Post some YABS bench here
1112113115117118120
  • AdvinAdvin Hosting Provider
    edited February 10
    MS said:
    @Neoon said:
    MS said:
    Who do GB multi core scores don't multiply wrt cores. For example, if single core score of an 8 core VPS is 1000, then why the multi core score is around 4000 most of the time, and not 8000. It's usually around single core score x around half of total cores of that plan.
    I see this happening more in plans with more than 6 cores. It multiples correctly as long as it's a 2 core plan, but then the ratio starts going down from one towards half with higher core plans.
    Is it just throttling by host, CPU generation/quality, or something else?
    Any ideas, @Mason, @cybertech, @all?
    I bet my ass, they are throttled or you see 6 cores but you can only use 4, so they limit you to 400%.
    Lemme run another geekbench with 4.
    I see this with all kinds of hosts, with their newer and not so new nodes. And, all kinds of CPUs.
    A 12 core E5 v4 plan with 700 for SC and around 4400 for MC.
    A 6 core Ryzen 7XXX with 1800 for SC and around 5900 for MC.
    I don’t think it’s because people are capping processors or anything like that, this seems to be more of a universal problem. I think the problem comes with how threads/hyperthreading/clock speeds work.
    As host nodes get loaded, the CPU clock speed will start to drop since most modern processors generally clock lower in all-core work loads. So it could be that a few cores are clocking high, but in an all-core workload where more cores are being stressed, the overall CPU clock speed of each core drops. On top of that, threads are effectively splitting the CPU cores, which could also drop performance if a node is loaded and if all of the physical cores are utilized (iirc).
    I’ve done some testing on EPYC Milan and noticed an almost 50% reduction in single core results when stressing half of the CPU threads, and even CPU steal presenting in VM’s at times, despite the hypervisor itself reporting 50% CPU being free. It’s also why I think that relying on Geekbench benchmarks is kind of a mediocre way to test performance. Even if a VPS host isn’t overselling their host nodes, the score is guaranteed to drop and fluctuate immensely.
    Thanked by (1)_MS_
  • @Advin said: hyperthreading
    I was thinking along the same lines.
    This, plus other factors mentioned by @Neoon and @cybertech are also the reasons. Capping could a reason with at least a few hosts.
    I'll do a raindog308 here, and write a little blog post on this topic. :smiley:
    I asked BeroHost for a refugee deal, same specs, same cpu.
    As soon its delivered, we gonna put to the test.
    Thanked by (1)_MS_
    edited February 10
    Hmm, interesting, I will run 2 tests on a 8 Core Xeon E5-2690 VPS, with different CPU settings, no capping, will post shortly.
    edited February 10
    8 core VCPU, no NUMA setting, all 8 cores assigned to 1 socket.
    root@test:~# curl -sL yabs.sh | bash -s -- -i -f
    #                     v2024-01-01                    #
    Sat Feb 10 17:03:42 UTC 2024
    Uptime     : 0 days, 0 hours, 0 minutes
    Processor  : Intel(R) Xeon(R) CPU E5-2690 v4 @ 2.60GHz
    CPU cores  : 8 @ 2599.996 MHz
    RAM        : 3.8 GiB
    Swap       : 0.0 KiB
    Disk       : 19.6 GiB
    Kernel     : 6.1.0-17-cloud-amd64
    ISP        : Andrei Tiberiu Holt
    ASN        : AS211462 Andrei Tiberiu Holt
    Host       : Andrei Tiberiu Holt
    Country    : Romania
    Single Core     | 1118
    Multi Core      | 3979
    Full Test       | https://browser.geekbench.com/v6/cpu/4854141
    YABS completed in 7 min 31 sec
    Second YABS, same 8 core but with NUMA enabled and 8 core spread to 2 sockets, each having 4 CPU
    root@test:~# curl -sL yabs.sh | bash -s -- -f -i
    #                     v2024-01-01                    #
    Sat Feb 10 17:16:36 UTC 2024
    RAM        : 3.8 GiB
    Swap       : 0.0 KiB
    Disk       : 19.6 GiB
    Country    : Romania
    Single Core     | 1090
    Multi Core      | 4015
    Full Test       | https://browser.geekbench.com/v6/cpu/4854315
    Prox 8.1, no capping. As there is no difference in score, I think it might be a test issue?
