@msatt said: On the servers page, can you link all of the available commands so that they pre fill in the box just by clicking them - saves typing & mistakes.
@Otus9051 said: I would rather like a full-on CLI experience rather than the commands taking me to pages.
probably will make special page/subdomain where you can write everything in cli mode
v1.3
- Fixes:
- Top header menu shows in pages - why, tos, aup, privacypolicy
- When there is no history in account show "No data."
- After successful login no more show when redirect to index the input for account hash and password
- Changes:
- Input background changed to gray and font to white on pages - login, create-account
- Error on wrong login changed from "Passwords do not match." to "Login failed."
- Login failed now has text color red
- After login failed the input for account hash and password is no more show
- New features:
- Added link with text "You can now go here and login." after creating account.
- Added links to index page into Actions with their commands
- Server [ Port Open ]
- Server [ Create Status ]
- No need to type the commands, now all commands are clickable and auto fill to input
@s_e_r_v_e_r I assume there are some problems with the VM creation?
I created a vm and was able to access via ssh. Left for a few minutes and was logged out. Tried to reconnect and got connection refused. Logged in to panel and VM was not showing.
Created a new VM which created fine, when I tried logging in the password failed.
Deleted this VM and created a new server and had same password failure.
Don't know if the idea of charging 2.50 per creation will be part of the future plan, but if a VM 'fails' as above, I would not be happy.
@msatt
i never had a password failure when tested, which OS did you installed? which ssh client you use? windows? linux?
PM me the password so i can check myself
that deletion was caused by me i purged all of the test server
also there is support for that case when something fails, but we still testing so bugs got fixed
@VirtFusion said: You should probably make sure a user sets a password when registering. Currently you can register and leave the password field empty.
Thx!
v1.4
- Fixes:
- Info server page now only show data when SERVER-ID is valid
- When creating account from now on you need to enter password
- When no password provided it fails with error "Please enter the password!"
I like the Panel. I see the only way to add credits is to pay in cryptocurrency, so is there a way to get some free credits to test more of the panel's interface out?
Done
Like azure cli or aws cli.
Also i think stylizing the buttons and the text fields to be a bit of terminal style would be better, they look out of place.
Account Hash : P21XwBB0ia
Count me in.
@msatt
Account Hash: 2cYf3R6ajS
wanna try the cool panel
You can then login with just the hash.
VirtFusion Affordable, Reliable virtualization management software for the hosting industry · Connect with us on Discord
Thx!
My Hash: C4MQzTcXSa
Maybe you can add a pricing section? How much credits is needed to crate a vps is unknown.
VPS providers to check out:
Hash: wcSN1gRRn9
I want to try that nice panel
Is this Panel a new pay-2-win UI? Seriously, is there a way to get some free credits to test more of the panel's interface out?
Add balance to your account!
[ Account ]
Hash: nr1ac2UV8y
Account Hash: JSiXc2fRDC
I wanna try this console-like panel.
Please let me in.
