SkyLink Data Center BV - Eygelshoven
    awk: line 1: 92105e+101082 : decimal overflow
     Paris, FR        22.05 ms    0.0%    963.10 Mbps    996.39 Mbps    ORANGE - Paris
    awk: line 1: 80854e+11994 : decimal overflow
     Marseille, FR    24.57 ms    0.0%    961.22 Mbps    990.21 Mbps    GSL Networks - Marseille
     Madrid, ES       30.12 ms    0.0%    952.77 Mbps    987.45 Mbps    Orange - Jazztel - Madrid
     Barcelona, ES    35.50 ms    0.0%    697.84 Mbps    838.27 Mbps    Adamo - Barcelona
    awk: line 1: 3011e+1372 : decimal overflow
     Lisbon, PT       43.82 ms    0.0%    599.08 Mbps    950.18 Mbps    Edgoo Networks - Lisbon
    awk: line 1: 3012e+1374 : decimal overflow
    awk: line 1: syntax error at or near ;
     Rome, IT         27.94 ms    0.0%    950.98 Mbps    1003.74 Mbps   TIM SpA - Rome
    awk: line 1: 96103e+10883 : decimal overflow
     Milan, IT        20.91 ms    0.0%    957.39 Mbps    989.24 Mbps    Fastweb SpA - Milan
     Zurich, CH       9.66 ms     0.0%    955.96 Mbps    997.87 Mbps    Sunrise Communication AG - Zurich
    awk: line 1: 61975e+11958 : decimal overflow
     Frankfurt, DE    4.14 ms     0.0%    945.44 Mbps    994.04 Mbps    23M GmbH - Frankfurt am Main
     Berlin, DE       10.89 ms    N/A     944.12 Mbps    749.58 Mbps    Misaka Network, Inc. - Berlin
     Vienna, AT       12.34 ms    0.0%    951.50 Mbps    994.83 Mbps    A1 Telekom Austria AG - Vienna
    2023 Nov 16 18:32:20 v220231112863243623 fatal: Timeout before authentication for 112.30.65.87 port 46277
     Budapest, HU     17.25 ms    0.0%    942.58 Mbps    991.05 Mbps    ATW Internet Kft. - Budapest
    awk: line 1: 89102e+10753 : decimal overflow
     Gdansk, PL       23.29 ms    0.0%    789.93 Mbps    995.03 Mbps    T-Mobile Polska S.A. - Gdańsk
     Warsaw, PL       39.41 ms    0.0%    610.45 Mbps    945.19 Mbps    Orange Polska S.A. - Warsaw
     Lviv, UA         28.49 ms    0.0%    958.89 Mbps    997.72 Mbps    Kyivstar - Lviv
    awk: line 1: 45989e+11847 : decimal overflow
     Kyiv, UA         37.03 ms    0.0%    813.03 Mbps    968.51 Mbps    o3 - Kyiv
     Minsk, BY        38.54 ms    0.5%    951.63 Mbps    677.85 Mbps    A1 - Minsk
     Bucharest, RO    29.82 ms    0.0%    877.41 Mbps    987.68 Mbps    Orange Romania Communications - Bucharest
    awk: line 1: 95948e+091040 : decimal overflow
     Iasi, RO         42.09 ms    0.0%    723.44 Mbps    956.15 Mbps    Digi
     Helsinki, FI     28.15 ms    0.0%    876.53 Mbps    989.09 Mbps    Elisa Oyj - Helsinki
     Stockholm, SE    37.67 ms    0.0%    788.55 Mbps    971.55 Mbps    i3D.net - Stockholm
     Oslo, NO         28.77 ms    0.0%    809.01 Mbps    980.98 Mbps    Speedtest.net - Oslo
    awk: line 1: 13955e+11920 : decimal overflow
     Moscow, RU       58.26 ms    0.0%    827.65 Mbps    933.22 Mbps    Rostelecom - Moscow
     Petersburg, RU   36.68 ms    0.0%    699.02 Mbps    967.36 Mbps    MTS OJSC - Saint Petersburg
    awk: line 1: 561e+091035 : decimal overflow
     Istanbul, TR     45.57 ms    0.0%    751.39 Mbps    972.00 Mbps    Turkcell - Istanbul
     Tbilisi, GE      65.24 ms    N/A     742.52 Mbps    788.57 Mbps    Silknet JSC - Tbilisi
     Avg DL Speed       : 25867648,53 Mbps
     Avg UL Speed       : 55,02 Mbps
     Total DL Data      : 0,00 GB
     Total UL Data      : 0,00 GB
     Total Data         : 0,00 GB
     Duration           : 12 min 17 sec
     System Time        : 16/11/2023 - 18:38:17 CET
     Total Script Runs  : 27254
     Result             : https://result.network-speed.xyz/r/1700155754_CYJDN1_EU.txt
  • 1€ IONOS France
     Basic System Info
     CPU Model          : AMD EPYC-Milan Processor
     CPU Cores          : 1 @ 1996.249 MHz
     CPU Cache          : 512 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 9.8 GB (1.9 GB Used)
     Total RAM          : 878.0 MB (237.2 MB Used)
     Total Swap         : 1024.0 MB (25.7 MB Used)
     System uptime      : 0 days, 0 hour 55 min
     Load average       : 0.12, 0.54, 0.42
     Kernel             : 6.1.0-9-cloud-amd64
     Virtualization     : MICROSOFT
     Basic Network Info
     ISP                : IONOS SE
     ASN                : AS8560 IONOS SE
     Host               : IONOS SE
     Location (IPv4)    : Paris, Île-de-France, FR
     ISP: 1&1 Internet AG
     Nearest          14.66 ms    0.0%    1535.13 Mbps   1811.75 Mbps   Netcom Kassel Gesellschaft für Telekommunikation mbH - Kassel
     London, UK       14.20 ms    0.0%    1590.98 Mbps   1857.88 Mbps   M247 Ltd - London
     Manchester, UK   24.26 ms    N/A     1956.40 Mbps   1844.98 Mbps   Vodafone UK - Manchester
     Dublin, IE       17.39 ms    0.0%    970.95 Mbps    1758.49 Mbps   Three Ireland - Dublin
     Amsterdam, NL    16.40 ms    0.0%    1341.42 Mbps   1788.98 Mbps   Melbicom - Amsterdam
     Eygelshoen, NL   20.15 ms    0.0%    1581.48 Mbps   1548.07 Mbps   SkyLink Data Center BV - Eygelshoven
     Paris, FR        1.60 ms     0.0%    2045.18 Mbps   1779.70 Mbps   ORANGE - Paris
     Marseille, FR    28.92 ms    0.0%    954.15 Mbps    1810.90 Mbps   GSL Networks - Marseille
     Madrid, ES       31.58 ms    0.0%    1023.66 Mbps   1865.77 Mbps   Orange - Jazztel - Madrid
     Barcelona, ES    23.99 ms    0.0%    360.69 Mbps    1828.12 Mbps   Adamo - Barcelona
     Lisbon, PT       40.29 ms    0.0%    1822.04 Mbps   1797.32 Mbps   Edgoo Networks - Lisbon
     Rome, IT         28.41 ms    0.0%    823.94 Mbps    1832.41 Mbps   TIM SpA - Rome
     Milan, IT        22.38 ms    0.0%    2048.36 Mbps   1809.51 Mbps   Fastweb SpA - Milan
     Zurich, CH       16.84 ms    0.0%    1968.43 Mbps   1878.36 Mbps   Sunrise Communication AG - Zurich
     Frankfurt, DE    13.71 ms    0.0%    1781.76 Mbps   1806.08 Mbps   23M GmbH - Frankfurt am Main
     Berlin, DE       19.52 ms    0.0%    1106.82 Mbps   996.00 Mbps    Misaka Network, Inc. - Berlin
     Vienna, AT       24.89 ms    0.0%    1584.29 Mbps   1805.46 Mbps   A1 Telekom Austria AG - Vienna
     Budapest, HU     24.82 ms    0.0%    2881.00 Mbps   1775.42 Mbps   ATW Internet Kft. - Budapest
     Gdansk, PL       39.92 ms    0.0%    1965.55 Mbps   1822.34 Mbps   T-Mobile Polska S.A. - Gdańsk
     Warsaw, PL       32.01 ms    0.0%    1588.00 Mbps   1865.91 Mbps   Orange Polska S.A. - Warsaw
     Lviv, UA         32.75 ms    0.0%    1092.87 Mbps   1750.76 Mbps   Kyivstar - Lviv
     Kyiv, UA         49.20 ms    0.0%    2068.05 Mbps   1586.49 Mbps   o3 - Kyiv
     Minsk, BY        63.56 ms    0.0%    922.10 Mbps    685.08 Mbps    A1 - Minsk
     Bucharest, RO    43.75 ms    0.0%    2226.91 Mbps   1859.40 Mbps   Orange Romania Communications - Bucharest
     Iasi, RO         41.44 ms    0.0%    1228.29 Mbps   527.06 Mbps    Digi
     Helsinki, FI     34.38 ms    0.0%    1072.02 Mbps   1811.15 Mbps   Elisa Oyj - Helsinki
     Stockholm, SE    38.19 ms    0.0%    1845.68 Mbps   1733.99 Mbps   i3D.net - Stockholm
     Oslo, NO         35.96 ms    0.0%    1561.99 Mbps   1778.27 Mbps   Speedtest.net - Oslo
     Moscow, RU       67.52 ms    3.0%    2235.29 Mbps   5.83 Mbps      Rostelecom - Moscow
     Petersburg, RU   42.57 ms    0.0%    2103.68 Mbps   1449.59 Mbps   MTS OJSC - Saint Petersburg
     Istanbul, TR     49.89 ms    0.0%    1628.39 Mbps   1541.87 Mbps   Turkcell - Istanbul
     Tbilisi, GE      73.91 ms    N/A     2626.16 Mbps   1218.66 Mbps   Silknet JSC - Tbilisi
     Avg DL Speed       : 1610.68 Mbps
     Avg UL Speed       : 1600.99 Mbps
     Total DL Data      : 67.47 GB
     Total UL Data      : 68.97 GB
     Total Data         : 136.44 GB
     Duration           : 13 min 29 sec
     System Time        : 16/11/2023 - 17:38:37 UTC
     Total Script Runs  : 27255
     Result             : https://result.network-speed.xyz/r/1700155772_8HYJKY_EU.txt
  • @Neoon said:
    1€ Netcup
     Basic System Info
     AES-NI             : ✔ Enabled
     Basic Network Info
     ISP                : netcup GmbH
     Host               : NETCUP-GMBH
     ISP: netcup
    Woah, that does not look good.