    CPU did not pass 35% total usage on both tests, and I can confirm abusers doing 100% on 16 cores, so it is not a KVM/PROX/Setup Issue in my opinion.
    Also this node is empty, so only this VPS run on the whole node.
    Thanked by (2)_MS_ Advin
  • _MS__MS_ OG
    edited February 10
    Yea, it's the hyper-threading effect.
    I bet if these test plans were with 2 cores, the MC score would still be around 2000. But for 4 cores it won't be 4000, instead we might see something around 3200, and for 8 cores as you can see, it's 4000.
    > Single Core     | 1118
    > Multi Core      | 3979
    > Single Core     | 1090
    > Multi Core      | 4015
    Thanks for taking part in this little experiment. :+1:
    I wonder if we'll see the same problem feature with the non-hyper-threading/SMT CPUs. Like Ryzen 3 3200G, which has 4 Cores = 4 Threads.
    MS
    Hmm, good point.
    I will stop the server later and disable HT, redo the tests, ~2Hours
    edited February 10
    MS
    ok, HT disabled, same node, 1 VPS on it
    8 core, 2 socket, 4 cores each, numa enabled
    #                     v2024-01-01                    #
    Sat Feb 10 20:45:04 UTC 2024
    RAM        : 3.8 GiB
    Swap       : 0.0 KiB
    Disk       : 19.6 GiB
    Country    : Romania
    Single Core     | 1123
    Multi Core      | 4067
    Full Test       | https://browser.geekbench.com/v6/cpu/4856714
    YABS completed in 7 min 36 sec
    doing the 1 socket, 8 core, no numa right now
    PS: Overall usage on CPU did not go over 45% during the test.
    #                     v2024-01-01                    #
    Sat Feb 10 20:57:17 UTC 2024
    RAM        : 3.8 GiB
    Swap       : 0.0 KiB
    Disk       : 19.6 GiB
    Country    : Romania
    Single Core     | 1137
    Multi Core      | 4258
    Full Test       | https://browser.geekbench.com/v6/cpu/4856830
    YABS completed in 7 min 37 sec
    well, it is kinda the same.
    GB6 bug? let me run this on bare-metal node, it will take 8 minutes
    Thanked by (1)_MS_
    edited February 10
    #                     v2024-01-01                    #
    Sat Feb 10 23:35:14 EET 2024
    Uptime     : 0 days, 0 hours, 2 minutes
    CPU cores  : 28 @ 2599.869 MHz
    RAM        : 251.8 GiB
    Swap       : 512.0 GiB
    Disk       : 94.0 TiB
    Kernel     : 6.5.11-8-pve
    VM Type    : NONE
    Single Core     | 1072
    Multi Core      | 9462
    Full Test       | https://browser.geekbench.com/v6/cpu/4857194
    YABS completed in 6 min 47 sec
    HT enabled coming next, bare metal
    Thanked by (1)_MS_
    edited February 10
    MS
    #                     v2024-01-01                    #
    Sat Feb 10 23:51:18 EET 2024
    CPU cores  : 56 @ 3500.000 MHz
    RAM        : 251.8 GiB
    Swap       : 512.0 GiB
    Disk       : 94.0 TiB
    VM Type    : NONE
    Single Core     | 1183
    Multi Core      | 9153
    Full Test       | https://browser.geekbench.com/v6/cpu/4857362
    YABS completed in 6 min 35 sec
    It is kinda the same, Performance on VPS is ±5-7% less then on bare metal,
    GB6 score the same, with or without HT
    Thanked by (1)_MS_
  • BeroHost refugee deal 8.99€
    I guess @Advin was right or BeroHost is also capping at 4.
