Authy desktop EOL
Well, if the fuckers had one thing going for them, it was the quite decent desktop app.
Now, some management genius has decided it should be removed. More info:
https://help.twilio.com/articles/22771146070299-End-user-guide-End-of-Life-EOL-for-Twilio-Authy-Desktop-app
Guess I need a decent 2FA alternative.
  • A working desktop app is very much preferred.
  • An option to see the damned HOTP/TOTP key is a must (Authy didn't allow that, so I must disable/re-enable 2FA for all the 2FA accounts now).
Rant/news over.
Looking forward to any tips (pun intended - it's a ko-fi link :) ).
Relja
Thanked by (2)Not_Oles localhost
  • edited February 13
    Buy a yubikey is mostly the best option, or some payed options like lastpass, bitwarden.
    edited February 13
    Received the email today. Considering to move my OTPs to a solution that still supports a desktop app. Aegis only supports Android afaik, unfortunately. Don't wanna use Enpass, since I'd like to keep the OTP and pw manager apps separate.
    @bikegremlin if you haven't been using Enpass so far, I can recommend them. Been using Enpass as a pw manager for years. Allows syncing via cloud of preferance (encryption/decryption of vault happens on device locally, not in the cloud), or local folder sync, or even local wifi-sync.
    It also has portable desktop versions and also a Linux app: https://www.enpass.io/downloads/
    Desktop App ist completely free, Android App is limited to 25 items in "lite" (= free) mode. That said, if you don't have more than 25 sites where you need OTP, it would be enough :)
    Get started for free
    The Enpass Lite subscription (priced at $0, d’oh!) is the best way to get started with password management. The free plan allows you full access on desktop – Windows, mac OS, Linux – while you’re limited to 25 items on mobile – Android, iOS. This is a great plan for desktop-only users or the ones who want to evaluate Enpass without going for a paid plan.
  • JabJab Senpai
    edited February 13
    KeePassXC ftw :D
    @bikegremlin said: An option to see the damned HOTP/TOTP key is a must (Authy didn't allow that, so I must disable/re-enable 2FA for all the 2FA accounts now).
    If Authy worked offline then they must have stored seeds somewhere, wait few days for someone to actually care and create extractor for that :D
    First github result https://github.com/alexzorin/authy :D
    edited February 13
    I'd rather not go with something physical.
    I highly prefer encrypted cloud storage with an encrypted keybase.
    When I'm sober enough to remember the passwords that is.
    I live in the Balkans. Must always be ready to run naked and start from zero. :)
    Edit:
    Both are fun and liberating, but quite awkward. :)
    Thanked by (2)Ympker MannDude
    @Jab said:
    KeePassXC ftw :D
    Great for passwords, but as far as I know, it won't do the 2FA TOTP stuff.
    @bikegremlin if you haven't been using Enpass so far, I can recommend them. Been using Enpass as a pw manager for year. Allows syncing via cloud of preferance (encryption/decryption of vault happens on device locally, not in the cloud), or local folder sync, or even local wifi-sync.
    I will have to go with a damn smartphone after all (not very smart, but a necessity).
    In that case - a reliable option that lets me see (and store in my KeePass) the TOTP keys is a must (that should allow me to simply switch to a different app that supports the import of those, without disabling the 2FA).
  • JabJab Senpai
    @bikegremlin said: Great for passwords, but as far as I know, it won't do the 2FA TOTP stuff.
    Of course it does :D
    Thanks for the hint, got accessed my 2FA, though i forgot the backup password.
    The android app is most likely the option to go, but they could let it die soon if they get to. Since it was free, they could charge some bucks.
    Forgot to note:
    Yes, I sold two goats for an Iphone, so Android stuff won't work. :(
    edited February 13
    This one should let me import and export keys:
    OTP Auth
    https://apps.apple.com/us/app/otp-auth/id659877384
    Any reasons to avoid it?
    Any better alternatives?
    OTP Auth
    https://apps.apple.com/us/app/ente-authenticator/id6444121398
    https://apps.apple.com/us/app/tofu-authenticator/id1082229305
    https://apps.apple.com/us/app/2fa-authenticator-2fas/id1217793794
    https://apps.apple.com/us/app/freeotp-authenticator/id872559395
    Raivo also used to be great but there was a huge drama regarding it some time ago, so I'd avoid that, there are alternatives as good without drama.