  • @sh97 said:
    @Neoon said:
    1€ Netcup
     Basic System Info
     AES-NI             : ✔ Enabled
     Basic Network Info
     ISP                : netcup GmbH
     Host               : NETCUP-GMBH
     ISP: netcup
    Probably a missing package.
    A few more days to wait until IPv6/64 arrives from crunchbits, so I tried an HE tunnel. HE gave a /48. Here is network-speed using the HE tunnel. I wish everyone a great day! 😃
    • India
     Basic System Info
     CPU Model          : Intel(R) Xeon(R) CPU E3-1245 v5 @ 3.50GHz
     CPU Cores          : 8 @ 3599.665 MHz
     CPU Cache          : 8192 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 3.7 TB (2.7 GB Used)
     Total RAM          : 62.6 GB (864.4 MB Used)
     Total Swap         : 12.0 GB (0 Used)
     System uptime      : 0 days, 20 hour 41 min
     Load average       : 0.14, 0.13, 0.09
     OS                 : Fedora release 40 (Rawhide)
     Kernel             : 6.7.0-0.rc1.20231115gitc42d9eeef8e5.18.fc40.x86_64
     Virtualization     : NONE
     Basic Network Info
     ISP                : Hurricane Electric LLC
     ASN                : AS6939 Hurricane Electric LLC
     ASN (IPv4)         : AS400304 REDOUBT NETWORKS
     Host               : Hurricane Electric
     Speedtest.net (Region: INDIA | भारत)
     ISP: Nerocloud
     Nearest          17.54 ms    0.0%    943.80 Mbps    934.19 Mbps    Cutting Edge Communications, Inc - Spokane, WA
     Mumbai, MH       271.61 ms   N/A     9.18 Mbps      248.90 Mbps    Jio - Mumbai
     Mumbai, MH       247.45 ms   0.0%    446.94 Mbps    369.59 Mbps    Airtel Broadband - Mumbai
     Pune, MH         283.47 ms   0.3%    446.88 Mbps    301.33 Mbps    Tata Play Fiber - Pune
     Hyderabad, AP/TL 277.05 ms   N/A     361.29 Mbps    276.36 Mbps    Airtel Broadband - Hyderabad
     Bangalore, KA    255.46 ms   0.0%    456.13 Mbps    226.35 Mbps    Bharti Airtel Ltd - Bangalore
     Bangalore, KA    278.22 ms   0.0%    401.82 Mbps    298.68 Mbps    ACT FIBERNET - Bangalore
     Mangalore, KA    252.25 ms   0.0%    331.67 Mbps    323.10 Mbps    BBNL - Mangalore
     Chennai, TN      250.88 ms   N/A     448.77 Mbps    283.65 Mbps    Jio - Chennai
     Coimbatore, TN   275.49 ms   0.0%    148.57 Mbps    279.70 Mbps    Airtel Broadband - Coimbatore
     Madurai, TN      289.55 ms   0.0%    386.90 Mbps    311.09 Mbps    Vi India - Madurai
     Kochi, KL        268.63 ms   N/A     444.64 Mbps    289.34 Mbps    Jio - Kochi
     Kochi, KL        277.71 ms   0.0%    429.51 Mbps    304.53 Mbps    Asianet Broadband - Cochin
     Trivandrum, KL   302.41 ms   0.0%    404.62 Mbps    212.26 Mbps    Keralavision Broadband - Trivandrum
     Kolkata, WB      302.54 ms   0.0%    406.21 Mbps    249.23 Mbps    Alliance Broadband Services Pvt Ltd - Kolkata
     Delhi, DL        323.64 ms   0.0%    428.76 Mbps    291.62 Mbps    Extreme IX - New Delhi
     Gurgaon, HR      262.08 ms   0.0%    444.56 Mbps    346.16 Mbps    Powernet - Gurgaon
     Patna, BH        298.46 ms   N/A     422.82 Mbps    206.76 Mbps    Vi India - Patna
     Avg DL Speed       : 409.06 Mbps
     Avg UL Speed       : 319.60 Mbps
     Total DL Data      : 10.09 GB
     Total UL Data      : 7.52 GB
     Total Data         : 17.62 GB
     Duration           : 10 min 13 sec
     System Time        : 18/11/2023 - 01:06:58 UTC
     Total Script Runs  : 27344
     Result             : https://result.network-speed.xyz/r/1700269062_TSY919_INDIA.txt
    [root@crunchy ~]#
    • China
     Basic System Info
     CPU Cores          : 8 @ 3786.549 MHz
     CPU Cache          : 8192 KB
     AES-NI             : ✔ Enabled
     Total RAM          : 62.6 GB (884.1 MB Used)
     System uptime      : 0 days, 19 hour 24 min
     Load average       : 0.07, 0.64, 0.53
     Basic Network Info
     Speedtest.net (Region: CHINA | 中華人民共和國)
     ISP: Nerocloud
     Nearest          17.35 ms    0.0%    944.18 Mbps    936.95 Mbps    Cutting Edge Communications, Inc - Spokane, WA
     CU - Shanghai    165.16 ms   0.0%    408.17 Mbps    535.70 Mbps    China Unicom 5G - Shanghai
     CM - Beijing     208.57 ms   0.3%    615.09 Mbps    126.65 Mbps    China Mobile Group Beijing Co.Ltd - Beijing
     CU - Beijing     190.26 ms   N/A     274.38 Mbps    335.80 Mbps    BJ Unicom - Beijing
     CT - Nanjing     176.97 ms   0.0%    628.00 Mbps    18.91 Mbps     China Telecom JiangSu 5G - Nanjing
     CU - Shenyang    220.21 ms   15.3%   1.01 Mbps      0.61 Mbps      Unicom - Shenyang
     CT - Suzhou      177.86 ms   N/A     650.06 Mbps    380.13 Mbps    China Telecom JiangSu 5G - Suzhou
     CT - Yangzhou    178.59 ms   0.0%    19.92 Mbps     2.01 Mbps      江苏电信5G - Yangzhou
     CM - Hangzhou    284.71 ms   0.0%    861.87 Mbps    170.72 Mbps    China Mobile Zhejiang 5G - Hangzhou
     CU - Zhengzhou   210.58 ms   N/A     418.26 Mbps    334.59 Mbps    China Unicom HeNan 5G - Zhengzhou
     CT - Changsha    227.15 ms   0.3%    11.06 Mbps     44.28 Mbps     湖南电信5G - Changsha
     CU - Changsha    195.41 ms   N/A     13.29 Mbps     468.19 Mbps    湖南联通5G - Changsha
     CM - Chengdu     287.64 ms   20.3%   579.14 Mbps    0.41 Mbps      China Mobile Group Sichuan - Chengdu
     CT - Wuhan       FAILED
     CM - Xi an       375.72 ms   1.0%    734.60 Mbps    289.19 Mbps    陕西移动5G - Xi'an
     CT - Hefei       181.63 ms   0.0%    685.82 Mbps    434.78 Mbps    China Telecom AnHui 5G - Hefei
     CT - TianJin     208.01 ms   0.0%    13.11 Mbps     378.02 Mbps    China Telecom TianJin-5G - TianJin
     CM - Kwai Chung  FAILED
     CM - Hong Kong   210.73 ms   0.0%    0.34 Mbps      4.94 Mbps      China Mobile Hong Kong Boardband - Hong Kong
     Hong Kong        179.50 ms   0.0%    500.24 Mbps    289.34 Mbps    HKIX - Hong Kong
     Hong Kong        181.23 ms   N/A     722.06 Mbps    490.08 Mbps    fdcservers.net - Hong Kong
     Hong Kong        174.19 ms   0.0%    267.49 Mbps    206.86 Mbps    Misaka Network, Inc. - Hong Kong
     Avg DL Speed       : 417.40 Mbps
     Avg UL Speed       : 272.41 Mbps
     Total DL Data      : 12.24 GB
     Total UL Data      : 7.94 GB
     Total Data         : 20.19 GB
     Duration           : 10 min 54 sec
     System Time        : 17/11/2023 - 23:50:56 UTC
     Total Script Runs  : 27329
     Result             : https://result.network-speed.xyz/r/1700264500_7D3NG6_CHINA.txt
    [root@crunchy ~]#
    • Global
     Basic System Info
     CPU Cores          : 8 @ 3640.388 MHz
     CPU Cache          : 8192 KB
     AES-NI             : ✔ Enabled
