SMTP relay questions
So, I have postfix as MTA. I will test these external relay providers:
mail.baby
mailcheap.co
My questions before I start:
- Does the relay thing happens before rspamd rules or after? Will I have chance to limit user email quantity per certain amount of time?
- Is there any hidden quirks while utilizing such third party relays? I mean forwarding, plus addressing etc. works as it would work with standard postfix?
- Maybe anyone else knows better mail relays for web hosting providers?
@jarland
.. As long as you don't need the output from your daily cron jobs.
Mailfrom="cron@cron.cron" would resolve this?
Output from daily cron jobs is okay as long as you're not trying to send it to the Googles, right?
Could do that. Could also set up postfix to funnel them to /dev/null via a transport map.
I don't think it was ever a problem @jarland just wanted proper e-mails - headers, etc. cron was missing FROM: and it was blocked
Sufficient to be classed as Matched map: SPAMMY_SUBJ
'kin ironic that I have to get around to using hotmail for notifications.
Anyone knows https://www.spamwall.com/ ?
Their website isn't responsive and it's hosted on Apache 2.2.34 (EOL 2018-1-1) with PHP 5.5.31 (EOL 2016-1-1).
seems like a good place for @FlorinMarian