    #                     v2024-01-01                    #
    Sa 10. Feb 23:30:33 CET 2024
    Processor  : AMD EPYC 7443 24-Core Processor
    CPU cores  : 6 @ 2844.656 MHz
    RAM        : 25.4 GiB
    Swap       : 1024.0 MiB
    Disk       : 293.2 GiB
    Kernel     : 6.1.0-18-amd64
    ISP        : Oliver Horscht is trading as \"SYNLINQ\"
    ASN        : AS44486 Oliver Horscht is trading as \"SYNLINQ\"
    Host       : Rubv6
    Country    : Germany
    fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sda3):
    Read       | 132.45 MB/s  (33.1k) | 711.92 MB/s  (11.1k)
    Write      | 132.80 MB/s  (33.2k) | 715.67 MB/s  (11.1k)
    Total      | 265.26 MB/s  (66.3k) | 1.42 GB/s    (22.3k)
    Read       | 1.12 GB/s     (2.1k) | 1.52 GB/s     (1.4k)
    Write      | 1.18 GB/s     (2.3k) | 1.62 GB/s     (1.5k)
    Total      | 2.30 GB/s     (4.4k) | 3.14 GB/s     (3.0k)
    Clouvider       | London, UK (10G)          | 926 Mbits/sec   | 824 Mbits/sec   | 12.9 ms
    Scaleway        | Paris, FR (10G)           | busy            | 919 Mbits/sec   | 12.1 ms
    NovoServe       | North Holland, NL (40G)   | 933 Mbits/sec   | 934 Mbits/sec   | 8.76 ms
    Uztelecom       | Tashkent, UZ (10G)        | 582 Mbits/sec   | 418 Mbits/sec   | 93.1 ms
    Clouvider       | NYC, NY, US (10G)         | 823 Mbits/sec   | 347 Mbits/sec   | 80.8 ms
    Clouvider       | Dallas, TX, US (10G)      | 372 Mbits/sec   | 462 Mbits/sec   | 116 ms
    Clouvider       | Los Angeles, CA, US (10G) | 669 Mbits/sec   | 219 Mbits/sec   | 147 ms
    Clouvider       | London, UK (10G)          | 920 Mbits/sec   | 972 Mbits/sec   | 11.0 ms
    Scaleway        | Paris, FR (10G)           | 919 Mbits/sec   | 958 Mbits/sec   | 13.1 ms
    NovoServe       | North Holland, NL (40G)   | 927 Mbits/sec   | 959 Mbits/sec   | 7.27 ms
    Uztelecom       | Tashkent, UZ (10G)        | 534 Mbits/sec   | 437 Mbits/sec   | 93.1 ms
    Clouvider       | NYC, NY, US (10G)         | 641 Mbits/sec   | 801 Mbits/sec   | 80.8 ms
    Clouvider       | Dallas, TX, US (10G)      | 521 Mbits/sec   | 653 Mbits/sec   | 116 ms
    Clouvider       | Los Angeles, CA, US (10G) | 535 Mbits/sec   | 410 Mbits/sec   | 145 ms
    Single Core     | 1430
    Multi Core      | 4831
    Full Test       | https://browser.geekbench.com/v6/cpu/4857827
    YABS completed in 12 min 55 sec
    Thanked by (1)_MS_
    edited February 11
    I have a spare EPYC 7763/7B13 node that is not in production yet, I will do some testing on there and report the results maybe. Will try various different loads and see how it impacts performance with EPYC Milan. I did some testing previously but I didn't document it, just observations since I didn't think anyone was really that interested. Maybe I can make a thread about it with some more data on how various CPU loads impacts GB6/GB5 in VM's, despite not being oversold.
    Thanked by (4)host_c _MS_ lapua Decicus
    edited February 11
    MS , if there's any specific results/data you want to see (i.e. when node is loaded 75%, 50%, etc), just let me know and I can test it for you on a Proxmox install
    Thanked by (1)_MS_
    dont forget crazy deals after testing.
