ServerFactory NL-AMD EPYC™ S IPv6 ONLY VPS in Eygelshoven
sunny@ixp5:~$ curl -sL yabs.sh | bash -s -- -s "https://yabsdb.com/add" # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2023-11-30 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Sat Dec 2 15:15:31 UTC 2023 Basic System Information: --------------------------------- Uptime : 0 days, 12 hours, 54 minutes Processor : AMD EPYC 7452 32-Core Processor CPU cores : 2 @ 2349.998 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 7.7 GiB Swap : 512.0 MiB Disk : 199.8 GiB Distro : Debian GNU/Linux 12 (bookworm) Kernel : 6.1.0-13-amd64 VM Type : KVM IPv4/IPv6 : ❌ Offline / ✔ Online fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sda3): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 217.98 MB/s (54.4k) | 2.03 GB/s (31.7k) Write | 218.55 MB/s (54.6k) | 2.04 GB/s (31.9k) Total | 436.54 MB/s (109.1k) | 4.07 GB/s (63.6k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 3.71 GB/s (7.2k) | 5.17 GB/s (5.0k) Write | 3.91 GB/s (7.6k) | 5.52 GB/s (5.3k) Total | 7.62 GB/s (14.8k) | 10.69 GB/s (10.4k) iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 1.03 Gbits/sec | 982 Mbits/sec | 14.7 ms Scaleway | Paris, FR (10G) | 1.04 Gbits/sec | 984 Mbits/sec | 12.4 ms NovoServe | North Holland, NL (40G) | 1.04 Gbits/sec | 988 Mbits/sec | 4.16 ms Uztelecom | Tashkent, UZ (10G) | 835 Mbits/sec | 929 Mbits/sec | 95.5 ms Clouvider | NYC, NY, US (10G) | 831 Mbits/sec | 936 Mbits/sec | 84.9 ms Clouvider | Dallas, TX, US (10G) | 654 Mbits/sec | 900 Mbits/sec | 120 ms Clouvider | Los Angeles, CA, US (10G) | 579 Mbits/sec | 747 Mbits/sec | 153 ms Geekbench releases can only be downloaded over IPv4. FTP the Geekbench files and run manually. YABS completed in 3 min 11 sec View your YABS here https://yabsdb.com/yabs/joN3Qc4u
BuyVM 1GB in Luxembourg
sunny@ixp4:~$ curl -sL yabs.sh | bash -s -- -s "https://yabsdb.com/add" # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2023-11-30 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Sat Dec 2 15:14:06 UTC 2023 Basic System Information: --------------------------------- Uptime : 1 days, 21 hours, 52 minutes Processor : AMD Ryzen 9 5900X 12-Core Processor CPU cores : 1 @ 3693.060 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 960.6 MiB Swap : 512.0 MiB Disk : 19.9 GiB Distro : Debian GNU/Linux 12 (bookworm) Kernel : 6.1.0-13-amd64 VM Type : KVM IPv4/IPv6 : ✔ Online / ✔ Online IPv6 Network Information: --------------------------------- ISP : FranTech Solutions ASN : AS53667 FranTech Solutions Host : FranTech Solutions Location : Luxembourg, Luxembourg (LU) Country : Luxembourg fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda1): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 285.80 MB/s (71.4k) | 992.71 MB/s (15.5k) Write | 286.56 MB/s (71.6k) | 997.93 MB/s (15.5k) Total | 572.36 MB/s (143.0k) | 1.99 GB/s (31.1k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.07 GB/s (2.0k) | 1.05 GB/s (1.0k) Write | 1.12 GB/s (2.2k) | 1.12 GB/s (1.1k) Total | 2.20 GB/s (4.2k) | 2.18 GB/s (2.1k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 1.10 Gbits/sec | 960 Mbits/sec | 14.1 ms Scaleway | Paris, FR (10G) | 1.11 Gbits/sec | 865 Mbits/sec | 10.6 ms NovoServe | North Holland, NL (40G) | 1.11 Gbits/sec | 971 Mbits/sec | 8.20 ms Uztelecom | Tashkent, UZ (10G) | 1.03 Gbits/sec | 423 Mbits/sec | 98.1 ms Clouvider | NYC, NY, US (10G) | 1.05 Gbits/sec | 271 Mbits/sec | 81.3 ms Clouvider | Dallas, TX, US (10G) | 469 Mbits/sec | 164 Mbits/sec | 122 ms Clouvider | Los Angeles, CA, US (10G) | 744 Mbits/sec | 336 Mbits/sec | 151 ms iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 1.10 Gbits/sec | 939 Mbits/sec | 14.1 ms Scaleway | Paris, FR (10G) | 1.10 Gbits/sec | 950 Mbits/sec | 10.2 ms NovoServe | North Holland, NL (40G) | 1.10 Gbits/sec | 960 Mbits/sec | 8.20 ms Uztelecom | Tashkent, UZ (10G) | 1.04 Gbits/sec | 420 Mbits/sec | 97.9 ms Clouvider | NYC, NY, US (10G) | 1.05 Gbits/sec | 144 Mbits/sec | 81.2 ms Clouvider | Dallas, TX, US (10G) | 935 Mbits/sec | 343 Mbits/sec | 122 ms Clouvider | Los Angeles, CA, US (10G) | 729 Mbits/sec | 350 Mbits/sec | 151 ms Geekbench test failed and low memory was detected. Add at least 1GB of SWAP or use GB4 instead (higher compatibility with low memory systems). YABS completed in 10 min 41 sec View your YABS here https://yabsdb.com/yabs/8Vnpx99t
HostNamaste Black Friday & Cyber Monday Deals - 2.5GB KVM VPS - $24 per YEAR in Dallas
sunny@box3:~$ curl -sL yabs.sh | bash -s -- -s "https://yabsdb.com/add" # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2023-11-30 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Sat Dec 2 15:12:26 UTC 2023 Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 4 minutes Processor : QEMU Virtual CPU version 2.5+ CPU cores : 2 @ 2199.998 MHz AES-NI : ❌ Disabled VM-x/AMD-V : ❌ Disabled RAM : 2.4 GiB Swap : 512.0 MiB Disk : 39.9 GiB Distro : Debian GNU/Linux 12 (bookworm) Kernel : 6.1.0-13-amd64 VM Type : KVM IPv4/IPv6 : ✔ Online / ✔ Online IPv6 Network Information: --------------------------------- ISP : Limestone Networks, Inc. ASN : AS46475 Limestone Networks, Inc. Host : Limestone Networks, Inc. Location : Dallas, Texas (TX) Country : United States fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda1): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 129.40 MB/s (32.3k) | 599.84 MB/s (9.3k) Write | 129.74 MB/s (32.4k) | 602.99 MB/s (9.4k) Total | 259.14 MB/s (64.7k) | 1.20 GB/s (18.7k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.53 GB/s (3.0k) | 4.89 GB/s (4.7k) Write | 1.61 GB/s (3.1k) | 5.21 GB/s (5.0k) Total | 3.15 GB/s (6.1k) | 10.10 GB/s (9.8k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 1.17 Gbits/sec | 1.70 Gbits/sec | 105 ms Scaleway | Paris, FR (10G) | 1.87 Gbits/sec | 1.65 Gbits/sec | 114 ms NovoServe | North Holland, NL (40G) | 1.58 Gbits/sec | 1.62 Gbits/sec | 106 ms Uztelecom | Tashkent, UZ (10G) | 569 Mbits/sec | 648 Mbits/sec | 203 ms Clouvider | NYC, NY, US (10G) | 4.74 Gbits/sec | 4.87 Gbits/sec | 36.3 ms Clouvider | Dallas, TX, US (10G) | 838 Mbits/sec | 1.49 Gbits/sec | 1.05 ms Clouvider | Los Angeles, CA, US (10G) | 3.07 Gbits/sec | 5.89 Gbits/sec | 36.6 ms iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 1.73 Gbits/sec | 1.77 Gbits/sec | 101 ms Scaleway | Paris, FR (10G) | 1.93 Gbits/sec | 1.75 Gbits/sec | 108 ms NovoServe | North Holland, NL (40G) | 1.67 Gbits/sec | 1.69 Gbits/sec | 106 ms Uztelecom | Tashkent, UZ (10G) | 512 Mbits/sec | 822 Mbits/sec | 203 ms Clouvider | NYC, NY, US (10G) | 5.20 Gbits/sec | 5.33 Gbits/sec | 36.2 ms Clouvider | Dallas, TX, US (10G) | 9.27 Gbits/sec | 9.19 Gbits/sec | 0.954 ms Clouvider | Los Angeles, CA, US (10G) | 5.13 Gbits/sec | 5.19 Gbits/sec | 36.5 ms Geekbench 6 Benchmark Test: --------------------------------- Test | Value | Single Core | 465 Multi Core | 854 Full Test | https://browser.geekbench.com/v6/cpu/3822294 YABS completed in 24 min 59 sec View your YABS here https://yabsdb.com/yabs/Dzq2EMgg