     Total RAM          : 62.6 GB (859.7 MB Used)
     System uptime      : 0 days, 22 hour 7 min
     Load average       : 0.27, 0.13, 0.10
     Basic Network Info
     ISP: Nerocloud
     Nearest          17.53 ms    0.0%    943.29 Mbps    932.16 Mbps    Cutting Edge Communications, Inc - Spokane, WA
     Kochi, IN        273.00 ms   0.0%    273.02 Mbps    191.48 Mbps    Asianet Broadband - Cochin
     Bangalore, IN    259.34 ms   0.0%    275.03 Mbps    244.36 Mbps    Bharti Airtel Ltd - Bangalore
     Chennai, IN      241.20 ms   N/A     233.68 Mbps    167.67 Mbps    Jio - Chennai
     Mumbai, IN       276.75 ms   0.0%    289.81 Mbps    159.94 Mbps    i3D.net - Mumbai
     Delhi, IN        289.32 ms   0.0%    290.05 Mbps    209.67 Mbps    Tata Teleservices Ltd - New Delhi
     Seattle, US      12.39 ms    N/A     337.99 Mbps    345.89 Mbps    Comcast - Seattle, WA
     Los Angeles, US  36.56 ms    0.0%    292.04 Mbps    178.31 Mbps    ReliableSite Hosting - Los Angeles, CA
     Dallas, US       66.74 ms    0.0%    248.84 Mbps    173.47 Mbps    Hivelocity - Dallas, TX
     Miami, US        139.90 ms   1.7%    606.38 Mbps    95.28 Mbps     AT&T - Miami, FL
     New York, US     82.27 ms    0.0%    898.64 Mbps    891.30 Mbps    GSL Networks - New York, NY
     Toronto, CA      FAILED
     London, UK       134.00 ms   0.7%    620.21 Mbps    60.31 Mbps     VeloxServ Communications - London
     Amsterdam, NL    133.21 ms   0.0%    974.04 Mbps    653.24 Mbps    31173 Services AB - Amsterdam
     Paris, FR        138.72 ms   N/A     978.12 Mbps    620.41 Mbps    Axione - Paris
     Frankfurt, DE    146.57 ms   0.0%    451.12 Mbps    273.62 Mbps    23M GmbH - Frankfurt am Main
     Warsaw, PL       159.29 ms   0.0%    322.11 Mbps    294.46 Mbps    UPC Polska - Warszawa
     Bucharest, RO    188.13 ms   0.0%    644.75 Mbps    471.37 Mbps    Vodafone Romania Fixed – Bucharest - Bucharest
     Jeddah, SA       199.62 ms   3.7%    614.55 Mbps    192.37 Mbps    Saudi Telecom Company
     Dubai, AE        251.44 ms   0.0%    564.40 Mbps    351.35 Mbps    du - Dubai
     Fujairah, AE     283.27 ms   0.0%    857.68 Mbps    349.09 Mbps    ETISALAT-UAE - Fujairah
     Tokyo, JP        136.94 ms   N/A     663.48 Mbps    184.36 Mbps    fdcservers.net - Tokyo
     Shanghai, CU-CN  164.92 ms   0.0%    664.63 Mbps    528.81 Mbps    China Unicom 5G - Shanghai
     Nanjing, CT-CN   178.77 ms   0.0%    587.99 Mbps    28.15 Mbps     China Telecom JiangSu 5G - Nanjing
     Hong Kong, CN    174.98 ms   N/A     558.20 Mbps    507.87 Mbps    STC - Hong Kong
     Singapore, SG    204.30 ms   0.0%    401.54 Mbps    372.48 Mbps    i3D.net - Singapore
     Jakarta, ID      FAILED - IP has been rate limited. Try again after 1 hour.
     Avg DL Speed       : 543.66 Mbps
     Avg UL Speed       : 339.10 Mbps
     Total DL Data      : 18.97 GB
     Total UL Data      : 12.17 GB
     Total Data         : 31.14 GB
     Duration           : 13 min 19 sec
     System Time        : 18/11/2023 - 02:36:50 UTC
     Total Script Runs  : 27346
     Result             : https://result.network-speed.xyz/r/1700274453_REL5OF_GLOBAL.txt
    [root@crunchy ~]#
    HOST-C, MInimal VPS, Romania
     Basic System Info
     CPU Model          : Intel(R) Xeon(R) CPU E5-2660 v4 @ 2.00GHz
     CPU Cores          : 1 @ 1999.998 MHz
     AES-NI             : ✔ Enabled
     Total Disk         : 9.8 GB (1.4 GB Used)
     Total RAM          : 1.9 GB (62.4 MB Used)
     System uptime      : 4 days, 18 hour 23 min
     Load average       : 0.17, 0.57, 0.45
     OS                 : Debian GNU/Linux 11
     Kernel             : 5.10.0-26-cloud-amd64
     Basic Network Info
     ISP                : Andrei Tiberiu Holt
     ASN                : AS211462 Andrei Tiberiu Holt
     Host               : Andrei Tiberiu Holt
     ISP: Andrei Tiberiu Holt
     Nearest          6.50 ms     0.0%    4751.26 Mbps   3081.20 Mbps   efectRO - Cluj-Napoca
     London, UK       36.28 ms    0.0%    2747.43 Mbps   1178.47 Mbps   M247 Ltd - London
     Manchester, UK   35.00 ms    N/A     2627.48 Mbps   1187.39 Mbps   Vodafone UK - Manchester
     Dublin, IE       40.76 ms    0.0%    3933.90 Mbps   1495.30 Mbps   Three Ireland - Dublin
     Amsterdam, NL    33.91 ms    0.0%    3886.77 Mbps   1804.90 Mbps   Melbicom - Amsterdam
     Eygelshoen, NL   35.99 ms    0.0%    2401.15 Mbps   837.53 Mbps    SkyLink Data Center BV - Eygelshoven
     Paris, FR        37.02 ms    0.0%    2098.19 Mbps   1605.34 Mbps   ORANGE - Paris
     Marseille, FR    31.39 ms    0.0%    4207.75 Mbps   1861.95 Mbps   GSL Networks - Marseille
     Madrid, ES       44.72 ms    0.0%    3535.38 Mbps   1899.20 Mbps   Orange - Jazztel - Madrid
     Barcelona, ES    48.29 ms    0.0%    1801.90 Mbps   1079.40 Mbps   Adamo - Barcelona
     Lisbon, PT       59.21 ms    0.0%    2467.70 Mbps   1042.31 Mbps   Edgoo Networks - Lisbon
     Rome, IT         57.15 ms    0.0%    3832.90 Mbps   1383.83 Mbps   TIM SpA - Rome
     Milan, IT        25.35 ms    0.0%    2524.45 Mbps   2139.76 Mbps   Fastweb SpA - Milan
     Zurich, CH       38.87 ms    0.0%    3190.73 Mbps   1770.99 Mbps   Sunrise Communication AG - Zurich
     Frankfurt, DE    28.06 ms    0.0%    3929.12 Mbps   2093.26 Mbps   23M GmbH - Frankfurt am Main
     Berlin, DE       29.10 ms    N/A     3537.38 Mbps   809.34 Mbps    Misaka Network, Inc. - Berlin
     Vienna, AT       39.84 ms    0.0%    3989.66 Mbps   2332.87 Mbps   A1 Telekom Austria AG - Vienna
     Budapest, HU     8.68 ms     0.0%    4384.32 Mbps   2212.28 Mbps   ATW Internet Kft. - Budapest
     Gdansk, PL       33.67 ms    0.0%    2801.27 Mbps   944.52 Mbps    T-Mobile Polska S.A. - Gdańsk
     Warsaw, PL       43.33 ms    0.0%    2345.25 Mbps   1662.83 Mbps   Orange Polska S.A. - Warsaw
     Lviv, UA         19.35 ms    0.0%    4589.41 Mbps   1322.69 Mbps   Kyivstar - Lviv
     Kyiv, UA         33.26 ms    0.0%    2650.85 Mbps   794.94 Mbps    o3 - Kyiv
     Minsk, BY        29.14 ms    0.0%    4154.64 Mbps   1920.75 Mbps   A1 - Minsk
     Bucharest, RO    11.20 ms    0.0%    4894.73 Mbps   2674.72 Mbps   Orange Romania Communications - Bucharest
     Iasi, RO         16.33 ms    0.0%    3914.64 Mbps   2767.53 Mbps   Digi
     Helsinki, FI     36.73 ms    0.0%    1666.23 Mbps   1759.31 Mbps   Elisa Oyj - Helsinki
     Stockholm, SE    56.99 ms    0.0%    2871.24 Mbps   1159.47 Mbps   i3D.net - Stockholm
     Oslo, NO         52.60 ms    0.0%    2598.29 Mbps   1377.09 Mbps   Speedtest.net - Oslo
     Moscow, RU       48.95 ms    0.0%    2425.61 Mbps   1829.80 Mbps   Rostelecom - Moscow
