@remy said: @iandk said: Pi 5 Basic System Information: --------------------------------- Uptime : 0 days, 1 hours, 6 minutes Processor : Cortex-A76 CPU cores : 4 @ 2400.0000 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 4.0 GiB Swap : 100.0 MiB Disk : 458.7 GiB Distro : Debian GNU/Linux 12 (bookworm) Kernel : 6.1.0-rpi6-rpi-2712 VM Type : NONE IPv4/IPv6 : ✔ Online / ✔ Online IPv6 Network Information: --------------------------------- ISP : Vodafone ASN : AS3209 Vodafone GmbH Host : Vodafone BW GmbH Location : Karlsruhe, Baden-Wurttemberg (BW) Country : Germany fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sda2): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 60.80 MB/s (15.2k) | 162.40 MB/s (2.5k) Write | 60.76 MB/s (15.1k) | 167.23 MB/s (2.6k) Total | 121.57 MB/s (30.3k) | 329.63 MB/s (5.1k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 197.01 MB/s (384) | 194.58 MB/s (190) Write | 213.86 MB/s (417) | 217.10 MB/s (212) Total | 410.88 MB/s (801) | 411.69 MB/s (402) Running GB6 benchmark test... *cue elevator music* Geekbench 6 Benchmark Test: --------------------------------- Test | Value | Single Core | 797 Multi Core | 1815 Full Test | https://browser.geekbench.com/v6/cpu/4269215 YABS completed in 10 min 2 sec At home ? Or datacenter ? I assume that vodaphone has data centres where they offer colocation. Although I think it's at home!
@iandk said: Pi 5
At home
AMD EPYC / NVMe / 10GBPs KVM in Frankfurt - https://v6node.com Looking for an unbeatable AMD EPYC Baremetal Server in Frankfurt? Drop me a PM
much better gb6 values then:
@lapua said: @iandk said: Pi 5 Basic System Information: --------------------------------- Uptime : 0 days, 1 hours, 6 minutes Processor : Cortex-A76 CPU cores : 4 @ 2400.0000 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 4.0 GiB Swap : 100.0 MiB Disk : 458.7 GiB Distro : Debian GNU/Linux 12 (bookworm) Kernel : 6.1.0-rpi6-rpi-2712 VM Type : NONE IPv4/IPv6 : ✔ Online / ✔ Online IPv6 Network Information: --------------------------------- ISP : Vodafone ASN : AS3209 Vodafone GmbH Host : Vodafone BW GmbH Location : Karlsruhe, Baden-Wurttemberg (BW) Country : Germany fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sda2): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 60.80 MB/s (15.2k) | 162.40 MB/s (2.5k) Write | 60.76 MB/s (15.1k) | 167.23 MB/s (2.6k) Total | 121.57 MB/s (30.3k) | 329.63 MB/s (5.1k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 197.01 MB/s (384) | 194.58 MB/s (190) Write | 213.86 MB/s (417) | 217.10 MB/s (212) Total | 410.88 MB/s (801) | 411.69 MB/s (402) Running GB6 benchmark test... *cue elevator music* Geekbench 6 Benchmark Test: --------------------------------- Test | Value | Single Core | 797 Multi Core | 1815 Full Test | https://browser.geekbench.com/v6/cpu/4269215 YABS completed in 10 min 2 sec much better gb6 values then: inleed vps starter 8€/month (https://lowendspirit.com/discussion/comment/166230/#Comment_166230) ionos 1€/month (https://lowendspirit.com/discussion/comment/164988/#Comment_164988)
@lapua said:
Yes, great performance. Wonder what type of disks it has? @iandk
Got a new home server, Asus PN53, Ryzen 7 7735H 2 x 4096 GB Kingston KC3000 NVMe in RAID1 Debian 12, 6.1 kernel
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2024-01-01 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Fri Jan 5 11:36:46 PM CET 2024 Basic System Information: --------------------------------- Uptime : 0 days, 5 hours, 31 minutes Processor : AMD Ryzen 7 7735HS with Radeon Graphics CPU cores : 16 @ 1600.000 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 62.0 GiB Swap : 0.0 KiB Disk : 91.5 GiB Distro : Debian GNU/Linux 12 (bookworm) Kernel : 6.1.0-17-amd64 VM Type : NONE IPv4/IPv6 : ✔ Online / ❌ Offline fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/md0): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 987.91 MB/s (246.9k) | 3.93 GB/s (61.4k) Write | 990.52 MB/s (247.6k) | 3.95 GB/s (61.7k) Total | 1.97 GB/s (494.6k) | 7.88 GB/s (123.1k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 4.30 GB/s (8.4k) | 4.35 GB/s (4.2k) Write | 4.52 GB/s (8.8k) | 4.64 GB/s (4.5k) Total | 8.83 GB/s (17.2k) | 9.00 GB/s (8.7k) Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1736 Multi Core | 10572 Full Test | https://browser.geekbench.com/v5/cpu/22110124 Geekbench 6 Benchmark Test: --------------------------------- Test | Value | Single Core | 2227 Multi Core | 10919 Full Test | https://browser.geekbench.com/v6/cpu/4275547 YABS completed in 9 min 48 sec
@loay said: @lapua said: @iandk said: Pi 5 Basic System Information: --------------------------------- Uptime : 0 days, 1 hours, 6 minutes Processor : Cortex-A76 CPU cores : 4 @ 2400.0000 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 4.0 GiB Swap : 100.0 MiB Disk : 458.7 GiB Distro : Debian GNU/Linux 12 (bookworm) Kernel : 6.1.0-rpi6-rpi-2712 VM Type : NONE IPv4/IPv6 : ✔ Online / ✔ Online IPv6 Network Information: --------------------------------- ISP : Vodafone ASN : AS3209 Vodafone GmbH Host : Vodafone BW GmbH Location : Karlsruhe, Baden-Wurttemberg (BW) Country : Germany fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sda2): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 60.80 MB/s (15.2k) | 162.40 MB/s (2.5k) Write | 60.76 MB/s (15.1k) | 167.23 MB/s (2.6k) Total | 121.57 MB/s (30.3k) | 329.63 MB/s (5.1k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 197.01 MB/s (384) | 194.58 MB/s (190) Write | 213.86 MB/s (417) | 217.10 MB/s (212) Total | 410.88 MB/s (801) | 411.69 MB/s (402) Running GB6 benchmark test... *cue elevator music* Geekbench 6 Benchmark Test: --------------------------------- Test | Value | Single Core | 797 Multi Core | 1815 Full Test | https://browser.geekbench.com/v6/cpu/4269215 YABS completed in 10 min 2 sec much better gb6 values then: inleed vps starter 8€/month (https://lowendspirit.com/discussion/comment/166230/#Comment_166230) ionos 1€/month (https://lowendspirit.com/discussion/comment/164988/#Comment_164988) Yes, great performance. Wonder what type of disks it has? @iandk
@loay said:
It's an old Samsung T5 that I still had lying around. I'm really pleased with the performance.
