hostEONS - Ryzen 7950x VDS/Hybrid Dedi - $7 - 1 vCore / 4 GB RAM / 50 GB NVME / 15TB / 10G Port
hostEONShostEONS Hosting ProviderOG
Here we are with with much demanded VDS based on Ryzen 7950X CPU
This is a VDS with dedicated CPU vCores:
Dedicated 1 vCore (Ryzen 7950x 4.5 Ghz)
4 GB RAM
25 GB NVME - 50 GB NVME
15 TB Transfer
10 Gbps (Shared Port)
1 IPv4
/64 IPv6
Linux and Windows Supported
Custom ISO Support
VPS Control Panel
Backup Optional - Monthly Backup
RDNS
Just $7/mo
Order link: https://my.hosteons.com/store/ryzen-7950x-based-hybrid-dedicated-server
If you need higher specs, no worries, just check the above link we have VDS available with upto 5 Cores and 20GB RAM, if you need even more resources, let us know, will add more packages.
To get your disk space upgraded to 50 GB and also get free monthly backup just mention your invoice number in comments
Looking Glass: https://lg.slc2.hosteons.com
Yet-Another-Bench-Script
v2023-09-06
Mon Oct 16 00:10:51 EDT 2023
Uptime : 0 days, 0 hours, 0 minutes
Processor : AMD Ryzen 9 7950X 16-Core Processor
CPU cores : 2 @ 4499.952 MHz
AES-NI : ✔ Enabled
RAM : 7.8 GiB
Swap : 1024.0 MiB
Disk : 48.1 GiB
Distro : Debian GNU/Linux 11 (bullseye)
Kernel : 5.10.0-23-amd64
VM Type : KVM
ISP : Hosteons Pte. Ltd.
ASN : AS142036 Hosteons Pte. Ltd.
Host : Hosteons Pte. Ltd
Country : United States
Read 730.51 MB/s (182.6k) 1.88 GB/s (29.3k)
Write 732.44 MB/s (183.1k) 1.89 GB/s (29.5k)
Total 1.46 GB/s (365.7k) 3.77 GB/s (58.9k)
Read 1.76 GB/s (3.4k) 2.31 GB/s (2.2k)
Write 1.85 GB/s (3.6k) 2.46 GB/s (2.4k)
Total 3.62 GB/s (7.0k) 4.78 GB/s (4.6k)
Provider Location (Link) Send Speed Recv Speed Ping
Clouvider London, UK (10G) 149 Mbits/sec busy 138 ms
Scaleway Paris, FR (10G) busy 1.23 Gbits/sec 147 ms
NovoServe North Holland, NL (40G) 681 Mbits/sec 604 Mbits/sec --
Uztelecom Tashkent, UZ (10G) 460 Mbits/sec 46.9 Mbits/sec 213 ms
Clouvider NYC, NY, US (10G) 3.05 Gbits/sec 3.46 Gbits/sec 50.9 ms
Clouvider Dallas, TX, US (10G) 1.21 Gbits/sec 1.27 Gbits/sec 31.1 ms
Clouvider Los Angeles, CA, US (10G) 3.19 Gbits/sec 6.09 Gbits/sec 26.1 ms
Clouvider London, UK (10G) 1.49 Gbits/sec 1.59 Gbits/sec 115 ms
Scaleway Paris, FR (10G) 1.41 Gbits/sec 881 Mbits/sec 130 ms
NovoServe North Holland, NL (40G) 3.23 Mbits/sec 409 Mbits/sec 228 ms
Uztelecom Tashkent, UZ (10G) 871 Mbits/sec 44.4 Mbits/sec 213 ms
Clouvider NYC, NY, US (10G) 3.64 Gbits/sec 3.84 Gbits/sec 49.4 ms
Clouvider Dallas, TX, US (10G) 6.14 Gbits/sec 5.55 Gbits/sec 31.0 ms
Clouvider Los Angeles, CA, US (10G) 7.22 Gbits/sec 5.72 Gbits/sec 26.0 ms
Test | Value
Single Core | 3008
Multi Core | 5359
Full Test | https://browser.geekbench.com/v6/cpu/3103745
YABS completed in 12 min 2 sec