     Petersburg, RU   46.30 ms    0.0%    1774.20 Mbps   1478.27 Mbps   MTS OJSC - Saint Petersburg
     Istanbul, TR     39.57 ms    0.0%    3457.11 Mbps   1879.65 Mbps   Turkcell - Istanbul
     Tbilisi, GE      66.34 ms    N/A     2212.18 Mbps   1107.90 Mbps   Silknet JSC - Tbilisi
     Avg DL Speed       : 3193.84 Mbps
     Avg UL Speed       : 1640.47 Mbps
     Total DL Data      : 148.80 GB
     Total UL Data      : 69.18 GB
     Total Data         : 217.97 GB
     Duration           : 15 min 5 sec
     System Time        : 20/11/2023 - 07:57:05 UTC
     Total Script Runs  : 27493
     Result             : https://result.network-speed.xyz/r/1700466460_HLYHU0_EU.txt
  • ServerFactory NL (new NL location)
     Basic System Info
     CPU Model          : AMD EPYC 7702P 64-Core Processor
     CPU Cores          : 1 @ 1999.999 MHz
     CPU Cache          : 512 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 49.1 GB (1.8 GB Used)
     Total RAM          : 1.9 GB (560.0 MB Used)
     System uptime      : 8 days, 22 hour 0 min
     Load average       : 0.00, 0.00, 0.00
     Basic Network Info
     ISP                : xxx
     ASN                : xxx
     ASN (IPv4)         : AS206075 Maximilian Jacobsen
     Host               : xxx
     Location (IPv4)    : Hopel, Limburg, NL
     ISP: xxx
     Nearest          3.88 ms     0.0%    989.74 Mbps    1038.62 Mbps   tropic-host.de - Amsterdam
     London, UK       12.37 ms    0.0%    995.64 Mbps    679.72 Mbps    M247 Ltd - London
     Manchester, UK   19.38 ms    N/A     1002.29 Mbps   517.82 Mbps    Vodafone UK - Manchester
     Dublin, IE       24.07 ms    0.0%    1015.08 Mbps   425.87 Mbps    Three Ireland - Dublin
     Amsterdam, NL    7.53 ms     0.0%    987.83 Mbps    965.24 Mbps    Melbicom - Amsterdam
     Eygelshoen, NL   5.38 ms     0.0%    987.39 Mbps    978.82 Mbps    SkyLink Data Center BV - Eygelshoven
     Paris, FR        15.91 ms    0.0%    1002.38 Mbps   572.39 Mbps    ORANGE - Paris
     Marseille, FR    20.97 ms    0.0%    1012.89 Mbps   448.45 Mbps    GSL Networks - Marseille
     Madrid, ES       34.06 ms    0.0%    1002.12 Mbps   370.05 Mbps    Orange - Jazztel - Madrid
     Barcelona, ES    37.32 ms    0.0%    995.80 Mbps    441.97 Mbps    Adamo - Barcelona
     Lisbon, PT       38.93 ms    0.0%    991.08 Mbps    368.18 Mbps    Edgoo Networks - Lisbon
     Rome, IT         31.41 ms    0.0%    1018.22 Mbps   411.96 Mbps    TIM SpA - Rome
     Milan, IT        14.82 ms    0.0%    1006.76 Mbps   677.84 Mbps    Fastweb SpA - Milan
     Zurich, CH       11.25 ms    0.0%    998.69 Mbps    740.57 Mbps    Sunrise Communication AG - Zurich
     Frankfurt, DE    5.78 ms     0.0%    987.99 Mbps    892.80 Mbps    23M GmbH - Frankfurt am Main
     Berlin, DE       16.18 ms    N/A     990.66 Mbps    365.10 Mbps    Misaka Network, Inc. - Berlin
     Vienna, AT       16.35 ms    0.0%    1004.35 Mbps   548.17 Mbps    A1 Telekom Austria AG - Vienna
     Budapest, HU     18.65 ms    0.0%    985.96 Mbps    641.39 Mbps    ATW Internet Kft. - Budapest
     Gdansk, PL       25.05 ms    0.0%    995.77 Mbps    488.44 Mbps    T-Mobile Polska S.A. - Gdańsk
     Warsaw, PL       23.56 ms    0.0%    991.69 Mbps    539.96 Mbps    Orange Polska S.A. - Warsaw
     Lviv, UA         34.87 ms    0.0%    1008.33 Mbps   361.71 Mbps    Kyivstar - Lviv
     Kyiv, UA         32.36 ms    0.0%    1006.58 Mbps   421.08 Mbps    o3 - Kyiv
     Minsk, BY        28.60 ms    0.0%    1012.82 Mbps   472.46 Mbps    A1 - Minsk
     Bucharest, RO    34.76 ms    0.0%    1005.90 Mbps   444.14 Mbps    Orange Romania Communications - Bucharest
     Iasi, RO         40.80 ms    0.0%    996.12 Mbps    386.36 Mbps    Digi
     Helsinki, FI     27.90 ms    0.0%    990.87 Mbps    527.52 Mbps    Elisa Oyj - Helsinki
     Stockholm, SE    29.43 ms    0.0%    988.13 Mbps    379.41 Mbps    i3D.net - Stockholm
     Oslo, NO         26.90 ms    0.0%    999.39 Mbps    479.29 Mbps    Speedtest.net - Oslo
     Moscow, RU       181.66 ms   0.0%    996.79 Mbps    187.27 Mbps    Rostelecom - Moscow
     Petersburg, RU   35.21 ms    0.0%    993.60 Mbps    491.58 Mbps    MTS OJSC - Saint Petersburg
     Istanbul, TR     58.34 ms    0.0%    1005.75 Mbps   322.30 Mbps    Turkcell - Istanbul
     Tbilisi, GE      68.06 ms    N/A     1008.79 Mbps   352.22 Mbps    Silknet JSC - Tbilisi
     Avg DL Speed       : 999.24 Mbps
     Avg UL Speed       : 529.34 Mbps
     Total DL Data      : 37.85 GB
     Total UL Data      : 18.01 GB
     Total Data         : 55.86 GB
     Duration           : 11 min 57 sec
     System Time        : 21/11/2023 - 16:32:42 IST
     Total Script Runs  : 27582
    Thanks @sh97! Just noticed you added more locations to the Middle East test.
     Basic Network Info
     ISP                : OVH SAS
     Host               : OVH
     Location (IPv4)    : Strasbourg, Grand Est, FR
     ISP: OVH SAS
     Nearest          6.82 ms     0.0%    935.57 Mbps    237.50 Mbps    Nextmap - LeKloud - Paris
     Abu Dhabi, AE    150.00 ms   0.0%    955.18 Mbps    244.27 Mbps    du - Abu Dhabi
     Dubai, AE        114.07 ms   0.0%    931.34 Mbps    237.27 Mbps    i3D.net - Dubai
     Fujairah, AE     117.42 ms   0.0%    966.65 Mbps    243.99 Mbps    ETISALAT-UAE - Fujairah
     Muscat, OM       114.65 ms   0.0%    931.65 Mbps    245.38 Mbps    OmanTel - Muscat
     Seeb, OM         112.93 ms   0.0%    930.85 Mbps    233.41 Mbps    Ooredoo Oman - Seeb
     Sanaa, YE        157.85 ms   0.0%    933.30 Mbps    237.47 Mbps    Yemen Net - Sanaa
     Doha, QA         134.77 ms   0.0%    970.02 Mbps    239.03 Mbps    Ooredoo Qatar - Doha
     Rayan, QA        145.27 ms   0.0%    741.32 Mbps    21.51 Mbps     Vodafone Qatar PQSC - Rayan
     Manama, BH       98.95 ms    0.0%    961.89 Mbps    241.70 Mbps    ZainBH - Manama
     Rifa, BH         85.70 ms    0.0%    893.77 Mbps    223.23 Mbps    stc Bahrain - Riffa
     Kuwait, KW       101.05 ms   0.0%    934.90 Mbps    231.09 Mbps    Zain Kuwait - Kuwait City
     Kuwait, KW       133.22 ms   N/A     931.96 Mbps    240.15 Mbps    Ooredoo Kuwait - Kuwait City
     Riyadh, SA       81.46 ms    0.0%    960.29 Mbps    206.67 Mbps    Mobily - Riyadh
     Dammam, SA       90.99 ms    0.0%    964.35 Mbps    240.90 Mbps    Saudi Telecom Company
     Jeddah, SA       79.05 ms    0.0%    957.81 Mbps    240.75 Mbps    Zain KSA - Jeddah
     Jeddah, SA       72.05 ms    0.0%    953.35 Mbps    237.07 Mbps    Saudi Telecom Company