NL Idler
Basic System Information: --------------------------------- Uptime : 36 days, 9 hours, 22 minutes Processor : Intel(R) Xeon(R) Gold 6138 CPU @ 2.00GHz CPU cores : 80 @ 2000.000 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 125.5 GiB Swap : 8.0 GiB Disk : 3.4 TiB Distro : Ubuntu 22.04.3 LTS Kernel : 5.15.0-89-generic VM Type : NONE IPv4/IPv6 : ✔ Online / ❌ Offline IPv4 Network Information: --------------------------------- ISP : RoyaleHosting BV ASN : AS212477 RoyaleHosting BV Host : RoyaleHosting BV Location : Amsterdam, North Holland (NH) Country : The Netherlands fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/nvme0n1p2): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 715.29 MB/s (178.8k) | 1.60 GB/s (25.1k) Write | 717.18 MB/s (179.2k) | 1.61 GB/s (25.2k) Total | 1.43 GB/s (358.1k) | 3.22 GB/s (50.4k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.98 GB/s (3.8k) | 2.17 GB/s (2.1k) Write | 2.09 GB/s (4.0k) | 2.31 GB/s (2.2k) Total | 4.08 GB/s (7.9k) | 4.49 GB/s (4.3k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 8.34 Gbits/sec | 8.20 Gbits/sec | 5.76 ms Scaleway | Paris, FR (10G) | 2.84 Gbits/sec | busy | 9.65 ms NovoServe | North Holland, NL (40G) | 9.27 Gbits/sec | 3.70 Gbits/sec | 0.662 ms Uztelecom | Tashkent, UZ (10G) | 464 Mbits/sec | 724 Mbits/sec | 232 ms Clouvider | NYC, NY, US (10G) | 1.80 Gbits/sec | 1.56 Gbits/sec | 75.0 ms Clouvider | Dallas, TX, US (10G) | 1.66 Gbits/sec | 1.70 Gbits/sec | 107 ms Clouvider | Los Angeles, CA, US (10G) | 998 Mbits/sec | 1.43 Gbits/sec | 125 ms Geekbench 6 Benchmark Test: --------------------------------- Test | Value | Single Core | 1223 Multi Core | 9840 Full Test | https://browser.geekbench.com/v6/cpu/4304917 YABS completed in 10 min 22 sec
@fluttershy said: Processor : Intel(R) Xeon(R) Gold 6138 CPU @ 2.00GHz CPU cores : 80 @ 2000.000 MHz
Holy 🐮!
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2024-01-01 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Tue Jan 9 05:19:32 AM EST 2024 Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 2 minutes Processor : AMD EPYC 7742 64-Core Processor CPU cores : 255 @ 1500.000 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 1.8 TiB Swap : 0.0 KiB Disk : 27.8 TiB Distro : Debian GNU/Linux 12 (bookworm) Kernel : 6.1.0-17-amd64 VM Type : NONE IPv4/IPv6 : ✔ Online / ❌ Offline IPv4 Network Information: --------------------------------- ISP : WebHorizon Internet Services ASN : AS149020 WebHorizon Internet Services Host : Webhrzn Location : Tokyo, Tokyo (13) Country : Japan fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/md0): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 481.35 MB/s (120.3k) | 3.52 GB/s (55.0k) Write | 482.62 MB/s (120.6k) | 3.53 GB/s (55.3k) Total | 963.98 MB/s (240.9k) | 7.06 GB/s (110.3k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 4.64 GB/s (9.0k) | 5.08 GB/s (4.9k) Write | 4.88 GB/s (9.5k) | 5.42 GB/s (5.2k) Total | 9.53 GB/s (18.6k) | 10.51 GB/s (10.2k) Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1046 Multi Core | 29827 Full Test | https://browser.geekbench.com/v5/cpu/22119886
https://webhorizon.net
@Abdullah said:
> # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # > # Yet-Another-Bench-Script # > # v2024-01-01 # > # https://github.com/masonr/yet-another-bench-script # > # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # > > Tue Jan 9 05:19:32 AM EST 2024 > > > Basic System Information: > --------------------------------- > Uptime : 0 days, 0 hours, 2 minutes > Processor : AMD EPYC 7742 64-Core Processor > CPU cores : 255 @ 1500.000 MHz > AES-NI : ✔ Enabled > VM-x/AMD-V : ✔ Enabled > RAM : 1.8 TiB > Swap : 0.0 KiB > Disk : 27.8 TiB > Distro : Debian GNU/Linux 12 (bookworm) > Kernel : 6.1.0-17-amd64 > VM Type : NONE > IPv4/IPv6 : ✔ Online / ❌ Offline > > IPv4 Network Information: > --------------------------------- > ISP : WebHorizon Internet Services > ASN : AS149020 WebHorizon Internet Services > Host : Webhrzn > Location : Tokyo, Tokyo (13) > Country : Japan > > fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/md0): > --------------------------------- > Block Size | 4k (IOPS) | 64k (IOPS) > ------ | --- ---- | ---- ---- > Read | 481.35 MB/s (120.3k) | 3.52 GB/s (55.0k) > Write | 482.62 MB/s (120.6k) | 3.53 GB/s (55.3k) > Total | 963.98 MB/s (240.9k) | 7.06 GB/s (110.3k) > | | > Block Size | 512k (IOPS) | 1m (IOPS) > ------ | --- ---- | ---- ---- > Read | 4.64 GB/s (9.0k) | 5.08 GB/s (4.9k) > Write | 4.88 GB/s (9.5k) | 5.42 GB/s (5.2k) > Total | 9.53 GB/s (18.6k) | 10.51 GB/s (10.2k) > > Geekbench 5 Benchmark Test: > --------------------------------- > Test | Value > | > Single Core | 1046 > Multi Core | 29827 > Full Test | https://browser.geekbench.com/v5/cpu/22119886 >
wow beefy! in best location!
1046x255=29827 oha!