---------------------------- network-speed.xyz ----------------------------
A simple script to test network performance using speedtest-cli
Version : v2023.09.30
Global Speedtest : wget -qO- network-speed.xyz | bash
Region Speedtest : wget -qO- network-speed.xyz | bash -s -- -r
Basic System Info
CPU Model : AMD Ryzen 9 7950X 16-Core Processor
CPU Cores : 2 @ 4499.952 MHz
CPU Cache : 1024 KB
AES-NI : ✔ Enabled
Total Disk : 48.1 GB (1.5 GB Used)
Total RAM : 7.8 GB (75.3 MB Used)
Total Swap : 1024.0 MB (0 Used)
System uptime : 0 days, 0 hour 13 min
Load average : 0.20, 0.34, 0.17
OS : Debian GNU/Linux 11
Arch : x86_64 (64 Bit)
Virtualization : KVM
Basic Network Info
IPv6 Access : ✔ Online
IPv4 Access : ✔ Online
Location (IPv4) : Los Angeles, California, US
Location Latency Loss DL Speed UP Speed Server
ISP: Hosteons
Nearest 0.96 ms 0.0% 6121.09 Mbps 6664.12 Mbps Sumo Fiber - Salt Lake City, UT
Kochi, IN 261.80 ms 0.0% 3159.69 Mbps 359.04 Mbps Asianet Broadband - Cochin
Bangalore, IN 241.18 ms N/A 3170.90 Mbps 287.47 Mbps Bharti Airtel Ltd - Bangalore
Chennai, IN 241.00 ms N/A 2735.69 Mbps 35.65 Mbps Jio - Chennai
Mumbai, IN 267.83 ms 0.0% 2933.11 Mbps 254.06 Mbps i3D.net - Mumbai
Delhi, IN 279.48 ms 0.0% 2104.80 Mbps 302.07 Mbps Tata Teleservices Ltd - New Delhi
Seattle, US FAILED
Los Angeles, US 41.37 ms 0.0% 3837.98 Mbps 1234.36 Mbps ReliableSite Hosting - Los Angeles, CA
Dallas, US 32.09 ms 0.0% 6405.22 Mbps 2808.81 Mbps Hivelocity - Dallas, TX
Miami, US 67.69 ms 0.0% 6663.37 Mbps 1349.94 Mbps AT&T - Miami, FL
New York, US 59.21 ms 0.0% 6455.51 Mbps 1621.97 Mbps GSL Networks - New York, NY
Toronto, CA 43.53 ms 0.0% 6609.66 Mbps 2027.69 Mbps Rogers - Toronto, ON
London, UK 122.55 ms 0.0% 6196.83 Mbps 796.35 Mbps VeloxServ Communications - London
Amsterdam, NL FAILED
Paris, FR FAILED
Frankfurt, DE 134.82 ms 0.0% 5583.32 Mbps 677.74 Mbps 23M GmbH - Frankfurt am Main
Warsaw, PL FAILED
Bucharest, RO 172.89 ms 0.0% 4629.94 Mbps 534.31 Mbps Vodafone Romania Fixed – Bucharest - Bucharest
Jeddah, SA 179.09 ms N/A 4045.95 Mbps 480.28 Mbps Saudi Telecom Company
Dubai, AE 242.68 ms 0.0% 3313.38 Mbps 404.40 Mbps du - Dubai
Fujairah, AE 247.61 ms 0.0% 3179.02 Mbps 383.92 Mbps ETISALAT-UAE - Fujairah
Tokyo, JP 122.46 ms N/A 927.01 Mbps 734.03 Mbps fdcservers.net - Tokyo
Shanghai, CU-CN 168.54 ms 0.0% 4686.96 Mbps 563.88 Mbps China Unicom 5G - Shanghai
Nanjing, CT-CN 194.37 ms 0.0% 1756.80 Mbps 146.84 Mbps China Telecom JiangSu 5G - Nanjing
Hong Kong, CN 153.66 ms N/A 5155.07 Mbps 597.13 Mbps STC - Hong Kong
Singapore, SG 189.29 ms 0.0% 4203.68 Mbps 498.54 Mbps i3D.net - Singapore
Jakarta, ID 204.17 ms 0.0% 3782.32 Mbps 235.05 Mbps PT. Telekomunikasi Indonesia - Jakarta
Avg DL Speed : 4245.97 Mbps
