server-factory.com | NL | AMD Ryzen™ 5950X & 7950X VPS
Hi there!
The Netherlands AMD RYZEN™ 5000 VPS are back in stock and it is the first time we offer The Netherlands AMD RYZEN™ 7000 VPS for LES/LET!
The following Prices are exclusive VAT. VAT will be added during order if you are from the EU, otherwise no VAT will be added.
Plans are hosted on:
AMD Ryzen™ 9 7950X with 4.50 GHZ BASE CLOCK and UP TO 5.70 GHZ BOOST CLOCK
128 GiB DDR5 3600 MHZ ECC RAM
2x Datacenter NVME PCIe 4.0 SSD (ZFS RAID 1)
2x 10 Gbit Uplink (LACP) to redundant Switches (2.5 Gbit UPLINK per VPS)
Redundant Power Supply
NL-AMD RYZEN™ 7000 XXS VPS: 1 Core / 2 GiB RAM / 50 GiB STORAGE / 2.5 Gbit UPLINK / UNMETERED INCOMING TRAFFIC / 4 TiB OUTGOING TRAFFIC PER MONTH / 1 IPv4 Address / /64 IPv6 Subnet (ROUTED)
5 € per month (ORDER HERE!)
In need of Plans with higher specs? Check out our Website!
AMD Ryzen™ 9 5950X with 3.40 GHZ BASE CLOCK and UP TO 4.90 GHZ BOOST CLOCK
128 GiB DDR4 2666 MHZ ECC RAM
2x 10 Gbit Uplink (LACP) to redundant Switches (1 Gbit UPLINK per VPS)
None-Redundant Power Supply
NL-AMD RYZEN™ 5000 XXS VPS: 1 Core / 2 GiB RAM / 25 GiB STORAGE / 1 Gbit UPLINK / UNMETERED INCOMING TRAFFIC / 4 TiB OUTGOING TRAFFIC PER MONTH / 1 IPv4 Address / /64 IPv6 Subnet (ROUTED)
4 € per month (ORDER HERE!)
General Information
  • No refunds! Request a Trial VPS via Ticket if you want to test network/performance before your order!
  • Pay with Bitcoin/Litecoin/Monero | Credit Card (Visa | Mastercard | American Express | UnionPay) | SEPA Bank Transfer | PayPal
  • Debian 11 and 12 / Ubuntu Server 20.04 and 22.04 / AlmaLinux 8 and 9 / Rocky Linux 8 and 9 / MikroTik RouterOS 7 / Windows Server 2022 Standard Trial (BYOL)
  • Looking Glass (IPv4: 31.41.249.10 - IPv6: 2a07:e042:1:10::1) => lg.nl.server-factory.com
  • Owned Hardware colocated in SkyLink Data Center, Eygelshoven, The Netherlands
  • RIPE Member => Link
  • Own IPv6 Subnet => Link
  • Own IPv4 Subnets => Link 1
  • Free BGP Sessions
  • Privacy Policy and Terms of Service and Site Notice
Thanks!
Kind regards,
Max from server-factory.com
Thanked by (1)AlwaysSkint
  • yabs please
    Thanked by (1)mxmla
  • YABS for NL-AMD RYZEN™ 7000 XXS VPS Plan:
    root@benchmark:~# curl -sL yabs.sh | bash
    Yet-Another-Bench-Script
    v2024-01-01
    Wed Jan 10 01:31:36 PM CET 2024
    Uptime : 0 days, 0 hours, 28 minutes
    Processor : AMD Ryzen 9 7950X 16-Core Processor
    CPU cores : 1 @ 4491.556 MHz
    AES-NI : ✔ Enabled
    RAM : 1.9 GiB
    Swap : 0.0 KiB
    Disk : 49.1 GiB
    Kernel : 6.1.0-17-amd64
    VM Type : KVM
    ISP : Maximilian Jacobsen
    ASN : AS206075 Maximilian Jacobsen
    Host : De Maximilian Jacobsen
    Country : The Netherlands
    fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sda2):
    Read 428.03 MB/s (107.0k) 3.06 GB/s (47.9k)
    Write 429.16 MB/s (107.2k) 3.08 GB/s (48.1k)
    Total 857.20 MB/s (214.3k) 6.15 GB/s (96.0k)
    Read 3.66 GB/s (7.1k) 3.52 GB/s (3.4k)
    Write 3.86 GB/s (7.5k) 3.75 GB/s (3.6k)
    Total 7.53 GB/s (14.7k) 7.28 GB/s (7.1k)
    Provider Location (Link) Send Speed Recv Speed Ping
    Clouvider London, UK (10G) 2.38 Gbits/sec 2.15 Gbits/sec 8.80 ms
    Scaleway Paris, FR (10G) busy busy 12.9 ms
    NovoServe North Holland, NL (40G) 2.60 Gbits/sec 2.43 Gbits/sec 4.25 ms
    Uztelecom Tashkent, UZ (10G) busy 1.62 Gbits/sec 92.1 ms
    Clouvider NYC, NY, US (10G) busy busy 77.7 ms
    Clouvider Dallas, TX, US (10G) 379 Mbits/sec busy 118 ms