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2024-01-01 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Wed Jan 10 05:25:27 AM EST 2024 Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 19 minutes Processor : AMD EPYC 7B13 64-Core Processor CPU cores : 256 @ 1500.000 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 1.8 TiB Swap : 0.0 KiB Disk : 27.8 TiB Distro : Debian GNU/Linux 12 (bookworm) Kernel : 6.1.0-17-amd64 VM Type : NONE IPv4/IPv6 : ✔ Online / ❌ Offline fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/md0): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 435.69 MB/s (108.9k) | 2.48 GB/s (38.7k) Write | 436.84 MB/s (109.2k) | 2.49 GB/s (38.9k) Total | 872.54 MB/s (218.1k) | 4.97 GB/s (77.7k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 4.77 GB/s (9.3k) | 4.37 GB/s (4.2k) Write | 5.02 GB/s (9.8k) | 4.66 GB/s (4.5k) Total | 9.79 GB/s (19.1k) | 9.03 GB/s (8.8k) Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1201 Multi Core | 48604 Full Test | https://browser.geekbench.com/v5/cpu/22122849
@Abdullah said: Single Core | 1201 Multi Core | 48604
Enough teasing, now show us the real thing, I mean release the... deals. Deadpool Wolverine deals to fill the servers
1201x256=48604 oha!
@Abdullah
this is epic:
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2024-01-01 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Wed Jan 10 14:12:50 UTC 2024 Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 1 minutes Processor : Intel Xeon Processor (Skylake, IBRS) CPU cores : 1 @ 2099.998 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 943.1 MiB Swap : 2.0 GiB Disk : 9.8 GiB Distro : Debian GNU/Linux 11 (bullseye) Kernel : 5.10.0-27-cloud-amd64 VM Type : MICROSOFT IPv4/IPv6 : ✔ Online / ❌ Offline IPv4 Network Information: --------------------------------- ISP : Strato AG ASN : AS6724 Strato AG Host : Strato AG Location : Berlin, Land Berlin (BE) Country : Germany fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda1): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 22.04 MB/s (5.5k) | 241.50 MB/s (3.7k) Write | 22.06 MB/s (5.5k) | 242.77 MB/s (3.7k) Total | 44.10 MB/s (11.0k) | 484.27 MB/s (7.5k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 474.09 MB/s (925) | 480.48 MB/s (469) Write | 499.28 MB/s (975) | 512.48 MB/s (500) Total | 973.38 MB/s (1.9k) | 992.96 MB/s (969) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 1.57 Gbits/sec | 1.70 Gbits/sec | 21.8 ms Scaleway | Paris, FR (10G) | 1.31 Gbits/sec | 1.60 Gbits/sec | 24.7 ms NovoServe | North Holland, NL (40G) | 1.74 Gbits/sec | 1.61 Gbits/sec | 18.9 ms Uztelecom | Tashkent, UZ (10G) | 799 Mbits/sec | 1.61 Gbits/sec | 109 ms Clouvider | NYC, NY, US (10G) | 1.29 Gbits/sec | 1.20 Gbits/sec | 93.9 ms Clouvider | Dallas, TX, US (10G) | 1.21 Gbits/sec | 813 Mbits/sec | 125 ms Clouvider | Los Angeles, CA, US (10G) | 1.06 Gbits/sec | 566 Mbits/sec | 157 ms Geekbench 6 Benchmark Test: --------------------------------- Test | Value | Single Core | 167 Multi Core | 137 YABS completed in 65 min 1 sec
@mxmla's SWE pre-order for €48 / year, which is NL now
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2024-01-01 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Wed Jan 10 02:43:31 PM CET 2024 Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 38 minutes Processor : AMD Ryzen 9 7950X 16-Core Processor CPU cores : 2 @ 4491.556 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 3.5 GiB Swap : 0.0 KiB Disk : 99.9 GiB Distro : Rocky Linux 9.3 (Blue Onyx) Kernel : 5.14.0-362.13.1.el9_3.x86_64 VM Type : KVM IPv4/IPv6 : ✔ Online / ✔ Online IPv6 Network Information: --------------------------------- ISP : Maximilian Jacobsen ASN : AS206075 Maximilian Jacobsen Host : De Maximilian Jacobsen Location : Eygelshoven, Limburg (LI) Country : The Netherlands fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sda3): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 420.05 MB/s (105.0k) | 3.10 GB/s (48.5k) Write | 421.16 MB/s (105.2k) | 3.12 GB/s (48.8k) Total | 841.21 MB/s (210.3k) | 6.23 GB/s (97.3k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 3.65 GB/s (7.1k) | 4.21 GB/s (4.1k) Write | 3.84 GB/s (7.5k) | 4.49 GB/s (4.3k) Total | 7.50 GB/s (14.6k) | 8.70 GB/s (8.4k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 2.51 Gbits/sec | 2.39 Gbits/sec | 8.70 ms Scaleway | Paris, FR (10G) | 2.42 Gbits/sec | 2.38 Gbits/sec | 12.9 ms NovoServe | North Holland, NL (40G) | 2.59 Gbits/sec | 2.44 Gbits/sec | 4.33 ms Uztelecom | Tashkent, UZ (10G) | 834 Mbits/sec | 1.75 Gbits/sec | 92.0 ms Clouvider | NYC, NY, US (10G) | 573 Mbits/sec | 1.90 Gbits/sec | 77.7 ms Clouvider | Dallas, TX, US (10G) | 481 Mbits/sec | 1.60 Gbits/sec | 119 ms Clouvider | Los Angeles, CA, US (10G) | 484 Mbits/sec | 1.08 Gbits/sec | 148 ms iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 2.44 Gbits/sec | 2.35 Gbits/sec | 8.70 ms Scaleway | Paris, FR (10G) | busy | busy | 13.1 ms NovoServe | North Holland, NL (40G) | 2.59 Gbits/sec | 2.40 Gbits/sec | 4.21 ms Uztelecom | Tashkent, UZ (10G) | 286 Mbits/sec | 1.74 Gbits/sec | 91.9 ms Clouvider | NYC, NY, US (10G) | 363 Mbits/sec | busy | 77.5 ms Clouvider | Dallas, TX, US (10G) | 384 Mbits/sec | 1.05 Gbits/sec | 119 ms Clouvider | Los Angeles, CA, US (10G) | 389 Mbits/sec | 938 Mbits/sec | 149 ms Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 2222 Multi Core | 4226 Full Test | https://browser.geekbench.com/v5/cpu/22123309 Geekbench 6 Benchmark Test: --------------------------------- Test | Value | Single Core | 3070 Multi Core | 5419 Full Test | https://browser.geekbench.com/v6/cpu/4335150 YABS completed in 13 min 29 sec