     Tehran, IR       72.11 ms    0.0%    942.68 Mbps    243.08 Mbps    Irancell - Tehran
     Baghdad, IQ      78.37 ms    0.4%    943.84 Mbps    66.95 Mbps     Al-Jazeera Telecom - Baghdad
     Beirut, LB       56.94 ms    0.0%    413.58 Mbps    223.92 Mbps    Ogero - Beirut
     Nicosia, CY      55.79 ms    0.0%    946.00 Mbps    223.79 Mbps    Cyprus Telecommunications Authority - Nicosia
     Tel Aviv, IL     62.87 ms    0.0%    944.63 Mbps    238.46 Mbps    Bezeq - Tel Aviv
     Amman, JO        60.01 ms    0.0%    946.83 Mbps    229.25 Mbps    Zain Jordan - Amman
     Cairo, EG        56.31 ms    0.0%    939.11 Mbps    232.51 Mbps    Etisalat Misr - Cairo
     Cairo, EG        52.18 ms    0.0%    947.74 Mbps    218.90 Mbps    Vodafone Egypt - Cairo
     Istanbul, TR     51.35 ms    0.0%    947.56 Mbps    240.83 Mbps    Vodafone TR - Istanbul
     Avg DL Speed       : 916.39 Mbps
     Avg UL Speed       : 219.96 Mbps
     Total DL Data      : 34.61 GB
     Total UL Data      : 7.53 GB
     Total Data         : 42.13 GB
     Duration           : 12 min 0 sec
     System Time        : 21/11/2023 - 22:23:08 UTC
     Total Script Runs  : 27609
     Result             : https://result.network-speed.xyz/r/1700604799_E92QFG_MIDDLE-EAST.txt
    Thanked by (1)sh97
  • Advin Genoa Germany
     Basic System Info
     CPU Model          : AMD EPYC 9554 64-Core Processor
     CPU Cores          : 2 @ 3099.996 MHz
     CPU Cache          : 512 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 36.3 GB (3.8 GB Used)
     Total RAM          : 3.8 GB (198.0 MB Used)
     System uptime      : 0 days, 0 hour 24 min
     Load average       : 0.00, 0.08, 0.13
     OS                 : Ubuntu 22.04.3 LTS
     Kernel             : 5.15.0-69-generic
     Basic Network Info
     ISP                : Advin Services LLC
     ASN                : AS206216 Advin Services LLC
     Host               : Advin Services LLC
     Location (IPv4)    : Nürnberg, Bavaria, DE
     ISP: Advin Services
     Nearest          14.86 ms    0.0%    7697.48 Mbps   5221.25 Mbps   31173 Services AB - Amsterdam
     Kochi, IN        157.02 ms   0.0%    4868.26 Mbps   534.75 Mbps    Asianet Broadband - Cochin
     Bangalore, IN    134.53 ms   0.0%    5206.31 Mbps   647.82 Mbps    Bharti Airtel Ltd - Bangalore
     Chennai, IN      144.52 ms   N/A     5409.05 Mbps   710.07 Mbps    Jio - Chennai
     Mumbai, IN       138.35 ms   0.0%    4621.43 Mbps   630.94 Mbps    i3D.net - Mumbai
     Delhi, IN        152.91 ms   0.0%    2698.85 Mbps   618.17 Mbps    Tata Teleservices Ltd - New Delhi
     Seattle, US      160.74 ms   N/A     4411.93 Mbps   508.26 Mbps    Comcast - Seattle, WA
     Los Angeles, US  154.92 ms   0.0%    3145.17 Mbps   569.50 Mbps    ReliableSite Hosting - Los Angeles, CA
     Dallas, US       129.79 ms   0.0%    3567.84 Mbps   716.73 Mbps    Hivelocity - Dallas, TX
     Miami, US        127.52 ms   0.0%    2569.81 Mbps   729.62 Mbps    AT&T - Miami, FL
     New York, US     88.61 ms    0.7%    5399.75 Mbps   782.14 Mbps    GSL Networks - New York, NY
     Toronto, CA      109.79 ms   1.5%    6040.88 Mbps   869.69 Mbps    Rogers - Toronto, ON
     London, UK       20.69 ms    0.8%    7613.20 Mbps   589.85 Mbps    VeloxServ Communications - London
     Amsterdam, NL    14.69 ms    0.0%    7966.11 Mbps   3629.03 Mbps   31173 Services AB - Amsterdam
     Paris, FR        18.81 ms    N/A     7129.75 Mbps   1415.32 Mbps   Axione - Paris
     Frankfurt, DE    8.26 ms     0.0%    7558.40 Mbps   7354.03 Mbps   23M GmbH - Frankfurt am Main
     Warsaw, PL       25.34 ms    0.0%    7170.89 Mbps   3444.61 Mbps   UPC Polska - Warszawa
     Bucharest, RO    30.24 ms    0.0%    8011.69 Mbps   2784.67 Mbps   Vodafone Romania Fixed – Bucharest - Bucharest
     Jeddah, SA       68.03 ms    0.0%    5403.32 Mbps   1470.15 Mbps   Saudi Telecom Company
     Dubai, AE        143.05 ms   0.0%    4635.95 Mbps   726.16 Mbps    du - Dubai
     Fujairah, AE     120.51 ms   0.0%    5637.62 Mbps   815.84 Mbps    ETISALAT-UAE - Fujairah
     Tokyo, JP        224.27 ms   N/A     3396.78 Mbps   82.95 Mbps     fdcservers.net - Tokyo
     Shanghai, CU-CN  246.00 ms   0.0%    2951.89 Mbps   425.04 Mbps    China Unicom 5G - Shanghai
     Nanjing, CT-CN   288.91 ms           1159.79 Mbps   FAILED         China Telecom JiangSu 5G - Nanjing
     Hong Kong, CN    166.75 ms   N/A     2715.60 Mbps   541.25 Mbps    STC - Hong Kong
     Singapore, SG    155.86 ms   0.0%    4835.97 Mbps   564.67 Mbps    i3D.net - Singapore
     Jakarta, ID      190.21 ms   0.0%    4285.15 Mbps   296.75 Mbps    PT. Telekomunikasi Indonesia - Jakarta
     Avg DL Speed       : 5041.11 Mbps
     Avg UL Speed       : 1358.49 Mbps
     Total DL Data      : 198.50 GB
     Total UL Data      : 50.06 GB
     Total Data         : 248.56 GB
     Duration           : 19 min 28 sec
     System Time        : 22/11/2023 - 07:34:27 UTC
     Total Script Runs  : 27638
     Result             : https://result.network-speed.xyz/r/1700637874_N0JR8N_GLOBAL.txt
    Hi,
    I have two suggestion :)
    add the tcp_congestion_control ,then we can know the linux tcp_congestion_control is cubic or bbr , I think cubic is more reflective of the quality of the network than bbr
    add an ipv4/ipv6 parameter, so that we can choose test with ipv4 or ipv6,
    I have set ipv4 priority on my linux vps, but I noticed network-speed.xyz still use ipv6 for network test.
    my blog: https://tang.lu
  • @tanglu said:
    Hi,
    Hey, thanks for the suggestions!
    TCP control should be easily addable - I will have a look into this!
    About v6/v4 - this uses speedtest-cli underneath and unfortunately the CLI does not have support for something like that. I could probably force v4 only via the system level for tests, but that is not a good idea - having no v6 access for the duration of the tests.
    Thanked by (1)tanglu
  • About v6/v4 - this uses speedtest-cli underneath and unfortunately the CLI does not have support for something like that. I could probably force v4 only via the system level for tests, but that is not a good idea - having no v6 access for the duration of the tests.
    I see, I just know yabs have ipv4 and ipv6 network test, I don't know which tool yabs use.
    As I have said, I have tried to force v4 only via the system level for tests, but it failed, you can test it.
    Thanked by (1)sh97
    Yes, iperf has option for v4 and v6. By force, I mean disable v6 through sysconf, and re enable after test. But that's a very bad idea.