Retslav €5 IPv4 NAT Port forwarding done in Virtfusion Panel which is a plus
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2023-11-30 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Sun Dec 3 07:29:44 AM +08 2023 Basic System Information: --------------------------------- Uptime : 0 days, 2 hours, 57 minutes Processor : Intel Core Processor (Broadwell, IBRS) CPU cores : 1 @ 2199.990 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 1.9 GiB Swap : 0.0 KiB Disk : 31.9 GiB Distro : Debian GNU/Linux 12 (bookworm) Kernel : 6.1.0-9-amd64 VM Type : KVM IPv4/IPv6 : ✔ Online / ❌ Offline IPv4 Network Information: --------------------------------- ISP : RoyaleHosting BV ASN : AS212477 RoyaleHosting BV Host : RoyaleHosting BV Location : Amsterdam, North Holland (NH) Country : The Netherlands fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda3): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 9.60 MB/s (2.4k) | 99.39 MB/s (1.5k) Write | 9.63 MB/s (2.4k) | 99.92 MB/s (1.5k) Total | 19.24 MB/s (4.8k) | 199.31 MB/s (3.1k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 256.61 MB/s (501) | 257.69 MB/s (251) Write | 270.24 MB/s (527) | 274.85 MB/s (268) Total | 526.85 MB/s (1.0k) | 532.54 MB/s (519) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 938 Mbits/sec | 175 Mbits/sec | 6.18 ms Scaleway | Paris, FR (10G) | 937 Mbits/sec | busy | 10.3 ms NovoServe | North Holland, NL (40G) | 941 Mbits/sec | 896 Mbits/sec | 1.05 ms Uztelecom | Tashkent, UZ (10G) | 619 Mbits/sec | 26.8 Mbits/sec | 234 ms Clouvider | NYC, NY, US (10G) | 809 Mbits/sec | 23.3 Mbits/sec | 75.5 ms Clouvider | Dallas, TX, US (10G) | 672 Mbits/sec | 14.7 Mbits/sec | 229 ms Clouvider | Los Angeles, CA, US (10G) | 631 Mbits/sec | 22.5 Mbits/sec | 129 ms Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 3360 Multi Core | 3017 Full Test | https://browser.geekbench.com/v4/cpu/17001411 YABS completed in 8 min 8 sec
Bruh, this is so crunchy. @crunchbits Crunchbits $42.75/yr VDS
# root @ Crunchy in ~ [13:35:14] C:1 $ curl -sL yabs.sh | bash # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2023-11-30 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Sun Dec 3 01:35:24 PM GMT 2023 Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 3 minutes Processor : Intel Xeon Processor (Skylake, IBRS) CPU cores : 8 @ 2194.842 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 19.5 GiB Swap : 0.0 KiB Disk : 991.9 GiB Distro : Debian GNU/Linux 12 (bookworm) Kernel : 6.6.4-x64v4-xanmod1 VM Type : KVM IPv4/IPv6 : ✔ Online / ✔ Online IPv6 Network Information: --------------------------------- ISP : Redoubt Networks ASN : AS400304 Redoubt Networks Host : Crunchbits LLC Location : Liberty Lake, Washington (WA) Country : United States fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sda3): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 125.48 MB/s (31.3k) | 989.42 MB/s (15.4k) Write | 125.81 MB/s (31.4k) | 994.63 MB/s (15.5k) Total | 251.30 MB/s (62.8k) | 1.98 GB/s (31.0k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.10 GB/s (2.1k) | 1.06 GB/s (1.0k) Write | 1.16 GB/s (2.2k) | 1.13 GB/s (1.1k) Total | 2.26 GB/s (4.4k) | 2.20 GB/s (2.1k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 1.35 Gbits/sec | 520 Mbits/sec | 128 ms Scaleway | Paris, FR (10G) | busy | busy | 226 ms NovoServe | North Holland, NL (40G) | 1.32 Gbits/sec | 1.22 Gbits/sec | 139 ms Uztelecom | Tashkent, UZ (10G) | 916 Mbits/sec | 653 Mbits/sec | 267 ms Clouvider | NYC, NY, US (10G) | 2.60 Gbits/sec | 733 Mbits/sec | 62.7 ms Clouvider | Dallas, TX, US (10G) | 755 Mbits/sec | 356 Mbits/sec | 67.1 ms Clouvider | Los Angeles, CA, US (10G) | 2.66 Gbits/sec | 1.84 Gbits/sec | 35.9 ms iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 1.35 Gbits/sec | 527 Mbits/sec | 128 ms Scaleway | Paris, FR (10G) | busy | busy | 132 ms NovoServe | North Holland, NL (40G) | 1.26 Gbits/sec | 1.17 Gbits/sec | 139 ms Uztelecom | Tashkent, UZ (10G) | 601 Mbits/sec | 1.12 Gbits/sec | 241 ms Clouvider | NYC, NY, US (10G) | 2.60 Gbits/sec | 910 Mbits/sec | 62.2 ms Clouvider | Dallas, TX, US (10G) | 2.59 Gbits/sec | 1.01 Gbits/sec | 67.0 ms Clouvider | Los Angeles, CA, US (10G) | 2.66 Gbits/sec | busy | 35.9 ms Geekbench 6 Benchmark Test: --------------------------------- Test | Value | Single Core | 1093 Multi Core | 5133 Full Test | https://browser.geekbench.com/v6/cpu/3836004 YABS completed in 16 min 3 sec
Crunchbits VDS $42.75 first year then $171/yr
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2023-11-30 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Sun Dec 3 08:00:26 AM PST 2023 Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 0 minutes Processor : Intel Xeon Processor (Skylake, IBRS) CPU cores : 8 @ 2194.842 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 19.5 GiB Swap : 0.0 KiB Disk : 991.9 GiB Distro : Debian GNU/Linux 12 (bookworm) Kernel : 6.1.0-13-amd64 VM Type : KVM IPv4/IPv6 : ✔ Online / ✔ Online IPv6 Network Information: --------------------------------- ISP : Redoubt Networks ASN : AS400304 Redoubt Networks Host : Crunchbits LLC Location : Liberty Lake, Washington (WA) Country : United States fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sdb3): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 132.18 MB/s (33.0k) | 849.91 MB/s (13.2k) Write | 132.53 MB/s (33.1k) | 854.39 MB/s (13.3k) Total | 264.72 MB/s (66.1k) | 1.70 GB/s (26.6k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.15 GB/s (2.2k) | 1.30 GB/s (1.2k) Write | 1.21 GB/s (2.3k) | 1.39 GB/s (1.3k) Total | 2.37 GB/s (4.6k) | 2.70 GB/s (2.6k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 1.33 Gbits/sec | 195 Mbits/sec | 127 ms Scaleway | Paris, FR (10G) | busy | busy | 220 ms NovoServe | North Holland, NL (40G) | 1.30 Gbits/sec | 151 Mbits/sec | 139 ms Uztelecom | Tashkent, UZ (10G) | busy | busy | 271 ms Clouvider | NYC, NY, US (10G) | 2.55 Gbits/sec | busy | 62.8 ms Clouvider | Dallas, TX, US (10G) | busy | busy | 71.8 ms Clouvider | Los Angeles, CA, US (10G) | 2.66 Gbits/sec | busy | 39.3 ms iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | busy | 139 Mbits/sec | 127 ms Scaleway | Paris, FR (10G) | busy | busy | 133 ms NovoServe | North Holland, NL (40G) | busy | busy | 139 ms Uztelecom | Tashkent, UZ (10G) | busy | busy | 284 ms Clouvider | NYC, NY, US (10G) | 2.59 Gbits/sec | busy | 62.5 ms Clouvider | Dallas, TX, US (10G) | busy | busy | 71.7 ms Clouvider | Los Angeles, CA, US (10G) | 2.66 Gbits/sec | 1.20 Gbits/sec | 38.5 ms Geekbench 6 Benchmark Test: --------------------------------- Test | Value | Single Core | 955 Multi Core | 4172 Full Test | https://browser.geekbench.com/v6/cpu/3837791 YABS completed in 15 min 25 sec
@cybertech said: repuc $17.08 Turkey
after reassigned to a node with better IO
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2023-11-30 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Sun 03 Dec 2023 11:21:10 AM EST Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 0 minutes Processor : Intel(R) Xeon(R) CPU E5-2697 v2 @ 2.70GHz CPU cores : 4 @ 2693.509 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 11.7 GiB Swap : 0.0 KiB Disk : 68.8 GiB Distro : Debian GNU/Linux 11 (bullseye) Kernel : 6.5.0-5-amd64 VM Type : VMWARE IPv4/IPv6 : ✔ Online / ❌ Offline IPv4 Network Information: --------------------------------- ISP : Omer Faruk Demirci ASN : AS47436 Omer Faruk Demirci Host : Ipxo Location : Bursa, Bursa Province (16) Country : Turkey fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sda1): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 36.02 MB/s (9.0k) | 98.33 MB/s (1.5k) Write | 36.14 MB/s (9.0k) | 98.85 MB/s (1.5k) Total | 72.16 MB/s (18.0k) | 197.19 MB/s (3.0k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 871.90 MB/s (1.7k) | 986.18 MB/s (963) Write | 918.23 MB/s (1.7k) | 1.05 GB/s (1.0k) Total | 1.79 GB/s (3.4k) | 2.03 GB/s (1.9k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 768 Mbits/sec | 23.7 Mbits/sec | 72.0 ms Scaleway | Paris, FR (10G) | busy | busy | 65.0 ms NovoServe | North Holland, NL (40G) | 813 Mbits/sec | 534 Mbits/sec | 59.9 ms Uztelecom | Tashkent, UZ (10G) | 558 Mbits/sec | 35.9 Mbits/sec | 147 ms Clouvider | NYC, NY, US (10G) | 515 Mbits/sec | 5.28 Mbits/sec | 129 ms Clouvider | Dallas, TX, US (10G) | busy | 17.9 Mbits/sec | 316 ms Clouvider | Los Angeles, CA, US (10G) | 440 Mbits/sec | 6.41 Mbits/sec | 194 ms Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 2270 Multi Core | 7130 Full Test | https://browser.geekbench.com/v4/cpu/17003764 YABS completed in 10 min 51 sec
@MallocVoidstar said: Crunchbits VDS $42.75 first year then $171/yr
First 2 years (initial + renewal of any length)
Looking at adding behind-the-scenes disaster recovery included for these plans too, since it is a single dedicated disk.
Crunchbits.com
VirMach / NVMe1G / TYOC036 / $7.4 year recurring with BF 90% discount
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2023-11-30 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # 2023年 12月 04日 星期一 10:32:16 CST Basic System Information: --------------------------------- Uptime : 1 days, 31 hours, 0 minutes Processor : AMD Ryzen 9 5900X 12-Core Processor CPU cores : 1 @ 3693.062 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 988.7 MiB Swap : 0.0 KiB Disk : 29.4 GiB Distro : Debian GNU/Linux 12 (bookworm) Kernel : 6.5.10 VM Type : KVM IPv4/IPv6 : ✔ Online / ✔ Online fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda1): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 134.25 MB/s (33.5k) | 58.22 MB/s (909) Write | 134.61 MB/s (33.6k) | 58.77 MB/s (918) Total | 268.86 MB/s (67.2k) | 117.00 MB/s (1.8k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 90.08 MB/s (175) | 183.97 MB/s (179) Write | 94.87 MB/s (185) | 196.22 MB/s (191) Total | 184.95 MB/s (360) | 380.19 MB/s (370) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 658 Mbits/sec | 44.2 Mbits/sec | 227 ms Scaleway | Paris, FR (10G) | busy | busy | 241 ms NovoServe | North Holland, NL (40G) | 662 Mbits/sec | 29.3 Mbits/sec | 244 ms Uztelecom | Tashkent, UZ (10G) | 700 Mbits/sec | 55.2 Mbits/sec | 230 ms Clouvider | NYC, NY, US (10G) | 727 Mbits/sec | 70.9 Mbits/sec | 173 ms Clouvider | Dallas, TX, US (10G) | 159 Mbits/sec | 25.3 Mbits/sec | 303 ms Clouvider | Los Angeles, CA, US (10G) | 718 Mbits/sec | 42.5 Mbits/sec | 143 ms iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 651 Mbits/sec | 34.2 Mbits/sec | 226 ms Scaleway | Paris, FR (10G) | busy | busy | 231 ms NovoServe | North Holland, NL (40G) | 654 Mbits/sec | 29.3 Mbits/sec | 244 ms Uztelecom | Tashkent, UZ (10G) | busy | 45.0 Mbits/sec | 230 ms Clouvider | NYC, NY, US (10G) | 741 Mbits/sec | 57.7 Mbits/sec | 173 ms Clouvider | Dallas, TX, US (10G) | 770 Mbits/sec | 40.8 Mbits/sec | 305 ms Clouvider | Los Angeles, CA, US (10G) | 764 Mbits/sec | 73.5 Mbits/sec | 117 ms Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1406 Multi Core | 1398 Full Test | https://browser.geekbench.com/v5/cpu/22011645
VirMach: Customer’s Service cannot use more than 10% of the monthly allocated bandwidth in under twenty-four (24) hours. https://virmach.com/terms-conditions/#aup
@abiaolaoge said: VirMach / NVMe1G / TYOC036 / $7.4 year recurring with BF 90% discount IPv4/IPv6 : ✔ Online / ✔ Online
They have ipv6? Subnet or single ipv6?
@arirang said: @abiaolaoge said: VirMach / NVMe1G / TYOC036 / $7.4 year recurring with BF 90% discount IPv4/IPv6 : ✔ Online / ✔ Online They have ipv6? Subnet or single ipv6?
@arirang said:
Not that person but my Tokyo box says I have a /48 subnet. I haven't tested trying to use more than just a single IPv6, though.