Fiberstate Ryzen dedicated for $49.95 / month
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2024-01-01 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Sun Jan 7 01:32:17 EST 2024 Basic System Information: --------------------------------- Uptime : 0 days, 5 hours, 17 minutes Processor : AMD Ryzen 7 5700G with Radeon Graphics CPU cores : 16 @ 3800.000 MHz AES-NI : ✔️ Enabled VM-x/AMD-V : ✔️ Enabled RAM : 61.9 GiB Swap : 32.0 GiB Disk : 899.1 GiB Distro : AlmaLinux 9.3 (Shamrock Pampas Cat) Kernel : 5.14.0-284.11.1.el9_2.x86_64 VM Type : NONE IPv4/IPv6 : ✔️ Online / ❌ Offline IPv4 Network Information: --------------------------------- ISP : FiberState, LLC ASN : AS26042 FiberState, LLC Host : FiberState, LLC Location : Draper, Utah (UT) Country : United States fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/nvme0n1p4): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 734.61 MB/s (183.6k) | 381.06 MB/s (5.9k) Write | 736.55 MB/s (184.1k) | 383.06 MB/s (5.9k) Total | 1.47 GB/s (367.7k) | 764.12 MB/s (11.9k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 621.50 MB/s (1.2k) | 765.58 MB/s (747) Write | 654.52 MB/s (1.2k) | 816.57 MB/s (797) Total | 1.27 GB/s (2.4k) | 1.58 GB/s (1.5k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 851 Mbits/sec | 629 Mbits/sec | 114 ms Scaleway | Paris, FR (10G) | busy | busy | 126 ms Clouvider | NYC, NY, US (10G) | 908 Mbits/sec | 913 Mbits/sec | 48.5 ms Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1691 Multi Core | 9968 Full Test | https://browser.geekbench.com/v5/cpu/22113841 Geekbench 6 Benchmark Test: --------------------------------- Test | Value | Single Core | 2190 Multi Core | 10260 Full Test | https://browser.geekbench.com/v6/cpu/4292982 YABS completed in 9 min 53 sec
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2024-01-01 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Fri Jan 12 12:44:18 PM CET 2024 Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 7 minutes Processor : AMD Ryzen 9 7950X 16-Core Processor CPU cores : 1 @ 4491.556 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 1.9 GiB Swap : 0.0 KiB Disk : 49.1 GiB Distro : Debian GNU/Linux 12 (bookworm) Kernel : 6.1.0-17-amd64 VM Type : KVM IPv4/IPv6 : ✔ Online / ✔ Online IPv6 Network Information: --------------------------------- ISP : Maximilian Jacobsen ASN : AS206075 Maximilian Jacobsen Host : De Maximilian Jacobsen Location : Eygelshoven, Limburg (LI) Country : The Netherlands fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sda2): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 422.08 MB/s (105.5k) | 3.26 GB/s (51.0k) Write | 423.19 MB/s (105.7k) | 3.28 GB/s (51.3k) Total | 845.28 MB/s (211.3k) | 6.55 GB/s (102.3k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 3.48 GB/s (6.8k) | 3.53 GB/s (3.4k) Write | 3.67 GB/s (7.1k) | 3.77 GB/s (3.6k) Total | 7.15 GB/s (13.9k) | 7.30 GB/s (7.1k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 2.49 Gbits/sec | 2.39 Gbits/sec | 8.83 ms Scaleway | Paris, FR (10G) | busy | 2.37 Gbits/sec | 12.1 ms NovoServe | North Holland, NL (40G) | 2.59 Gbits/sec | 2.43 Gbits/sec | 4.28 ms Uztelecom | Tashkent, UZ (10G) | 538 Mbits/sec | 1.57 Gbits/sec | 90.5 ms Clouvider | NYC, NY, US (10G) | 529 Mbits/sec | 2.03 Gbits/sec | 77.8 ms Clouvider | Dallas, TX, US (10G) | 382 Mbits/sec | 1.10 Gbits/sec | 121 ms Clouvider | Los Angeles, CA, US (10G) | 388 Mbits/sec | 1.14 Gbits/sec | 156 ms iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 2.46 Gbits/sec | 2.37 Gbits/sec | 8.71 ms Scaleway | Paris, FR (10G) | busy | busy | 16.7 ms NovoServe | North Holland, NL (40G) | 2.59 Gbits/sec | 2.40 Gbits/sec | 4.27 ms Uztelecom | Tashkent, UZ (10G) | 451 Mbits/sec | 1.85 Gbits/sec | 90.4 ms Clouvider | NYC, NY, US (10G) | 289 Mbits/sec | 1.80 Gbits/sec | 77.5 ms Clouvider | Dallas, TX, US (10G) | 298 Mbits/sec | 1.13 Gbits/sec | 122 ms Clouvider | Los Angeles, CA, US (10G) | 410 Mbits/sec | 1.17 Gbits/sec | 156 ms Geekbench 6 Benchmark Test: --------------------------------- Test | Value | Single Core | 3041 Multi Core | 3070 YABS completed in 13 min 21 sec
@govac said: @mxmla's SWE pre-order for €48 / year, which is NL now
good deal for this beast. - new nl are much more expensive.