    If you want pure v4 result, you could also try doing that
     Basic System Info
     CPU Model          : AMD EPYC 7B13 64-Core Processor
     CPU Cores          : 8 @ 2245.780 MHz
     CPU Cache          : 512 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 232.5 GB (2.0 GB Used)
     Total RAM          : 15.6 GB (229.9 MB Used)
     System uptime      : 0 days, 2 hour 22 min
     Kernel             : 5.15.0-87-generic
     Basic Network Info
     ISP                : WebHorizon Internet Services
     ASN                : AS149020 WebHorizon Internet Services
     Host               : WebHorizon IT Broadband Limited
     Speedtest.net (Region: ASIA)
     ISP: WebHorizon Internet Services
     Nearest          0.23 ms     N/A     5749.83 Mbps   6365.54 Mbps   fdcservers.net - Tokyo
     Tokyo, JP        3.27 ms     0.0%    6963.40 Mbps   2852.63 Mbps   Rakuten Mobile, Inc - Tokyo
     Tapei, TW        31.28 ms    N/A     6871.51 Mbps   1406.04 Mbps   Chunghwa Mobile - Taipei
     China Telecom    FAILED
     China Unicom     156.77 ms   0.0%    3176.49 Mbps   525.37 Mbps    China Unicom 5G - Shanghai
     China Mobile     FAILED
     Hong Kong, CN    55.84 ms    0.0%    7296.66 Mbps   975.38 Mbps    i3D.net - Hong Kong
     Ho Chi Minh, VN  84.29 ms    0.0%    2172.85 Mbps   963.51 Mbps    CMC Telecom - Ho Chi Minh
     Hanoi, VN        76.68 ms    0.0%    5992.62 Mbps   838.60 Mbps    FPT Telecom - Hanoi
     Bangkok, TH      197.50 ms   0.0%    3822.49 Mbps   468.05 Mbps    3BB - Bangkok
     Manila, PH       FAILED
     Singapore, SG    129.39 ms   0.0%    4589.93 Mbps   546.22 Mbps    MyRepublic Singapore - Singapore
     Singapore, SG    131.70 ms   N/A     5319.88 Mbps   539.81 Mbps    StarHub Ltd - Singapore
     Jakarta, ID      139.89 ms   0.0%    223.19 Mbps    443.47 Mbps    Biznet Networks - Jakarta
     Surabaya, ID     87.03 ms    N/A     7063.39 Mbps   671.69 Mbps    PT. Indonesia Comnets Plus - Surabaya
     Kuala Lum, MY    96.04 ms    0.0%    1314.19 Mbps   743.87 Mbps    Telekom Malaysia Berhad - Kuala Lumpur
     Mumbai, IN       129.74 ms   0.0%    5460.11 Mbps   467.47 Mbps    i3D.net - Mumbai
     Chennai, IN      215.01 ms   N/A     3783.91 Mbps   339.69 Mbps    Jio - Chennai
     Bangalore, IN    241.28 ms   0.0%    3211.08 Mbps   379.79 Mbps    Bharti Airtel Ltd - Bangalore
     Karachi, PK      350.82 ms   0.0%    2239.98 Mbps   137.63 Mbps    JAZZ - Karachi
     Lahore, PK       164.52 ms   N/A     4289.40 Mbps   291.95 Mbps    Telenor Pakistan - Lahore
     Kathmandu, NP    155.12 ms   0.0%    3112.54 Mbps   415.75 Mbps    Ncell Axiata Ltd - Kathmandu
     Colombo, SL      110.46 ms   N/A     1160.25 Mbps   774.14 Mbps    Airtel Lanka - Colombo
     Dhaka, BD        114.99 ms   N/A     4726.08 Mbps   615.99 Mbps    Grameenphone Ltd - Dhaka
     Novosibirsk, RU  292.38 ms   0.0%    2696.16 Mbps   325.86 Mbps    MegaFon - Novosibirsk
     Almaty, KZ       120.24 ms   0.0%    4630.94 Mbps   674.23 Mbps    Kazakhtelecom - Almaty
     Tehran, IR       339.97 ms   0.0%    2312.72 Mbps   131.17 Mbps    Irancell - Tehran
     Dubai, AE        177.44 ms   N/A     4801.52 Mbps   45.03 Mbps     ETISALAT-UAE - Dubai
     Jeddah, SA       217.97 ms   0.0%    3460.77 Mbps   227.53 Mbps    Mobily - Jeddah
     Istanbul, TR     283.17 ms   0.0%    2396.79 Mbps   335.29 Mbps    Turkcell - Istanbul
     Avg DL Speed       : 4031.07 Mbps
     Avg UL Speed       : 833.40 Mbps
     Total DL Data      : 149.21 GB
     Total UL Data      : 25.52 GB
     Total Data         : 174.74 GB
     Duration           : 14 min 5 sec
     System Time        : 24/11/2023 - 18:26:18 GMT
     Total Script Runs  : 28074
     Result             : https://result.network-speed.xyz/r/1700849764_274HN0_ASIA.txt
    Thanked by (1)Abdullah
  • Crunchbits 4TB storage
     Basic System Info
     CPU Model          : Intel Core Processor (Broadwell)
     CPU Cores          : 2 @ 1795.840 MHz
     AES-NI             : ✔ Enabled
     Total Disk         : 4.0 TB (3.4 GB Used)
     Total RAM          : 3.8 GB (499.6 MB Used)
     System uptime      : 0 days, 14 hour 23 min
     Basic Network Info
     ISP                : Redoubt Networks
     ASN                : AS400304 REDOUBT NETWORKS
     ASN (IPv4)         : AS400304 Redoubt Networks
     Host               : Crunchbits LLC
     ISP: Redoubt-net
     Nearest          0.16 ms     0.0%    939.94 Mbps    988.91 Mbps    Crunchbits - Spokane, WA
     Kochi, IN        255.90 ms   0.0%    578.14 Mbps    373.02 Mbps    Asianet Broadband - Cochin
     Bangalore, IN    241.93 ms   0.0%    843.07 Mbps    299.39 Mbps    Bharti Airtel Ltd - Bangalore
     Chennai, IN      267.85 ms   N/A     724.54 Mbps    370.73 Mbps    Jio - Chennai
     Mumbai, IN       251.53 ms   0.0%    850.71 Mbps    288.55 Mbps    i3D.net - Mumbai
     Delhi, IN        272.81 ms   0.0%    575.68 Mbps    318.91 Mbps    Tata Teleservices Ltd - New Delhi
     Seattle, US      11.65 ms    N/A     939.38 Mbps    1005.14 Mbps   Comcast - Seattle, WA
     Los Angeles, US  36.76 ms    0.0%    924.11 Mbps    1011.71 Mbps   ReliableSite Hosting - Los Angeles, CA
     Dallas, US       74.29 ms    0.0%    919.49 Mbps    912.62 Mbps    Hivelocity - Dallas, TX
     Miami, US        89.82 ms    0.0%    915.55 Mbps    787.41 Mbps    AT&T - Miami, FL
     New York, US     82.09 ms    0.0%    948.09 Mbps    1039.83 Mbps   GSL Networks - New York, NY
     Toronto, CA      77.48 ms    0.0%    918.36 Mbps    1037.29 Mbps   Rogers - Toronto, ON
     London, UK       128.57 ms   0.0%    958.84 Mbps    835.06 Mbps    VeloxServ Communications - London
     Amsterdam, NL    133.58 ms   0.0%    978.21 Mbps    852.35 Mbps    31173 Services AB - Amsterdam
     Paris, FR        139.69 ms   N/A     977.22 Mbps    412.25 Mbps    Axione - Paris
     Frankfurt, DE    149.49 ms   0.0%    925.32 Mbps    506.19 Mbps    23M GmbH - Frankfurt am Main
     Warsaw, PL       186.67 ms   0.0%    893.09 Mbps    477.71 Mbps    PLAY - Warszawa
     Bucharest, RO    186.88 ms   0.0%    656.25 Mbps    476.61 Mbps    Vodafone Romania Fixed – Bucharest - Bucharest
     Jeddah, SA       212.01 ms   0.0%    974.05 Mbps    475.44 Mbps    Saudi Telecom Company
     Dubai, AE        245.54 ms   0.0%    719.69 Mbps    458.44 Mbps    du - Dubai
     Fujairah, AE     253.02 ms   0.0%    939.75 Mbps    446.31 Mbps    ETISALAT-UAE - Fujairah
     Tokyo, JP        136.92 ms   N/A     896.42 Mbps    506.13 Mbps    fdcservers.net - Tokyo
     Shanghai, CU-CN  181.89 ms   0.0%    359.01 Mbps    620.63 Mbps    China Unicom 5G - Shanghai
     Nanjing, CT-CN   167.40 ms   0.7%    584.65 Mbps    33.16 Mbps     China Telecom JiangSu 5G - Nanjing
     Hong Kong, CN    174.96 ms   N/A     820.86 Mbps    521.21 Mbps    STC - Hong Kong
     Singapore, SG    190.50 ms   0.0%    922.86 Mbps    470.39 Mbps    i3D.net - Singapore
     Jakarta, ID      228.96 ms   0.0%    671.73 Mbps    177.35 Mbps    PT. Telekomunikasi Indonesia - Jakarta
     Avg DL Speed       : 827.97 Mbps
     Avg UL Speed       : 581.58 Mbps
     Total DL Data      : 31.64 GB
     Total UL Data      : 21.03 GB
     Total Data         : 52.67 GB
     System Time        : 24/11/2023 - 13:49:21 PST
     Total Script Runs  : 28104
     Result             : https://result.network-speed.xyz/r/1700861947_PRPEP6_GLOBAL.txt
  • Yes, iperf has option for v4 and v6. By force, I mean disable v6 through sysconf, and re enable after test. But that's a very bad idea.