@crunchbits said: @MallocVoidstar said: Crunchbits VDS $42.75 first year then $171/yr First 2 years (initial + renewal of any length) Looking at adding behind-the-scenes disaster recovery included for these plans too, since it is a single dedicated disk.
@crunchbits said:
Any link to the deal? Can't find it here or in the admin section.
@DanSummer said: @crunchbits said: @MallocVoidstar said: Crunchbits VDS $42.75 first year then $171/yr First 2 years (initial + renewal of any length) Looking at adding behind-the-scenes disaster recovery included for these plans too, since it is a single dedicated disk. Any link to the deal? Can't find it here or in the admin section.
@DanSummer said:
BF flash sale, small quantity.
@MallocVoidstar said: @DanSummer said: @crunchbits said: @MallocVoidstar said: Crunchbits VDS $42.75 first year then $171/yr First 2 years (initial + renewal of any length) Looking at adding behind-the-scenes disaster recovery included for these plans too, since it is a single dedicated disk. Any link to the deal? Can't find it here or in the admin section. BF flash sale, small quantity.
Aha, thanks! These stuff always seem to fly right by me without me noticing. Lol
Only two IPv6 addresses.
JustHost.ru / HDD VPS Start / Rostelecom (ex Adman) / 156 ₽ month / unlimited 200 Mbit bandwidth
Basic System Information: --------------------------------- Uptime : 1 days, 3 hours, 22 minutes Processor : Intel(R) Xeon(R) CPU E5-2697 v2 @ 2.70GHz CPU cores : 1 @ 2693.508 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 485.5 MiB Swap : 512.0 MiB Disk : 5.9 GiB Distro : Debian GNU/Linux 12 (bookworm) Kernel : 6.5.10 VM Type : KVM IPv4/IPv6 : ✔ Online / ✔ Online fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda1): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 21.10 MB/s (5.2k) | 61.25 MB/s (957) Write | 21.11 MB/s (5.2k) | 61.56 MB/s (961) Total | 42.21 MB/s (10.5k) | 122.81 MB/s (1.9k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 58.51 MB/s (114) | 57.61 MB/s (56) Write | 61.65 MB/s (120) | 61.67 MB/s (60) Total | 120.16 MB/s (234) | 119.28 MB/s (116) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 193 Mbits/sec | 23.2 Mbits/sec | 95.0 ms Scaleway | Paris, FR (10G) | busy | busy | 93.0 ms NovoServe | North Holland, NL (40G) | 198 Mbits/sec | 101 Mbits/sec | 96.8 ms Uztelecom | Tashkent, UZ (10G) | 194 Mbits/sec | 64.7 Mbits/sec | 96.6 ms Clouvider | NYC, NY, US (10G) | 188 Mbits/sec | 43.5 Mbits/sec | 147 ms Clouvider | Dallas, TX, US (10G) | busy | 1.08 Mbits/sec | 317 ms Clouvider | Los Angeles, CA, US (10G) | 159 Mbits/sec | 1.77 Mbits/sec | 214 ms iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 192 Mbits/sec | 58.4 Mbits/sec | 94.8 ms Scaleway | Paris, FR (10G) | 195 Mbits/sec | busy | 92.6 ms NovoServe | North Holland, NL (40G) | 198 Mbits/sec | 108 Mbits/sec | 96.5 ms Uztelecom | Tashkent, UZ (10G) | 193 Mbits/sec | 35.1 Mbits/sec | 95.7 ms Clouvider | NYC, NY, US (10G) | 180 Mbits/sec | 16.4 Mbits/sec | 147 ms Clouvider | Dallas, TX, US (10G) | 171 Mbits/sec | 17.1 Mbits/sec | 313 ms Clouvider | Los Angeles, CA, US (10G) | 168 Mbits/sec | 1.35 Mbits/sec | 214 ms Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 419 Multi Core | 438 Full Test | https://browser.geekbench.com/v5/cpu/22012190
I just tested it, it is a /48 subnet.
SpartanHost / 29.95 USD / yr / 1TB HDD / 1 CPU / 1G / 5TB / 1Gbps Port / US
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2023-11-30 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Sun Dec 3 08:40:25 AM EST 2023 Basic System Information: --------------------------------- Uptime : 1 days, 24 hours, 0 minutes Processor : Intel(R) Xeon(R) CPU E5-2670 v2 @ 2.50GHz CPU cores : 1 @ 2499.998 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 960.6 MiB Swap : 1024.0 MiB Disk : 1007.1 GiB Distro : Debian GNU/Linux 12 (bookworm) Kernel : 6.1.0-13-amd64 VM Type : KVM IPv4/IPv6 : ✔ Online / ✔ Online IPv6 Network Information: --------------------------------- ISP : Psychz Networks ASN : AS40676 Psychz Networks Host : SmartHost LLC Location : Ashburn, Virginia (VA) Country : United States fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda1): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 5.67 MB/s (1.4k) | 96.30 MB/s (1.5k) Write | 5.67 MB/s (1.4k) | 96.81 MB/s (1.5k) Total | 11.35 MB/s (2.8k) | 193.12 MB/s (3.0k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 266.65 MB/s (520) | 433.48 MB/s (423) Write | 280.82 MB/s (548) | 462.35 MB/s (451) Total | 547.48 MB/s (1.0k) | 895.83 MB/s (874) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 443 Mbits/sec | 167 Mbits/sec | 126 ms Scaleway | Paris, FR (10G) | busy | busy | 136 ms NovoServe | North Holland, NL (40G) | 420 Mbits/sec | 140 Mbits/sec | -- Uztelecom | Tashkent, UZ (10G) | 490 Mbits/sec | 36.4 Mbits/sec | 235 ms Clouvider | NYC, NY, US (10G) | 446 Mbits/sec | 251 Mbits/sec | 63.3 ms Clouvider | Dallas, TX, US (10G) | 426 Mbits/sec | 93.8 Mbits/sec | 33.8 ms Clouvider | Los Angeles, CA, US (10G) | 631 Mbits/sec | 1.00 Gbits/sec | 0.634 ms iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 420 Mbits/sec | 160 Mbits/sec | 125 ms Scaleway | Paris, FR (10G) | busy | busy | 139 ms NovoServe | North Holland, NL (40G) | 373 Mbits/sec | 133 Mbits/sec | 145 ms Uztelecom | Tashkent, UZ (10G) | 382 Mbits/sec | 97.4 Mbits/sec | 234 ms Clouvider | NYC, NY, US (10G) | 421 Mbits/sec | 125 Mbits/sec | 63.2 ms Clouvider | Dallas, TX, US (10G) | 443 Mbits/sec | 332 Mbits/sec | 31.8 ms Clouvider | Los Angeles, CA, US (10G) | 322 Mbits/sec | 1.06 Gbits/sec | 0.522 ms Geekbench 6 Benchmark Test: --------------------------------- Test | Value | Single Core | 349 Multi Core | 227 Full Test | https://browser.geekbench.com/v6/cpu/3836785 YABS completed in 76 min 16 sec
@boatmac said: SpartanHost
do you mean smarthost
$9 VDS in Dallas:
v2023-11-30
Mon 04 Dec 2023 08:54:48 AM EST
Uptime : 0 days, 0 hours, 1 minutes Processor : AMD Ryzen 9 7950X 16-Core Processor CPU cores : 2 @ 4491.560 MHz AES-NI : ‚úî Enabled VM-x/AMD-V : ‚úî Enabled RAM : 7.8 GiB Swap : 1024.0 MiB Disk : 48.1 GiB Distro : Debian GNU/Linux 11 (bullseye) Kernel : 5.10.0-23-amd64 VM Type : KVM IPv4/IPv6 : ‚úî Online / ‚úî Online
ISP : Hosteons Pte. Ltd. ASN : AS142036 Hosteons Pte. Ltd. Host : Hosteons Pte. Ltd Location : Dallas, Texas (TX) Country : United States
