@localhost said: @c1vhosting what is the log policy for VPN? I could not find that info in the T&C
Hello,
no any particular logging as now.
If our policy changes (e.g. to comply with future legislation) we will notify you via email.
wow thats awesome.
Any third party can audit your claims of no-logging? This will help build credibility in the long term.
Um, no. We should raise prices to afford certifications etc..
I am sure people will be happy to shell out more when they know what you say corroborates by a third party - specially in this black box type system. Good luck to you and your users!
Hello,
wow thats awesome.
Our energy is supplied using exclusively green sources.
Power redundant 34,5W/0.15A included (24,84kWh/month)
Port speed 1Gbps shared, 10TB monthly traffic included
IPv4 1 IPv4 addresses included
IPv6 /48 IPv6 subnet included
Basic Remote Hands
Double disk space for commenting your order number ?
How can install from ISO ?
I get the error msg "CD ROM volume not found" when attempt to install from ISO.
Attemped to change the "boot device 1" to CD/ISO, option is not available. Only options are "None, Drive, Network"
Same problem.. Ticket #C1V_8901368_TCUSID opened, but no answer.. I need AlmaLinux 8 for this vps, only debian/ubuntu templates available..
No
Just open a ticket with service id and what iso you want.
Thank you. Alma is installed, but network almost died.. Was very bad before Alma install with ubuntu also. SSH-login take long time and shut down without warning. Webmin say "connection lost" and even VNC via control panel can't connect most times.
Reboot/shutdown/restart not fix a situation.
Can you check it, please?
No
Sad.
Can you share me a case to study?
C1V Hosting: Low cost Italian Cloud & Data Center Solutions 🚀 | Contact us for special offers. | Our deals on Telegram
C1V HOSTING IS THE BEST ON LES, GO TO https://www.c1vhosting.it/link.php?id=38
https://protonvpn.com/blog/no-logs-audit/
I am not an expert at this but something similar. Maybe there are some experts in the community here that can chime in
Please give a technical view how you obtain the no-logging
Sultan Muda - Amazon Store
i might be a freeloader but why shill?
thx!
| Psikolog Jogja | Biro Psikologi Jogja |
1U COLOCATION (Low Power)
Basic Remote Hands
Price: €12,20/month
Discount code: Y4P16JIUVG
Order link
Why Choose C1V Hosting?
Useful Links
ADDED FEATURE: Additional VPN profiles
You can now order multiple VPN profiles with your VPN service.
4GB €12/yr NVME KVM - C1V HOSTING
ROME VPS
Specs: 2 vCore CPU, 4GB DDR4 ECC RAM, 35GB SSD NVMe PCIe, 20TB @ 1Gbps monthly traffic usage, 1 IPv4 address, 1 IPv6 address
Order link
Discount code: VQLR58CN5U
Note: Select annual billing cycle to apply discount.
Useful Links
No
Your ticket is being reviewed
ROME VPS
Order link
Discount code: 1Y3M1ZN4IH
Useful Links
€12/yr VPS is good friend.
Sad.
TY
My Italian is rusty but... "creaiamo" sounds like a misspelling?
Lead Platform Architect at the day job, Ethical Hacker/Bug Bounty Hunter on the side
yes