    All free, private, and open source :)
    Of course they let you backup everything.
    Thanked by (2)bikegremlin Not_Oles
    HN discussion, in case it's helpful:
    https://news.ycombinator.com/item?id=39360439
    OTP Auth
    I used this app for years until consolidating on 1Password. One can argue the merits and issues with having TOTP in the one app, but I like the solution.
    Good app. Reason to not use it would be that it’s Apple devices only, which wasn’t a concern for me but might be for some.
    One of the things I liked about it was the ability to load my own icons in for apps, which not all apps support. Sync between Mac and iOS worked well too.
    OTP Auth
    I plan to keep KeePass for passwords & usernames.
    So, even with 1Password, I'd probably only use the TOTP function.
    I understand that it's paid (don't like that, but it's not too bad).
    The fact it only works on iPhone is not a problem for now.
    The important thing is: does it allow for import and export of TOTP keys, so I can easily save them and more easily switch to a different TOTP software in the future?
  • edited February 14
    OTP Auth
    In OTP Auth you can edit any entry and you’ll have the options to “show secret” or “show QR Code”, which can be used to recreate the entry in another app.
    Not sure if you can bulk export into a text file. They have a backup mechanism but not sure if the file format can be read by anything else. Worse case there’s that manual option but. I used this when I cut over from OTPAuth to 1Password.
    OTP Auth
    Have you checked out Enpass regarding TOTP yet? Also supports Apple and Linux, and the Desktop app is totally free.
    See here for import/export: https://support.enpass.io/docs/manual-desktop/import_export.html
    @Ympker said:
    OTP Auth
    I highly value LESbian knowledge and experience.
    That's why I've decided to give it a few days before trying the recommended options - to gather advice first.
    I'm already using KeePass for passwords.
    So, I thought it would make most sense to get just a 2FA/TOTP app, not a full-sized password manager.
    Can the Enpass be used for that only (I would expect yes, but doesn't hurt to ask).
    Apart from that, this is the other pick on my shortlist so far:
    @Richard said:
    OTP Auth
    No, no - single entry copy/paste is perfectly fine.
    I will have to re-create each 2FA anyway.
    That's a good opportunity to store the damn keys at the same time.
    edited February 14
    @Ympker said:
    OTP Auth
    Likewise, I also want to keep the pw manager and TOTP app separate. Hence, why I'll also look into another app, although I have also considered just creating another vault in Enpass (with a different password/finger print) for TOTP. I don't see why Enpass wouldn't work as "just" a TOTP app. Keep in mind the 25 item limit for the mobile apps when using the free version. The free Desktop app has no limits afaik.
  • vyasvyas OGSenpai
    edited February 14
    Reading the two lines together still reminds me of Pulp Fiction and Daddy’s watch…
    On separate note… you made a kind of post @ehab would nod affirmatively 👍
    Thanked by (2)bikegremlin ehab
  • Thanked by (1)bikegremlin
    F. Battiato ---
    @Ympker said:
    @Ympker said:
    OTP Auth
    Cool.
    I could then use the desktop app, and use a separate phone app as a "quick backup." :)
    @Ympker said:
    @Ympker said:
    OTP Auth
    Cool.
    Exactly. You can use any numbre of TOTP apps (not limited to one). Unlike using different pw managers, this might actually make sense (e.g. bc Aegis TOTP is only available for mobile).
  • vyasvyas OGSenpai
    edited February 14
    Well there’s Zoho
    https://www.zoho.com/accounts/oneauth/authenticator-app.html
    iOS, android, mac, windows.
    Now we can scream but there’s no Linux app!
    Thanked by (2)bikegremlin localhost
  • edited February 15
    There is this opensource portable app for Windows https://github.com/winauth/winauth which is going to be discontinued. But it is opensource .
    Edit. I have downloaded this portable version and I am manually adding useful services (hetzner, cloudflare, gmail...) . it looks good! And you can reveal the secret any time. The local codes are password protected.
  • Which 2FA apps still offer a Windows desktop app?
    edited February 19
    Enpass (which I use as a pw manager) and KeepassXC (someone mentioned it) should be solid options.
    Thanked by (2)bikegremlin Joseph
  • Which apps allow you to save passphrases, so that you can login with your passphrases from any device you install the app?
    I installed both Enpass and KeepassXC on a Windows desktop. Where do I add 2FA logins for various accounts in Enpass and KeepassXC?