Block Size 4k (IOPS) 64k (IOPS) Read 745.59 MB/s (186.3k) 4.71 GB/s (73.6k) Write 747.56 MB/s (186.8k) 4.73 GB/s (73.9k) Total 1.49 GB/s (373.2k) 9.44 GB/s (147.6k) Block Size 512k (IOPS) 1m (IOPS) ------ --- ---- ---- ---- Read 5.64 GB/s (11.0k) 5.44 GB/s (5.3k) Write 5.94 GB/s (11.6k) 5.80 GB/s (5.6k) Total 11.58 GB/s (22.6k) 11.24 GB/s (10.9k) iperf3 Network Speed Tests (IPv4):
Provider Location (Link) Send Speed Recv Speed Ping Clouvider London, UK (10G) 1.41 Gbits/sec 1.45 Gbits/sec 104 ms Scaleway Paris, FR (10G) busy busy 112 ms NovoServe North Holland, NL (40G) 1.57 Gbits/sec 174 Mbits/sec 107 ms Uztelecom Tashkent, UZ (10G) 222 Mbits/sec 221 Mbits/sec 202 ms Clouvider NYC, NY, US (10G) 3.94 Gbits/sec 4.40 Gbits/sec 36.2 ms Clouvider Dallas, TX, US (10G) 1.36 Gbits/sec 1.26 Gbits/sec 2.04 ms Clouvider Los Angeles, CA, US (10G) 3.01 Gbits/sec 4.83 Gbits/sec 36.9 ms iperf3 Network Speed Tests (IPv6):
Provider Location (Link) Send Speed Recv Speed Ping Clouvider London, UK (10G) 1.68 Gbits/sec 1.48 Gbits/sec 104 ms Scaleway Paris, FR (10G) 1.81 Gbits/sec busy 109 ms NovoServe North Holland, NL (40G) 1.64 Gbits/sec 376 Mbits/sec 107 ms Uztelecom Tashkent, UZ (10G) 387 Mbits/sec 657 Mbits/sec 202 ms Clouvider NYC, NY, US (10G) 4.65 Gbits/sec 2.16 Gbits/sec 35.8 ms Clouvider Dallas, TX, US (10G) 9.22 Gbits/sec 9.14 Gbits/sec 0.673 ms Clouvider Los Angeles, CA, US (10G) 4.55 Gbits/sec 4.73 Gbits/sec 36.8 ms Geekbench 6 Benchmark Test:
Test | Value | Single Core | 3036 Multi Core | 5416 Full Test | https://browser.geekbench.com/v6/cpu/3849259
YABS completed in 12 min 44 sec
hostEONS.com - 9 Locations for VPS (US and EU).. Free Blesta License, Free Windows 2019 License and more. Shared DA Hosting. AS142036 .. Ryzen 7950X Based VDS in SLC, LA and Dallas
@cybertech said: @boatmac said: SpartanHost do you mean smarthost
@cybertech said:
Oh,no. I made a mistake with copy & paste. Yes, it is SmartHost.
retslav.nl - BF23 small VPS NAT 3€/y
~$ yabs # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2023-11-30 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Mon Dec 4 05:39:35 PM CET 2023 Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 12 minutes Processor : Intel Core Processor (Broadwell, IBRS) CPU cores : 1 @ 2199.990 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 925.8 MiB Swap : 1.5 GiB Disk : 15.9 GiB Distro : Debian GNU/Linux 12 (bookworm) Kernel : 6.1.0-13-amd64 VM Type : KVM IPv4/IPv6 : ✔ Online / ❌ Offline IPv4 Network Information: --------------------------------- ISP : RoyaleHosting BV ASN : AS212477 RoyaleHosting BV Host : RoyaleHosting BV Location : Amsterdam, North Holland (NH) Country : The Netherlands fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda3): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 6.57 MB/s (1.6k) | 39.03 MB/s (609) Write | 6.58 MB/s (1.6k) | 39.29 MB/s (613) Total | 13.16 MB/s (3.2k) | 78.32 MB/s (1.2k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 49.70 MB/s (97) | 51.02 MB/s (49) Write | 52.63 MB/s (102) | 54.51 MB/s (53) Total | 102.33 MB/s (199) | 105.54 MB/s (102) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 939 Mbits/sec | 168 Mbits/sec | 6.31 ms Scaleway | Paris, FR (10G) | busy | busy | 10.3 ms NovoServe | North Holland, NL (40G) | 941 Mbits/sec | 864 Mbits/sec | 0.851 ms Uztelecom | Tashkent, UZ (10G) | 241 Mbits/sec | busy | 234 ms Clouvider | NYC, NY, US (10G) | 856 Mbits/sec | 22.9 Mbits/sec | 75.5 ms Clouvider | Dallas, TX, US (10G) | 494 Mbits/sec | 6.48 Mbits/sec | 251 ms Clouvider | Los Angeles, CA, US (10G) | 782 Mbits/sec | 23.4 Mbits/sec | 129 ms Geekbench 6 Benchmark Test: --------------------------------- Test | Value | Single Core | 609 Multi Core | 324 Full Test | https://browser.geekbench.com/v6/cpu/3851530 YABS completed in 44 min 45 sec
Cloudstorage Filen.io Aff - filelu Aff Free Uptime Monitoring HetrixTools Aff
canceled old BF22 plan from inception hosting - 15€/y
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2023-11-24 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Tue Nov 28 10:46:52 PM CET 2023 Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 11 minutes Processor : Intel(R) Xeon(R) E-2278G CPU @ 3.40GHz CPU cores : 2 @ 3407.964 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 960.4 MiB Swap : 1.5 GiB Disk : 38.4 GiB Distro : Debian GNU/Linux 12 (bookworm) Kernel : 6.1.0-13-amd64 VM Type : KVM IPv4/IPv6 : ✔ Online / ✔ Online IPv6 Network Information: --------------------------------- ISP : Clouvider Limited ASN : AS62240 Clouvider Host : Clouvider Limited Location : London, England (ENG) Country : United Kingdom fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda1): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 163.84 MB/s (40.9k) | 300.43 MB/s (4.6k) Write | 164.27 MB/s (41.0k) | 302.01 MB/s (4.7k) Total | 328.11 MB/s (82.0k) | 602.45 MB/s (9.4k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 296.49 MB/s (579) | 346.93 MB/s (338) Write | 312.25 MB/s (609) | 370.04 MB/s (361) Total | 608.75 MB/s (1.1k) | 716.97 MB/s (699) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | busy | 5.96 Gbits/sec | 11.4 ms Scaleway | Paris, FR (10G) | busy | busy | 9.61 ms NovoServe | North Holland, NL (40G) | busy | busy | 7.76 ms Uztelecom | Tashkent, UZ (10G) | 2.82 Gbits/sec | 2.04 Gbits/sec | 76.0 ms Clouvider | NYC, NY, US (10G) | 1.89 Gbits/sec | 636 Mbits/sec | 88.4 ms Clouvider | Dallas, TX, US (10G) | 835 Mbits/sec | 1.12 Gbits/sec | 129 ms Clouvider | Los Angeles, CA, US (10G) | 434 Mbits/sec | 990 Mbits/sec | 144 ms iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 4.47 Gbits/sec | 1.10 Gbits/sec | 11.3 ms Scaleway | Paris, FR (10G) | busy | busy | 9.04 ms NovoServe | North Holland, NL (40G) | 4.88 Gbits/sec | 5.03 Gbits/sec | 7.62 ms Uztelecom | Tashkent, UZ (10G) | 1.28 Gbits/sec | 383 Mbits/sec | 75.8 ms Clouvider | NYC, NY, US (10G) | 660 Mbits/sec | 207 Mbits/sec | 88.3 ms Clouvider | Dallas, TX, US (10G) | 504 Mbits/sec | 90.6 Mbits/sec | 129 ms Clouvider | Los Angeles, CA, US (10G) | 810 Mbits/sec | 243 Mbits/sec | 143 ms Geekbench 6 Benchmark Test: --------------------------------- Test | Value | Single Core | 1323 Multi Core | 1388 Full Test | https://browser.geekbench.com/v6/cpu/3765314 Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1219 Multi Core | 2202 Full Test | https://browser.geekbench.com/v5/cpu/21994648
