@spiritlhl said:
Every page doesn't seem to have a back to home button or a top menu bar similar to what exists on WHMCS, I have to click the browser's back button every time I need to go to another page, is this intentional?
@s_e_r_v_e_r said: the second one i dont think it will work like that, you create server with credits for one whole month, you can only renew (non functional)
Ah, ok. And without renew, it will expire automatically after that one month runs out?
Will add some top menu bar probably too
Maybe you could implement it bottom-row, tmux-style like?
10th : not really a panel feature, more the image (Alpine) or mounting options; anyway: I lack permissions for ping :
CTnthhh/Ulq-GigZKe7cVcsthsntC:~$ ping lowendspirit.com
PING lowendspirit.com (104.21.66.20): 56 data bytes
ping: permission denied (are you root?)
edit - my bad, I can't read :-P
CTnthhh/Ulq-GigZKe7cVcsthsntC:~$ sudo su -
CTnthhh/Ulq-GigZKe7cVcsthsntC:~# ping lowendspirit.com
64 bytes from 104.21.66.20: seq=0 ttl=60 time=1.680 ms
64 bytes from 104.21.66.20: seq=1 ttl=60 time=2.215 ms
@wankel said: 10th : not really a panel feature, more the image (Alpine) or mounting options; anyway: I lack permissions for ping :
was about to comment you figured it out
basic top menu is on
Few observations
Put the toolbar on the pages Why should I trust?
Terms of Service
Acceptable Use Policy
Privacy Policy
On the servers page, can you link all of the available commands so that they pre fill in the box just by clicking them - saves typing & mistakes.
Can you or anyone else here please point me at other web page designs or at entire websites powered by inline-block plus at least partly what looks like command line terminal output?
I went looking around on Google and didn't find much, so thanks for any help!
first, in mobile device your input text color value is black same as background color value, so i did'nt know what was i am typing.
secondly, when I created a server there was only 1, but I got 2, could this be due to the effect of returning to the previous page (because I couldn't find the home menu/dashboard)?
third, when I wanted to try remote ssh with a domain address and port I got refused, maybe I should have used the IP address of that domain. but I hurriedly tried to delete one of the servers
fourth, when I delete one of the servers by giving the server name as server-id both of my servers are all deleted, or is the procedure like this?
v1.2
- Fixes:
- Css now loading from style.css
- HTML header has now separate file to load from
- Top header menu has now separate file to load from
- Install log now does error when SERVER-ID not found
- In Actions changed input background to gray and font white
- Changes:
- Top header menu "Servers" renamed to "Actions"
- In account panel menu "Servers" renamed to "Actions"
- Top header menu "Status" renamed to "Servers"
- In account panel menu "Status" renamed to "Servers"
v1.1
- New features:
- Command for opening new port
- Command for delete server
- Add Balance via plisio.net
- Top header menu
- Check if opened port number is in range from 1024 to 65535
- Check if command is available
- Check for available OS
- Added new OS Debian, Ubuntu, Alpine, CentOS, AlmaLinux, Devuan, Fedora, Gentoo, Kali, Mint, RockyLinux
- Added support panel
- Added account history
- Switched to account hash instead of username while registering
- Server could be deleted only via stop and delete command
- "To delete server first stop server then delete it."
v1.0
Initial
6th: added server delete command
Fun that it works without using the panel, once logged in, by using the URL-bar as command line and typing https://panel.s-e-r-v-e-r.pw/cmd?cmd=server+delete+NfTLBqhUlq-KLBfutuGkT7odJCl9BLd :-P
edit: although.... There was a confirmation the server got deleted, but it is still visible in the status page.
Deleted server: NfTLBqhUlq-KLBfutuGkT7odJCl9BLd
https://panel.s-e-r-v-e-r.pw/status
@wankel o well another bug
(> @s_e_r_v_e_r said:
Can't have everything at once :-D
Edit - maybe for the better that the confirmation is not what it seems :
Love the aesthetic!
Nope, so here is what I found out.
Once I checked the status: server info SERVER-ID
Then it started showing up in https://panel.s-e-r-v-e-r.pw/status
Maybe a bug?
Thats weird as server info have separate page https://panel.s-e-r-v-e-r.pw/info?server=SERVER-ID
maybe next bug
I'd like to test it out.
account hash: UVgI5n0Pcr
Nice!
What would you think of renaming the section 'Server' to 'Actions', and 'Status' to 'Server'?
Why? It seems the options under 'Server' are all actions, and the lines under 'Status' list servers.
Not sure if it really adds something, it just feels more to the point. Status could be referring to the status of the platform itself, maybe?
like it! but next changes/credits only tomorrow i dont have more time today.
thx so much for everyone out there!
My pleasure!
Happy to do some testing
Account Hash : 0TDFGB7Wt5
Few observations
Why should I trust?
Terms of Service
Privacy Policy
I like the aesthetics.
I don't like the AUP.
Good luck either way.
Greetings @s_e_r_v_e_r!
Welcome to LES!
Best wishes!
Tom
So everybody can see conveniently, here are screenshots and page code for @s_e_r_v_e_r's panel and landing page:
at last a beautiful site
did any tag @Not_Oles yet... he would censored word enjoy this
OH dear --- he already wrote ,, must had this old version.
he is here already, reverse engineering it
yep, long day for him
later
Thank you @s_e_r_v_e_r for this opportunity,
Your web panel look simple and awesome, like it.
So the panel lets you initiate a state change with a GET request? That seems like risky business.
https://www.rfc-editor.org/rfc/rfc7231#section-4.2.1
fuck the RFC
I'd like to give it a go if it's still open for testing!
Hash: lYbsNB6aJM
piximg image hosting
@itsdeadjim
@ialexpw
you can start testing
Again thx for everyone out there for helping
Still not everything fixed but we slowly fixing it!
https://panel.s-e-r-v-e-r.pw/changelog
v1.2 - Fixes: - Css now loading from style.css - HTML header has now separate file to load from - Top header menu has now separate file to load from - Install log now does error when SERVER-ID not found - In Actions changed input background to gray and font white - Changes: - Top header menu "Servers" renamed to "Actions" - In account panel menu "Servers" renamed to "Actions" - Top header menu "Status" renamed to "Servers" - In account panel menu "Status" renamed to "Servers" v1.1 - New features: - Command for opening new port - Command for delete server - Add Balance via plisio.net - Top header menu - Check if opened port number is in range from 1024 to 65535 - Check if command is available - Check for available OS - Added new OS Debian, Ubuntu, Alpine, CentOS, AlmaLinux, Devuan, Fedora, Gentoo, Kali, Mint, RockyLinux - Added support panel - Added account history - Switched to account hash instead of username while registering - Server could be deleted only via stop and delete command - "To delete server first stop server then delete it." v1.0 Initial
