EDIT, also do you have that can du 10G constant, recommend me something in EU, I am fed up with the 10G guarantied lines in Romania, M247 is our last Colo there, the 3'rd one will definitely be somewhere alse.
For now we have 2, 2.3G constant traffic, and I cannot manage to drain 10G.
Our link to US was usualy 1.5-2G, I think they switched the routing to Pigeon-By-Wing-5G now.
@host_c i was given this title from the original owner of this forum because only i had the time to run YABS all day long from my work desk that nobody cares about. luckily the forum was handed over to the creator of YABS so i got to keep this title.
also I'm more interested in CPU, disk IO and RAM speed as a hobby and know not much about networking.
what i do know from all these YABSing is that due to the popularity of this script, the iperf servers are being abused and gets rate limited from time to time, so not getting >8G is normal unless host is in the same vicinity (e.g. LA server to Clouvider LA).
Hence usually i would follow up with bench.sh and it does a speedtest.net test instead, which shows 7-9G most of the time if the host network bandwidth is indeed good.
also the locations of these iperf servers are not within close proximity (<10ms) of Romania (which explains why speedtest.net is much faster), so to me your numbers are respectable, although only you know if there can be room for optimization.
i mean you most likely know more than me that there are just so many factors to network speeds and latencies.
@cybertech said: i mean you most likely know more than me that there are just so many factors to network speeds and latencies.
Yes we do, I am just pissed that something happened ~1 month back, and even with the abuse of these tests, I lost my 9-9.8 mojo on EU. I did put the blame on the BF deals sold here and on other forums at first, but it's been weeks since then, and I do not see a big increase in performance.
I usually watch the threads with net tests, and I see that almost all have lower results for the past ~1mo. I doubt everybody started netflix @4K and left it on loop, or pronhub, I will not discuss the tastes.
That is why I asked if you have a access to a VPS at Telia, or other High Tier ISP in EU.
I think the tech guys at RDS NOC had enough of me, opening tickets and so on.
on your input, THX.
@amj said:
Usercloud BF2023 / KVM / 1 CPU / 712MB RAM / 15GB SAS / 1TB BW / 80 HKD yearly / HK
Test | Value
Single Core | 117
Multi Core | 42
Full Test | https://browser.geekbench.com/v6/cpu/4115041
YABS completed in 958 min 12 sec
Even @cociu looks like AWS, Azure, GCP in front of this score.
microLXC Romania Node
XSIG-2 - skhron.com.ua
Bucharest, Romania NVMe
Hosteroid
Romania
@cybertech
can you post a net test from any vps in M247 Romania, that is not limited to 1G?
Thank you, hope we will have at least that there.
all the best!
@cybertech
Since you are the King on this
Do you have something on 10G Telia as a provider?
IONOS 1€/month recurring
network speed:
https://lowendspirit.com/discussion/comment/164986/#Comment_164986
Hosteroid after a complete fresh install from netboot and lifting iperf limit
VirMach / KVM / 1 CPU / 1111MB RAM / 11GB NVMe / 1111GB BW / 1.11 USD yearly / NYCB035 node
Did you wait to post it on Page 111?
If you ever want to transfer this for some reason, just PM me
I had not noticed. What a coincidence!
Or a reverse coincidence, you got the $1.11 because in future you were to post a YABS on the page 111 of The YABS Thread.
VirMach / KVM / 1 CPU / 1111MB RAM / 11GB NVMe / 1111GB BW / 1.11 USD yearly / NYCB035 node --- wow!
YABS completed in 958 min 12 sec - EPIC!!!
Melbicom
KVM-1-SIN Plan
Singapore
HOSTSLICK-BLACKFRIDAY2023-2 2023 Specials
OVH Gravelines RISE-GAME-2
On he's Xeon 5600X Series, lol again mate!
Speedypage Singapore 7900
BuyVM Lux 512M
OneAsiaHost
Singapore
SGKVM-2048
Hosteroid / 4GB / 2 E5-2690v4 cores / 50GB
