Ping Testing in Web Browsers
I was scheming on a Hetzner setup, and I wanted to poke around to check speeds from here to their various datacenters. I found this site useful:
https://cloudpingtest.com/
I really wish this one had some Hetzner love: https://www.cloudping.info/
I like its simplicity. It has his GitHub link if you want to fork his code...
This one seemed to only have some of the larger operators: https://webping.cloud/
Any you recommend?
ping.sx is a good one
edit: misread
https://www.meter.net/tools/world-ping-test/
I use ping.pe
he wants to check ping from host rather than to host, idk if ping.pe does that
mtr.tools is another good option
Check our KVM VPS plans in π΅π± Warsaw, Poland and πΈπͺ Stockholm, Sweden
I personally have used @Neoon 's https://github.com/Ne00n/Multi-Ping
Some list are now getting weekly updated.
I put my 6$/y Crunchbits to use.
However, most of the stuff is still static.
The crawler is broken beyond repair and has a memory leak.
I have to rewrite them at some point.
ping.pw
solely from greencloud
Vultr's looking glass