Avg UL Speed : 999.89 Mbps
Total DL Data : 130.70 GB
Total UL Data : 27.87 GB
Total Data : 158.57 GB
Duration : 11 min 59 sec
System Time : 16/10/2023 - 00:35:48 EDT
Total Script Runs : 25327
Result : https://result.network-speed.xyz/r/1697430678_JLYRSU_GLOBAL.txt
hostEONS.com - 9 Locations for VPS (US and EU).. Free Blesta License, Free Windows 2019 License and more. Shared DA Hosting. AS142036 .. Ryzen 7950X Based VDS in SLC, LA and Dallas
Thanked by (1)Decicus
  • hostEONShostEONS Hosting ProviderOG
    7950x VDS Now launched even in LA and Dallas, YABS for Dallas VDS:
    v2023-11-30
    Mon 04 Dec 2023 08:54:48 AM EST
    Uptime : 0 days, 0 hours, 1 minutes
    CPU cores : 2 @ 4491.560 MHz
    AES-NI : ‚úî Enabled
    VM-x/AMD-V : ‚úî Enabled
    RAM : 7.8 GiB
    Swap : 1024.0 MiB
    Disk : 48.1 GiB
    VM Type : KVM
    IPv4/IPv6 : ‚úî Online / ‚úî Online
    Read 745.59 MB/s (186.3k) 4.71 GB/s (73.6k)
    Write 747.56 MB/s (186.8k) 4.73 GB/s (73.9k)
    Total 1.49 GB/s (373.2k) 9.44 GB/s (147.6k)
    Read 5.64 GB/s (11.0k) 5.44 GB/s (5.3k)
    Write 5.94 GB/s (11.6k) 5.80 GB/s (5.6k)
    Total 11.58 GB/s (22.6k) 11.24 GB/s (10.9k)
    Clouvider London, UK (10G) 1.41 Gbits/sec 1.45 Gbits/sec 104 ms
    Scaleway Paris, FR (10G) busy busy 112 ms
    NovoServe North Holland, NL (40G) 1.57 Gbits/sec 174 Mbits/sec 107 ms
    Uztelecom Tashkent, UZ (10G) 222 Mbits/sec 221 Mbits/sec 202 ms
    Clouvider NYC, NY, US (10G) 3.94 Gbits/sec 4.40 Gbits/sec 36.2 ms
    Clouvider Dallas, TX, US (10G) 1.36 Gbits/sec 1.26 Gbits/sec 2.04 ms
    Clouvider Los Angeles, CA, US (10G) 3.01 Gbits/sec 4.83 Gbits/sec 36.9 ms
    Clouvider London, UK (10G) 1.68 Gbits/sec 1.48 Gbits/sec 104 ms
    Scaleway Paris, FR (10G) 1.81 Gbits/sec busy 109 ms
    NovoServe North Holland, NL (40G) 1.64 Gbits/sec 376 Mbits/sec 107 ms
    Uztelecom Tashkent, UZ (10G) 387 Mbits/sec 657 Mbits/sec 202 ms
    Clouvider NYC, NY, US (10G) 4.65 Gbits/sec 2.16 Gbits/sec 35.8 ms
    Clouvider Dallas, TX, US (10G) 9.22 Gbits/sec 9.14 Gbits/sec 0.673 ms
    Clouvider Los Angeles, CA, US (10G) 4.55 Gbits/sec 4.73 Gbits/sec 36.8 ms
    Test | Value
    Single Core | 3036
    Multi Core | 5416
    Full Test | https://browser.geekbench.com/v6/cpu/3849259
    YABS completed in 12 min 44 sec
    Network Speedtests for Dallas:
    Version : v2023.12.01
    Basic System Info
    CPU Cores : 2 @ 4491.560 MHz
    CPU Cache : 1024 KB
    Total RAM : 7.8 GB (74.0 MB Used)
    System uptime : 0 days, 0 hour 14 min
    Load average : 0.28, 0.35, 0.16
    TCP Control : cubic
    Basic Network Info
    Primary Network : IPv6
    IPv6 Access : ‚úî Online
    IPv4 Access : ‚úî Online
    ISP: Hosteons.com