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2024-01-01 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Fri Jan 12 03:35:14 PM CET 2024 Basic System Information: --------------------------------- Uptime : 0 days, 2 hours, 57 minutes Processor : AMD Ryzen 9 7950X 16-Core Processor CPU cores : 1 @ 4491.556 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 1.9 GiB Swap : 0.0 KiB Disk : 49.1 GiB Distro : Debian GNU/Linux 12 (bookworm) Kernel : 6.1.0-17-amd64 VM Type : KVM IPv4/IPv6 : ✔ Online / ✔ Online IPv6 Network Information: --------------------------------- ISP : Maximilian Jacobsen ASN : AS206075 Maximilian Jacobsen Host : De Maximilian Jacobsen Location : Eygelshoven, Limburg (LI) Country : The Netherlands fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sda2): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 422.42 MB/s (105.6k) | 3.53 GB/s (55.2k) Write | 423.54 MB/s (105.8k) | 3.55 GB/s (55.5k) Total | 845.96 MB/s (211.4k) | 7.09 GB/s (110.8k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 3.59 GB/s (7.0k) | 3.69 GB/s (3.6k) Write | 3.78 GB/s (7.3k) | 3.93 GB/s (3.8k) Total | 7.37 GB/s (14.3k) | 7.62 GB/s (7.4k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 2.48 Gbits/sec | 2.38 Gbits/sec | 8.75 ms Scaleway | Paris, FR (10G) | busy | busy | 12.0 ms NovoServe | North Holland, NL (40G) | 2.60 Gbits/sec | 2.43 Gbits/sec | 4.18 ms Uztelecom | Tashkent, UZ (10G) | 490 Mbits/sec | 1.70 Gbits/sec | 90.8 ms Clouvider | NYC, NY, US (10G) | 635 Mbits/sec | busy | 77.4 ms Clouvider | Dallas, TX, US (10G) | 275 Mbits/sec | 1.56 Gbits/sec | 119 ms Clouvider | Los Angeles, CA, US (10G) | 450 Mbits/sec | 1.17 Gbits/sec | 156 ms iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 2.50 Gbits/sec | 2.37 Gbits/sec | 8.69 ms Scaleway | Paris, FR (10G) | busy | busy | 16.3 ms NovoServe | North Holland, NL (40G) | 2.59 Gbits/sec | 2.40 Gbits/sec | 4.15 ms Uztelecom | Tashkent, UZ (10G) | 149 Mbits/sec | busy | 91.1 ms Clouvider | NYC, NY, US (10G) | 307 Mbits/sec | 1.40 Gbits/sec | 77.4 ms Clouvider | Dallas, TX, US (10G) | 287 Mbits/sec | 885 Mbits/sec | 119 ms Clouvider | Los Angeles, CA, US (10G) | 345 Mbits/sec | 1.15 Gbits/sec | 156 ms Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 9280 Multi Core | 8637 YABS completed in 11 min 5 sec
@abiaolaoge said: Mini PC bought on Xianyu for $8, looks pretty good. The TDP is only 4.4 watts. Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 14 minutes Processor : Intel(R) Atom(TM) CPU Z3735F @ 1.33GHz CPU cores : 4 @ 678.840 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 1.9 GiB Swap : 0.0 KiB Disk : 28.5 GiB Distro : Debian GNU/Linux 12 (bookworm) Kernel : 6.5.0-0.deb12.4-amd64 VM Type : NONE IPv4/IPv6 : ✔ Online / ❌ Offline fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/mmcblk2p2): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 2.73 MB/s (683) | 20.10 MB/s (314) Write | 2.74 MB/s (686) | 20.72 MB/s (323) Total | 5.47 MB/s (1.3k) | 40.82 MB/s (637) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 26.21 MB/s (51) | 26.01 MB/s (25) Write | 28.10 MB/s (54) | 28.21 MB/s (27) Total | 54.31 MB/s (105) | 54.23 MB/s (52) Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 190 Multi Core | 594 Full Test | https://browser.geekbench.com/v5/cpu/22095348
link pleasee
E3 from F4
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2024-01-01 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Sat Jan 13 10:25:27 PM UTC 2024 Basic System Information: --------------------------------- Uptime : 13 days, 20 hours, 47 minutes Processor : Intel(R) Xeon(R) CPU E3-1240 v3 @ 3.40GHz CPU cores : 8 @ 3612.688 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 15.6 GiB Swap : 3.8 GiB Disk : 178.4 GiB Distro : Debian GNU/Linux 12 (bookworm) Kernel : 6.5.11-7-pve VM Type : NONE IPv4/IPv6 : ✔ Online / ❌ Offline IPv4 Network Information: --------------------------------- ISP : Rozint Ltd Co ASN : AS21738 Rozint Ltd Co Host : Rozint Ltd Co Location : Kansas City, Missouri (MO) Country : United States fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/mapper/kc--hvr--002--vg-root): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 156.51 MB/s (39.1k) | 160.46 MB/s (2.5k) Write | 156.93 MB/s (39.2k) | 161.30 MB/s (2.5k) Total | 313.45 MB/s (78.3k) | 321.77 MB/s (5.0k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 142.79 MB/s (278) | 152.66 MB/s (149) Write | 150.38 MB/s (293) | 162.83 MB/s (159) Total | 293.18 MB/s (571) | 315.50 MB/s (308) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 22.7 Mbits/sec | 149 Mbits/sec | 104 ms Scaleway | Paris, FR (10G) | busy | busy | 108 ms NovoServe | North Holland, NL (40G) | 13.2 Mbits/sec | 586 Mbits/sec | 111 ms Uztelecom | Tashkent, UZ (10G) | 6.89 Mbits/sec | 40.1 Mbits/sec | 196 ms Clouvider | NYC, NY, US (10G) | 46.7 Mbits/sec | 314 Mbits/sec | 30.5 ms Clouvider | Dallas, TX, US (10G) | 77.6 Mbits/sec | 458 Mbits/sec | 11.6 ms Clouvider | Los Angeles, CA, US (10G) | 31.4 Mbits/sec | 264 Mbits/sec | 41.8 ms Geekbench 6 Benchmark Test: --------------------------------- Test | Value | Single Core | 1245 Multi Core | 4058 Full Test | https://browser.geekbench.com/v6/cpu/4381153 YABS completed in 12 min 14 sec
8GB €10/yr NVME KVM - C1V HOSTING 2 vCore CPU, 8GB DDR4 ECC RAM, 70GB SSD NVMe PCIe, 25TB @ 1Gbps monthly traffic usage, 1 IPv4 address, 1 IPv6 address
Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 1 minutes Processor : Intel(R) Xeon(R) CPU E5-2697A v4 @ 2.60GHz CPU cores : 2 @ 2596.990 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 7.6 GiB Swap : 0.0 KiB Disk : 68.3 GiB Distro : Debian GNU/Linux 12 (bookworm) Kernel : 6.5.0-0.deb12.4-cloud-amd64 VM Type : KVM IPv4/IPv6 : ✔ Online / ✔ Online fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sda1): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 91.72 MB/s (22.9k) | 560.16 MB/s (8.7k) Write | 91.96 MB/s (22.9k) | 563.11 MB/s (8.7k) Total | 183.69 MB/s (45.9k) | 1.12 GB/s (17.5k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 532.27 MB/s (1.0k) | 585.39 MB/s (571) Write | 560.55 MB/s (1.0k) | 624.38 MB/s (609) Total | 1.09 GB/s (2.1k) | 1.20 GB/s (1.1k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 1.01 Gbits/sec | 556 Mbits/sec | 43.9 ms Scaleway | Paris, FR (10G) | 1.02 Gbits/sec | busy | 32.3 ms NovoServe | North Holland, NL (40G) | 1.02 Gbits/sec | 970 Mbits/sec | 32.6 ms Uztelecom | Tashkent, UZ (10G) | 908 Mbits/sec | 908 Mbits/sec | 117 ms Clouvider | NYC, NY, US (10G) | 682 Mbits/sec | 232 Mbits/sec | 142 ms Clouvider | Dallas, TX, US (10G) | 614 Mbits/sec | 576 Mbits/sec | 135 ms Clouvider | Los Angeles, CA, US (10G) | busy | 534 Mbits/sec | 165 ms iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 1.02 Gbits/sec | 968 Mbits/sec | 43.9 ms Scaleway | Paris, FR (10G) | busy | busy | 23.4 ms NovoServe | North Holland, NL (40G) | 1.02 Gbits/sec | 964 Mbits/sec | 33.8 ms Uztelecom | Tashkent, UZ (10G) | 781 Mbits/sec | 917 Mbits/sec | 118 ms Clouvider | NYC, NY, US (10G) | 657 Mbits/sec | 514 Mbits/sec | 142 ms Clouvider | Dallas, TX, US (10G) | 623 Mbits/sec | 893 Mbits/sec | 135 ms Clouvider | Los Angeles, CA, US (10G) | 564 Mbits/sec | 854 Mbits/sec | 165 ms Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 657 Multi Core | 692 Full Test | https://browser.geekbench.com/v5/cpu/22136999
VirMach: Customer’s Service cannot use more than 10% of the monthly allocated bandwidth in under twenty-four (24) hours. https://virmach.com/terms-conditions/#aup
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2024-01-01 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Mon Jan 15 18:16:08 UTC 2024 Basic System Information: --------------------------------- Uptime : 0 days, 19 hours, 2 minutes Processor : AMD EPYC 7543 32-Core Processor CPU cores : 4 @ 2799.998 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 15.6 GiB Swap : 0.0 KiB Disk : 121.1 GiB Distro : Ubuntu 22.04.3 LTS Kernel : 5.15.0-91-generic VM Type : KVM IPv4/IPv6 : ✔ Online / ✔ Online fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sda1): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 315.22 MB/s (78.8k) | 3.35 GB/s (52.3k) Write | 316.06 MB/s (79.0k) | 3.36 GB/s (52.6k) Total | 631.29 MB/s (157.8k) | 6.72 GB/s (105.0k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 3.39 GB/s (6.6k) | 3.18 GB/s (3.1k) Write | 3.57 GB/s (6.9k) | 3.39 GB/s (3.3k) Total | 6.97 GB/s (13.6k) | 6.58 GB/s (6.4k) Geekbench 6 Benchmark Test: --------------------------------- Test | Value | Single Core | 1637 Multi Core | 5328 YABS completed in 6 min 10 sec
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2024-01-01 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Mon Jan 15 18:21:49 UTC 2024 Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 5 minutes Processor : AMD Ryzen 9 7900X3D 12-Core Processor CPU cores : 4 @ 4399.996 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 15.6 GiB Swap : 0.0 KiB Disk : 193.8 GiB Distro : Ubuntu 22.04.3 LTS Kernel : 5.15.0-91-generic VM Type : KVM IPv4/IPv6 : ✔ Online / ✔ Online fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sda1): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 521.77 MB/s (130.4k) | 1.62 GB/s (25.4k) Write | 523.14 MB/s (130.7k) | 1.63 GB/s (25.5k) Total | 1.04 GB/s (261.2k) | 3.26 GB/s (51.0k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.96 GB/s (3.8k) | 2.26 GB/s (2.2k) Write | 2.07 GB/s (4.0k) | 2.41 GB/s (2.3k) Total | 4.04 GB/s (7.8k) | 4.68 GB/s (4.5k) Geekbench 6 Benchmark Test: --------------------------------- Test | Value | Single Core | 2772 Multi Core | 8397 YABS completed in 4 min 59 sec
32GB €15/yr NVME KVM - C1V HOSTING 1 vCores, 32GB RAM, 25GB SSD, 10TB @ 500Mbps bandwidth, 1 IPv4, 1 IPv6 address
Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 0 minutes Processor : Intel(R) Xeon(R) CPU E5-2698 v4 @ 2.20GHz CPU cores : 1 @ 2199.996 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 30.6 GiB Swap : 0.0 KiB Disk : 24.4 GiB Distro : Debian GNU/Linux 12 (bookworm) Kernel : 6.5.10 VM Type : KVM IPv4/IPv6 : ✔ Online / ✔ Online fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sda1): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 19.30 MB/s (4.8k) | 254.52 MB/s (3.9k) Write | 19.30 MB/s (4.8k) | 255.85 MB/s (3.9k) Total | 38.60 MB/s (9.6k) | 510.37 MB/s (7.9k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 792.73 MB/s (1.5k) | 947.06 MB/s (924) Write | 834.85 MB/s (1.6k) | 1.01 GB/s (986) Total | 1.62 GB/s (3.1k) | 1.95 GB/s (1.9k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 504 Mbits/sec | 448 Mbits/sec | 33.0 ms Scaleway | Paris, FR (10G) | busy | busy | 32.3 ms NovoServe | North Holland, NL (40G) | 502 Mbits/sec | 464 Mbits/sec | 32.0 ms Uztelecom | Tashkent, UZ (10G) | 440 Mbits/sec | 442 Mbits/sec | 129 ms Clouvider | NYC, NY, US (10G) | 438 Mbits/sec | 381 Mbits/sec | 104 ms Clouvider | Dallas, TX, US (10G) | 425 Mbits/sec | 389 Mbits/sec | 136 ms Clouvider | Los Angeles, CA, US (10G) | 388 Mbits/sec | 349 Mbits/sec | 156 ms iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 505 Mbits/sec | 477 Mbits/sec | 33.0 ms Scaleway | Paris, FR (10G) | busy | busy | 23.5 ms NovoServe | North Holland, NL (40G) | 502 Mbits/sec | 474 Mbits/sec | 33.1 ms Uztelecom | Tashkent, UZ (10G) | 443 Mbits/sec | 455 Mbits/sec | 128 ms Clouvider | NYC, NY, US (10G) | 462 Mbits/sec | 450 Mbits/sec | 104 ms Clouvider | Dallas, TX, US (10G) | 440 Mbits/sec | 426 Mbits/sec | 134 ms Clouvider | Los Angeles, CA, US (10G) | 395 Mbits/sec | busy | 156 ms Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 349 Multi Core | 349 Full Test | https://browser.geekbench.com/v5/cpu/22141579
Our newest member to the offer family. 22 USD /YR. - Kepler-70 - NVME VPS - HOST-C 1C/1G/20GB NVME, 1GBPS@2TB traffic.
