£3/month! 4GB DDR4 RAM / 2 cores / 25GB NVMe SSD / 1Gbps w/ CDN77 DDoS Protection in Germany
Hello! We're back on LES with an amazing budget offer.
KVM-EPYC-4GB
- 4GB DDR4 RAM
- 2 vCores (AMD Epyc 7401P)
- 25GB NVMe SSD
- 4TB Bandwidth @ 1Gbps
- CDN77/Datapacket DDoS Protection
- 1 IPv4 + /64 IPv6
£3/month! Order: https://deploy.hostaris.com
We also have some previews of our new billing system and I'd love some feedback on this whether positive or negative! https://imgur.com/a/AmuQ28Q
Network benchmark: https://result.network-speed.xyz/r/1705791694_852ZZ6_EU.txt
LG: https://lg.hostaris.com
Test IP: 45.158.9.1
Network: https://bgp.tools/as/199765
yabs
Working on that now, takes a while
Temporarily prioritize support on Discord? Well, that's something I didn't have on my bingo card.
It's not prioritised, we're not favouring Discord over a different platform. Even so, what's wrong with Discord?
If you're don't have an account or for whatever reason you're allergic to Discord, you can email me and expect a response within minutes as the inbox is always being checked.
Any stock in UK?
Yeah, just not on the site at the minute. What specs you looking for?
First reaction for first screenshot is: God damn I am not that blind, I don't need such big font in those Next Invoice, Invoices Due etc - they are kinda little too big for the label above. (-:
and this one https://i.imgur.com/kVbavby.png - I am missing the [SELECT] or something button - it's kinda not clear that I need to click one of those boxes... that don't even feel like box due to lack of border.
https://i.imgur.com/54bhi3F.png -> Category selection is justified to left while next step choose plan is centered? Makes kinda no sense - stick to one flow I guess. also same feedback as above - nothing that screams here "SELECT".
https://i.imgur.com/osXDMyN.png -> hate grey font for actual entries here - why not white like everywhere else?
https://i.imgur.com/j89FM9y.png -> this one feels too narrow/packed - little more margins, padding, anything. Also the manage button seems to have dedicated line so please make it bigger (wider) and easier to click.
And the biggest mistake of them all
Thanks for the feedback, will definitely take this into consideration. On the first two, the cards grow & a border is added when you hover over. Might change them but not too sure.
On the services list there is supposed to be 3 buttons (VirtFusion redirect, manage, and terminate), so that's why it looks so small.
Choose plan is not intentionally centred, has something to do with the grid or whatever I used haha.
Thanks for the victimisation.
No hostname available. affbrr