    Nearest 0.27 ms 0.0% 9107.54 Mbps 9283.93 Mbps Frontier - Dallas, TX
    Kochi, IN 269.49 ms 0.0% 2806.41 Mbps 164.13 Mbps Asianet Broadband - Cochin
    Bangalore, IN 246.45 ms 0.0% 2551.12 Mbps 180.02 Mbps Bharti Airtel Ltd - Bangalore
    Chennai, IN 255.18 ms N/A 2293.43 Mbps 387.46 Mbps Jio - Chennai
    Mumbai, IN 266.72 ms 0.0% 1880.14 Mbps 227.82 Mbps i3D.net - Mumbai
    Delhi, IN 263.34 ms 0.0% 2972.32 Mbps 339.98 Mbps Tata Play Fiber - New Delhi
    Seattle, US 45.18 ms N/A 8815.06 Mbps 1605.88 Mbps Comcast - Seattle, WA
    Los Angeles, US 32.57 ms 0.0% 7923.70 Mbps 1726.48 Mbps ReliableSite Hosting - Los Angeles, CA
    Dallas, US 0.90 ms 0.0% 9075.67 Mbps 6049.63 Mbps Hivelocity - Dallas, TX
    Miami, US 36.46 ms 0.0% 5067.36 Mbps 1562.93 Mbps AT&T - Miami, FL
    New York, US 39.44 ms 0.0% 8153.29 Mbps 571.45 Mbps GSL Networks - New York, NY
    Toronto, CA 44.40 ms 0.0% 3797.76 Mbps 658.11 Mbps Rogers - Toronto, ON
    London, UK 101.72 ms 0.0% 7554.90 Mbps 711.86 Mbps VeloxServ Communications - London
    Amsterdam, NL 112.16 ms 0.0% 7033.07 Mbps 727.21 Mbps 31173 Services AB - Amsterdam
    Paris, FR 110.78 ms N/A 6935.11 Mbps 296.29 Mbps Axione - Paris
    Frankfurt, DE 113.82 ms 0.0% 4889.48 Mbps 334.35 Mbps 23M GmbH - Frankfurt am Main
    Warsaw, PL 122.58 ms 0.0% 6389.72 Mbps 815.93 Mbps Play - Warszawa
    Bucharest, RO 145.68 ms 0.0% 3775.34 Mbps 350.17 Mbps Vodafone Romania Fixed – Bucharest - Bucharest
    Moscow, RU 149.63 ms 0.0% 4555.81 Mbps 426.26 Mbps MegaFon - Moscow
    Jeddah, SA 161.82 ms 0.0% 4795.03 Mbps 597.27 Mbps Saudi Telecom Company
    Dubai, AE 235.71 ms 0.0% 3430.69 Mbps 246.49 Mbps du - Dubai
    Fujairah, AE 212.93 ms 0.0% 2434.18 Mbps 413.01 Mbps ETISALAT-UAE - Fujairah
    Tehran, IR 188.60 ms N/A 2141.12 Mbps 403.60 Mbps Asiatech - Tehran
    Cairo, EG 151.36 ms 0.0% 1891.07 Mbps 590.05 Mbps Vodafone Egypt - Cairo
    Tokyo, JP 140.11 ms N/A 4866.34 Mbps 0.69 Mbps fdcservers.net - Tokyo
    Shanghai, CU-CN 264.09 ms 3.7% 1947.85 Mbps 1.63 Mbps China Unicom 5G - Shanghai
    Nanjing, CT-CN 209.79 ms 0.0% 3771.12 Mbps 81.23 Mbps China Telecom JiangSu 5G - Nanjing
    Hong Kong, CN 169.01 ms N/A 4601.75 Mbps 522.56 Mbps STC - Hong Kong
    Singapore, SG 211.43 ms 0.0% 1970.93 Mbps 443.14 Mbps i3D.net - Singapore
    Jakarta, ID 217.11 ms 0.0% 3145.45 Mbps 94.17 Mbps PT. Telekomunikasi Indonesia - Jakarta
    Avg DL Speed : 4685.77 Mbps
    Avg UL Speed : 993.79 Mbps
    Total DL Data : 193.50 GB
    Total UL Data : 28.57 GB
    Total Data : 222.07 GB
    Duration : 15 min 14 sec
    System Time : 04/12/2023 - 09:23:23 EST
    Total Script Runs : 28969
    Result : https://result.network-speed.xyz/r/1701699103_EZFSLS_GLOBAL.txt