root@test:~# curl -sL yabs.sh | bash # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2024-01-01 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Wed Jan 17 12:52:19 UTC 2024 Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 0 minutes Processor : Intel(R) Xeon(R) CPU E5-2690 v4 @ 2.60GHz CPU cores : 1 @ 2599.996 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 977.2 MiB Swap : 0.0 KiB Disk : 19.6 GiB Distro : Debian GNU/Linux 12 (bookworm) Kernel : 6.1.0-17-cloud-amd64 VM Type : KVM IPv4/IPv6 : ✔ Online / ❌ Offline IPv4 Network Information: --------------------------------- ISP : Andrei Tiberiu Holt ASN : AS211462 Andrei Tiberiu Holt Host : Andrei Tiberiu Holt Location : Oradea, Bihor County (BH) Country : Romania fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sda1): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 140.78 MB/s (35.1k) | 1.22 GB/s (19.0k) Write | 141.15 MB/s (35.2k) | 1.22 GB/s (19.1k) Total | 281.93 MB/s (70.4k) | 2.44 GB/s (38.2k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.51 GB/s (2.9k) | 1.54 GB/s (1.5k) Write | 1.59 GB/s (3.1k) | 1.65 GB/s (1.6k) Total | 3.10 GB/s (6.0k) | 3.19 GB/s (3.1k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 952 Mbits/sec | 979 Mbits/sec | 29.5 ms Scaleway | Paris, FR (10G) | busy | 945 Mbits/sec | 27.6 ms NovoServe | North Holland, NL (40G) | 964 Mbits/sec | 898 Mbits/sec | 32.4 ms Uztelecom | Tashkent, UZ (10G) | 506 Mbits/sec | 676 Mbits/sec | 103 ms Clouvider | NYC, NY, US (10G) | 523 Mbits/sec | 720 Mbits/sec | 114 ms Clouvider | Dallas, TX, US (10G) | 428 Mbits/sec | 572 Mbits/sec | 136 ms Clouvider | Los Angeles, CA, US (10G) | 429 Mbits/sec | busy | 161 ms Geekbench test failed and low memory was detected. Add at least 1GB of SWAP or use GB4 instead (higher compatibility with low memory systems). YABS completed in 7 min 31 sec
A great YABS looks even better when that deal is no longer available.
Crunchbits - $11.69/year.
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2024-01-01 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Thu Jan 18 04:41:52 AM PST 2024 Basic System Information: --------------------------------- Uptime : 0 days, 2 hours, 16 minutes Processor : Intel Core Processor (Broadwell) CPU cores : 1 @ 2095.320 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 1.4 GiB Swap : 1024.0 MiB Disk : 39.9 GiB Distro : Debian GNU/Linux 12 (bookworm) Kernel : 6.1.0-9-amd64 VM Type : KVM IPv4/IPv6 : ✔ Online / ✔ Online IPv6 Network Information: --------------------------------- ISP : Redoubt Networks ASN : AS400304 Redoubt Networks Host : Crunchbits LLC Location : Liberty Lake, Washington (WA) Country : United States fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sda3): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 178.26 MB/s (44.5k) | 1.94 GB/s (30.4k) Write | 178.73 MB/s (44.6k) | 1.95 GB/s (30.5k) Total | 356.99 MB/s (89.2k) | 3.90 GB/s (60.9k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 5.41 GB/s (10.5k) | 5.65 GB/s (5.5k) Write | 5.70 GB/s (11.1k) | 6.02 GB/s (5.8k) Total | 11.12 GB/s (21.7k) | 11.68 GB/s (11.4k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 978 Mbits/sec | 252 Mbits/sec | 127 ms Scaleway | Paris, FR (10G) | busy | busy | 143 ms NovoServe | North Holland, NL (40G) | 993 Mbits/sec | 674 Mbits/sec | 153 ms Uztelecom | Tashkent, UZ (10G) | 625 Mbits/sec | 388 Mbits/sec | 243 ms Clouvider | NYC, NY, US (10G) | 1.01 Gbits/sec | 293 Mbits/sec | 69.5 ms Clouvider | Dallas, TX, US (10G) | 935 Mbits/sec | 849 Mbits/sec | 71.1 ms Clouvider | Los Angeles, CA, US (10G) | 1.05 Gbits/sec | 880 Mbits/sec | 91.5 ms iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 971 Mbits/sec | 329 Mbits/sec | 127 ms Scaleway | Paris, FR (10G) | busy | busy | 132 ms NovoServe | North Holland, NL (40G) | 985 Mbits/sec | 652 Mbits/sec | 153 ms Uztelecom | Tashkent, UZ (10G) | busy | 522 Mbits/sec | 242 ms Clouvider | NYC, NY, US (10G) | 1.01 Gbits/sec | 370 Mbits/sec | 69.4 ms Clouvider | Dallas, TX, US (10G) | 1.02 Gbits/sec | 865 Mbits/sec | 70.3 ms Clouvider | Los Angeles, CA, US (10G) | 981 Mbits/sec | 753 Mbits/sec | 92.7 ms Geekbench 6 Benchmark Test: --------------------------------- Test | Value | Single Core | 848 Multi Core | 790 Full Test | https://browser.geekbench.com/v6/cpu/4443003 YABS completed in 22 min 41 sec
MS you are right
13.69
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2024-01-01 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Thu 18 Jan 2024 10:07:39 PM +08 Basic System Information: --------------------------------- Uptime : 49 days, 22 hours, 17 minutes Processor : Intel Core Processor (Broadwell) CPU cores : 2 @ 2194.916 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 2.8 GiB Swap : 0.0 KiB Disk : 25.0 GiB Distro : Debian GNU/Linux 11 (bullseye) Kernel : 6.5.0-4-amd64 VM Type : KVM IPv4/IPv6 : ✔ Online / ✔ Online IPv6 Network Information: --------------------------------- ISP : Redoubt Networks ASN : AS400304 Redoubt Networks Host : Crunchbits LLC Location : Liberty Lake, Washington (WA) Country : United States fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sda3): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 161.94 MB/s (40.4k) | 1.36 GB/s (21.3k) Write | 162.36 MB/s (40.5k) | 1.37 GB/s (21.4k) Total | 324.30 MB/s (81.0k) | 2.73 GB/s (42.7k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.15 GB/s (2.2k) | 1.35 GB/s (1.3k) Write | 1.21 GB/s (2.3k) | 1.44 GB/s (1.4k) Total | 2.37 GB/s (4.6k) | 2.79 GB/s (2.7k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 984 Mbits/sec | 139 Mbits/sec | 128 ms Scaleway | Paris, FR (10G) | busy | 699 