My internal vps
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2023-03-24 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Wed 29 Nov 2023 02 : 16 : 11 Basic System Information: --------------------------------- Uptime : 0 days, 1 hours, 13 minutes Processor : AMD Ryzen 9 7950X 16-Core Processor CPU cores : 4 @ 4499.820 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 7.8 GiB Swap : 0.0 MiB Disk : 58.2 GiB Distro : AlmaLinux 8.6 (Sky Tiger) Kernel : 4.18.0-372.9.1.el8.x86_64 VM Type : KVM IPv4/IPv6 : ✔ Online / ❌ Offline IPv6 Network Information: --------------------------------- ISP : GorillaServers, Inc. ASN : AS53850 GorillaServers, Inc. Host : WebNX, Inc. Location : Ogden, Utah (UT) Country : United States fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 1.23 GB/s (270.0k) | 5.17 GB/s (150.6k) Write | 1.23 GB/s (270.7k) | 5.82 GB/s (151.4k) Total | 2.46 GB/s (540.7k) | 11.33 GB/s (302.0k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 7.27 GB/s (13.6k) | 6.13 GB/s (5.9k) Write | 8.64 GB/s (14.3k) | 6.53 GB/s (6.3k) Total | 15.91 GB/s (27.9k) | 12.67 GB/s (12.3k)
Hostslick eur 8 flash deal openvz
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2023-11-30 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Wed Dec 6 20:38:52 EST 2023 Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 4 minutes Processor : Intel(R) Xeon(R) CPU E5-2690 v4 @ 2.60GHz CPU cores : 2 @ 1200.000 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 2.0 GiB Swap : 0.0 KiB Disk : 24.5 GiB Distro : Debian GNU/Linux 11 (bullseye) Kernel : 4.19.0 VM Type : OPENVZ IPv4/IPv6 : ✔ Online / ❌ Offline IPv4 Network Information: --------------------------------- ISP : EGIHosting ASN : AS18779 EGIHosting Host : RaziNetwork Location : Amsterdam, North Holland (NH) Country : Netherlands fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/ploop44348p1): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 119.20 MB/s (29.8k) | 322.63 MB/s (5.0k) Write | 119.52 MB/s (29.8k) | 324.33 MB/s (5.0k) Total | 238.73 MB/s (59.6k) | 646.96 MB/s (10.1k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 416.65 MB/s (813) | 474.97 MB/s (463) Write | 438.79 MB/s (857) | 506.60 MB/s (494) Total | 855.45 MB/s (1.6k) | 981.58 MB/s (957) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 5.62 Gbits/sec | 3.28 Gbits/sec | -- Scaleway | Paris, FR (10G) | busy | busy | 12.5 ms NovoServe | North Holland, NL (40G) | 6.34 Gbits/sec | 6.88 Gbits/sec | -- Uztelecom | Tashkent, UZ (10G) | 2.19 Gbits/sec | 1.52 Gbits/sec | -- Performing IPv4 iperf3 send test to Clouvider (Attempt #2 of 3)... Clouvider | NYC, NY, US (10G) | 695 Mbits/sec | 467 Mbits/sec | -- Clouvider | Dallas, TX, US (10G) | busy | 60.7 Mbits/sec | -- Clouvider | Los Angeles, CA, US (10G) | 808 Mbits/sec | busy | -- Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 3972 Multi Core | 6896 Full Test | https://browser.geekbench.com/v4/cpu/17015363 YABS completed in 9 min 55 sec
Our Paris VPS YABS
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2023-11-30 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Wed 06 Dec 2023 07:01:58 AM EST Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 18 minutes Processor : Intel(R) Xeon(R) Gold 6142 CPU @ 2.60GHz CPU cores : 2 @ 2593.902 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 2.4 GiB Swap : 512.0 MiB Disk : 28.9 GiB Distro : Debian GNU/Linux 11 (bullseye) Kernel : 5.10.0-23-amd64 VM Type : KVM IPv4/IPv6 : ✔ Online / ❌ Offline IPv4 Network Information: --------------------------------- ISP : Hosteons Pte. Ltd ASN : Unknown Host : Hosteons Pte. Ltd Location : Paris, Île-de-France (IDF) Country : France fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda1): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 79.20 MB/s (19.8k) | 1.03 GB/s (16.0k) Write | 79.41 MB/s (19.8k) | 1.03 GB/s (16.1k) Total | 158.61 MB/s (39.6k) | 2.06 GB/s (32.2k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 2.33 GB/s (4.5k) | 2.37 GB/s (2.3k) Write | 2.46 GB/s (4.8k) | 2.53 GB/s (2.4k) Total | 4.79 GB/s (9.3k) | 4.91 GB/s (4.8k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 8.10 Gbits/sec | 8.08 Gbits/sec | 7.99 ms Scaleway | Paris, FR (10G) | busy | busy | 1.20 ms NovoServe | North Holland, NL (40G) | busy | busy | 9.37 ms Uztelecom | Tashkent, UZ (10G) | 1.49 Gbits/sec | 1.49 Gbits/sec | 108 ms Clouvider | NYC, NY, US (10G) | busy | 2.10 Gbits/sec | 77.8 ms Clouvider | Dallas, TX, US (10G) | busy | 520 Mbits/sec | 226 ms Clouvider | Los Angeles, CA, US (10G) | 1.08 Gbits/sec | 891 Mbits/sec | 141 ms Geekbench 6 Benchmark Test: --------------------------------- Test | Value | Single Core | 1252 Multi Core | 2267 Full Test | https://browser.geekbench.com/v6/cpu/3873742 YABS completed in 11 min 47 sec
Our Frankfurt VPS YABS:
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2023-11-30 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Wed 06 Dec 2023 07:01:02 AM EST Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 15 minutes Processor : Intel(R) Xeon(R) Gold 6142 CPU @ 2.60GHz CPU cores : 2 @ 2593.904 MHz AES-NI : ‚úî Enabled VM-x/AMD-V : ‚úî Enabled RAM : 2.4 GiB Swap : 512.0 MiB Disk : 28.9 GiB Distro : Debian GNU/Linux 11 (bullseye) Kernel : 5.10.0-23-amd64 VM Type : KVM IPv4/IPv6 : ‚úî Online / ‚úî Online IPv6 Network Information: --------------------------------- ISP : Hosteons Pte. Ltd ASN : Unknown Host : Hosteons Pte. Ltd Location : Frankfurt am Main, Hesse (HE) Country : Germany fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda1): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 295.10 MB/s (73.7k) | 2.14 GB/s (33.5k) Write | 295.88 MB/s (73.9k) | 2.15 GB/s (33.7k) Total | 590.99 MB/s (147.7k) | 4.30 GB/s (67.2k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 2.36 GB/s (4.6k) | 2.39 GB/s (2.3k) Write | 2.48 GB/s (4.8k) | 2.54 GB/s (2.4k) Total | 4.84 GB/s (9.4k) | 4.94 GB/s (4.8k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 6.39 Gbits/sec | 8.48 Gbits/sec | 13.6 ms Scaleway | Paris, FR (10G) | busy | busy | 10.8 ms NovoServe | North Holland, NL (40G) | busy | 8.23 Gbits/sec | 7.04 ms Uztelecom | Tashkent, UZ (10G) | 1.25 Gbits/sec | busy | 115 ms Clouvider | NYC, NY, US (10G) | 1.41 Gbits/sec | 648 Mbits/sec | 80.9 ms Clouvider | Dallas, TX, US (10G) | 561 Mbits/sec | 478 Mbits/sec | 126 ms Clouvider | Los Angeles, CA, US (10G) | 825 Mbits/sec | busy | 147 ms iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 4.53 Gbits/sec | 8.49 Gbits/sec | 13.7 ms Scaleway | Paris, FR (10G) | busy | busy | 13.0 ms NovoServe | North Holland, NL (40G) | 9.10 Gbits/sec | 8.05 Gbits/sec | 7.07 ms Uztelecom | Tashkent, UZ (10G) | 898 Mbits/sec | 167 Mbits/sec | 114 ms Clouvider | NYC, NY, US (10G) | 1.92 Gbits/sec | 1.89 Gbits/sec | 80.9 ms Clouvider | Dallas, TX, US (10G) | 1.29 Gbits/sec | 1.21 Gbits/sec | 125 ms Clouvider | Los Angeles, CA, US (10G) | 875 Mbits/sec | 933 Mbits/sec | 147 ms Geekbench 6 Benchmark Test: --------------------------------- Test | Value | Single Core | 1283 Multi Core | 2276 Full Test | https://browser.geekbench.com/v6/cpu/3873761 YABS completed in 14 min 7 sec