    @Advin Can you compare GB5 on a VM with 8 cores assigned, SMT enabled & disabled on host node.
    I don't have a spare node, but VM performance should be better with SMT disabled.
    Yeah, for sure
  • edited February 12
    Aéza Hi-CPU (i9 14900k) | Moscow, 🇷🇺 | 8.51€/month
    #                     v2024-01-01                    #
    Mon Feb 12 06:12:12 PM MSK 2024
    Processor  : Intel(R) Core(TM) i9-14900K
    CPU cores  : 1 @ 3187.200 MHz
    RAM        : 1.9 GiB
    Swap       : 1024.0 MiB
    Disk       : 29.4 GiB
    ISP        : Aeza International LTD
    ASN        : AS210644 AEZA INTERNATIONAL LTD
    Host       : Aeza Network MSK
    Country    : The Netherlands
    Read       | 120.38 MB/s  (30.0k) | 2.10 GB/s    (32.8k)
    Write      | 120.69 MB/s  (30.1k) | 2.11 GB/s    (33.0k)
    Total      | 241.07 MB/s  (60.2k) | 4.21 GB/s    (65.9k)
    Read       | 5.58 GB/s    (10.9k) | 6.65 GB/s     (6.4k)
    Write      | 5.87 GB/s    (11.4k) | 7.09 GB/s     (6.9k)
    Total      | 11.45 GB/s   (22.3k) | 13.75 GB/s   (13.4k)
    Clouvider       | London, UK (10G)          | 3.59 Gbits/sec  | 1.60 Gbits/sec  | 47.2 ms
    Scaleway        | Paris, FR (10G)           | 3.33 Gbits/sec  | 3.84 Gbits/sec  | 48.8 ms
    NovoServe       | North Holland, NL (40G)   | 3.96 Gbits/sec  | 4.51 Gbits/sec  | 40.1 ms
    Uztelecom       | Tashkent, UZ (10G)        | 3.19 Gbits/sec  | 3.38 Gbits/sec  | 84.0 ms
    Clouvider       | NYC, NY, US (10G)         | 1.46 Gbits/sec  | 1.69 Gbits/sec  | 122 ms
    Clouvider       | Dallas, TX, US (10G)      | 968 Mbits/sec   | 1.10 Gbits/sec  | 139 ms
    Clouvider       | Los Angeles, CA, US (10G) | 768 Mbits/sec   | 932 Mbits/sec   | 166 ms
    Clouvider       | London, UK (10G)          | 3.61 Gbits/sec  | 1.67 Gbits/sec  | 47.1 ms
    Scaleway        | Paris, FR (10G)           | 3.57 Gbits/sec  | 1.89 Gbits/sec  | 48.5 ms
    NovoServe       | North Holland, NL (40G)   | 4.31 Gbits/sec  | 4.80 Gbits/sec  | 40.2 ms
    Uztelecom       | Tashkent, UZ (10G)        | 1.67 Gbits/sec  | 1.68 Gbits/sec  | 84.6 ms
    Clouvider       | NYC, NY, US (10G)         | 1.25 Gbits/sec  | 1.56 Gbits/sec  | 122 ms
    Clouvider       | Dallas, TX, US (10G)      | 1.01 Gbits/sec  | 857 Mbits/sec   | 138 ms
    Clouvider       | Los Angeles, CA, US (10G) | 809 Mbits/sec   | 855 Mbits/sec   | 167 ms
    Single Core     | 2931
    Multi Core      | 2841
    Full Test       | https://browser.geekbench.com/v6/cpu/4882133
    YABS completed in 13 min 24 sec
  • Oracle VM - $317.96/month