    I see, a good idea
    I use precedence ::ffff:0:0/96 100 before, which don't work
  • Crunchbits
    [LBLK] Big Storage VPS - 2TB Storage VPS
     Basic System Info
     CPU Cores          : 1 @ 2095.148 MHz
     AES-NI             : ✔ Enabled
     Total Disk         : 2.0 TB (5.9 GB Used)
     Total RAM          : 1.9 GB (840.9 MB Used)
     System uptime      : 0 days, 1 hour 35 min
     Load average       : 1.26, 0.89, 0.50
     Kernel             : 6.1.0-9-amd64
     Basic Network Info
     Speedtest.net (Region: INDONESIA)
     ISP: Redoubt-net
     Nearest          0.20 ms     0.0%    933.16 Mbps    987.16 Mbps    Crunchbits - Spokane, WA
     Jakarta          326.70 ms   0.0%    914.82 Mbps    108.78 Mbps    Hutchison 3 Indonesia  CGK-MM - Jakarta
     Jakarta          218.88 ms   0.0%    699.86 Mbps    42.50 Mbps     DomaiNesia - Jakarta
     Jakarta          228.43 ms   0.0%    608.63 Mbps    91.64 Mbps     PT. Telekomunikasi Indonesia - Jakarta
     Jakarta          357.59 ms   0.7%    422.45 Mbps    63.84 Mbps     PT Indosat Tbk - Jakarta
     Jakarta          212.87 ms   0.0%    554.68 Mbps    411.81 Mbps    MyRepublic Indonesia - South Jakarta
     Bandung          228.31 ms   N/A     183.55 Mbps    44.97 Mbps     HYPERNET - Bandung
     Bekasi           FAILED
     Bogor            203.01 ms   0.0%    921.93 Mbps    218.93 Mbps    PT. Java Digital Nusantara - Bogor
     Malang           218.69 ms   0.0%    238.29 Mbps    78.63 Mbps     GlobalXtreme - Malang
     Semarang         200.44 ms   N/A     787.80 Mbps    330.71 Mbps    PT. Indonesia Comnets Plus - Semarang
     Surabaya         224.13 ms   N/A     859.58 Mbps    415.17 Mbps    PT. Indonesia Comnets Plus - Surabaya
     Yogyakarta       294.00 ms   1.0%    672.83 Mbps    68.98 Mbps     PT Union Routelink Communication - Yogyakarta
     Banda Aceh       231.38 ms   0.0%    473.41 Mbps    383.72 Mbps    PT. Telekomunikasi Indonesia - Banda Aceh
     Medan            221.59 ms   0.0%    755.42 Mbps    398.99 Mbps    Biznet Networks - Medan
     Palembang        221.81 ms   N/A     896.05 Mbps    58.91 Mbps     PT. Sakti Putra Mandiri - Palembang
     Pekanbaru        217.31 ms   0.0%    20.59 Mbps     28.84 Mbps     PT Hexa Media Sarana - Pekanbaru
     Bali             239.59 ms   0.0%    631.11 Mbps    371.63 Mbps    Biznet Networks - Bali
     Makassar         247.29 ms   0.0%    230.74 Mbps    95.79 Mbps     Biznet Networks - Makassar
     Depok            239.80 ms   0.8%    435.00 Mbps    172.57 Mbps    ADI - Depok
     Tangerang        210.49 ms   0.0%    871.67 Mbps    48.24 Mbps     PT. Java Medianet Tekhnologi - Tangerang
     Avg DL Speed       : 605.58 Mbps
     Avg UL Speed       : 221.09 Mbps
     Total DL Data      : 16.25 GB
     Total UL Data      : 6.31 GB
     Total Data         : 22.56 GB
     Duration           : 11 min 6 sec
     System Time        : 25/11/2023 - 12:04:24 WIB
     Total Script Runs  : 28145
     Result             : https://result.network-speed.xyz/r/1700888053_ORAWKA_INDONESIA.txt
  • VirMach mystery box Germany
     Basic System Info
     CPU Model          : AMD Ryzen 9 5900X 12-Core Processor
     CPU Cores          : 2 @ 3693.060 MHz
     CPU Cache          : 512 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 48.6 GB (1.4 GB Used)
     Total RAM          : 1.9 GB (54.1 MB Used)
     Total Swap         : 512.0 MB (3.4 MB Used)
     System uptime      : 0 days, 0 hour 21 min
     Load average       : 0.02, 0.31, 0.23
     Kernel             : 5.10.0-26-amd64
     Basic Network Info
     ISP                : xTom GmbH
     ASN                : AS3214 xTom GmbH
     Host               : xTom Customer - Frankfurt
     ISP: xTom
     Nearest          0.69 ms     N/A     936.96 Mbps    1874.37 Mbps   Netprotect - Frankfurt
     Kochi, IN        177.45 ms   0.0%    1038.12 Mbps   489.33 Mbps    Asianet Broadband - Cochin
     Bangalore, IN    130.20 ms   0.0%    1025.78 Mbps   628.96 Mbps    Bharti Airtel Ltd - Bangalore
     Chennai, IN      163.61 ms   N/A     1005.71 Mbps   602.93 Mbps    Jio - Chennai
     Mumbai, IN       157.54 ms   0.0%    1247.01 Mbps   434.72 Mbps    i3D.net - Mumbai
     Delhi, IN        172.70 ms   0.0%    1177.77 Mbps   489.98 Mbps    Tata Teleservices Ltd - New Delhi
     Seattle, US      151.09 ms   N/A     977.39 Mbps    580.86 Mbps    Comcast - Seattle, WA
     Los Angeles, US  138.28 ms   0.0%    1107.43 Mbps   601.16 Mbps    ReliableSite Hosting - Los Angeles, CA
     Dallas, US       113.84 ms   0.0%    1113.40 Mbps   771.27 Mbps    Hivelocity - Dallas, TX
     Miami, US        116.77 ms   0.0%    1027.95 Mbps   753.64 Mbps    AT&T - Miami, FL
     New York, US     79.74 ms    0.0%    1668.15 Mbps   1067.57 Mbps   GSL Networks - New York, NY
     Toronto, CA      87.75 ms    0.0%    1140.40 Mbps   963.18 Mbps    Rogers - Toronto, ON
     London, UK       13.96 ms    0.0%    1826.35 Mbps   1789.25 Mbps   VeloxServ Communications - London
     Amsterdam, NL    8.07 ms     0.0%    940.01 Mbps    1850.50 Mbps   31173 Services AB - Amsterdam
     Paris, FR        11.25 ms    N/A     940.75 Mbps    1818.12 Mbps   Axione - Paris
     Frankfurt, DE    1.18 ms     0.0%    1826.04 Mbps   1816.06 Mbps   23M GmbH - Frankfurt am Main
     Warsaw, PL       20.56 ms    0.0%    1517.71 Mbps   1749.90 Mbps   PLAY - Warszawa
     Bucharest, RO    28.05 ms    0.0%    1479.87 Mbps   1616.59 Mbps   Vodafone Romania Fixed – Bucharest - Bucharest
     Jeddah, SA       81.50 ms    0.0%    1783.36 Mbps   1018.26 Mbps   Saudi Telecom Company
     Dubai, AE        138.47 ms   0.0%    1471.07 Mbps   563.40 Mbps    du - Dubai
     Fujairah, AE     107.79 ms   0.0%    1401.25 Mbps   754.28 Mbps    ETISALAT-UAE - Fujairah
     Tokyo, JP        246.03 ms   N/A     841.42 Mbps    285.75 Mbps    fdcservers.net - Tokyo
     Shanghai, CU-CN  156.27 ms   4.0%    905.22 Mbps    397.23 Mbps    China Unicom 5G - Shanghai
     Nanjing, CT-CN   226.98 ms   0.0%    1136.13 Mbps   49.42 Mbps     China Telecom JiangSu 5G - Nanjing
     Hong Kong, CN    243.82 ms   N/A     826.24 Mbps    389.24 Mbps    STC - Hong Kong
     Singapore, SG    150.25 ms   0.0%    1142.97 Mbps   416.39 Mbps    i3D.net - Singapore
     Jakarta, ID      161.71 ms   0.0%    1059.02 Mbps   286.11 Mbps    PT. Telekomunikasi Indonesia - Jakarta
     Avg DL Speed       : 1206.05 Mbps
     Avg UL Speed       : 891.06 Mbps
     Total DL Data      : 46.42 GB
     Total UL Data      : 28.12 GB
     Total Data         : 74.53 GB
     Duration           : 12 min 45 sec
     System Time        : 27/11/2023 - 22:25:42 EST
     Total Script Runs  : 28472
     Result             : https://result.network-speed.xyz/r/1701141299_ZTN9Z3_GLOBAL.txt
    The Kernel seems not the TCP control
    And can you support single threading instead of multithreading? Single threading via cubic can better reflect network conditions
  • v6node - 15 EUR/yr Flash Sale
     Basic System Info
     CPU Model          : AMD EPYC 7542 32-Core Processor
     CPU Cores          : 1 @ 2899.998 MHz
     CPU Cache          : 512 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 19.6 GB (965.7 MB Used)
     Total RAM          : 1.9 GB (246.6 MB Used)
     System uptime      : 1 days, 20 hour 48 min
     Kernel             : 6.1.0-13-cloud-amd64
     Basic Network Info
     ISP                : Ian David Klemm
     ASN                : AS200461 Ian David Klemm
     Host               : Ian David Klemm
     Location (IPv4)    : Frankfurt am Main, Hesse, DE
     ISP: The Mastermind Holding