HostSlick OpenVZ / 2 CPU / 4GB RAM / 35GB SSD / 5TB @ 10Gbps / 16.37 USD yearly / Netherlands
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2023-11-30 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Thu Dec 7 16:14:45 JST 2023 Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 4 minutes Processor : Intel(R) Xeon(R) CPU E5-2690 v4 @ 2.60GHz CPU cores : 2 @ 1200.000 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 4.0 GiB Swap : 0.0 KiB Disk : Distro : Debian GNU/Linux 12 (bookworm) Kernel : 4.19.0 VM Type : OPENVZ IPv4/IPv6 : ✔ Online / ❌ Offline IPv4 Network Information: --------------------------------- ISP : EGIHosting ASN : AS18779 EGIHosting Host : RaziNetwork Location : Amsterdam, North Holland (NH) Country : Netherlands fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/ploop33260p1): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 75.30 MB/s (18.8k) | 278.81 MB/s (4.3k) Write | 75.50 MB/s (18.8k) | 280.27 MB/s (4.3k) Total | 150.80 MB/s (37.7k) | 559.09 MB/s (8.7k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 482.60 MB/s (942) | 513.42 MB/s (501) Write | 508.25 MB/s (992) | 547.61 MB/s (534) Total | 990.85 MB/s (1.9k) | 1.06 GB/s (1.0k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 4.15 Gbits/sec | 6.37 Gbits/sec | -- Scaleway | Paris, FR (10G) | 3.76 Gbits/sec | busy | 12.3 ms NovoServe | North Holland, NL (40G) | 4.82 Gbits/sec | 6.34 Gbits/sec | -- Uztelecom | Tashkent, UZ (10G) | 1.32 Gbits/sec | 1.85 Gbits/sec | -- Clouvider | NYC, NY, US (10G) | 1.90 Gbits/sec | 1.78 Gbits/sec | -- Clouvider | Dallas, TX, US (10G) | 1.33 Gbits/sec | 1.35 Gbits/sec | -- Clouvider | Los Angeles, CA, US (10G) | 937 Mbits/sec | 1.19 Gbits/sec | -- Geekbench 6 Benchmark Test: --------------------------------- Test | Value | Single Core | 1096 Multi Core | 1848 Full Test | https://browser.geekbench.com/v6/cpu/3884414 YABS completed in 13 min 16 sec
buyVM 2GB
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2023-11-30 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Fri Dec 8 01:16:08 AM UTC 2023 Basic System Information: --------------------------------- Uptime : 0 days, 9 hours, 55 minutes Processor : AMD Ryzen 9 3900X 12-Core Processor CPU cores : 1 @ 3792.872 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 1.9 GiB Swap : 0.0 KiB Disk : 290.2 GiB Distro : Ubuntu 22.04 LTS Kernel : 5.15.0-25-generic VM Type : KVM IPv4/IPv6 : ✔ Online / ❌ Offline IPv4 Network Information: --------------------------------- ISP : FranTech Solutions ASN : AS53667 FranTech Solutions Host : BuyVM Location : Bissen, Mersch (ME) Country : Luxembourg fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda2): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 271.39 MB/s (67.8k) | 642.79 MB/s (10.0k) Write | 272.11 MB/s (68.0k) | 646.17 MB/s (10.0k) Total | 543.51 MB/s (135.8k) | 1.28 GB/s (20.1k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 846.61 MB/s (1.6k) | 891.72 MB/s (870) Write | 891.59 MB/s (1.7k) | 951.11 MB/s (928) Total | 1.73 GB/s (3.3k) | 1.84 GB/s (1.7k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 1.11 Gbits/sec | 209 Mbits/sec | 13.9 ms Scaleway | Paris, FR (10G) | busy | busy | 10.2 ms NovoServe | North Holland, NL (40G) | 1.12 Gbits/sec | 949 Mbits/sec | 8.04 ms Uztelecom | Tashkent, UZ (10G) | 1.05 Gbits/sec | 73.0 Mbits/sec | 97.4 ms Clouvider | NYC, NY, US (10G) | busy | 84.1 Mbits/sec | 82.1 ms Clouvider | Dallas, TX, US (10G) | 998 Mbits/sec | 53.3 Mbits/sec | 124 ms Clouvider | Los Angeles, CA, US (10G) | 982 Mbits/sec | 72.8 Mbits/sec | 153 ms Geekbench 6 Benchmark Test: --------------------------------- Test | Value | Single Core | 1193 Multi Core | 1191 Full Test | https://browser.geekbench.com/v6/cpu/3894924
c1v after tweaking performance
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2023-11-30 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Wed Dec 13 02:19:00 UTC 2023 Basic System Information: --------------------------------- Uptime : 0 days, 1 hours, 7 minutes Processor : Intel(R) Xeon(R) CPU E5-2698 v4 @ 2.20GHz CPU cores : 2 @ 2199.998 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 1.9 GiB Swap : 0.0 KiB Disk : 59.0 GiB Distro : Debian GNU/Linux 12 (bookworm) Kernel : 6.1.0-15-amd64 VM Type : KVM IPv4/IPv6 : ✔ Online / ✔ Online IPv6 Network Information: --------------------------------- ISP : Cinzia Tocci trading as C1V ASN : AS212271 Cinzia Tocci trading as C1V Host : C1V Hosting Location : Milan, Lombardy (25) Country : Italy fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sda1): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 61.52 MB/s (15.3k) | 218.49 MB/s (3.4k) Write | 61.63 MB/s (15.4k) | 219.64 MB/s (3.4k) Total | 123.16 MB/s (30.7k) | 438.13 MB/s (6.8k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 237.54 MB/s (463) | 235.94 MB/s (230) Write | 250.16 MB/s (488) | 251.65 MB/s (245) Total | 487.70 MB/s (951) | 487.59 MB/s (475) Geekbench 6 Benchmark Test: --------------------------------- Test | Value | Single Core | 659 Multi Core | 1147 Full Test | https://browser.geekbench.com/v6/cpu/3965018 YABS completed in 21 min 46 sec
HostSlick - 2023 10G KVM VPS BF Deal III - €39/year
2023 10G KVM VPS BF Deal III CPU - 6 vCore - Intel XEON E5-2690v4 RAM - 12GB DDR4 ECC RAM Bandwidth - 10Gbit unmetered !SHARED! (FAIR USE! - 1gbit limit after 44TB BW) Disk Space - 120 GB RAID10-M2 SSD (Order till 02/12/2023 yearly and get 180GB SSD!!!) Port Speed - 10 Gbit IP Addresse(s) - 1x IPv4 - 1x IPv6 DDoS Protection - included. up to 1tbit Operating System - Linux Location - Netherlands (EU) ONLY 78€/EUR YEAR!