    Spoiler
    ubuntu@blue:~$ curl -sL yabs.sh | bash
    #                     v2024-01-01                    #
    Tue Feb 13 11:22:57 UTC 2024
    Uptime     : 0 days, 0 hours, 47 minutes
    Processor  : Intel(R) Xeon(R) Platinum 8358 CPU @ 2.60GHz
    CPU cores  : 16 @ 2593.994 MHz
    RAM        : 62.8 GiB
    Swap       : 0.0 KiB
    Disk       : 96.8 GiB
    Distro     : Ubuntu 22.04.3 LTS
    Kernel     : 5.15.0-1049-oracle
    ISP        : Oracle Corporation
    ASN        : AS31898 Oracle Corporation
    Host       : Oracle Cloud Infrastructure (ap-hyderabad-1)
    Country    : India
    Read       | 12.57 MB/s    (3.1k) | 25.89 MB/s     (404)
    Write      | 12.57 MB/s    (3.1k) | 26.34 MB/s     (411)
    Total      | 25.14 MB/s    (6.2k) | 52.24 MB/s     (815)
    Read       | 24.47 MB/s      (47) | 23.91 MB/s      (23)
    Write      | 25.99 MB/s      (50) | 26.40 MB/s      (25)
    Total      | 50.47 MB/s      (97) | 50.31 MB/s      (48)
    Clouvider       | London, UK (10G)          | 518 Mbits/sec   | 996 Mbits/sec   | 128 ms
    Scaleway        | Paris, FR (10G)           | busy            | busy            | 125 ms
    NovoServe       | North Holland, NL (40G)   | 456 Mbits/sec   | 1.17 Gbits/sec  | 142 ms
    Uztelecom       | Tashkent, UZ (10G)        | 229 Mbits/sec   | 527 Mbits/sec   | 214 ms
    Clouvider       | NYC, NY, US (10G)         | 301 Mbits/sec   | busy            | 208 ms
    Clouvider       | Dallas, TX, US (10G)      | 235 Mbits/sec   | 165 Mbits/sec   | 231 ms
    Clouvider       | Los Angeles, CA, US (10G) | 225 Mbits/sec   | 428 Mbits/sec   | 226 ms
    Single Core     | 1550
    Multi Core      | 9407
    Full Test       | https://browser.geekbench.com/v6/cpu/4893350
    YABS completed in 13 min 1 sec
    ubuntu@blue:~$
    edited February 13
    @alamin655 said: Oracle VM - $317.96/month
    100 GB on raid 5/6 at 320USD/mo?
    The $320/month covers only the compute. Oracle provides free 200GB block volume, and additional storage costs approximately $0.04/GB.
    I am not amazed
  • @host_c said:
    I am not amazed
    Yeah, it's not that great. They have this VPU (Volume Performance Unit), which ranges from 10 to 120. I forgot and chose 10 vpu instead of 120.
    https://imgur.com/K32otis
    Boot volume sized at 50 GBs, configured for the Ultra High Performance level, at 120 VPUs/GB. The maximum performance for this volume is 11,250 IOPS. (50 GB x 225 IOPS/GB = 11,250.)
    @alamin655
    THX for the update, I imagined Oracle having a better price than MSFT.