     Nearest          7.78 ms     0.0%    6386.40 Mbps   4646.83 Mbps   WorldStream B.V. - Naaldwijk
     London, UK       12.20 ms    0.0%    6557.74 Mbps   3481.12 Mbps   M247 Ltd - London
     Manchester, UK   20.11 ms    N/A     6421.34 Mbps   1914.03 Mbps   Vodafone UK - Manchester
     Dublin, IE       33.77 ms    0.0%    5567.48 Mbps   1573.46 Mbps   Three Ireland - Dublin
     Amsterdam, NL    6.75 ms     0.0%    6252.88 Mbps   4619.97 Mbps   Melbicom - Amsterdam
     Eygelshoen, NL   7.85 ms     0.0%    5884.21 Mbps   2089.94 Mbps   SkyLink Data Center BV - Eygelshoven
     Paris, FR        10.68 ms    0.0%    4946.27 Mbps   3523.94 Mbps   ORANGE - Paris
     Marseille, FR    16.23 ms    0.0%    6265.99 Mbps   2024.07 Mbps   GSL Networks - Marseille
     Madrid, ES       28.77 ms    0.4%    5948.33 Mbps   1609.65 Mbps   Orange - Jazztel - Madrid
     Barcelona, ES    30.23 ms    0.0%    6207.30 Mbps   1168.46 Mbps   Adamo - Barcelona
     Lisbon, PT       34.43 ms    0.0%    6163.97 Mbps   1363.45 Mbps   Edgoo Networks - Lisbon
     Rome, IT         20.46 ms    0.0%    6053.90 Mbps   1637.04 Mbps   TIM SpA - Rome
     Milan, IT        10.67 ms    0.0%    6332.83 Mbps   3497.70 Mbps   Fastweb SpA - Milan
     Zurich, CH       7.77 ms     0.0%    6482.24 Mbps   4013.38 Mbps   Sunrise Communication AG - Zurich
     Frankfurt, DE    0.96 ms     0.0%    6293.74 Mbps   7659.50 Mbps   23M GmbH - Frankfurt am Main
     Berlin, DE       11.43 ms    N/A     6213.65 Mbps   1197.40 Mbps   Misaka Network, Inc. - Berlin
     Vienna, AT       13.83 ms    0.0%    6412.65 Mbps   2268.05 Mbps   A1 Telekom Austria AG - Vienna
     Budapest, HU     14.25 ms    0.0%    6529.54 Mbps   2477.05 Mbps   ATW Internet Kft. - Budapest
     Gdansk, PL       19.84 ms    0.0%    3656.96 Mbps   1848.68 Mbps   T-Mobile Polska S.A. - Gdańsk
     Warsaw, PL       20.49 ms    0.0%    6214.56 Mbps   2079.23 Mbps   Orange Polska S.A. - Warsaw
     Lviv, UA         26.22 ms    0.0%    6289.73 Mbps   1580.40 Mbps   Kyivstar - Lviv
     Kyiv, UA         28.44 ms    0.0%    6458.71 Mbps   854.76 Mbps    o3 - Kyiv
     Minsk, BY        34.43 ms    0.0%    5679.56 Mbps   1303.58 Mbps   A1 - Minsk
     Bucharest, RO    30.36 ms    0.0%    6399.74 Mbps   1351.33 Mbps   Orange Romania Communications - Bucharest
     Iasi, RO         30.95 ms    0.0%    6144.68 Mbps   1342.97 Mbps   Digi
     Helsinki, FI     29.84 ms    0.0%    6467.58 Mbps   1169.65 Mbps   Elisa Oyj - Helsinki
     Stockholm, SE    29.00 ms    0.0%    6140.52 Mbps   1313.16 Mbps   i3D.net - Stockholm
     Oslo, NO         26.58 ms    0.0%    6114.50 Mbps   1396.16 Mbps   Speedtest.net - Oslo
     Moscow, RU       36.33 ms    0.0%    6326.55 Mbps   1538.74 Mbps   Rostelecom - Moscow
     Petersburg, RU   31.44 ms    0.0%    4170.82 Mbps   1108.02 Mbps   MTS OJSC - Saint Petersburg
     Istanbul, TR     43.35 ms    0.0%    6413.62 Mbps   1450.74 Mbps   Turkcell - Istanbul
     Tbilisi, GE      62.66 ms    N/A     5992.72 Mbps   893.74 Mbps    Silknet JSC - Tbilisi
     Avg DL Speed       : 6043.59 Mbps
     Avg UL Speed       : 2187.38 Mbps
     Total DL Data      : 244.20 GB
     Total UL Data      : 85.84 GB
     Total Data         : 330.04 GB
     Duration           : 12 min 46 sec
     System Time        : 30/11/2023 - 13:11:08 UTC
     Total Script Runs  : 28705
     Result             : https://result.network-speed.xyz/r/1701349205_8Q2S1I_EU.txt
    Thanked by (1)iandk
    Nope, as I said what happens inside the speedtest-cli can't be controlled by me.
  • Updated to v2023.12.01
    * Updated broken servers, add new locations
    * Add TCP Congestion Control Info
     Version            : v2023.12.01
     Basic System Info
     CPU Model          : Intel(R) Xeon(R) CPU E5-2630 v4 @ 2.20GHz
     CPU Cores          : 2 @ 2199.996 MHz
     AES-NI             : ✔ Enabled
     Total Disk         : 26.5 GB (1.6 GB Used)
     Total RAM          : 1.9 GB (232.3 MB Used)
     Total Swap         : 1024.0 MB (268.0 KB Used)
     System uptime      : 2 days, 4 hour 47 min
     TCP Control        : cubic
     Basic Network Info
     ISP                : velia.net Internetdienste GmbH
     ASN                : AS29066 velia.net Internetdienste GmbH
     Host               : RackNerd, LLC
     ISP: velia.net Internetdienste
     Nearest          6.76 ms     0.0%    769.49 Mbps    868.56 Mbps    Frachtwerk GmbH - Karlsruhe
     Kochi, IN        189.76 ms   0.0%    441.25 Mbps    435.14 Mbps    Asianet Broadband - Cochin
     Bangalore, IN    182.35 ms   0.5%    484.92 Mbps    534.99 Mbps    Bharti Airtel Ltd - Bangalore
     Chennai, IN      145.04 ms   N/A     446.86 Mbps    549.74 Mbps    Jio - Chennai
     Mumbai, IN       155.94 ms   0.0%    403.81 Mbps    330.95 Mbps    i3D.net - Mumbai
     Delhi, IN        170.56 ms   0.0%    530.51 Mbps    514.70 Mbps    Tata Play Fiber - New Delhi
     Seattle, US      154.27 ms   N/A     449.39 Mbps    509.32 Mbps    Comcast - Seattle, WA
     Los Angeles, US  142.68 ms   0.0%    442.40 Mbps    514.33 Mbps    ReliableSite Hosting - Los Angeles, CA
     Dallas, US       119.81 ms   0.0%    615.17 Mbps    662.90 Mbps    Hivelocity - Dallas, TX
     Miami, US        116.91 ms   0.0%    602.89 Mbps    676.18 Mbps    AT&T - Miami, FL
     New York, US     81.90 ms    0.0%    927.27 Mbps    728.71 Mbps    GSL Networks - New York, NY
     Toronto, CA      93.25 ms    0.0%    532.33 Mbps    669.10 Mbps    Rogers - Toronto, ON
     London, UK       20.55 ms    0.0%    903.53 Mbps    831.55 Mbps    VeloxServ Communications - London
     Amsterdam, NL    10.07 ms    0.0%    906.27 Mbps    844.53 Mbps    31173 Services AB - Amsterdam
     Paris, FR        13.02 ms    N/A     901.93 Mbps    808.83 Mbps    Axione - Paris
     Frankfurt, DE    3.77 ms     0.0%    812.38 Mbps    831.58 Mbps    23M GmbH - Frankfurt am Main
     Warsaw, PL       21.45 ms    0.0%    905.61 Mbps    819.21 Mbps    Play - Warszawa
     Bucharest, RO    29.68 ms    0.0%    506.89 Mbps    334.64 Mbps    Vodafone Romania Fixed – Bucharest - Bucharest
     Moscow, RU       35.36 ms    0.0%    863.26 Mbps    699.03 Mbps    MegaFon - Moscow
     Jeddah, SA       84.33 ms    0.0%    923.63 Mbps    626.14 Mbps    Saudi Telecom Company
     Dubai, AE        126.92 ms   0.0%    765.39 Mbps    634.13 Mbps    du - Dubai
     Fujairah, AE     112.61 ms   0.0%    914.24 Mbps    681.98 Mbps    ETISALAT-UAE - Fujairah
     Tehran, IR       92.92 ms    N/A     575.44 Mbps    377.36 Mbps    Asiatech - Tehran
     Cairo, EG        54.58 ms    0.0%    597.59 Mbps    765.98 Mbps    Vodafone Egypt - Cairo
     Tokyo, JP        247.98 ms   N/A     588.62 Mbps    358.81 Mbps    fdcservers.net - Tokyo
     Shanghai, CU-CN  165.63 ms   0.0%    503.65 Mbps    414.50 Mbps    China Unicom 5G - Shanghai
     Nanjing, CT-CN   175.44 ms   0.0%    526.82 Mbps    190.64 Mbps    China Telecom JiangSu 5G - Nanjing
     Hong Kong, CN    234.10 ms   N/A     417.41 Mbps    360.46 Mbps    STC - Hong Kong
     Singapore, SG    153.29 ms   0.0%    419.52 Mbps    554.89 Mbps    i3D.net - Singapore
     Jakarta, ID      189.76 ms   1.3%    439.92 Mbps    97.47 Mbps     PT. Telekomunikasi Indonesia - Jakarta
     Avg DL Speed       : 637.28 Mbps
     Avg UL Speed       : 574.21 Mbps
     Total DL Data      : 26.58 GB
     Total UL Data      : 23.08 GB
     Total Data         : 49.66 GB
     Duration           : 14 min 40 sec
     System Time        : 01/12/2023 - 10:24:47 EST
     Total Script Runs  : 28773
     Result             : https://result.network-speed.xyz/r/1701443613_JBMRKA_GLOBAL.txt