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2023-11-30 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Thu 14 Dec 2023 02:04:36 AM EST Basic System Information: --------------------------------- Uptime : 0 days, 1 hours, 6 minutes Processor : Intel(R) Xeon(R) CPU E5-2690 v4 @ 2.60GHz CPU cores : 12 @ 2596.990 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 11.6 GiB Swap : 1024.0 MiB Disk : 179.8 GiB Distro : Debian GNU/Linux 11 (bullseye) Kernel : 5.10.0-8-amd64 VM Type : KVM IPv4/IPv6 : ✔ Online / ✔ Online IPv6 Network Information: --------------------------------- ISP : ColocationX Ltd. ASN : AS208046 ColocationX Ltd. Host : ColocationXV6 Location : Amsterdam, North Holland (NH) Country : The Netherlands fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda1): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 5.85 MB/s (1.4k) | 223.29 MB/s (3.4k) Write | 5.87 MB/s (1.4k) | 224.47 MB/s (3.5k) Total | 11.73 MB/s (2.9k) | 447.77 MB/s (6.9k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 878.28 MB/s (1.7k) | 1.56 GB/s (1.5k) Write | 924.94 MB/s (1.8k) | 1.66 GB/s (1.6k) Total | 1.80 GB/s (3.5k) | 3.22 GB/s (3.1k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 5.05 Gbits/sec | 5.69 Gbits/sec | 16.5 ms Scaleway | Paris, FR (10G) | 5.04 Gbits/sec | busy | 13.0 ms NovoServe | North Holland, NL (40G) | 5.91 Gbits/sec | 7.60 Gbits/sec | 4.21 ms Uztelecom | Tashkent, UZ (10G) | 1.73 Gbits/sec | 1.72 Gbits/sec | 90.7 ms Clouvider | NYC, NY, US (10G) | 1.06 Gbits/sec | 1.75 Gbits/sec | 89.7 ms Clouvider | Dallas, TX, US (10G) | 1.14 Gbits/sec | 1.40 Gbits/sec | 118 ms Clouvider | Los Angeles, CA, US (10G) | 1.15 Gbits/sec | 1.19 Gbits/sec | 170 ms iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 5.48 Gbits/sec | 7.26 Gbits/sec | 11.4 ms Scaleway | Paris, FR (10G) | 4.99 Gbits/sec | busy | 12.7 ms NovoServe | North Holland, NL (40G) | 2.32 Gbits/sec | 7.35 Gbits/sec | 4.11 ms Uztelecom | Tashkent, UZ (10G) | 421 Mbits/sec | 1.83 Gbits/sec | 91.0 ms Clouvider | NYC, NY, US (10G) | 2.02 Gbits/sec | 2.11 Gbits/sec | 85.0 ms Clouvider | Dallas, TX, US (10G) | 1.50 Gbits/sec | 1.51 Gbits/sec | 118 ms Clouvider | Los Angeles, CA, US (10G) | 927 Mbits/sec | 1.19 Gbits/sec | 168 ms Geekbench 6 Benchmark Test: --------------------------------- Test | Value | Single Core | 1012 Multi Core | 6570 Full Test | https://browser.geekbench.com/v6/cpu/3981245 YABS completed in 14 min 3 sec
Good enough for a WireGuard instance.
c1v after further tweaks
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2023-11-30 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Fri Dec 15 03:31:35 UTC 2023 Basic System Information: --------------------------------- Uptime : 0 days, 23 hours, 6 minutes Processor : Intel(R) Xeon(R) CPU E5-2698 v4 @ 2.20GHz CPU cores : 2 @ 2199.998 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 1.9 GiB Swap : 1.0 GiB Disk : 59.0 GiB Distro : Debian GNU/Linux 12 (bookworm) Kernel : 6.1.0-15-amd64 VM Type : KVM IPv4/IPv6 : ✔ Online / ✔ Online IPv6 Network Information: --------------------------------- ISP : Cinzia Tocci trading as C1V ASN : AS212271 Cinzia Tocci trading as C1V Host : C1V Hosting Location : Milan, Lombardy (25) Country : Italy fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sda1): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 75.73 MB/s (18.9k) | 223.77 MB/s (3.4k) Write | 75.93 MB/s (18.9k) | 224.95 MB/s (3.5k) Total | 151.67 MB/s (37.9k) | 448.73 MB/s (7.0k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 237.98 MB/s (464) | 232.64 MB/s (227) Write | 250.63 MB/s (489) | 248.13 MB/s (242) Total | 488.61 MB/s (953) | 480.77 MB/s (469) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 504 Mbits/sec | 22.8 Mbits/sec | 29.3 ms Scaleway | Paris, FR (10G) | 511 Mbits/sec | 24.4 Mbits/sec | 32.1 ms NovoServe | North Holland, NL (40G) | 489 Mbits/sec | 295 Mbits/sec | 33.0 ms Uztelecom | Tashkent, UZ (10G) | 400 Mbits/sec | 2.94 Mbits/sec | 106 ms Clouvider | NYC, NY, US (10G) | 449 Mbits/sec | busy | 96.2 ms Clouvider | Dallas, TX, US (10G) | 388 Mbits/sec | busy | 131 ms Clouvider | Los Angeles, CA, US (10G) | 380 Mbits/sec | 7.55 Mbits/sec | 161 ms iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 509 Mbits/sec | 487 Mbits/sec | 29.2 ms Scaleway | Paris, FR (10G) | busy | busy | 23.3 ms NovoServe | North Holland, NL (40G) | 503 Mbits/sec | 488 Mbits/sec | 33.0 ms Uztelecom | Tashkent, UZ (10G) | 453 Mbits/sec | 450 Mbits/sec | 131 ms Clouvider | NYC, NY, US (10G) | 446 Mbits/sec | 369 Mbits/sec | 96.1 ms Clouvider | Dallas, TX, US (10G) | 418 Mbits/sec | 447 Mbits/sec | 131 ms Clouvider | Los Angeles, CA, US (10G) | 404 Mbits/sec | 442 Mbits/sec | 161 ms Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 2846 Multi Core | 5154 Full Test | https://browser.geekbench.com/v4/cpu/17046253 YABS completed in 14 min 28 sec
Retslav
€5
IPv4 NAT
First 2 years
Crunchbits.com
$9 VDS in Dallas:
v2023-11-30
RAM : 7.8 GiB
Swap : 1024.0 MiB
Disk : 48.1 GiB
VM Type : KVM
Test | Value
Single Core | 3036
Multi Core | 5416
My internal vps
Hostslick
eur 8 flash deal
openvz
Our Paris VPS YABS
buyVM 2GB
BRUTAL
c1v