    Thanked by (1)alamin655
  • Oracle VM - AMD EPYC™ 7742
    Spoiler
    ubuntu@red1:~$ curl -sL yabs.sh | bash
    #                     v2024-01-01                    #
    Tue Feb 13 15:16:13 UTC 2024
    Uptime     : 0 days, 0 hours, 4 minutes
    Processor  : AMD EPYC 7742 64-Core Processor
    CPU cores  : 16 @ 2245.778 MHz
    VM-x/AMD-V : ❌ Disabled
    RAM        : 54.9 GiB
    Swap       : 0.0 KiB
    Disk       : 96.8 GiB
    Country    : India
    Read       | 48.36 MB/s   (12.0k) | 97.70 MB/s    (1.5k)
    Write      | 48.42 MB/s   (12.1k) | 98.21 MB/s    (1.5k)
    Total      | 96.79 MB/s   (24.1k) | 195.92 MB/s   (3.0k)
    Read       | 88.69 MB/s     (173) | 88.16 MB/s      (86)
    Write      | 93.40 MB/s     (182) | 94.03 MB/s      (91)
    Total      | 182.09 MB/s    (355) | 182.20 MB/s    (177)
    Clouvider       | London, UK (10G)          | 482 Mbits/sec   | 674 Mbits/sec   | 146 ms
    Scaleway        | Paris, FR (10G)           | 470 Mbits/sec   | busy            | 142 ms
    NovoServe       | North Holland, NL (40G)   | 465 Mbits/sec   | 1.24 Gbits/sec  | 157 ms
    Uztelecom       | Tashkent, UZ (10G)        | 60.9 Mbits/sec  | 827 Mbits/sec   | 233 ms
    Clouvider       | NYC, NY, US (10G)         | 299 Mbits/sec   | 509 Mbits/sec   | 205 ms
    Clouvider       | Dallas, TX, US (10G)      | 259 Mbits/sec   | 497 Mbits/sec   | 236 ms
    Clouvider       | Los Angeles, CA, US (10G) | 247 Mbits/sec   | 498 Mbits/sec   | 237 ms
    Single Core     | 1345
    Multi Core      | 8474
    Full Test       | https://browser.geekbench.com/v6/cpu/4896335
    YABS completed in 15 min 12 sec
    ubuntu@red1:~$
  • HostBRR Valentine Special - EUR 4.5/m
    #                     v2024-01-01                    #
    Thu Feb 15 16:51:03 IST 2024
    Uptime     : 0 days, 1 hours, 3 minutes
    Processor  : AMD Ryzen 9 7950X3D 16-Core Processor
    CPU cores  : 2 @ 4199.996 MHz
    RAM        : 5.7 GiB
    Swap       : 1024.0 MiB
    Disk       : 77.5 GiB
    Kernel     : 5.15.0-94-generic
    ISP        : GHOSTnet GmbH
    ASN        : AS12586 GHOSTnet GmbH
    Host       : Ip Network
    Country    : Germany
    Read       | 686.23 MB/s (171.5k) | 2.96 GB/s    (46.2k)
    Write      | 688.04 MB/s (172.0k) | 2.97 GB/s    (46.5k)
    Total      | 1.37 GB/s   (343.5k) | 5.94 GB/s    (92.8k)
    Read       | 3.48 GB/s     (6.7k) | 3.60 GB/s     (3.5k)
    Write      | 3.66 GB/s     (7.1k) | 3.84 GB/s     (3.7k)
    Total      | 7.14 GB/s    (13.9k) | 7.44 GB/s     (7.2k)
    Geekbench 5 Benchmark Test:
    Single Core     | 2007
    Multi Core      | 3569
    Full Test       | https://browser.geekbench.com/v5/cpu/22227389
    YABS completed in 1 min 51 sec
    @Labze give us some exclusive love on LES.
    Thanked by (1)loay
    @sh97 that looks amazing
    Thanked by (1)sh97
  • @sh97 is your HostBRR Valentine Special - EUR 4.5/m running stable?
    Niet.
    There is some intermittent network issue.
    edited February 16
    Processor  : AMD EPYC 7702 64-Core Processor
    CPU cores  : 128 @ 1500.000 MHz
    RAM        : 995.5 GiB
    Swap       : 0.0 KiB
    Disk       : 457.2 GiB
    VM Type    : NONE
    Single Core     | 1052
    Multi Core      | 35748
    Full Test       | https://browser.geekbench.com/v5/cpu/22231241
    EPYC 7702 / 16 x 64GB DDR4 / 4 x 3.84TB NVMe + 1TB NVMe + 2 x 512GB NVMe
    225W power limit, seems to be 185W to CPU under 100% load for some reason
    2 GHz all core CPU load, 308W full system power
    Thanked by (2)_MS_ noisycode