    Clouvider Los Angeles, CA, US (10G) 362 Mbits/sec busy 152 ms
    Clouvider London, UK (10G) 2.22 Gbits/sec 2.35 Gbits/sec 8.69 ms
    Scaleway Paris, FR (10G) busy busy 16.6 ms
    NovoServe North Holland, NL (40G) 2.59 Gbits/sec 2.39 Gbits/sec 4.12 ms
    Uztelecom Tashkent, UZ (10G) 122 Mbits/sec 1.80 Gbits/sec 92.2 ms
    Clouvider NYC, NY, US (10G) 240 Mbits/sec 1.27 Gbits/sec 77.5 ms
    Clouvider Dallas, TX, US (10G) 315 Mbits/sec 1.46 Gbits/sec 118 ms
    Clouvider Los Angeles, CA, US (10G) 377 Mbits/sec 1.16 Gbits/sec 152 ms
    Test | Value
    Single Core | 3077
    Multi Core | 3145
    Full Test | https://browser.geekbench.com/v6/cpu/4334454
    YABS completed in 14 min 11 sec
    YABS for NL-AMD RYZEN™ 5000 XXS VPS Plan:
    v2024-01-01
    Wed Jan 10 01:06:05 PM CET 2024
    Uptime : 0 days, 0 hours, 3 minutes
    Processor : AMD Ryzen 9 5950X 16-Core Processor
    CPU cores : 1 @ 3393.622 MHz
    AES-NI : ✔ Enabled
    RAM : 1.9 GiB
    Swap : 0.0 KiB
    Disk : 24.5 GiB
    VM Type : KVM
    Read 310.83 MB/s (77.7k) 2.74 GB/s (42.8k)
    Write 311.65 MB/s (77.9k) 2.75 GB/s (43.1k)
    Total 622.48 MB/s (155.6k) 5.50 GB/s (86.0k)
    Read 2.73 GB/s (5.3k) 2.45 GB/s (2.3k)
    Write 2.88 GB/s (5.6k) 2.61 GB/s (2.5k)
    Total 5.61 GB/s (10.9k) 5.06 GB/s (4.9k)
    Clouvider London, UK (10G) busy 1.00 Gbits/sec 8.92 ms
    Scaleway Paris, FR (10G) 1.01 Gbits/sec 998 Mbits/sec 12.4 ms
    NovoServe North Holland, NL (40G) 1.05 Gbits/sec 1.00 Gbits/sec 4.16 ms
    Uztelecom Tashkent, UZ (10G) 263 Mbits/sec 937 Mbits/sec 91.2 ms
    Clouvider NYC, NY, US (10G) 308 Mbits/sec 952 Mbits/sec 77.5 ms
    Clouvider Dallas, TX, US (10G) 199 Mbits/sec 931 Mbits/sec 117 ms
    Clouvider Los Angeles, CA, US (10G) 311 Mbits/sec 892 Mbits/sec 148 ms
    Clouvider London, UK (10G) 1.03 Gbits/sec busy 8.88 ms
    Scaleway Paris, FR (10G) busy 984 Mbits/sec 12.7 ms
    NovoServe North Holland, NL (40G) 1.04 Gbits/sec 988 Mbits/sec 4.46 ms
    Uztelecom Tashkent, UZ (10G) 118 Mbits/sec 928 Mbits/sec 91.0 ms
    Clouvider NYC, NY, US (10G) 188 Mbits/sec 941 Mbits/sec 77.4 ms
    Clouvider Dallas, TX, US (10G) 123 Mbits/sec 879 Mbits/sec 117 ms
    Clouvider Los Angeles, CA, US (10G) 297 Mbits/sec 875 Mbits/sec 149 ms
    Test | Value
    Single Core | 2315
    Multi Core | 2315
    Full Test | https://browser.geekbench.com/v6/cpu/4334189
    YABS completed in 13 min 10 sec
    Thanked by (1)lapua
  • I've got an IPv6 only VPS in Sweden in last August which is stable, performant and very satisfying.
    Thanked by (1)mxmla
  • Is Sweden sinking into the ocean?
    Thanked by (1)mxmla
    No hostname available. affbrr
    yes.
    @mikho was digging his cables around neighbors shed and opened hell.
    Thanks for your feedback! Glad you are satisfied with our Services!
    Sweden will be expanded as soon as we solve our Stock issues in NL and migrate from the old to the new NL location ;)
    Thanked by (1)Decicus
  • @mxmla , its Friday and we need sex a Flash
    Thanked by (3)lapua kry0 mxmla
  • is it worth to trial before? or orrrrderrrr NL-AMD RYZEN™ 7000 blind?!
    Thanked by (1)mxmla
    Nothing to flash here :P
    Yeah, Trial it ;)
  • @mxmla said: Nothing to flash here :P
    For you, normal people. But for me, @ehab and @lapua ... that's a different story.
    Thanked by (2)lapua ehab
  • We added a IPv6 ONLY VPS 24 HOUR TRIAL VPS based on the NL-AMD RYZEN™ 7000 XXS VPS Plan:
    Order here: https://my.server-factory.com/cart/nl-amd-ryzen-vps/
