server-factory.com | NL | AMD Ryzen™ 5950X & 7950X VPS
Hi there!
The Netherlands AMD RYZEN™ 5000 VPS are back in stock and it is the first time we offer The Netherlands AMD RYZEN™ 7000 VPS for LES/LET!
The following Prices are exclusive VAT. VAT will be added during order if you are from the EU, otherwise no VAT will be added.
Plans are hosted on:
AMD Ryzen™ 9 7950X with 4.50 GHZ BASE CLOCK and UP TO 5.70 GHZ BOOST CLOCK
128 GiB DDR5 3600 MHZ ECC RAM
2x Datacenter NVME PCIe 4.0 SSD (ZFS RAID 1)
2x 10 Gbit Uplink (LACP) to redundant Switches (2.5 Gbit UPLINK per VPS)
Redundant Power Supply
NL-AMD RYZEN™ 7000 XXS VPS: 1 Core / 2 GiB RAM / 50 GiB STORAGE / 2.5 Gbit UPLINK / UNMETERED INCOMING TRAFFIC / 4 TiB OUTGOING TRAFFIC PER MONTH / 1 IPv4 Address / /64 IPv6 Subnet (ROUTED)
5 € per month (ORDER HERE!)
In need of Plans with higher specs? Check out our Website!
AMD Ryzen™ 9 5950X with 3.40 GHZ BASE CLOCK and UP TO 4.90 GHZ BOOST CLOCK
128 GiB DDR4 2666 MHZ ECC RAM
2x 10 Gbit Uplink (LACP) to redundant Switches (1 Gbit UPLINK per VPS)
None-Redundant Power Supply
NL-AMD RYZEN™ 5000 XXS VPS: 1 Core / 2 GiB RAM / 25 GiB STORAGE / 1 Gbit UPLINK / UNMETERED INCOMING TRAFFIC / 4 TiB OUTGOING TRAFFIC PER MONTH / 1 IPv4 Address / /64 IPv6 Subnet (ROUTED)
4 € per month (ORDER HERE!)
General Information
No refunds! Request a Trial VPS via Ticket if you want to test network/performance before your order!
Pay with Bitcoin/Litecoin/Monero | Credit Card (Visa | Mastercard | American Express | UnionPay) | SEPA Bank Transfer | PayPal
Debian 11 and 12 / Ubuntu Server 20.04 and 22.04 / AlmaLinux 8 and 9 / Rocky Linux 8 and 9 / MikroTik RouterOS 7 / Windows Server 2022 Standard Trial (BYOL)
Looking Glass (IPv4: 31.41.249.10 - IPv6: 2a07:e042:1:10::1) => lg.nl.server-factory.com
Owned Hardware colocated in SkyLink Data Center, Eygelshoven, The Netherlands
RIPE Member => Link
Own IPv6 Subnet => Link
Own IPv4 Subnets => Link 1
Free BGP Sessions
Thanks!
Kind regards,
Max from server-factory.com
yabs please
YABS for NL-AMD RYZEN™ 7000 XXS VPS Plan:
root@benchmark:~# curl -sL yabs.sh | bash
Yet-Another-Bench-Script
v2024-01-01
Wed Jan 10 01:31:36 PM CET 2024
Uptime : 0 days, 0 hours, 28 minutes
Processor : AMD Ryzen 9 7950X 16-Core Processor
CPU cores : 1 @ 4491.556 MHz
AES-NI : ✔ Enabled
RAM : 1.9 GiB
Swap : 0.0 KiB
Disk : 49.1 GiB
Kernel : 6.1.0-17-amd64
VM Type : KVM
ISP : Maximilian Jacobsen
ASN : AS206075 Maximilian Jacobsen
Host : De Maximilian Jacobsen
Country : The Netherlands
fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sda2):
Test | Value
Single Core | 3077
Multi Core | 3145
Full Test | https://browser.geekbench.com/v6/cpu/4334454
YABS completed in 14 min 11 sec
YABS for NL-AMD RYZEN™ 5000 XXS VPS Plan:
v2024-01-01
Wed Jan 10 01:06:05 PM CET 2024
Uptime : 0 days, 0 hours, 3 minutes
Processor : AMD Ryzen 9 5950X 16-Core Processor
CPU cores : 1 @ 3393.622 MHz
AES-NI : ✔ Enabled
RAM : 1.9 GiB
Swap : 0.0 KiB
Disk : 24.5 GiB
VM Type : KVM
Test | Value
Single Core | 2315
Multi Core | 2315
Full Test | https://browser.geekbench.com/v6/cpu/4334189
YABS completed in 13 min 10 sec
server-factory.com
I've got an IPv6 only VPS in Sweden in last August which is stable, performant and very satisfying.
Is Sweden sinking into the ocean?
vps9hostname is available. affbrryes.
@mikho was digging his cables around neighbors shed and opened hell.
Thanks for your feedback! Glad you are satisfied with our Services!
Sweden will be expanded as soon as we solve our Stock issues in NL and migrate from the old to the new NL location
server-factory.com
@mxmla , its Friday and we need sex a Flash
is it worth to trial before? or orrrrderrrr NL-AMD RYZEN™ 7000 blind?!
Nothing to flash here :P
Yeah, Trial it
server-factory.com
For you, normal people. But for me, @ehab and @lapua ... that's a different story.
We added a IPv6 ONLY VPS 24 HOUR TRIAL VPS based on the NL-AMD RYZEN™ 7000 XXS VPS Plan:
Order here: https://my.server-factory.com/cart/nl-amd-ryzen-vps/
server-factory.com