Mbits/sec | 142 ms NovoServe | North Holland, NL (40G) | 988 Mbits/sec | 679 Mbits/sec | 163 ms Uztelecom | Tashkent, UZ (10G) | busy | 521 Mbits/sec | 240 ms Clouvider | NYC, NY, US (10G) | 1.04 Gbits/sec | 208 Mbits/sec | 70.4 ms Clouvider | Dallas, TX, US (10G) | 1.03 Gbits/sec | 591 Mbits/sec | 70.2 ms Clouvider | Los Angeles, CA, US (10G) | 1.06 Gbits/sec | 821 Mbits/sec | 92.4 ms iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 981 Mbits/sec | 264 Mbits/sec | 128 ms Scaleway | Paris, FR (10G) | busy | 144 Mbits/sec | 133 ms NovoServe | North Holland, NL (40G) | 981 Mbits/sec | 655 Mbits/sec | 162 ms Uztelecom | Tashkent, UZ (10G) | busy | 400 Mbits/sec | 240 ms Clouvider | NYC, NY, US (10G) | 1.04 Gbits/sec | 495 Mbits/sec | 69.6 ms Clouvider | Dallas, TX, US (10G) | 1.04 Gbits/sec | 888 Mbits/sec | 70.1 ms Clouvider | Los Angeles, CA, US (10G) | 1.02 Gbits/sec | 815 Mbits/sec | 92.4 ms Geekbench 6 Benchmark Test: --------------------------------- Test | Value | Single Core | 836 Multi Core | 1472 Full Test | https://browser.geekbench.com/v6/cpu/4444101 YABS completed in 19 min 44 sec
HostBrr 5950X Flash Deal €30/quarterly
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2024-01-01 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Fri Jan 19 14:09:08 HKT 2024 Basic System Information: --------------------------------- Uptime : 0 days, 1 hours, 42 minutes Processor : AMD Ryzen 9 5950X 16-Core Processor CPU cores : 6 @ 3393.624 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 19.5 GiB Swap : 1024.0 MiB Disk : 193.8 GiB Distro : Ubuntu 22.04.3 LTS Kernel : 5.15.0-91-generic VM Type : KVM IPv4/IPv6 : ✔ Online / ❌ Offline IPv4 Network Information: --------------------------------- ISP : Hetzner Online GmbH ASN : AS24940 Hetzner Online GmbH Host : Hetzner Location : Frankfurt am Main, Hesse (HE) Country : Germany fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda1): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 595.84 MB/s (148.9k) | 4.20 GB/s (65.7k) Write | 597.41 MB/s (149.3k) | 4.23 GB/s (66.1k) Total | 1.19 GB/s (298.3k) | 8.43 GB/s (131.8k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 4.29 GB/s (8.3k) | 3.98 GB/s (3.8k) Write | 4.51 GB/s (8.8k) | 4.25 GB/s (4.1k) Total | 8.81 GB/s (17.2k) | 8.24 GB/s (8.0k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 928 Mbits/sec | 919 Mbits/sec | 22.9 ms Scaleway | Paris, FR (10G) | busy | busy | 24.6 ms NovoServe | North Holland, NL (40G) | 938 Mbits/sec | 935 Mbits/sec | 10.4 ms Uztelecom | Tashkent, UZ (10G) | 860 Mbits/sec | 498 Mbits/sec | 94.9 ms Clouvider | NYC, NY, US (10G) | 842 Mbits/sec | 493 Mbits/sec | 96.4 ms Clouvider | Dallas, TX, US (10G) | 810 Mbits/sec | 290 Mbits/sec | 123 ms Clouvider | Los Angeles, CA, US (10G) | 766 Mbits/sec | 430 Mbits/sec | 159 ms Geekbench 6 Benchmark Test: --------------------------------- Test | Value | Single Core | 2185 Multi Core | 8523 Full Test | https://browser.geekbench.com/v6/cpu/4453996 YABS completed in 9 min 25 sec
Ionos £1 VPS 1CPU / 512MB
Cheeky self plug review: https://cyberhost.uk/ionos-1-vps-review
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2023-11-30 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Fri Dec 15 15:03:20 UTC 2023 Basic System Information: --------------------------------- Uptime : 1 days, 21 hours, 29 minutes Processor : Intel Xeon Processor (Skylake, IBRS) CPU cores : 1 @ 2100.000 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 942.4 MiB Swap : 1024.0 MiB Disk : 9.8 GiB Distro : Debian GNU/Linux 12 (bookworm) Kernel : 6.1.0-15-cloud-amd64 VM Type : MICROSOFT IPv4/IPv6 : ✔ Online / ✔ Online IPv4 Network Information: --------------------------------- ISP : IONOS SE ASN : AS8560 IONOS SE Host : Ionos Location : City of Westminster, England (ENG) Country : United Kingdom fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda1): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 40.02 MB/s (10.0k) | 498.01 MB/s (7.7k) Write | 40.12 MB/s (10.0k) | 500.63 MB/s (7.8k) Total | 80.15 MB/s (20.0k) | 998.64 MB/s (15.6k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 474.75 MB/s (927) | 469.26 MB/s (458) Write | 499.98 MB/s (976) | 500.51 MB/s (488) Total | 974.73 MB/s (1.9k) | 969.78 MB/s (946) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 1.87 Gbits/sec | 3.48 Gbits/sec | 1.46 ms Scaleway | Paris, FR (10G) | 1.86 Gbits/sec | 3.65 Gbits/sec | 7.93 ms NovoServe | North Holland, NL (40G) | 1.90 Gbits/sec | 3.26 Gbits/sec | 14.1 ms Uztelecom | Tashkent, UZ (10G) | 454 Mbits/sec | 1.02 Gbits/sec | 191 ms Clouvider | NYC, NY, US (10G) | 1.74 Gbits/sec | 374 Mbits/sec | 74.3 ms Clouvider | Dallas, TX, US (10G) | 1.68 Gbits/sec | 1.71 Gbits/sec | 107 ms Clouvider | Los Angeles, CA, US (10G) | 1.04 Gbits/sec | 1.25 Gbits/sec | 133 ms iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 1.81 Gbits/sec | 2.92 Gbits/sec | 2.21 ms Scaleway | Paris, FR (10G) | busy | busy | 9.88 ms NovoServe | North Holland, NL (40G) | 1.82 Gbits/sec | 1.73 Gbits/sec | 9.39 ms Uztelecom | Tashkent, UZ (10G) | busy | busy | -- Clouvider | NYC, NY, US (10G) | 1.62 Gbits/sec | 1.12 Gbits/sec | 74.4 ms Clouvider | Dallas, TX, US (10G) | 1.27 Gbits/sec | 1.02 Gbits/sec | 111 ms Clouvider | Los Angeles, CA, US (10G) | 1000 Mbits/sec | 1.06 Gbits/sec | 135 ms Geekbench 6 Benchmark Test: --------------------------------- Test | Value | Single Core | 700 Multi Core | 502 Full Test | https://browser.geekbench.com/v6/cpu/3999447
At home
NL Idler
Holy 🐮!
1046x255=29827 oha!
1201x256=48604 oha!
@Abdullah
this is epic:
link pleasee
E3 from F4
MS you are right
13.69
Ionos £1 VPS
1CPU / 512MB
